(AVM) EVA Revision: 1.1964 Version: 2964
(C) Copyright 2005 AVM Date: Nov 27 2013 Time: 14:33:10 (0) 3 0x0-0x740D
[FLASH:] MACRONIX Uniform-Flash 1MB 256 Bytes WriteBuffer
[FLASH:](Eraseregion [0] 16 sectors a 64kB)
[NAND:] 512MB MICRON 2048 Pagesize 128k Blocksize 4096 Blocks 8Bit 1 CS HW
[SYSTEM:] VR9 on 500MHz/250MHz/250MHz
.Atheros 8030/35 detected
Eva_AVM >##........................................
Lantiq xDSL CPE VR9
[ 0.000000] Linux version 2.6.32.61 (hjortmann@EmbeddedVM) (gcc version 4.8.1 (Buildroot 2013.05) ) #2 SMP Mon Oct 27 16:49:55 CET 2014
[ 0.000000] phym = 10000000, mem = 10000000, max_pfn = 00010000
[ 0.000000] Reserving memory for CP1 @0xb0000000, size 0x00000000
[ 0.000000] [init_avm_kernel_config] AVM Kernel Config (ptr 806c2000)
[ 0.000000] [init_avm_kernel_config] AVM Kernel Config: module memory entry
[ 0.000000] bootconsole [early0] enabled
[ 0.000000] CPU revision is: 00019556 (MIPS 34Kc)
[ 0.000000] Determined physical RAM map:
[ 0.000000] Initrd not found or empty - disabling initrd
[ 0.000000] Zone PFN ranges:
[ 0.000000] Normal 0x00000000 -> 0x00010000
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] early_node_map[1] active PFN ranges
[ 0.000000] 0: 0x00000000 -> 0x00010000
[ 0.000000] [module-alloc-by-name] 'modulemem' not in use, use AVM Kernel Config (6651904 bytes, reserved for module mem)
[ 0.000000] [module-alloc] use 0x658000 bytes at 0x81202000
[ 0.000000] 1 available secondary CPU TC(s)
[ 0.000000] PERCPU: Embedded 7 pages/cpu @8185e000 s5760 r8192 d14720 u65536
[ 0.000000] pcpu-alloc: s5760 r8192 d14720 u65536 alloc=16*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 65024
[ 0.000000] Kernel command line: console=ttyS0,115200n8r nor_size=0MB sflash_size=1024KB nand_size=512MB ethaddr=34:31:C4:47:BE:A5
[ 0.000000] [NAND] nand_size = 0x20000000
[ 0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] wait instruction: r4k_wait_irqoff
[ 0.000000] [avm_cache_set_coherency]: setting cache coherency for HWRevision=185 to write back allocate
[ 0.000000] Primary instruction cache 32kB, VIPT, 4-way, linesize 32 bytes.
[ 0.000000] Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
[ 0.000000] Writing ErrCtl register=00044400
[ 0.000000] Readback ErrCtl register=00044400
[ 0.000000] Memory: 245316k/262144k available (4743k kernel code, 16480k reserved, 2172k data, 216k init, 0k highmem)
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] NR_IRQS:181
[ 0.000000] [mips_cpu_irq_init] irq_base 0
[ 0.000000] SRSConf0 0x3feffbfe: SRS1: 0xffffffff, SRS2 0xffffffff, SRS3 0xffffffff
[ 0.000000] Console: colour dummy device 80x25
[ 0.000000] console [ttyS0] enabled, bootconsole disabled
[ 0.020000] Calibrating delay loop... 332.59 BogoMIPS (lpj=1662976)
[ 0.240000] Security Framework initialized
[ 0.240000] Mount-cache hash table entries: 512
[ 0.250000] kernel_init: started
[ 0.250000] kernel_init: kernel locked
[ 0.250000] Limit of 2 TCs set
[ 0.250000] TLB of 32 entry pairs shared by 2 VPEs
[ 0.250000] VPE 0: TC 0, VPE 1: TC 1
[ 0.250000] IPI buffer pool of 8 buffers
[ 0.260000] CPU revision is: 00019556 (MIPS 34Kc)
[ 0.490000] TC 1 going on-line as CPU 1
[ 0.500000] Brought up 2 CPUs
[ 0.510000] [yield_context_init] cpu=1 tc=2 mask=300
[ 0.510000] [yield_context_init] cpu=0 tc=3 mask=410
[power_managment_setup] reset 'DSL, DFE, AFE, VOICE, DSLTC, ARC'
[power_managment_setup] reset 'LDO'
[power_managment_setup] power down 'PPE TC, PPE EMA, LEDC, DFEV1, DFEV0'
[power_managment_setup] power down 'MSI1, PDI1 PCIE1 PCIE1_PHY'
[power_managment_setup] power down 'USB CTRL'
[power_managment_setup] power down 'GPHY'
[power_managment_setup] disable power domain 'DSL + DFE'
[final_setup_dcdc] start
*((volatile unsigned char *)0xBF106A17) = 0x5A;
*((volatile unsigned char *)0xBF106A18) = 0x46;
*((volatile unsigned char *)0xBF106A11) = 0x13;
*((volatile unsigned char *)0xBf106a00) = 0;
*((volatile unsigned char *)0xBf106a01) = 0;
*((volatile unsigned char *)0xBf106a02) = 0xFF;
*((volatile unsigned char *)0xBf106a03) = 0xE6;
*((volatile unsigned char *)0xBf106a04) = 0;
*((volatile unsigned char *)0xBf106a05) = 0x1B;
*((volatile unsigned char *)0xBf106a15) = 0x8b;
*((volatile unsigned char *)0xBf106a17) = 0x80;
*((volatile unsigned char *)0xBf106a18) = 0x28;
*((volatile unsigned char *)0xBf106a06) = 0x52;
[final_setup_dcdc] done
[ 0.620000] NET: Registered protocol family 16
[ 0.620000] Lantiq GPIO driver, version 1.3.2, (c) 2001-2013 Lantiq Deutschland GmbH
: 27 CET 2014
[ 0.950000] Lantiq PCIe Root Complex driver, version 2.0.0, (c) 2001-2013 Lantiq Deutschland GmbH
[ 0.960000] bio: create slab <bio-0> at 0
[ 0.960000] ifx_pcie_rc_class_early_fixup port 0: fixed pcie host bridge to pci-pci bridge
[ 0.970000] pci 0000:00:00.0: PME# supported from D0 D3hot
[ 0.970000] pci 0000:00:00.0: PME# disabled
[ 0.980000] pci 0000:01:00.0: PME# supported from D0 D3hot
[ 0.980000] pci 0000:01:00.0: PME# disabled
[ 0.990000] pci 0000:00:00.0: PCI bridge, secondary bus 0000:01
[ 0.990000] pci 0000:00:00.0: IO window: disabled
[ 1.000000] pci 0000:00:00.0: MEM window: 0x1c000000-0x1c0fffff
[ 1.000000] pci 0000:00:00.0: PREFETCH window: disabled
[ 1.010000] NET: Registered protocol family 8
[ 1.010000] NET: Registered protocol family 20
[ 1.020000] NET: Registered protocol family 2
[ 1.020000] IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 1.020000] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[ 1.020000] TCP bind hash table entries: 8192 (order: 5, 163840 bytes)
[ 1.030000] TCP: Hash tables configured (established 8192 bind 8192)
[ 1.050000] TCP reno registered
[ 1.050000] NET: Registered protocol family 1
[ 1.050000] PCI: Enabling device 0000:01:00.0 (0000 -> 0002)
[ 1.060000] pci 0000:01:00.0: xHCI controller failing to respond
[ 1.070000] IFX DMA driver, version ifxmips_dma_core.c:v1.0.17 ,(c)2009 Infineon Technologies AG
[ 1.070000] skb_shared_size:344
[ 1.080000] Lantiq CGU driver, version 1.1.32, (c) 2001-2013 Lantiq Deutschland GmbH
[ 1.090000] squashfs: version 3.4 (2008/08/26) Phillip Lougher
[ 1.100000] fuse init (API version 7.13)
[ 1.100000] msgmni has been set to 479
[ 1.100000] io scheduler noop registered (default)
[ 1.110000] [avm_membench_init]
[ 1.380000] avm_net_trace: Up and running.
[ 1.380000] [loadcontrol] set auto - scale=1
[ 1.380000] [avm] configured: watchdog event debug
[ 1.390000] AVM_WATCHDOG: Watchdog Driver for AR7 Hardware (Version 1.0, build: Oct 27 2014 16:49:00)
[ 1.400000] ifx_pmu_init: Major 247
[ 1.400000] Lantiq PMU driver, version 1.2.6, (c) 2001-2013 Lantiq Deutschland GmbH
[ 1.410000] Infineon Technologies RCU driver version 1.0.7
[ 1.420000] Lantiq Thermal Sensor driver, version 1.0.3, (c) 2001-2013 Lantiq Deutschland GmbH
[ 1.420000] ttyS0 at MMIO 0x1e100c00 (irq = 107) is a PORT_IFX_ASC
[ 1.440000] loop: module loaded
[ 1.440000] nbd: registered device at major 43
[ 1.460000] Generic platform RAM MTD, (c) 2004 Simtec Electronics
[ 1.460000] Platform NOR MTD, (c) AVM 2010
[ 1.470000] [HSNAND] Hardware-ECC activated
[ 1.470000] NAND device: Manufacturer ID: 0x2c, Chip ID: 0xdc (Micron NAND 512MiB 3,3V 8-bit)
[ 1.480000] Scanning device for bad blocks
[ 1.830000] Creating 6 MTD partitions on "ifx_hsnand":
[ 1.830000] 0x000000000000-0x000000400000 : "kernel"
[ 1.840000] {ifx_mtd_add_notifier} name kernel
[ 1.840000] 0x000000400000-0x000003400000 : "filesystem"
[ 1.850000] {ifx_mtd_add_notifier} name filesystem
[ 1.850000] 0x000003400000-0x000003800000 : "reserved-kernel"
[ 1.860000] {ifx_mtd_add_notifier} name reserved-kernel
[ 1.860000] 0x000003800000-0x000006800000 : "reserved-filesystem"
[ 1.870000] {ifx_mtd_add_notifier} name reserved-filesystem
[ 1.870000] 0x000006800000-0x000006a00000 : "config"
[ 1.880000] {ifx_mtd_add_notifier} name config
[ 1.880000] 0x000006a00000-0x000020000000 : "nand-filesystem"
[ 1.890000] {ifx_mtd_add_notifier} name nand-filesystem
[ 1.890000] Lantiq SSC driver, version 2.4.1, (c) 2001-2013 Lantiq Deutschland GmbH
[ 1.900000] Creating 3 MTD partitions on "ifx_sflash":
[ 1.910000] 0x000000000000-0x000000040000 : "urlader"
[ 1.910000] {ifx_mtd_add_notifier} name urlader
[ 1.920000] 0x000000040000-0x0000000a0000 : "tffs (1)"
[ 1.920000] {ifx_mtd_add_notifier} name tffs (1)
[ 1.930000] 0x0000000a0000-0x000000100000 : "tffs (2)"
[ 1.930000] {ifx_mtd_add_notifier} name tffs (2)
[ 1.940000] Lantiq SPI flash driver, version 1.1.9, (c) 2001-2013 Lantiq Deutschland GmbH
[ 1.940000] tun: Universal TUN/TAP device driver, 1.6
[ 1.950000] tun: (C) 1999-2004 Max Krasnyansky <[email protected]>
[ 1.960000] IFX SWITCH API, Version 1.1.8.5
[ 1.960000] SWAPI: Registered character device [switch_api] with major no [81]
[ 1.970000] Switch API: PCE MicroCode loaded !!
[ 1.970000] res = 8f933500
[ 1.970000] i2c /dev entries driver
[ 1.980000] CAPI Subsystem Rev 1.1.2.8
[ 1.980000] AVM PA 4.3.10 2014-09-21
[ 1.980000] AVM PA skb pktinfo at offset 128 size 196
[ 1.990000] [loadcontrol]module avm_pa registered
[ 1.990000] IPv4 over IPv4 tunneling driver
[ 2.000000] TCP cubic registered
[ 2.000000] mcfw: IGMPv3 fast forwarding
[ 2.010000] NET: Registered protocol family 10
[ 2.010000] IPv6 over IPv4 tunneling driver
[ 2.020000] NET: Registered protocol family 17
[ 2.020000] NET: Registered protocol family 8
[ 2.020000] atmpvc_init() failed with -17
[ 2.030000] KOAM is loaded successfully.
[ 2.030000] l2tp_core: L2TP core driver, V2.0
[ 2.040000] l2tp_ip: L2TP IP encapsulation support (L2TPv3)
[ 2.040000] l2tp_netlink: L2TP netlink interface
[ 2.050000] l2tp_eth: L2TP ethernet pseudowire support (L2TPv3)
[ 2.050000] l2tp_ip6: L2TP IP encapsulation support for IPv6 (L2TPv3)
[ 2.060000] 802.1Q VLAN Support v1.8 Ben Greear <[email protected]>
[ 2.060000] All bugs added by David S. Miller <[email protected]>
[ 2.070000] <ifx_fix_timing>
[ 2.080000] TFFS: tiny flash file system driver. GPL (c) AVM Berlin (Version 2.0)
[ 2.080000] mount on mtd7 and mtd8 (double buffering)
[ 2.090000] Adam2 environment variables API installed.
[ 2.090000] [simple-profiling]: 2 performance counters implemented, NEW_34K
[ 2.100000] Enable Performance Counter 0 for Data cache load/stores (User-Mode enabled Supervisor-Mode enabled Kernel-Mode enabled Exeption-Mode disable)
[ 2.110000] Setup tcs=0x2 current_tc_mask=0x2, reg=0
[ 2.120000] [simple-profiling]: 2 performance counters implemented, NEW_34K
[ 2.130000] Enable Performance Counter 1 for Data cache load/store misses (User-Mode enabled Supervisor-Mode enabled Kernel-Mode enabled Exeption-Mode disable)
[ 2.140000] Setup tcs=0x2 current_tc_mask=0x2, reg=1
[ 2.150000] AVM Simple Profiling enabled Version 3.0
[ 2.150000] {avmnet_cfg_netinit}
[ 2.150000] [avmnet] No config found for HWRev 185, HWSubRev 4, Profile-ID 0, trying base config for HWSubRev
[ 2.160000] [avmnet] No config found for HWRev 185, HWSubRev 4, trying base config for HWRev
[ 2.180000] [avmnet] [avmnet_swi_7port_init] Init on module swi_vr9 called.
[ 2.600000] Loading AVM Net Common Datapath Driver for 7Port Switch......
[ 2.610000] [ppe_eth_init] init_hw()
[ 2.610000] [init_hw] ppe_hw_init=0xff successful
[ 2.620000] [ppe_eth_init] ifx_proc_file_create()
[ 2.620000] [ppe_eth_init] dma_setup_init()
[ 2.630000] [avmnet] [avmnet_swi_7port_disable_learning] Configuring CPU-port to receive all unknown unicast frames 0x48
[ 2.640000] [avmnet] [avmnet_swi_7port_disable_learning] Configuring CPU-port to receive all unknown multicast frames 0x48
[ 6.090000] [avm_pa_multiplexer_init] start
[ 6.090000] [avm_pa_multiplexer_init] init complete
[ 6.090000] [avm_pa_multiplexer_register_instance]
[ 6.090000] add:avmnet_7port_pce_add_session+0x0/0x5a0
[ 6.090000] remove:avmnet_7port_pce_remove_session+0x0/0x80
[ 6.120000] [avmnet_create_netdevice] setup offload_cpu_link on device wasp
[ 6.120000] kernel_init: basic setup done
[ 6.130000] SQUASHFS error: Can't find a SQUASHFS superblock on mtdblock1
[ 6.130000] yaffs: dev is 32505857 name is "mtdblock1" ro
[ 6.140000] yaffs: passed flags ""
[ 6.170000] VFS: Mounted root (yaffs filesystem) readonly on device 31:1.
[ 6.170000] Freeing unused kernel memory: 216k freed
[ 6.220000] trying /sbin/init
init started: BusyBox v1.23.2 (2015-06-08 20:44:29 CEST)
[ 6.420000] [squashfs] use zip compression
[VR9-flash] -- Test --
mount: mounting proc on /proc failed: Device or resource busy
tar: removing leading '/' from member names
source files in group 0 ...
/etc/init.d/S00-signal /etc/init.d/S05-watchdog /etc/init.d/S09-config
/etc/init.d/S01-head /etc/init.d/S06-logging /etc/init.d/S09-rtc
/etc/init.d/S02-led /etc/init.d/S08-tffs
processing /etc/init.d/S00-signal
processing /etc/init.d/S01-head
[ 6.880000] TFFS Name Table K
[config-space] detected mtdmtd4: size '2097152'
modprobe: module nand not found in modules.dep
[config-space][yaffs] driver is loaded
[config-space] using mtd[ 6.960000] yaffs: dev is 32505860 name is "mtdblock4" rw
[ 6.970000] yaffs: passed flags ""
4 for /var/flash
[config-space] /var/flash assigned @ /dev/mtdblock4
mknod: /var/flash/freetz: File exists
mknod: /var/flash/multid.leases: File exists
mknod: /var/flash/ar7.cfg: File exists
mknod: /var/flash/net.update: File exists
mknod: /var/flash/vpn.cfg: File exists
mknod: /var/flash/tr069.cfg: File exists
mknod: /var/flash/rext.cfg: File exists
mknod: /var/flash/nlr.cfg: File exists
mknod: /var/flash/cert.cfg: File exists
mknod: /var/flash/usb.cfg: File exists
mknod: /var/flash/xdslmode: File exists
mknod: /var/flash/umts.cfg: File exists
mknod: /var/flash/usbgsm.cfg: File exists
mknod: /var/flash/maild.xml: File exists
mknod: /var/flash/timeprofile.cfg: File exists
mknod: /var/flash/stat.cfg: File exists
mknod: /var/flash/wlan.cfg: File exists
mknod: /var/flash/user.cfg: File exists
mknod: /var/flash/userstat.cfg: File exists
mknod: /var/flash/voip.cfg: File exists
mknod: /var/flash/voipd_call_stat: File exists
mknod: /var/flash/telefon_misc: File exists
mknod: /var/flash/fx_cg: File exists
mknod: /var/flash/fx_moh: File exists
mknod: /var/flash/fx_lcr: File exists
mknod: /var/flash/fx_conf: File exists
mknod: /var/flash/calllog: File exists
mknod: /var/flash/phonebook: File exists
mknod: /var/flash/fonctrl: File exists
mknod: /var/flash/tamconf: File exists
mknod: /var/flash/dect_misc: File exists
mknod: /var/flash/dect_eeprom: File exists
mknod: /var/flash/dmgr_handset_user: File exists
mknod: /var/flash/aura-usb: File exists
mknod: /var/flash/configd: File exists
mknod: /var/flash/browser-data: File exists
mknod: /var/flash/websrv_ssl_key.pem: File exists
mknod: /var/flash/websrv_ssl_cert.pem: File exists
mknod: /var/flash/aha.cfg: File exists
mknod: /var/flash/ahausr.cfg: File exists
mknod: /var/flash/ahastat.cfg: File exists
mknod: /var/flash/ahadect.cfg: File exists
mknod: /var/flash/ahanet.cfg: File exists
mknod: /var/flash/ahaglobal.cfg: File exists
mknod: /var/flash/ahapushmail.cfg: File exists
mknod: /var/flash/featovl.cfg: File exists
mknod: /var/flash/modulemem: File exists
[yaffs_to_tffs_node] ignoring TFFS Node (minor: 60)
processing /etc/init.d/S02-led
[ 8.480000] [module-alloc-by-name] give 0x1a000 bytes at 0x81202000 to module 'led_modul_Fritz_Box_HW185' (0x63e000 bytes left)
[ 8.490000] led_modul_Fritz_Box_HW185: module license '
[ 8.490000] (C) Copyright 2012 by AVM
[ 8.490000] ' taints kernel.
[ 8.500000] Disabling lock debugging due to kernel taint
[ 8.530000] [LED] use GPIO 45 for 'gpio_avm_led_power'
[ 8.540000] [LED] use GPIO 47 for 'gpio_avm_led_internet'
[ 8.540000] [LED] use GPIO 36 for 'gpio_avm_led_festnetz'
[ 8.550000] [LED] use GPIO 35 for 'gpio_avm_led_wlan'
[ 8.550000] [LED] use GPIO 33 for 'gpio_avm_led_info'
[ 8.560000] [LED] use GPIO 46 for 'gpio_avm_led_info_red'
[ 8.560000] [BUTTON] use GPIO 29 for 'gpio_avm_button_wlan'
[ 8.570000] [BUTTON] use GPIO 1 for 'gpio_avm_button_dect'
[ 8.570000] [register_bug_debug_table] name='led-modul' 0x8120eec4 - 0x8120eed8
processing /etc/init.d/S05-watchdog
[ 8.590000] AVM_WATCHDOG: System Init UEberwachung 240 Sekunden
processing /etc/init.d/S06-logging
processing /etc/init.d/S08-tffs
P-Defaults: do nothing
processing /etc/init.d/S09-config
processing /etc/init.d/S09-rtc
[ 8.920000] [module-alloc-by-name] give 0x2000 bytes at 0x8121c000 to module 'rtc_avm' (0x63c000 bytes left)
[ 8.940000] rtc-avm rtc-avm.0: rtc core: registered avm as rtc0
[ 8.950000] [avm-rtc]: avm_rtc_probe: register: ret=0x8f3cc600
[ 8.950000] [avm-rtc]: avm_rtc_probe: success
executing files in group 0 ...
/etc/init.d/E05-basemodules
executing /etc/init.d/E05-basemodules
group 0 done ...
source files in group 1 ...
/etc/init.d/S10-html /etc/init.d/S12-default
/etc/init.d/S10-vm /etc/init.d/S15-filesys
/etc/init.d/S11-config_def /etc/init.d/S17-capi
/etc/init.d/S11-piglet /etc/init.d/S17-tam
processing /etc/init.d/S10-html
processing /etc/init.d/S10-vm
processing /etc/init.d/S11-config_def
processing /etc/[ 9.140000]
[ 9.140000] [avm_debug] standard kernel-messages
init.d/S11-piglet
PigletMode: 0
[ 9.260000] [module-alloc-by-name] give 0xd000 bytes at 0x8121e000 to module 'Piglet_noemif' (0x62f000 bytes left)
[ 9.270000] [module-alloc-by-name] 0xd000 bytes used, 0xeb80 bytes expected
[ 9.300000] [piglet]use settings for 185(7 gpios from hw_config)
[ 9.300000]
[ 9.380000] patch_dectfw: c0a2b000, totallen = 43514(a9fa)
[ 9.390000] patch_dectfw: patch_adress: a0 max_len: 26 with Version 2 Len: 17
[ 9.390000] dect_loader: slow-bootmode
[ 10.310000] *
[ 10.600000] *********************************************
[ 11.580000] [1]system-load 2 loadavg 0.39 0.8 0.3 - 38 tasks:73 % curr:busybox(18 %) max:init(47 %, pid:1), readytorun: 1, pgfault 1645/s (max 1 avg 1.0)
[ 11.610000] ***************************************
[ 12.510000] dect144xx_file_process: upload of '/lib/modules/dectfw_secondlevel_441.hex' successfull
[ 14.530000] [piglet]bitfile for autodetect '/lib/modules/bitfile_isdn.bit'
[ 14.540000] [piglet] try to preload in progress-context: /lib/modules/bitfile_isdn.bit
[ 15.610000] [piglet] bitfile 72761 bytes done
[ 15.620000] [piglet] "wyatt_earp_unload_xilinx" not loaded
[ 20.720000] [piglet] use preload[0] /lib/modules/bitfile_pots.bit
[ 21.780000] [1]system-load 2 loadavg 0.63 0.14 0.5 - 38 tasks:19 % curr:busybox(19 %) max:busybox(19 %, pid:413), readytorun: 1, pgfault 0/s (max 0 avg 0.0)
[ 21.800000] [piglet] bitfile 72761 bytes done
[ 21.800000] [piglet]-> POTS-Mode
[ 21.900000] [piglet]TDM: FS: 8005 Hz CLK: 2046315 Hz
processing /etc/init.d/S12-default
checkempty: : No such file or directory
processing /etc/init.d/S15-filesys
[yaffs] nand-mtd: mtd5: 19600000 00020000 "nand-filesystem"
[ 22.240000] yaffs: dev is 32505861 name is "mtdblock5" rw
[ 22.240000] yaffs: passed flags ""
[yaffs] Internal Memory assigned @ /var/media/ftp
[Internal Memory] is NOT empty
.start_indexation.mp3
Bilder
Dokumente
FRITZ
Musik
Videos
[Internal Memory] initially filling skipped
processing /etc/init.d/S17-capi
[ 23.080000] [module-alloc-by-name] give 0x66000 bytes at 0x8122b000 to module 'pcmlink' (0x5c9000 bytes left)
[ 23.090000] [module-alloc-by-name] 0x66000 bytes used, 0x65db8 bytes expected
[ 23.250000] [pcmlink]svn: 2091
[ 23.470000] [module-alloc-by-name] give 0xdb000 bytes at 0x81291000 to module 'isdn_fbox_fon5' (0x4ee000 bytes left)
[ 23.480000] [module-alloc-by-name] 0xdb000 bytes used, 0xdd72c bytes expected
[ 24.040000] avm_stack_attach: cpu0 -> cpu1
[ 24.040000] driver params overwritten io_addr=0x0 irq_num=0
[ 24.040000] lavm_stack_attach_oncpu: cpu1
[ 24.050000] [pcmlink]chrony-support
[ 24.150000] [pcmlink]workaround_regfailure: addr= 40 act 774 shadow 1107770
[ 24.150000] [pcmlink]workaround_regfailure: addr= 48 act 660 shadow 1106660
[ 24.260000] [pcmlink]workaround_regfailure: addr= 40 act 774 shadow 1107770
[ 24.260000] [pcmlink]workaround_regfailure: addr= 48 act 660 shadow 1106660
[ 24.370000] [module-alloc-by-name] give 0x69000 bytes at 0x8136c000 to module 'capi_codec' (0x485000 bytes left)
[ 24.370000] [module-alloc-by-name] 0x69000 bytes used, 0x6a4d8 bytes expected
[ 24.480000] capicodec_init()
[ 24.480000] [capi_codec] support fax
[ 24.490000] [capi_codec] support Codecs
[ 24.560000] [module-alloc-by-name] give 0x44000 bytes at 0x813d5000 to module 'avm_dect' (0x441000 bytes left)
[ 24.570000] [module-alloc-by-name] 0x44000 bytes used, 0x46008 bytes expected
[ 24.640000] [pcmlink] configure REG_PCM_CTRL_DECT=0xcba9ed00
[ 24.650000] [module-alloc-by-name] give 0x4000 bytes at 0x81419000 to module 'dect_io' (0x43d000 bytes left)
[ 24.660000] [module-alloc-by-name] 0x4000 bytes used, 0x483c bytes expected
processing /etc/init.d/S17-tam
TAM: create directory /data/tam
executing files in group 1 ...
/etc/init.d/E15-device
executing /etc/init.d/E15-device
mknod led c 242
mknod tffs c 243
mknod avm_power c 253
mknod debug c 249
mknod avm_event c 251
mknod capi_oslib c 68
mknod dect_io c 227
group 1 done ...
source files in group 2 ...
/etc/init.d/S20-modload /etc/init.d/S21-udev
processing /etc/init.d/S20-modload
Loading /var/flash/freetz ... done.
Loading users, groups and passwords ... done.
Loading hosts ... done.
Loading config ... done.
Loading modules ... [ 26.760000] [module-alloc-by-name] give 0x10000 bytes at 0x8141d000 to module 'fat' (0x42d000 bytes left)
[ 26.770000] [module-alloc-by-name] 0x10000 bytes used, 0x11424 bytes expected
[ 26.820000] [module-alloc-by-name] give 0x3000 bytes at 0x8142d000 to module 'vfat' (0x42a000 bytes left)
[ 26.830000] [module-alloc-by-name] 0x3000 bytes used, 0x46a0 bytes expected
[ 26.970000] [module-alloc-by-name] give 0x42000 bytes at 0x81430000 to module 'reiserfs' (0x3e8000 bytes left)
done.
processing /etc/init.d/S21-udev
executing files in group 2 ...
group 2 done ...
source files in group 3 ...
/etc/init.d/S30-ledcfg
processing /etc/init.d/S30-ledcfg
executing files in group 3 ...
group 3 done ...
source files in group 4 ...
Jan 1 01:00:27 udevd[681]: specified group 'tty' unknown
Jan 1 01:00:27 udevd[681]: specified group 'dialout' unknown
Jan 1 01:00:27 udevd[681]: specified group 'kmem' unknown
Jan 1 01:00:27 udevd[681]: specified group 'video' unknown
Jan 1 01:00:27 udevd[681]: specified group 'audio' unknown
Jan 1 01:00:27 udevd[681]: specified group 'lp' unknown
Jan 1 01:00:27 udevd[681]: specified group 'disk' unknown
/etc/init.d/S42-ptest /etc/init.d/S46-usb
/etc/init.d/S44-hostname /etc/init.d/S48-configd
Jan 1 01:00:27 udevd[681]: specified group 'floppy' unknown
Jan 1 01:00:27 udevd[681]: specified group 'cdrom' unknown
processing /etc/init.d/S42-ptest
Jan 1 01:00:27 udevd[681]: specified group 'tape' unknown
processing /etc/init.d/S44-hostname
processing /etc/init.d/S46-usb
[ 27.450000] [module-alloc-by-name] give 0x2b000 bytes at 0x81472000 to module 'usbcore' (0x3bd000 bytes left)
[ 27.460000] [module-alloc-by-name] 0x2b000 bytes used, 0x2b088 bytes expected
[ 27.620000] usbcore: registered new interface driver usbfs
[ 27.630000] usbcore: registered new interface driver hub
[ 27.630000] usbcore: registered new device driver usb
[ 27.870000] [module-alloc-by-name] give 0x10000 bytes at 0x8149d000 to module 'xhci' (0x3ad000 bytes left)
[ 27.880000] [module-alloc-by-name] 0x10000 bytes used, 0x10d60 bytes expected
[ 27.910000] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 27.910000] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ 27.920000] pci_bus 0000:01: firmware: requesting xhcifw.mem
[ 28.040000] xhci_hcd 0000:01:00.0: irq 138, io mem 0x1c000000
[ 28.040000] xHCI: PORT POWER on, delay 200ms
[ 28.260000] usb usb1: config 1 interface 0 altsetting 0 endpoint 0x81 has no SuperSpeed companion descriptor
[ 28.270000] usb usb1: configuration #1 chosen from 1 choice
[ 28.270000] hub 1-0:1.0: USB hub found
[ 28.270000] hub 1-0:1.0: 4 ports detected
[ 28.280000] AVM: disable USB3 port#1 status = 0x2a0
[ 28.280000] avm_net_trace: New net trace device 'usb1' registered with minor 161.
XHCI USB 3.0 Host with port_config:1 started
processing /etc/init.d/S48-configd
executing files in group 4 ...
/etc/init.d/E40-dsl /etc/init.d/E46-net /etc/init.d/E47-voip
executing /etc/init.d/E40-dsl
[ 29.580000] [0]system-load 2 loadavg 0.66 0.16 0.5 - 68 tasks:6 % curr:hotplug_env(0 %) max:ifx_ssc(1 %, pid:117), readytorun: 5, pgfault 1433/s (max 2 avg 1.0)
[dsl sus] dsl line test calib factory file available
[dsl get xtse] ANNEX=A DSLMODE=0
[dsl get xtse] setting ADSL Annex A/L/M and VDSL2 oPOTS
[dsl get xtse] 04 00 04 00 0C 01 04 07
[dsl sus] diagforce enabled
[dsl sus] starting vr9 dsp...
[dsl sus] ANNEX=A DSLMODE=0 DIAGNOSE=no
[ 31.550000] [module-alloc-by-name] give 0x2d000 bytes at 0x814ad000 to module 'mei_vr9' (0x380000 bytes left)
[ 31.560000] [module-alloc-by-name] 0x2d000 bytes used, 0x2e094 bytes expected
[ 31.630000] [dsl_mei] Lantiq (VRX) DSL CPE MEI driver, version 1.4.4, (c) 2013 Lantiq Deutschland GmbH
[ 31.640000] [dsl mei] tried to set GDBG Level to 4
[ 31.640000]
[ 31.640000] [dsl mei] debug_level=4, Global UsrDbgLevel=4 MEI_DRV UsrDbgLevel=4 MEI_MEI_ACCESS UsrDbgLevel=4
[ 31.640000]
[ 31.660000] [dsl mei] debug_level=4, Global IntDbgLevel=4 MEI_DRV IntDbgLevel=4 MEI_MEI_ACCESS IntDbgLevel=4
[ 31.660000]
[ 31.670000] [dsl_vr9] AVM_MEI_PowerUpDSLSubsystem enable power domain 'DSL + DFE'
[ 31.670000] [AVM_MEI_PowerUpDSLSubsystem] power up 'PPE TC, PPE EMA, LEDC, DFEV1, DFEV0'
[ 31.700000] [dsl_vr9] AVM_MEI_PowerUpDSLSubsystem unreset 'DSL, DFE, AFE, VOICE, DSLTC, ARC'
[ 31.710000] spi_clc=0x00000200
[dsl sus] loaded vr9 mei driver: mei_vr9.ko with params: , avmDslDiagEnabled=1
[ 31.810000] [module-alloc-by-name] give 0x4b000 bytes at 0x814da000 to module 'dsl_vr9' (0x335000 bytes left)
[ 31.810000] [module-alloc-by-name] 0x4b000 bytes used, 0x4bb20 bytes expected
[ 31.910000] [dsl drv] Lantiq CPE API Driver version: DSL CPE API V4.16.6-pd1
[ 31.920000] [dsl drv] Predefined debug level: 4
[ 31.920000] [dsl drv] dynamically registered major number 238 for dsl_vr9
[dsl sus] loaded vr9 dsl driver: .ko with params:
[dsl sus] created vr9 dsl device node /dev/dsl_vr9/0 (major: 238 , minor: 0)
[dsl sus] created vr9 mei device node /dev/mei_vr9 (major: 239 , minor: 0)
[dsl sus] invoke /sbin/notify_avmnet --broadband_type DSL hw_start_tm_ptm
[ 32.050000] [module-alloc-by-name] give 0x27000 bytes at 0x81525000 to module 'ifxmips_ppa_datapath_vr9_e5' (0x30e000 bytes left)
[ 32.110000] Loading E5 (MII0/1) driver ......
[ 32.120000] drivers/net/avm_cpmac/switch/ifx/vr9/ifxmips_ppa_datapath_vr9_e5.c:3243:init_local_variables: [init_local_variables] g_eth_wan_mode=0
[ 32.120000]
[ 32.140000] drivers/net/avm_cpmac/switch/ifx/vr9/ifxmips_ppa_datapath_vr9_e5.c:3302:init_local_variables: g_wan_itf=0x80, g_wanqos_en=8
[ 32.140000]
[ 32.170000] [avmnet] [avmnet_mcfw_enable] Device wasp has not been initialised!
[ 32.170000] CPU_TO_WAN_TX_DESC_BASE[0] =0xbe227400
[ 32.180000] [avmnet] [avmnet_swi_7port_disable_learning] Configuring CPU-port to receive all unknown unicast frames 0x48
[ 32.190000] [avmnet] [avmnet_swi_7port_disable_learning] Configuring CPU-port to receive all unknown multicast frames 0x48
[ 32.200000] [ppe_e5_init] Succeeded!
[ 32.200000] PPE datapath driver info:
[ 32.200000] Version ID: 64.3.3.1.0.1.1
[ 32.200000] Family : VR9
[ 32.200000] DR Type : Normal Data Path | Indirect-Fast Path
[ 32.200000] Interface : MII0 | MII1
[ 32.200000] Mode : Routing
[ 32.200000] Release : 0.1.1
[ 32.230000] PPE firmware info:
[ 32.230000] Version ID: 7.5.2.11.1
[ 32.230000] Family : VR9
[ 32.230000] FW Package: D5
[ 32.230000] Release : 2.11.1
[ 32.230000] PPE firmware feature:
[ 32.230000] ATM/PTM TC-Layer Bonding Support
[ 32.230000] L2 Trunking Support
[ 32.230000] Packet Acceleration Support
[ 32.230000] IPv4 Support
[ 32.230000] IPv6 Support
[ 32.230000] 6RD Support
[ 32.230000] DS-Lite Support
FIO_MEI_FW_MODE_STAT_GET failed!: Operation not permitted
[dsl sus] started dsl_control (configuration: -i04_00_04_00_0C_01_04_07 -f/var/dsl/dspfw/vr9-A-dsl.bin -n/etc/dsl/notify/dsl_notify.sh )
[dsl sus] started dsl_monitor
[dsl sus] ....vr9 dsp started
executing /etc/init.d/E46-net
[ 32.880000] activating IRQ mode
[ 32.880000] requesting IRQ
[ 32.880000] request_irq
[ 32.890000] usedIrq: 57 | usedIsrHandler: 814bc820 | usedFlags: 0x4000 | pUsedDevName: mei_vr9 | pUsedDevId: -1919563392
[ 32.900000] IRQ requested ok
[ 32.900000] MEI_DRV: MEI_IfxRequestIrq(IRQ = 57, .., ), lock = 1
check this C0]
[ 32.910000] about to check device status
[ 32.910000] MEI_DRV[00]: INIT DEVICE, phy addr = 0x1E116000, virt addr = 0xBE116000 IRQ = 57
[ 32.910000]
[ 33.100000] [module-alloc-by-name] give 0x184000 bytes at 0x8154c000 to module 'kdsldmod' (0x18a000 bytes left)
[ 33.100000] [module-alloc-by-name] 0x184000 bytes used, 0x1846a0 bytes expected
[ 34.000000] [1]system-load 2 loadavg 1.1 0.24 0.8 - 73 tasks:23 % curr:busybox(9 %) max:busybox(9 %, pid:995), readytorun: 4, pgfault 2259/s (max 1 avg 1.0)
[ 36.410000] kdsldmod: init start (Feb 2 2015 14:24:29) sizeof(struct sk_buff)=440
[ 36.420000] userman: device registerd (userman_url) with major=232
[ 36.420000] kdsld: ttychannel: ldisc 8 registered
[ 36.430000] PCP_NL: PCP netlink interface
[ 36.430000] kdsldmod: init done
Jan 1 01:00:37 l2tpv3d[1087]: starting.
Jan 1 01:00:37 l2tpv3d[1087]: verbose: DISABLED
[ 39.400000] [avm_power] eth: port 0 force normal CON t0
[ 39.400000] [avm_power] eth: port 1 force throttle CON t0
[ 39.410000] [avm_power] eth: port 2 force throttle CON t0
[ 39.410000] [avm_power] eth: port 3 force throttle CON t0
Jan 1 01:00:39 ctlmgr[1094]: WLANLIB: wlan_plugin_init:605: svn revision 1830
Jan 1 01:00:39 ctlmgr[1094]: WLANLIB: weak_wlan_check:81: Missing weak 'process_wlanmail'.
Jan 1 01:00:39 ctlmgr[1094]: WLANLIB: weak_wlan_check:84: Missing weak 'wlan_enabled_changed'.
Jan 1 01:00:39 ctlmgr[1094]: WLANLIB: weak_wlan_check:87: Missing weak 'wlan_wcfgutil_set_output'.
Jan 1 01:00:39 ctlmgr[1094]: WLANLIB: weak_wlan_check:88: Missing weak 'wlan_wcfgutil_set_dbg_level'.
AVMMULTID: Starting AVM multid ... done.
[ 40.840000] ADDRCONF(NETDEV_UP): lan: link is not ready
[ 40.870000] [avmnet] [avmnet_mcfw_enable] Device eth0 was enabled already
[ 40.870000] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 40.880000] device eth0 entered promiscuous mode
[ 40.890000] [avmnet] [avmnet_mcfw_enable] Device eth1 was enabled already
[ 40.890000] ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 40.900000] device eth1 entered promiscuous mode
[ 41.420000] [avmnet] [avmnet_mcfw_enable] Device eth2 was enabled already
[ 41.430000] ADDRCONF(NETDEV_UP): eth2: link is not ready
[ 41.440000] device eth2 entered promiscuous mode
[ 41.950000] [avmnet] [avmnet_mcfw_enable] Device eth3 was enabled already
[ 41.960000] ADDRCONF(NETDEV_UP): eth3: link is not ready
[ 41.970000] device eth3 entered promiscuous mode
rc.wlan: Start WLAN...
WLAND:[01175]:01:00.42/[42.14]:Build = Nov 26 2014 15:33:16
Jan 1 01:00:42 dsld[1192]: startup ($Revision: 1.160 $$CompileDate: Feb 2 2015 14:24:06 $)
Jan 1 01:00:42 dsld[1192]: set_preconfig1
Jan 1 01:00:42 dsld[1192]: sync_group in ar7.cfg:
Jan 1 01:00:42 dsld[1192]: sync_group:sync_dsl(enabled=1), nr=0
Jan 1 01:00:42 dsld[1192]: vcc:1/32
Jan 1 01:00:42 dsld[1192]: dsliface:internet
Jan 1 01:00:42 dsld[1192]: dsliface:voip
Jan 1 01:00:42 dsld[1192]: sync_group: dsl
Jan 1 01:00:42 dsld[1192]: sync_dsl is igd_device
Jan 1 01:00:42 dsld[1192]: set_preconfig2
Jan 1 01:00:42 dsld[1192]: add_vcc_connection: dsl
AVMDSLD: Starting AVM dsld ... done.
executing /etc/init.d/E47-voip
Jan 1 01:00:42 dsld[1194]: DSL Mac 34:31:c4:47:be:a9
Jan 1 01:00:42 dsld[119[ 42.840000] kdsld: kdsld_vcc_preunregister: *
4]: VOIP Mac 34:31:c4:47:be:aa
Jan 1 01:00:42 dsld[1194]: VCC2 Mac 34:31:c4:47:be:ab
Jan 1 01:00:42 dsld[1194]: VCC3 Mac 34:31:c4:47:be:a6
[ 42.930000] [avmnet] [avmnet_mcfw_enable] Device wasp has not been initialised!
[ 42.940000] ADDRCONF(NETDEV_UP): wasp: link is not ready
Jan 1 01:00:42 [ 42.940000] kdsld: nr_ipv4 0 nr_ipv6 0 nr_vpn 0
dsld[1194]: voip: ppptarget voip disabled, ignored
Jan 1 01:00:42 dsld[1194]: sync_group(prepare_interfaces): dsl: inet_nr=0
Jan 1 01:00:42 dsld[1194]: nach prepare_interfaces: dsld.dsliface_default_inet_nr=0, dsld.dsliface_voip_nr=-1
Jan 1 01:00:42 dsld[1194]: get_queueindex: none: not found
Jan 1 01:00:42[ 42.980000] ADDRCONF(NETDEV_UP): guest: link is not ready
dsld[1194]: queue 0: prio 0 weight 0 shrate 0 shburst 0 wan
Jan 1 01:00:42 dsld[1194]: queue 1: prio 10 weight 0 shrate 0 shburst 0 wan
Jan 1 01:00:42 dsld[1194]: queue 2: prio 20 weight 0 shrate 0 shburst 0 wan
Jan 1 01:00:42 dsld[1194]: queue 3: prio 30 weight 0 shrate 0 shburst 0 wan
Jan 1 01:00:42 dsld[1194]: queue 4: prio 100 weight 90 shrate 0 shburst 0 wan
Jan 1 01:00:42 dsld[1194]: queue 5: prio 100 weight 10 shrate 0 shburst 0 wan
Jan 1 01:00:42 dsld[1194]: queue 6: prio 200 weight 0 shrate 0 shburst 0 wan
Jan 1 01:00:42 dsld[1194]: appl 0: sip-appl result 1
Jan 1 01:[ 43.040000] [module-alloc-by-name] give 0x1e000 bytes at 0x816d0000 to module 'aae' (0x16c000 bytes left)
[ 43.040000] [module-alloc-by-name] 0x1e000 bytes used, 0x1ccec bytes expected
00:42 dsld[1194]: classifer: local "localmark sip" result 1
Jan 1 01:00:42 dsld[1194]: classifer: local "localmark rtp" result 1
Jan 1 01:00:42 dsld[1194]: classifer: local "localmark sip_internet" result 1
Jan 1 01:00:42 dsld[1194]: classifer: local "localmark rtp_internet" result 1
Jan 1 01:00:42 dsld[1194]: classifer: local "localmark sipdns,ntpdns,tr069dns,tr069" result 2
Jan 1 01:00:42 dsld[1194]: classifer: local "localmark igmp" result 3
Jan 1 01:00:42 dsld[1194]: classifer: local "localmark webdav" result 4
Jan 1 01:00:42 dsld[1194]: classifer: local "localmark dns" result 2
Jan 1 01:00:42 dsld[1194]: classifer: lan "udp.dport 43962,47806" result 2
Jan 1 01:00:42 dsld[1194]: classifer: lan "ip.proto IPv6-ICMP" result 2
Jan 1 01:00:42 dsld[1194]: classifer: lan "ip.proto icmp" result 2
Jan 1 01:00[ 43.130000] ADDRCONF(NETDEV_CHANGE): wasp: link becomes ready
:42 dsld[1194]: classifer: lan "udp.dport 53" result 2
Jan 1 01:00:42 dsld[1194]: classifer: lan "udp.dport 5060" result 5
Jan 1 01:00:42 dsld[1194]: classifer: lan "dhcpoption 12 FRITZ!Media* mediatab" result 6
Jan 1 01:00:42 dsld[1194]: classifer: lan "ethsrctab mediatab" result 6
Jan 1 01:00:42 dsld[1194]: result 0: tos 65535 vprio 65535 queue 5 appl 65535 bridge 65535 forward 65535
Jan 1 01:00:42 dsld[1194]: result 1: tos 65535 vprio 65535 queue 2 appl 65535 bridge 65535 forward 65535
Jan 1 01:00:42 dsld[1194]: result 2: tos 65535 vprio 65535 queue 1 appl 65535 bridge 65535 forward 65535
Jan 1 01:00:42 dsld[1194]: result 3: tos 65535 vprio 65535 queue 0 appl 65535 bridge 65535 forward 65535
Jan 1 01:00:42 dsld[1194]: result 4: tos 65535 vprio 65535 queue 6 appl 65535 bridge 65535 forward 65535
Jan 1 01:00:42 dsld[1194]: result 5: tos 65535 vprio 65535 queue 2 appl 0 bridge 65535 forward 65535
Jan 1 01:00:42 dsld[1194]: result 6: tos 65535 vprio 65535 queue 3 a[ 43.220000] [wlan_config] Given config is:
[ 43.220000] [wlan_config] hw_interface=0 chip_type=8 (scorpion) offload=3 (full)
[ 43.230000] [wlan_config] hw_interface=1 chip_type=11 (peregrine) offload=3 (full)
Jan 1 01[ 43.240000] [wlan_config] hwrev=185 hwsubrev=4 maca=34:31:c4:47:be:a5
[ 43.240000] [wlan_config] country=276 reg_domain_a=12 reg_domain_b=34
[ 43.240000] [WLAN_HEARTBEAT] start
[ 43.240000] [WLAN_COM] INFO: using dev 'wasp' (src=00:de:ad:be:ef:ca, dst=ff:ff:ff:ff:ff:ff)
[ 43.240000] [WLAN_COM] avm_wlan_com_tx_thread start
[ 43.250000] [wlan_eeprom] Calibration data blocks found = 2
[ 43.260000] [wlan_eeprom] EEPROM #1, type "AR93xx/AR95xx":
[ 43.260000] [wlan_eeprom] Customer data="AVM7490_CAL1_V3"
[ 43.260000] [wlan_eeprom] Build with ART2 4.4
[ 43.260000] [wlan_eeprom] EEPROM #2, type "QCA98xx":
[ 43.260000] [wlan_eeprom] Customer data="AVM7490_CAL2_V1"
[ 43.270000] avm_net_trace: New net trace device 'WLAN Management Traffic' registered with minor 128.
:00:43 dsld[1194]: interface lo [ 43.320000] kdsld: kdsld_vcc_preregister: predsl1
[ 43.320000] kdsld: kdsld_vcc_preregister: vcc->ifaces=(null)
added.
Jan 1 01:00:43 dsld[1194]: interface l[ 43.330000] kdsld: internet: set_rcv_ipaddr: 192.168.178.1
o up.
Jan 1 01:00:43 dsld[1194]: interface tunl0 added.
Jan 1 01:00:43 dsld[1194]: interface sit0 added.
Jan 1 01:00:43 dsld[1194]: interface eth0 added.
Jan 1 01:00:43 dsld[1194]: interface eth0 up.
Jan 1 01:00:43 dsld[1194]: interface eth1 added.
Jan 1 01:00:43 dsld[1194]: interface eth1 up.
Jan 1 01:00:43 dsld[1194]: interface eth2 added.
Jan 1 01:00:43 dsld[1194]: interface eth2 up.
Jan 1 01:00:43 dsld[1194]: interface eth3 added.
Jan 1 01:00:43 dsld[1194]: interface eth3 up.
Jan 1 01:00:43 dsld[1194]: interface wasp added.
Jan 1 01:00:43 dsld[1194]: interface wasp up.
Jan 1 01:00:43 dsld[1194]: interface ptm_vr9 added.
Jan 1 01:00:43 dsld[1194]: interface adsl added.
Jan 1 01:00:43 dsld[1194]: interface lan added.
Jan 1 01:00:43 dsld[1194]: interface lan up.
Jan 1 01:00:43 dsld[1194]: interface guest added.
Jan 1 01:00:43 dsld[1194]: interface guest up.
Jan 1 01:00:43 dsld[1194]: start register_vccs_and_ifaces_on_kdsld for sync_dsl
Jan 1 01:00:43 dsld[1194]: setup_dslchannel: ifname=
Jan 1 01:00:43 dsld[1194]: kdsld_preregister_vcc: predsl1
Jan 1 01:00:43 dsld[1194]: kdsld_preregister_vcc: kdsld_vccidx=0
Jan 1 01:00:43 multid[1147]: DHCPD on lan:0 skipped, is virtual interface
Jan 1 01:00:43 dsld[1194]: udslcb_created: nr=0 (sync_dsl)
Jan 1 01:00:43 dsld[1194]: udsliface->attached=1(0x44bf44)
Jan 1 01:00:43 dsld[1194]: udslinterface_set_internet_forwardrules: FORWARDRULES_INTERNET_NORMAL=13
Jan 1 01:00:43 dsld[1194]: udslinterface_set_forwardrules: group=13
Jan 1 01:00:43 dsld[1194]: notify_due_to_pm
Jan 1 01:00:43 dsld[1194]: udslinterface_set_forwardrules: group=10
Jan 1 01:00:43 dsld[1194]: notify_due_to_pm: timer already running
Jan 1 01:00:43 dsld[1194]: udslinterface_set_forwardrules: group=11
Jan 1 01:00:43 dsld[1194]: udslinterface_set_forwardrules: group=12
Jan 1 01:00:43 dsld[1194]: verbose: DISABLED
Jan 1 01:00:43 telefon[1232]: use clock_gettime(CLOCK_MONOTONIC)!
Jan 1 01:00:43 telefon[1232]: NoOldMSNNames
[ 43.820000] [module-alloc-by-name] give 0x20000 bytes at 0x816ee000 to module 'adf' (0x14c000 bytes left)
[ 43.830000] [module-alloc-by-name] 0x20000 bytes used, 0x1f64c bytes expected
[ 44.010000] [module-alloc-by-name] give 0x4000 bytes at 0x8170e000 to module 'hif_gmac' (0x148000 bytes left)
[ 44.020000] [module-alloc-by-name] 0x4000 bytes used, 0x4654 bytes expected
mknod: /var/flash/fx_def: File exists
telefon: SIGCHLD PID 1248 received!
Jan 1 01:00:44 telefon[1232]: WARNING No config file '/var/flash/fx_def' !
Jan 1 01:00:44 telefon[1232]: INFO No MOH file '/var/flash/fx_m[ 44.070000] tgt_if =wasp
[ 44.070000] mac address dest --> 0:de:ad:be:ef:ca
[ 44.070000] mac address src--> ff:ff:ff:ff:ff:ff
[ 44.070000]
[ 44.080000] __gmac_dev_event: wasp: 0x5 (NETDEV_REGISTER), pid=1251 (busybox)
[ 44.090000] __gmac_dev_event: wasp: 0x1 (NETDEV_UP), pid=1251 (busybox)
oh' !
Jan 1 01:00:44 ctlmgr[1094]: WLANLIB: wland_role_config_init:100: CFG2/API: WLAND configuration file(/var/tmp/wlan_roles) missing.
[ 44.130000] [module-alloc-by-name] give 0x2000 bytes at 0x81712000 to module 'athlogger' (0x146000 bytes left)
[ 44.140000] [module-alloc-by-name] 0x2000 bytes used, 0x33c0 bytes expected
[ 44.160000]
[ 44.160000] athlogger mode: host
[ 44.170000] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 44.180000] lan: port 1(eth0) entering forwarding state
[ 44.210000] [module-alloc-by-name] give 0x4000 bytes at 0x81714000 to module 'fwd' (0x142000 bytes left)
[ 44.220000] [module-alloc-by-name] 0x4000 bytes used, 0x4b80 bytes expected
[ 44.250000] FWD:loaded
[ 44.250000]
[ 44.380000] [module-alloc-by-name] give 0x28000 bytes at 0x81718000 to module 'atd' (0x11a000 bytes left)
[ 44.390000] [module-alloc-by-name] 0x28000 bytes used, 0x29cd0 bytes expected
[ 44.480000] [dma_device_write] auto open tx_chan_no:2
[ 44.500000] net wasp: firmware: requesting ath_tgt_fw1.fw
[ 44.540000] FWD:loaded1 over MDIO MAC 0
telefon: SIGCHLD PID 1260 received!
Jan 1 01:00:44 telefon[1253]: NoOldMSNNames
group 4 done ...
source files in group 5 ...
telefon: SIGCHLD PID 1268 received!
Jan 1 01:00:44 telefon[1253]: WARNING No config file '/var/flash/fx_def' !
executing files in group 5 ...
group 5 done ...
source f[ 45.250000] FWD:loaded1
[ 45.250000] mdio_start_handshake waiting for target to up unit 0
iles in group 6 ...
executing files in group 6 ...
group 6 done ...
source files in group 7 ...
/etc/init.d/S73-capitcp /etc/init.d/S76-media /etc/init.d/S78-aha
processing /etc/init.d/S73-capitcp
Jan 1 01:00:45 ctlmgr[1094]: WLANLIB: wland_role_config_init:100: CFG2/API: WLAND configuration file(/var/tmp/wlan_roles) missing.
[ 45.450000] mdio handshake is good
[ 45.450000] mdio_block_send exchanging block write parameters
[ 45.460000] .
[ 45.460000] mdio_block_send - start_address 0xbd003000 length 0x00003084 exec_address 0xbd003000
[ 45.470000] .Checksum for the file fda4d151
[ 45.470000] ..............................................................................................................................................................................................................................
[ 45.710000] [1]system-load 3 loadavg 2.14 0.52 0.17 - 92 tasks:58 % curr:busybox(8 %) max:ctlmgr(15 %, pid:1094), readytorun: 3, pgfault 1992/s (max 2 avg 0.4)
[ 45.730000] ...........................................................................................................................................................................................................done!
[ 45.870000] Send waiting for lock
[ 45.890000] MDIO FWD GOOD - releasing the lock
[ 45.890000] total transfer time in jiffies 440
processing /etc/init.d/S76-media
/etc/init.d/rc.S: /etc/init.d/S76-media: line 6: /etc/init.d/rc.media: not found
processing /etc/init.d/S78-aha
[ 46.770000] [0]system-load 2 loadavg 2.14 0.52 0.17 - 91 tasks:7 % curr:busybox(5 %) max:busybox(5 %, pid:1258), readytorun: 1, pgfault 1984/s (max 4 avg 1.5)
[ 47.180000] .
[ 47.180000] HIF GMAC parametrs sent
[ 47.180000] Discovery pkt from wasp
[ 47.180000]
[ 47.180000] Start Downloading all images
[ 47.190000]
[ 47.190000] net wasp: firmware: requesting ath_tgt_fw2.fw
[ 47.200000] [tdmlink]ltdm_frameyieldrxtxcpy_prepare: ERROR: BUSY
[ 47.290000] Discovery pkt from wasp
[ 47.400000] Discovery pkt from wasp
[ 47.510000] Discovery pkt from wasp
[ 47.620000] Discovery pkt from wasp
Jan 1 01:00:47 ctlmgr[1094]: WLANLIB: wland_rol[ 47.730000] Discovery pkt from wasp
Jan 1 01:00:47 telefon[1253]: Stop DECT
[ 47.830000] FWD: size: 2778564, upload_addr: 81a00000, exec_addr: 81a00000
[ 47.840000] Downloading target firmware image Waiting for Download complete...
[ 47.850000] ..............................................................................................................................................................................................................................
[ 47.970000] [module-alloc-by-name] give 0x2000 bytes at 0x81740000 to module 'sch_tbf' (0x118000 bytes left)
[ 47.970000] ............................................................................................
[ 47.990000] [module-alloc-by-name] 0x2000 bytes used, 0x291c bytes expected
[ 47.990000] ..............................................................................................................................................................................................................................
[ 48.050000] [module-alloc-by-name] give 0x3000 bytes at 0x81742000 to module 'sch_llq' (0x115000 bytes left)
[ 48.060000] [module-alloc-by-name] 0x3000 bytes used, 0x3dc4 bytes expected
[ 48.080000] .
[ 48.080000] sch_llq: Oct 27 2014 16:49:42
[ 48.090000] ...........................................................................................................................
[ 48.110000] [module-alloc-by-name] give 0x2000 bytes at 0x81745000 to module 'sch_sfq' (0x113000 bytes left)
[ 48.120000] .
[ 48.120000] [module-alloc-by-name] 0x2000 bytes used, 0x2c58 bytes expected
[ 48.130000] .............................................................................................................................................................................................................................l
done!
[ 48.720000] Downloading target firmware completed.
[ 48.730000]
[ 48.730000] All images completed.
executing files in group 7 ...
rc.wlan: WLAN daemon already running
group 7 done ...
source files in group 8 ...
/etc/init.d/S85-apps
processing /etc/init.d/S85-apps
executing files in group 8 ...
group 8 done ...
source files in group 9 ...
/etc/init.d/S99-tail /etc/init.d/S99-zzz-rcmod
processing /etc/init.d/S99-tail
run_clock demon [ 49.220000] AVM_WATCHDOG: System Init UEberwachung abgeschlossen (199380 ms noch verfuegbar)
started
mknod: /var/flash/debug.cfg: File exists
[ 49.250000] SysRq : Changing Loglevel
[ 49.250000] Loglevel set to 4
processing /etc/init.d/S99-zzz-rcmod
Jan 1 01:00:49 ctlmgr[1094]: WLANLIB: wland_role_config_init:100: CFG2/API: WLAND configuration file(/var/tmp/wlan_roles) missing.
rc.mod version freetz-devel-13159M
crond is disabled.
AVM telnetd is disabled.
Starting Freetz webinterface ... done.
swap is disabled.
syslogd is disabled.
Jan 1 01:00:51 ctlmgr[1094]: WLANLIB: wland_role_config_init:100: CFG2/API: WLAND configuration file(/var/tmp/wlan_roles) missing.
Starting inetd ... done.
Setting up SSH authorized_keys for root ... done.
Jan 1 01:00:53 ctlmgr[1094]: WLANLIB: wland_role_config_init:100: CFG2/API: WLAND configuration file(/var/tmp/wlan_roles) missing.
[ 53.780000] [module-alloc-by-name] give 0x11000 bytes at 0x81747000 to module 'userman_mod' (0x102000 bytes left)
[ 53.790000] [module-alloc-by-name] 0x11000 bytes used, 0x121a4 bytes expected
rc.mod finished.
executing files in group 9 ...
group 9 done ...
System init finished ...
Please press Enter to activate this console. Jan 1 01:00:55 ctlmgr[1094]: WLANLIB: wland_role_config_init:100: CFG2/API: WLAND configuration file(/var/tmp/wlan_roles) missing.
Jan 1 01:00:57 ctlmgr[1094]: WLANLIB: wland_role_config_init:100: CFG2/API: WLAND configuration file(/var/tmp/wlan_roles) missing.
Jan 1 01:00:59 ctlmgr[1094]: WLANLIB: wland_role_config_init:100: CFG2/API: WLAND configuration file(/var/tmp/wlan_roles) missing.
[ 60.910000] __gmac_dev_event: wifi0: 0x5 (NETDEV_REGISTER), pid=13 (events/0)
[ 60.920000] __gmac_dev_event: wifi1: 0x5 (NETDEV_REGISTER), pid=13 (events/0)
Jan 1 01:01:01 ctlmgr[1094]: WLANLIB: wland_role_config_init:100: CFG2/API: WLAND configuration file(/var/tmp/wlan_roles) missing.
[ 61.750000] __gmac_dev_event: ath0: 0x5 (NETDEV_REGISTER), pid=1178 (wland)
[ 62.160000] __gmac_dev_event: ath0: 0xd (NETDEV_PRE_UP), pid=1323 (hostapd)
[ 62.410000] __gmac_dev_event: ath0: 0x1 (NETDEV_UP), pid=1323 (hostapd)
[ 62.640000] __gmac_dev_event: ath1: 0x5 (NETDEV_REGISTER), pid=1178 (wland)
[ 63.210000] __gmac_dev_event: ath1: 0xd (NETDEV_PRE_UP), pid=1323 (hostapd)
[ 63.420000] __gmac_dev_event: ath1: 0x1 (NETDEV_UP), pid=1323 (hostapd)
telefon: SIGCHLD PID 1267 received!
telefon: SIGCHLD PID 1310 received!
[ 68.740000] Target Reset Magic Patteren set in MDIO_REGS[]={0x3a3b, 0x3c3d, 0x3e3f, 0x4a4b, 0x4c4d, 0x4e4f, 0x5a5b, 0x5c5d, }
