$ dmesg
g initcall 0x941fb220: init_mtdblock+0x0/0xc()
Calling initcall 0x941fb22c: cfi_probe_init+0x0/0x24()
Calling initcall 0x941fb250: cfi_amdstd_init+0x0/0x30()
Calling initcall 0x941fb280: cfi_intelext_init+0x0/0x4c()
Calling initcall 0x941fb2cc: jedec_probe_init+0x0/0x24()
Calling initcall 0x941fb2f0: map_ram_init+0x0/0x24()
Calling initcall 0x941fb314: init_physmap+0x0/0x170()
physmap flash device: 400000 at 10000000
phys_mapped_flash: Found 1 x16 devices at 0x0 in 16-bit bank
Amd/Fujitsu Extended Query Table at 0x0040
phys_mapped_flash: Swapping erase regions for broken CFI table.
number of CFI chips: 1
RedBoot partition parsing not available
Calling initcall 0x941fb484: platram_init+0x0/0x30()
Generic platform RAM MTD, (c) 2004 Simtec Electronics
Calling initcall 0x941fb4b4: init_ohio_flash+0x0/0x868()
Ohio flash driver (size->0x400000 mem->0x10000000)
flash_size=0x800000
flash_mask=0xffffff
Ohio flash memory: Found 1 x16 devices at 0x0 in 16-bit bank
[genprobe_ident_chips] 4 i 0 j 0
[genprobe_ident_chips] 5 i 0 j 1
Ohio flash memory: Swapping erase regions for broken CFI table.
[mtd]: jffs2_size = 28 * 64KByte (0x1c0000 Bytes)
[ohio_find_hidden_filesystem]: super block found: bytes_used: 0x4e218e/5120398
[init_ohio_flash] find hidden filesystem size=0x6cb200 offset=0xb4e00
[mtd] configure jffs2 partition
[mtd] fs_size=0x590000 max=0x1e0000 is=0x1c0000 max jffs2_size value 30
[mtd] ohio_flash_map: name=Ohio flash memory bankwidth=2 virt=0xb0000000 phys=0x10000000 size=0x800000
Creating 7 MTD partitions on "Ohio flash memory":
0x000b4e00-0x00780000 : "filesystem"
'nor-flash'
'Bits can be cleared (flash)'
'Has an erase function'
mtd: partition "filesystem" doesn't start on an erase block boundary -- force read-only
0x00010000-0x00780000 : "kernel"
'nor-flash'
0x00000000-0x00010000 : "bootloader"
'nor-flash'
0x00780000-0x007c0000 : "tffs (1)"
'nor-flash'
0x007c0000-0x00800000 : "tffs (2)"
'nor-flash'
0x005c0000-0x00780000 : "jffs2"
'nor-flash'
0x00010000-0x005c0000 : "Kernel without jffs2"
'nor-flash'
partition_info[0]: name=filesystem offset=b4e00 size=6cb200
partition_info[0]: 0xb00b4e00: 0x73717368 0x715
partition_info[1]: name=kernel offset=10000 size=770000
partition_info[1]: 0xb0010000: 0xfeed1281 0xa4db5
partition_info[2]: name=bootloader offset=0 size=10000
partition_info[2]: 0xb0000000: 0x40809000 0x40809800
partition_info[3]: name=tffs (1) offset=780000 size=40000
partition_info[3]: 0xb0780000: 0x40001 0xefffffff
partition_info[4]: name=tffs (2) offset=7c0000 size=40000
partition_info[4]: 0xb07c0000: 0x40001 0xeeffffff
partition_info[5]: name=jffs2 offset=5c0000 size=1c0000
partition_info[5]: 0xb05c0000: 0x20031985 0xc
partition_info[6]: name=Kernel without jffs2 offset=10000 size=5b0000
partition_info[6]: 0xb0010000: 0xfeed1281 0xa4db5
Calling initcall 0x941fbefc: kcapi_init+0x0/0x9c()
Calling initcall 0x941fc040: capi_oslib_init+0x0/0x8()
Calling initcall 0x941fcb0c: blackhole_module_init+0x0/0xc()
Calling initcall 0x941fd7fc: inet_init+0x0/0x504()
NET: Registered protocol family 2
IP route cache hash table entries: 512 (order: -1, 2048 bytes)
TCP established hash table entries: 2048 (order: 2, 16384 bytes)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 2048 bind 2048)
TCP reno registered
Calling initcall 0x94200214: init+0x0/0x8()
Calling initcall 0x9420021c: bictcp_register+0x0/0xc()
TCP bic registered
Calling initcall 0x94200228: mcfw_init_module+0x0/0x2c()
mcfw: IGMPv3 fast forwarding
Calling initcall 0x94200254: af_unix_init+0x0/0xa0()
NET: Registered protocol family 1
Calling initcall 0x942002f4: packet_init+0x0/0x80()
NET: Registered protocol family 17
Calling initcall 0x94200374: br_init+0x0/0x68()
Calling initcall 0x94200430: atm_init+0x0/0xec()
NET: Registered protocol family 8
NET: Registered protocol family 20
Calling initcall 0x942005d4: br2684_init+0x0/0x54()
Calling initcall 0x941eb024: ohio_install_dummy_irq_functions+0x0/0x58()
[setup_irq]: irq 1 irqaction->handler 0x94001590 (dummy_timer_irq+0x0/0x14 )
[setup_irq]: irq 6 irqaction->handler 0x940015a4 (dummy_system_irq_2+0x0/0x14 )
Calling initcall 0x940017e4: ohio_late_init+0x0/0x3c()
[ohio_late_init]
Calling initcall 0x941eb160: ohio_clk_switch_init+0x0/0x60()
Calling initcall 0x941eb3dc: speedup_init+0x0/0x3c()
Calling initcall 0x941f881c: seqgen_init+0x0/0x20()
Calling initcall 0x940cdff0: avm_event_push_button_init+0x0/0x130()
[avm_new] push_button_gpio=8 value=1 enabled
Calling initcall 0x941f9a98: tffs_init+0x0/0x224()
TFFS: tiny flash file system driver. GPL (c) AVM Berlin (Version 2.0)
mount on mtd4 and mtd5 (double buffering)
Adam2 environment variables API installed.
Calling initcall 0x941fa8e8: early_uart_console_switch+0x0/0xb4()
Calling initcall 0x94124db8: net_random_reseed+0x0/0x34()
Calling initcall 0x941fed1c: ip_auto_config+0x0/0x1120()
[prepare_namespace] new mount root /dev/mtdblock1
use lzma compression
VFS: Mounted root (squashfs filesystem) readonly.
Freeing prom memory: 0kb freed
Freeing unused kernel memory: 112k freed (7582 free)
[setup_irq]: irq 15 irqaction->handler 0x940da01c (serial8250_interrupt+0x0/0x13c )
AR7WDT: System Init UEberwachung 240 Sekunden
TFFS Name Table 9
Piglet: module license '
(C) Copyright 2005 by AVM
' taints kernel.
[avm_new]push_button 'Wlan-Taster', released: GPIO=8 presses=8000 key=button_key_3
EMIF: asize=1 ta=3 r_hold=0 w_strobe=6 r_strobe=6 ew=1
JFFS2 version 2.2. (NAND) (C) 2001-2003 Red Hat, Inc.
registered device TI Avalanche SAR
tiatm driver (patch_annex=0xc00ddeec)
[tiatm] Set StrictPriority=0
DSP binary filesize = 330196 bytes
[tiatm] INFO V2U-BRIDGEREGISTER: 0x00000019
[setup_irq]: irq 23 irqaction->handler 0xc00c5208 (tn7atm_sar_irq+0x0/0x30 [tiatm] )
[setup_irq]: irq 31 irqaction->handler 0xc00c5238 (tn7atm_dsl_irq+0x0/0x28 [tiatm] )
[tiatm]: Powermanagment (States => 1,3,10) supported!
Texas Instruments ATM driver: version:[4.06.04.45]
ubik2 driver (ubik2 - 0x10=0xc00390d4)
atm_dsp_register_ubik2: ubik2_ToMIPS_notify=0xc0028bfc
atm_dsp_register_ubik2: dsp mem pointer 0xa1c113ec
ubik2_init_interface: DSP-Link Version v3 8600
driver params overwritten io_addr=0x0 irq_num=0
[tiatm] DSL in training!
capicodec_init()
[capi_codec] support fax
usbcore: registered new driver usbfs
usbcore: registered new driver hub
AHCI RevisionID = 0x02, RamSize = 16384, NumPorts= 1
[setup_irq]: irq 9 irqaction->handler 0xc00bb490 (ahci_irq+0x0/0x880 [usbahcicore] )
ahci : new USB bus registered, assigned bus number 1
kdsldmod: init start (Sep 14 2007 12:49:34) sizeof(struct sk_buff)=176
kdsldmod: init done
kdsld: PPP led: off (value=0)
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
avm_net_trace: New net trace device 'WLAN' registered with minor 0.
usb 1-1: new full speed USB device using ahci and address 2
SCSI subsystem initialized
[ohio_vlynq_init] device 0
[ohio_vlynq_startup_link]
[setup_irq]: irq 29 irqaction->handler 0x940059ac (vlynq_interrupt+0x0/0x34 )
[setup_irq]: irq 79 irqaction->handler 0xc0401fac (tiwlan_ddaVlynqIsr+0x0/0x28 [tiap] )
Initializing USB Mass Storage driver...
USB Mass Storage device (08ec:0016) detected...
scsi0 : SCSI emulation for USB Mass Storage devices
usb-storage: device found at 2
usb-storage: waiting for device to settle before scanning
usbcore: registered new driver usb-storage
USB Mass Storage support registered.
[tiatm] ioctl wird von chrdev nicht unterst
[avm_power] : ethernet port 0 status 2
[avm_power] : ethernet port 1 status 2
[avm_power] : ethernet port 2 status 2
[avm_power] : ethernet port 3 status 2
userman: LAN Client Internet-Accounting and Blocking
userman: device registerd with major=228
userman: init ok
Vendor: Kingston Model: DataTraveler U3 Rev: 6.15
Type: Direct-Access ANSI SCSI revision: 00
SCSI device sda: 988159 512-byte hdwr sectors (506 MB)
sda: Write Protect is off
sda: Mode Sense: 45 00 00 08
sda: assuming drive cache: write through
sda: sda1
Attached scsi removable disk sda at scsi0, channel 0, id 0, lun 0
Type: CD-ROM ANSI SCSI revision: 00
usb-storage: device scan complete
[setup_irq]: irq 27 irqaction->handler 0x940eaa8c (cpmac_main_isr+0x0/0x78 )
[cpmac] cpmac_main_ioctl, unknown ioctl 35142
device eth0 entered promiscuous mode
device cpmac0 entered promiscuous mode
lan: port 1(eth0) entering learning state
lan: topology change detected, propagating
lan: port 1(eth0) entering forwarding state
device tiwlan0 entered promiscuous mode
lan: port 2(tiwlan0) entering learning state
lan: port 2(tiwlan0) entering forwarding state
device wdsup0 entered promiscuous mode
lan: port 3(wdsup0) entering learning state
lan: port 3(wdsup0) entering forwarding state
device wdsdw0 entered promiscuous mode
lan: port 4(wdsdw0) entering learning state
lan: port 4(wdsdw0) entering forwarding state
device wdsdw1 entered promiscuous mode
lan: port 5(wdsdw1) entering learning state
lan: port 5(wdsdw1) entering forwarding state
device wdsdw2 entered promiscuous mode
lan: port 6(wdsdw2) entering learning state
lan: port 6(wdsdw2) entering forwarding state
device wdsdw3 entered promiscuous mode
lan: port 7(wdsdw3) entering learning state
lan: port 7(wdsdw3) entering forwarding state
[tiatm] DSL in Sync
kdsld: showtime
kdsld: unsetup done.
kdsld: VCC 0: registered (1/32)
kdsld: 0: VPI/VCI 1/32 PPPoE internet 00:15:0c:ce:44:fb (32,0) mc upstream
kdsld: internet: set_rcv_ipaddr: 169.254.2.1
kdsld: dsl: registered
kdsld: VCC 0: iface internet dslencap PPPoE pcapencap ETHER llctype ether
kdsld: VCC 0: pcapencap RFC1843
kdsld: setup done.
kdsld_token_thread: start
kdsld: Channel 0 up (physical outgoing)
kdsld: internet: set_snd_ipaddr: 217.225.241.169
kdsld: internet: set_snd_mtu: 1492
kdsld: internet: connected
mcfw: forward enabled (vcc0: 00:15:0c:ce:44:fb, vlan 0, pppoe 12018)
kdsld: PPP led: on (value=1)
AR7WDT: System Init UEberwachung abgeschlossen (191140 ms noch verfuegbar)
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_cpuclock: norm_power_rate=100 act_rate=99 mul=0 div=1 offset=0 NormP=0 mW -> SumNormP=0 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_dspclock: norm_power_rate=100 act_rate=100 mul=154 div=10 offset=974 NormP=2514 mW -> SumNormP=2514 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_systemclock: norm_power_rate=100 act_rate=83 mul=65 div=10 offset=1793 NormP=2443 mW -> SumNormP=4957 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_wlan: norm_power_rate=100 act_rate=100 mul=84 div=10 offset=100 NormP=940 mW -> SumNormP=5897 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_isdnnt: norm_power_rate=100 act_rate=0 mul=1 div=1 offset=0 NormP=100 mW -> SumNormP=5997 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_isdnte: norm_power_rate=100 act_rate=-2147418012 mul=1 div=1 offset=0 NormP=100 mW -> SumNormP=6097 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_analog: norm_power_rate=300 act_rate=0 mul=141 div=10 offset=100 NormP=4330 mW -> SumNormP=10427 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_dect: norm_power_rate=100 act_rate=0 mul=0 div=1 offset=0 NormP=0 mW -> SumNormP=10427 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_ethernet: norm_power_rate=467 act_rate=83886344 mul=1 div=1 offset=50 NormP=517 mW -> SumNormP=10944 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_dsl: norm_power_rate=100 act_rate=0 mul=0 div=1 offset=0 NormP=0 mW -> SumNormP=10944 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_usb_host: norm_power_rate=500 act_rate=94 mul=55 div=10 offset=50 NormP=2800 mW -> SumNormP=13744 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_usb_client: norm_power_rate=0 act_rate=0 mul=0 div=1 offset=0 NormP=0 mW -> SumNormP=13744 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_charge: norm_power_rate=446 act_rate=0 mul=0 div=1 offset=0 NormP=0 mW -> SumNormP=13744 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_loadrate: norm_power_rate=100 act_rate=70 mul=29 div=10 offset=-17 NormP=273 mW -> SumNormP=14017 mW
SysRq : Changing Loglevel
Loglevel set to 4
CPU 0 Unable to handle kernel paging request at virtual address 00000004, epc == c011967c, ra == c01195f8
Oops in arch/mips/mm/fault.c::do_page_fault, line 167[#1]:
Cpu 0
$ 0 : 00000000 1000ce00 00000000 c011dfb0
$ 4 : c0120000 00000000 00000000 00000008
$ 8 : 00000034 940b041c 00000000 00000000
$12 : 94a7bd3c fffffffb 0000000a ffffffff
$16 : 94bf9cbc 9536a000 94bf9c80 00008000
$20 : 9536a000 94a8fa00 00000001 00000001
$24 : 00000000 00000000
$28 : 94a78000 94a7bc70 94a7bcd0 c01195f8
Hi : 00000000
Lo : 00000000
epc : c011967c fat_fill_super+0x104/0xee8 [fat] Tainted: P
ra : c01195f8 fat_fill_super+0x80/0xee8 [fat]
Status: 1000ce03 KERNEL EXL IE
Cause : 10800008
BadVA : 00000004
PrId : 00018448
Modules linked in: userman vfat fat nls_cp437 nls_iso8859_1 usb_storage sd_mod scsi_mod tiap kdsldmod usbahcicore usbcore capi_codec isdn_fbox_fon4 ubik2 tiatm jffs2 Piglet
Process mount (pid: 1016, threadinfo=94a78000, task=94d0fbf0)
Stack : 00000000 00000001 94a7bd3b 94a7bd0c 941c0000 ffffffff 00000002 94a7bd57
94a7bd38 00000020 0a4ce000 04a00000 0a4ce00c 00000000 0000000a ffffffff
ffffffff 00000002 952c7a4c 94a7bd38 952c7a40 00000001 9536a000 9536a000
9536a000 00490000 9536a000 94a8fa00 94a8fa00 94a8fa00 9428ea18 00008000
9536a000 9536a000 9536a000 00490000 004a8030 c0130e9c 00000001 00008000
Call Trace:
[<c0130e9c>] vfat_fill_super+0x2c/0x78 [vfat]
[<9406b0e8>] get_sb_bdev+0x154/0x1c8
[<94072f58>] link_path_walk+0x158/0x1b4
[<9400f1ec>] fixup_exception+0x2c/0x60
[<94071c00>] do_lookup+0x30/0x228
[<c0130f0c>] vfat_get_sb+0x24/0x38 [vfat]
[<c0130e70>] vfat_fill_super+0x0/0x78 [vfat]
[<9406b3b8>] do_kern_mount+0x70/0x10c
[<94073118>] path_lookup+0x164/0x184
[<940464bc>] filemap_nopage+0x1a0/0x420
[<94082494>] do_mount+0x574/0x5d8
[<9408200c>] do_mount+0xec/0x5d8
[<9400fab0>] tlb_do_page_fault_0+0x100/0x108
[<940714c8>] getname+0x28/0xc8
[<940b043c>] memset_partial+0x40/0x6c
[<94081e34>] copy_mount_options+0x38/0x124
[<94185f94>] __lock_text_end+0xd30/0x1218
[<940828f4>] sys_mount+0xa4/0xfc
[<9400da40>] stack_done+0x20/0x3c
Code: ae020004 8f820000 8c420320 <8c420004> a6020008 a602000a 3c02c012 8c42e024 ae030010
