Perhaps You could add a field "own prefix" to the options,
and could do the reading of CallMonitor.adr with consideration of this field?
I will do something, I still don't know exactly what now, but I will find a solution...
HfX schrieb:Hi,
Do you think you can make your ini file compatible with the phonebook of jfritz. Most people use jfritz so it would be easier for a lot of people?
Herman schrieb:- Wenn ich über das Tray-Menü auf "About" gehe, stürzt das Programm ohne jegliche Meldung ab.
- When I klick the "About"-entry of the tray-menu the program terminates without any message.
No about box...freesoft schrieb:Hi Herman, now can you see the about box or still not ? (with build 13)
Herman schrieb:Hello freesoft.
No about box...
There is something flashing for some milliseconds (blue background? default windowsXP-border?),
and then the program has terminated.
This is very strange, it means a part of the executable is corrupted. The about box is encrypted, it contains the short license terms (freeware). If there is any modification of the exe, it will immediately close. I will investigate, I suppose it comes from the upload on the forum ...
Turin schrieb:I doubt it became corrupted due to uploading to this forums.
Would you consider releasing an uncompressed version?
Maybe the about box doesn't work because of the CRC check or the strange import tables.
One more thing (suggestion). If you would use Windows API for the message requesters, the buttons "YES" and "NO" will always automatically translate into the users language.
Keep up the good work!
