If possible convert WLAN 7050 german to International English (AnnexB)?
vpe
24 Feb 2006
Is possible to convert FBF WLAN 7050 German version to International English version (Annex B too)?
I read this http://www.ip-phone-forum.de/showthread.php?t=93808 but i have WLAN 7050 and english firmware not nound on avm ftp :-(
I need English firmware for WLAN 7050 at all, but on AVM FTP not found!!
Or is German version FBF 7050 fully functional on Annex B lines in Poland, Czech Republic, etc.?
Please reply this thread or thread www.ip-phone-forum.de/showthread.php?t=93073 with identical querys. Many thanks for any tips!!!
none ideas? :-((
and also:
I have hardware FRITZ!Box Fon WLAN 7050, Firmware (english) Version 14.03.91 inside, please help with telnet or ssh enabling
(starttelnet.image not work with this version :-(
Hello All!
Have anyone FBF WLAN7050? Thanx!
I have a german box.
Telnet should work. It might be possible to rebrand german/english.
But there are some internal "problems".
- HWRevision, firmware_version and language needs to be modified
- It's not possible with a simple upload file
- so a special modified image is required.
- Do not know how Annex A/Annex B will react.
BR
Haveaniceday
PS: Busy during the next days... So not many replies from me..
Thx for reply. I have AnnexB Intl. revision, PN: 20002327.
Is this HW identical with German version (PN: 20002306)? German ver. have AnnexB too?
And inversible mod is possible? German 7050 PN:20002306 convert to Intl. AnnexB PN:pN: 20002327? Have anyone experience with this?
And please, please help me with telnet (on 20002327 or 20002306), i need cmd acces to fbf, many many thx.
I do not know the product numbers.
This thread contains the telnet file:
http://www.ip-phone-forum.de/showthread.php?t=69245
File: http://www.ip-phone-forum.de/attachment.php?attachmentid=3602&d=1106239999
The telnet password will be the same password as for your fritzbox web interface.
You can see from the Major version if a firmware matches.
Additionally the HWRevision ( gives Annex A/B ) and firmware_version ( avm/avme) and language defines if a firmware is loadable.
See here for some Major/HWRevision information: http://www.ip-phone-forum.de/showthread.php?p=541836#post541836
Be _very_ careful with modification. You can easy crash the settings and
you need to do a "hardcore" recover..
Haveaniceday
Thanx, i again try this, resume is:
The firmware update failed:
No error.
See picture
But telnet works, enjoy.
I have another question, i have experience With Asus WL500 and this have resistent bootcore, have FBF this technology too, or if I crash firmware flash, only JTAG or RS232 is solution?
Yes, there is an error within this telnet upload. It reports "error: no error".
I am too lazy to fix :)
The firmware has a bootloader so called "adam2".
The Flash contains several section:
mtd0 + mtd1 => kernel, filesystem size of the parts differs on different boxes.
mtd2: adam2 boot manager => can be reached for recovery via IP and managed with partial working ftp commands. No full ftp-protocol !
mtd3+mtd4=> storage for configuration/environment settings.
mtd2 destroyed/touched: JTAG requird
mtd3/mtd4 destroyed/wrong configured: reaction varies, no boot, no web interface, ...
The configuration is partially mapped to /var/flash/*. ( access is critical ! )
Do only read: cat /proc/avalanche/env
Makes sense: save mtd3 + mtd4
=> cat /dev/mtdblock/3 > /var/tmp/mtd3.sav
+ save with tftp to a linux/pc/unix
Same for mtd4
Unfortunately I do not know an english written description...
Haveaniceday
Same for mtd4
Haveaniceday
http://www.ip-phone-forum.de/showthread.php?p=542107#post542107
thx, backup of mtd3 and mtd4 english and restore in german version be enough?
Deutsch step-by-steb available? Babelfish translate for me :) Thx.
Again question - have fritz G729 or not? If you call Sipura and set in fritz compress codec always, sipura announce always G711 :-(
s cc
You have to tell us the HWrevision and the Annex.
I never had an international version to test or see.
mtd3+mtd4 backup can just be used with the firmware where it belongs to.
Trouble beside Annex A/B
mtd3+mtd4 settings: International "provider" avme, + "language" de
Web interface: /var/html => /usr/www/<avme>/<de>/... all web stuff
mtd3+mtd4 settings: "provider" avm, language do not care
Web interface: /var/html => /usr/www/avm/... all web stuff
The web interface and box does not start proper if /var/html does not point to a regular index.html + web stuff
Depending on the firmware it only contains one of:
/usr/www/avm/...
or
/usr/www/avme/{de,en}/...
Also: Annex A Hardware should never be used for Annex B PSTN. The frequency
interferes.
Annex B Hardware should work with less quality if set up as Annex A, if the
DSL-firmware supports.
For "perfekt" ADSL2+ firmware it will not be possible to have a unique Annex A/B support.
I do not know which "avme" international software is for annex A and which for annex B.
I just can tell if I unpack the firmware.
Haveaniceday
Haveaniceday
Could you provide us with instructions about using tftp ?
In English or in German or any link to a relevant page?
Thanks
mtd flash
mtd flash mtd flashmtd flashmtd flashmtd flashmtd flash
edit: (Firmware entfernt)
Es wurde schon so oft gesagt: Für AVM-Firmware nur zu AVM verlinken.
Translation:
- Firmware removed
- Often said, AVM firmware just as link to original AVM sites.
More translated: :idea:
AVM complains about offering firmware outside their web site.
Would give also trouble by german laws cause of parts with AVM copyright.
Haveaniceday
And last question - in Germany - PSTN is Annex B or Annex A or Annex B only ISDN Lines? Have in germany PSTN Analog lines? Thx.
Yes, PSTN have analog lines. But everybody uses Annex B only, also in combination
with analog lines.
Might give less bandwidth or no connection in rare cases, but the provider do
not care for those connection. They just tell you: No DSL possible in these
cases.
Haveaniceday
PS: I use e.g. an analog line, cause it's cheaper and voip gives a second line..
OK, FBF Intl version (English version) have Annex B only, this is different only by software.
I will try german software in my English box (eng updates not avaliable).
I have question - how (step by step) i flash german firmware (mtdXY block) to my FBF?
If necessary, i connect serial console (if sw operation progress step-by-step available). JTAG interface do not have (under Windows not available software)
I would wait until a new version is out.
You have already *.03.91 on your box.
I never did a migration from avm => avme or avme => avm.
There are some descriptions around, but I expect they are in german
and also more for the other way. avm("e"nglish) => avm german.
Regular you do not need the jtag interface.
- mtd2: _neeever_ touch, it's the bootloader adam2 ( or you need jtag..)
Should be the same for all boxes without specific language settings.
- mtd0 => filesystem
- mtd1 => kernel ( + see below )
- mtd3+mtd4 : flash archive for the settings.
- "mtd6" should be a hidden filesystem, mapped from inside mtd1 (behind kernel)
I compared the german 03.88 => 04.01 web interface. It might be a too ugly job
to combine/convert 03.91 englisch / 04.01 german for a proper english version.
But just ask AVM about an international update for your box.
They might do this as support.
Haveaniceday
Bipa
