The Linux task can never block interrupts or prevent itself from being preempted. The mechanism that makes this possible is the software emulation of interrupt control hardware. When any code in Linux tries to disable interrupts, the real time system intercepts the request, records it, and returns it to Linux. In fact, Linux is not permitted to ever really disable hardware interrupts, and hence, regardless of the state of Linux, it cannot add latency to the interrupt response time of the real time system. When an interrupt occurs, the real time kernel intercepts the interrupt and decides what to dispatch. If there is a real time handler for the interrupt, the appropriate handler is invoked. If there is no real time interrupt handler, or if the handler indicates that it wants to share the interrupt with Linux, then the interrupt is marked as pending. If Linux has requested that interrupts be enabled, any pending interrupts are enabled, and the appropriate Linux interrupt handler invoked - with hardware interrupts re-enabled. Regardless of the state of Linux: running in kernel mode; running a user process; disabling or enabling interrupts; the real-time system is always able to respond to an interrupt.
