(in freetz) let dnsmasq do the walking (now working)
johnbock
2 Mrz 2008
The current static dhcp configuration routine (in modhosts and dnsmasq_conf) for dnsmasq doesn't allow the dns part work with aliases nor with entries with out a mac.
A conventional configuration looks like
192.168.0.5 * * myfirsthost description
The following two patches will allow the following
192.168.0.5 dhcp-host * myfirsthost mfh1 ts # description
And sets up dnsmasq to lease the 192.168.05 to a host announcing itsself as myfirsthost regardless of the mac. The aliases mfh1 and ts will be configured into the hosts file. The hash (#) marks the rest of the line as a comment and will also be put into the hosts file.
These patches, once applied and configured will result in the following:
/var/tmp/flash/exhosts
10.0.1.101 *                 * delaware       de dns ntp gtw # 07.Dec.1787
10.0.1.102 a0:a1:a2:a3:a4:a5 * new-jersey     nj # 18.Dec.1787
10.0.1.103 dhcp-host         * new-york       ny # 26.Jul.1788
/var/tmp/hosts
127.0.0.1       localhost
10.0.1.101      delaware de dns ntp gtw # 07.Dec.1787
10.0.1.102      new-jersey nj # 18.Dec.1787
10.0.1.103      new-york ny # 26.Jul.1788
/var/tmp/ethers
a0:a1:a2:a3:a4:a5       new-jersey
/var/mod/etc/dnsmasq.conf
domain-needed
bogus-priv
read-ethers
dhcp-host=new-york
Note: the patches may be applied in the top-level freetz-trunk directory with the command
patch -p1 < patch.file
and follow the instructions from olistudent.
edit:
now the patch set is working as expected:)
The patch set is now working as designed and I hope you have as much fun with it as I;)
Hi.
The package patch is unnecessary. After applying the first patch you have to do a "make dnsmasq-dirclean" and the changed files will be copied to packages.
Greets Oliver
Hi Johnbock ;) ,
I am mainly looking for aliasses (2 URLs for one IP) and do not like to rebuild the FREETZ as long as it is not necessary (maybe I have to do soon for adding IPV6-Tunnle anyways), is this a change in the binariesof DNSmasq or only in the configgfiles mentoned above? And what do I have to add there to get 2 URLs for a given IP and MAC?
Hi chriwi,
nice to 'read of' you hheerree!
There are no patches neccessary to the dnmasq binary. The two patches above are to allow a more flexible configuration in freetz. For a given ip/mac pair only additional hosts must be specified:
1.2.3.4 12:23:34:56:78:90 * host alias1 alias2 aliasn # comment
AFAIK, full urls like virtual hosts in apache will probably not work. You could prove me wrong, though;)
Die Änderungen sind mir nicht so ganz klar. Deshalb hab ich den Patch noch nicht eingecheckt.
MfG Oliver
@olistudent
dnsmasq.dhcphost-config.patch.gz
These changes append the description to any 'ip'/'host' line. The description can contain host aliases as well as a comment. A comment must be prepended by a '#' to remain syntactically correct in the hosts file.
dnsmasq.modhosts-alias.gz
These changes configure dnsmasq to assign a static ip address to hosts identifying themselves with a hostname. The mac is irrelevant. And the keyword in the mac column is 'dhcp-host'.
mww-wol_dnsmasq_dhcp-host_alias.patch
Allow wol-cgi to list the correct mac address of hosts that got a dhcp lease with a hostname.
While filing the ticket I accidentally switched the names of the first two patches, sorry:rolleyes:
HTH... If you have any questions, please don't hesitate to contact me;)
I have read your ticket.
Do people using dnsmasq have to change something in their conf or does it work like before?
yes, comments must be prepended with a '#'... Otherwise, each word in the comment will be recognized as an alias.
Well, very nice I like your alias patch [host->predefined ip] no need to remember all the MAC-addresses anymore / no need to change the config when the networkcard or mainboard is exchanged!
Thanks!
Greets Manuel
@johnbock
Could you please have a look at r2053?
Can I close the ticket?
Greets Oliver
Thank you very much for your commitment.
An integration in the next Freetz trunk revision would be great!
@johnbock
Greets Oliver
Thanx @olistudent. I had forgotten to patch the description:rolleyes:
Just one thing though... I'm not sure if host defs like 'www.local' in 'trunk/root/etc/default.mod/exhosts.def' work. But otherwise, it looks good.
Thank you very much!
Maybe it would be nice if comments would be moved to a separate comment field in the web interface?
