olistudent schrieb:Ich hab mir jetzt eine 7170 bestellt. Vielleicht komm ich dann weiter. Und Mitte Oktober sind ja auch nur 3 Wochen.
MfG Oliver
STEP 2: MODIFY
applying patches
applying patches (fon_wlan_7141-de)
patching file etc/profile
patching file usr/bin/system_status
patching file etc/init.d/rc.net
patching file etc/init.d/rc.voip
patching file etc/init.d/rc.S
patching file usr/www/all/html/de/menus/menu2_fon.html
Hunk #1 succeeded at 62 (offset -9 lines).
patching file usr/www/all/html/de/menus/menu2_homehome.html
patching file usr/www/all/html/de/menus/menu2.inc
Hunk #1 FAILED at 9.
1 out of 1 hunk FAILED -- saving rejects to file usr/www/all/html/de/menus/menu2.inc.rej
patching file usr/www/all/html/de/menus/menu2_internet.html
patching file usr/www/all/html/de/menus/menu2_system.html
patching file usr/www/all/html/de/menus/menu2_usb.html
patching file usr/www/all/html/de/menus/menu2_wlan.html
make: *** [firmware] Fehler 2
sven@ubuntu:~/ds-0.2.9_26-1$
cat menu2.inc.rej
*** 9,11 ****
<? setvariable var:menuTelefonie "Telefonie" ?>
<? setvariable var:menuSystem "System" ?>
<? setvariable var:menuHilfe "Hilfe" ?>
--- 9,12 ----
+ <? setvariable var:menuDSMOD "DS-MOD" ?>
modcgi: can't resolve symbol '__uClibc_start_main'
Content-type: text/html; charset=iso-8859-1
<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN"
"http://www.w3.org/TR/html4/loose.dtd">
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=ISO-8859-1">
<meta http-equiv="Content-Language" content="de">
<meta http-equiv="Expires" content="0">
<meta http-equiv="Pragma" content="no-cache">
<title>DS-MOD - Fehler</title>
<link rel="stylesheet" type="text/css" href="/style.css">
</head>
<body>
<table border="0" cellspacing="0" cellpadding="0" align="center" width="770">
<tr>
<td width="20"><img src="/images/edge_lt.png" width="20" height="40" border="0" alt=""></td>
<td width="730" id="edgetop"><div class="version">ds-0.2.9</div><div class="title">DS-MOD - <span style="font-style: italic;">Fehler</span></div></td>
<td width="20"><img src="/images/edge_rt.png" width="20" height="40" border="0" alt=""></td>
</tr>
<tr>
<td width="20" id="edgeleft"></td>
<td width="730" id="content">
<p><b>Fehler</b>: Unbekannter Befehl ''</p>
</td>
<td width="20" id="edgeright"></td>
</tr>
<tr>
<td width="20"><img src="/images/edge_lb.png" width="20" height="20" border="0" alt=""></td>
<td width="730" id="edgebottom"><div class="opt">optimiert für Mozilla Firefox</div></td>
<td width="20"><img src="/images/edge_rb.png" width="20" height="20" border="0" alt=""></td>
</tr>
</table>
</body>
</html>
Heißt das also das die 7141 nicht wirklich läuffähig ist derzeit?3. modcgi ist Bestandteil des dsmod und dazu hab ich kein Source, kann es also nicht an die neue uClibc anpassen.
2. Wenn du die libssl/libcrypt tauschst, dann musst du aufpassen, dass deine /var/flash/tr069.cfg nicht die Zeile enabled = yes; enthält, sonst geht nichts mehr.
olistudent schrieb:'Der Source'
MfG Oliver
sd8rdb schrieb:ich habs auch mal probiert, bekomme folgende Meldung:
STEP 2: MODIFY
applying patches
