Fritz Box Fon WLAN 7340 International 99.05.22
F
Feuer-Fritz
Guest
Firmware
Recover
Neuerungen:
New with version 99.05.22:
DSL: New DSL-version with improvements for ADSL2+ and VDSL lines
DSL: improved VDSL-interoperability and performance
DSL: optimised display of DSL data-rate on annex J lines
DSL: improved interop for Globespan cabinet mode lines
DSL: improved interop for various lines by deactivating PTM
Internet: New- use MyFRITZ! to safely access your FRITZ!Box from abroad
Internet: New- optional possibility to manually configure DNS server
Internet: New- UMTS-fall-back in case of a problem with the Internet connection over DSL
Internet: New- display of line speed for Internet access via LAN added in the online-monitor
Internet: New- configurability of Exposed host and ping6 in the IPv6 settings
Internet: New- configurability of other IPv6-routers in your home-network
Internet: New- IPv6-support for UPnP, UPnP-AV and TR-064
Internet: New- DynDNS-support for IPv6 with dyndns.org and namemaster.de
Internet: New- possibility to deactivate NetBIOS-filter
Internet: redesign of internet-account information pages
Internet: completed support for DNSSEC
Internet: improved error handling with DynDNS refresh
Internet: Internet-page loading accelerated with active child-protection
WLAN: New- integrated possibility to send feedback per WLAN-device
WLAN: New- active MAC-filter now automatically deactivated during WPS pairing
WLAN: New WLAN module
WLAN: WLAN-start and changes in the configuration accelerated
WLAN: improved interoperability with Logitech Squeezebox Radio
WLAN: Mouse over display of WLAN device name and IP-address in the system log
WLAN: reduced WLAN events with WPS for Windows7 and Windows Vista clients
WLAN: display of WDS-devices improved
WLAN: display of link-speed added for connections to Apple MacBook
WLAN: added configurability for WLAN connects and disconnects messages in the syslog
WLAN: added "new WLAN device first connect" message in the syslog
WLAN: additional syslog entry in case the 5Ghz channel is used by systems with priority (radar)
WLAN: to improve Windows-compatibility space at the beginning or end of a WLAN key are filtered
Telephony: New- Prioritise phone calls in your WLAN with FRITZ!App Fon
Telephony: Menu option "Own Telephone Numbers" combines internet- and fixed-line numbers with a status overview
Telephony: display-name now also configurable for remotely managed Voip-accounts
Telephony: transmit the number of messages on the answering machine to IP-telephones (MWI)
Telephony: display-name of the own number now possible to transmit to IP-telephones
Telephony: simplified email-setup for fax-reception
Telephony: improved the behaviour for the sip-registration with alternative providers
Telephony: added IMS-support for "implicit registration"
Telephony: fixed a possible problem when taking over a call from the answering machine
Telephony: improved import of telephone book
Telephony: improved signalling on analogue extensions in some scenarios
Telephony: improved caller line detection for some analogue lines
Telephony: improved Internet telephony setup
Telephony: stability improvements
DECT/FRITZ!Fon: New- configurable background image with date/time
DECT/FRITZ!Fon: New- new start screen for FRITZ!Fon MT-F
DECT/FRITZ!Fon: New- display incoming calls with bigger font
DECT/FRITZ!Fon: New- new midi-ringtones
DECT/FRITZ!Fon: fixed sporadic loss of connection to DECT-base
DECT/FRITZ!Fon: improved interop with other DECT phones
DECT/FRITZ!Fon: corrected text display in podcasts
DECT/FRITZ!Fon: accelerated menu speed for podcasts and internet-radio
DECT/FRITZ!Fon: improved error handling in case of missing pictures
Homenetwork: New- Change your FRITZ!Box name: for WLAN SSID, SMB, DECT and more
Homenetwork: New- Internet access for guests connected to LAN4
Homenetwork: New- improved display of guest-devices in the network-overview
Homenetwork: New- network devices with an http interface can now be clicked in the networking-overview
Homenetwork: New- automatic wake on LAN for devices reachable from the internet (including IPv6)
Homenetwork: New- display of FRITZ!Powerline-devices in the network-overview
Homenetwork: New- details of network devices now shows extended information including IPv6 addresses
System: New - smartphone optimised web-pages for fritz.box and myfritz.box
System: New - name of FRITZ!Box and FRITZ!OS displayed on main-page
System: New - setup simplified (new passwords will now be initially shown in plain text at configuration)
System: New - simplified change between normal and expert view
System: New - push mail now contains more detailed DSL information
System: New - push-mail now displays current IP-address and missed phone calls
System: New - possibility to activated automated sending feedback in case of a crash
System: New - automatically synchronise WLAN night-settings between multiple FRITZ! products
System: improved stability System: added POP3 SLL support for web.de
System: DNS-server of FRITZ!Box enhanced (DNS over TCP)
System: corrected loss of APIPA-address 169.254.1.1
System: DOS-robustness of https-access towards the thc-ssl-dos-tool improved
System: fixed problems of displaying username and SMTP server in the push mail service
System: fixed possible problem with using IP-cameras with real time streaming-protocol
USB: multifunction printers now only need the activation of "printer" device type with USB remote connection
USB: Interop with EnOcean USB device improved
USB: improved write performance for USB memory
USB: improved stability when disconnecting USB memory
Memory/NAS: New- name of workgroup changeable
Memory/NAS: accelerated scanning of memory for internet-sharing
Memory/NAS: accelerated FTP connection for LAN-access to USB memory
Memory/NAS: improved handling of USB memory disconnects while scanning media-files
Memory/NAS: improved picture handling and search with Internet explorer 9
Mediaserver: New- playlist support added
Mediaserver: improved interop (Sony TV, Kathrein-receiver, Xbox360 ...)
Mediaserver: performance-improvements
Mediaserver: improved handling of Umlauts in MP3-Album covers and jpg files
UMTS: added support for some UMTS devices with CSV function
UMTS: added support for new UMTS devices (ZTE K4505-Z, Sierra USB 309, 4G Systems XS Stick P14)
[Firmware-Informationen]
Firmware         =  FRITZ.Box_Fon_WLAN_7340.en-de-es-it-fr.99.05.22.image
Firmware-Größe   =  15.994.880 Bytes (15.620 kB, 15,3 MB)
Firmware-Datum   =  25.04.2012 17:14:22
Firmware-md5     =  0xd887def011101bdc6836d8a84b17b62e
Kernel.image     =  kernel.image
Kernel-Größe     =  15.301.438 Bytes (14.942,8 kB, 14,6 MB)
Kernel-Datum     =  24.04.2012 16:06:32
Kernel-md5       =  0x2bcb99275201125736a3b404b724576a
Gedacht für Box  =  Fritz_Box_7340
Installtype      =  iks_16MB_xilinx_2eth_2ab_isdn_te_pots_wlan_usb_host_dect_63350
Versionsinfo     =  99.05.22
Checkpoint       =  r22284
Brandings        =  avme
Annex            =  kein Annex (Multi-Annex)
VDSL-Version     =
ADSL-Version     =
DECT-Version     =
Erstellt mit ruKernelTool, V0.6.2.2 beta (x64) am 26.04.2012 13:47:15
