Jan 1 01:00:58 fritz kern.warn kernel: *
Jan 1 01:00:58 fritz kern.info kernel: ramzswap: /dev/ramzswap0 initialized: disksize_kb=16384<6>Adding 16376k swap on /dev/ramzswap0. Priority:-1 extents:1 across:16376k
Jan 1 01:00:58 fritz kern.warn kernel: dect_uicp_from_dect, ignore 16 bytes, dect_manager not up: F614
Jan 1 01:00:58 fritz kern.info kernel: usbcore: registered new interface driver usbfs
Jan 1 01:00:58 fritz kern.info kernel: usbcore: registered new interface driver hub
Jan 1 01:00:58 fritz kern.info kernel: usbcore: registered new device driver usb
Jan 1 01:00:58 fritz kern.info kernel: ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Jan 1 01:00:58 fritz kern.info kernel: ikf68xx-ehci-hcd ikf68xx-ehci-hcd.0: Ikanos On-Chip EHCI Host Controller
Jan 1 01:00:58 fritz kern.info kernel: ikf68xx-ehci-hcd ikf68xx-ehci-hcd.0: new USB bus registered, assigned bus number 1
Jan 1 01:00:58 fritz kern.info kernel: ikf68xx-ehci-hcd ikf68xx-ehci-hcd.0: irq 35, io mem 0x19230000
Jan 1 01:00:58 fritz kern.info kernel: ikf68xx-ehci-hcd ikf68xx-ehci-hcd.0: USB 0.0 started, EHCI 1.00
Jan 1 01:00:58 fritz kern.info kernel: usb usb1: configuration #1 chosen from 1 choice
Jan 1 01:00:58 fritz kern.info kernel: hub 1-0:1.0: USB hub found
Jan 1 01:00:58 fritz kern.info kernel: hub 1-0:1.0: 2 ports detected
Jan 1 01:00:58 fritz kern.info kernel: avm_net_trace: New net trace device 'usb1' registered with minor 161.
Jan 1 01:00:58 fritz kern.info kernel: ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
Jan 1 01:00:58 fritz kern.debug kernel: drivers/usb/host/ohci-ikf68xx.c: Probing USB OHCI
Jan 1 01:00:58 fritz kern.debug kernel: drivers/usb/host/ohci-ikf68xx.c: starting IKF68XX OHCI USB Host Controller
Jan 1 01:00:58 fritz kern.debug kernel: drivers/usb/host/ohci-ikf68xx.c: Clock to USB host has been enabled
Jan 1 01:00:58 fritz kern.info kernel: ikf68xx-ohci-hcd ikf68xx-ohci-hcd.0: Ikanos On-Chip OHCI Host Controller
Jan 1 01:00:58 fritz kern.info kernel: usb 1-1: new high speed USB device using ikf68xx-ehci-hcd and address 2
Jan 1 01:00:58 fritz kern.info kernel: Port#1 config: AVM Powermeter changed to 100 mA
Jan 1 01:00:58 fritz kern.info kernel: usb 1-2.2: configuration #1 chosen from 1 choice
Jan 1 01:00:58 fritz kern.info kernel: usb 1-2.3: new full speed USB device using ikf68xx-ehci-hcd and address 5
Jan 1 01:00:58 fritz kern.info kernel: usb 1-2.3: configuration #1 chosen from 1 choice
Jan 1 01:00:58 fritz kern.info kernel: usb 1-2.4: new full speed USB device using ikf68xx-ehci-hcd and address 6
Jan 1 01:00:58 fritz kern.info kernel: usb 1-2.4: configuration #1 chosen from 1 choice
Jan 1 01:00:58 fritz kern.warn kernel: system-load 8 curr: configd runnable: 7
Jan 1 01:00:58 fritz kern.notice kernel: SCSI subsystem initialized
Jan 1 01:00:58 fritz kern.warn kernel: Driver 'sd' needs updating - please use bus_type methods
Jan 1 01:00:58 fritz kern.info kernel: Initializing USB Mass Storage driver...
Jan 1 01:00:58 fritz kern.info kernel: scsi0 : SCSI emulation for USB Mass Storage devices
Jan 1 01:00:58 fritz kern.debug kernel: usb-storage: device found at 2
Jan 1 01:00:58 fritz kern.debug kernel: usb-storage: waiting for device to settle before scanning
Jan 1 01:00:58 fritz kern.info kernel: scsi1 : SCSI emulation for USB Mass Storage devices
Jan 1 01:00:58 fritz kern.info kernel: usbcore: registered new interface driver usb-storage
Jan 1 01:00:58 fritz kern.info kernel: USB Mass Storage support registered.
Jan 1 01:00:58 fritz kern.debug kernel: usb-storage: device found at 4
Jan 1 01:00:58 fritz kern.info kernel: kdsldmod: init start (May 30 2012 15:49:01) sizeof(struct sk_buff)=536
Jan 1 01:00:58 fritz kern.info kernel: kdsld: ttychannel: ldisc 8 registered
Jan 1 01:00:58 fritz kern.info kernel: kdsldmod: init done
Jan 1 01:00:58 fritz kern.notice kernel: scsi 0:0:0:0: Direct-Access WD 3200BPV External 1.75 PQ: 0 ANSI: 4
Jan 1 01:00:58 fritz kern.notice kernel: sd 0:0:0:0: [sda] 625142448 512-byte hardware sectors: (320 GB/298 GiB)
Jan 1 01:00:58 fritz kern.notice kernel: sd 0:0:0:0: [sda] Write Protect is off
Jan 1 01:00:58 fritz kern.debug kernel: sd 0:0:0:0: [sda] Mode Sense: 23 00 00 00
Jan 1 01:00:58 fritz kern.err kernel: sd 0:0:0:0: [sda] Assuming drive cache: write through
Jan 1 01:00:58 fritz kern.info kernel: sda: sda1
Jan 1 01:00:58 fritz kern.notice kernel: sd 0:0:0:0: [sda] Attached SCSI disk
Jan 1 01:00:58 fritz kern.debug kernel: usb-storage: device scan complete
Jan 1 01:00:58 fritz kern.notice kernel: scsi 1:0:0:0: Direct-Access Intenso External USB 3.0 0205 PQ: 0 ANSI: 6
Jan 1 01:00:58 fritz kern.info kernel: kjournald starting. Commit interval 5 seconds
Jan 1 01:00:58 fritz kern.info kernel: EXT3 FS on sda1, internal journal
Jan 1 01:00:58 fritz kern.info kernel: EXT3-fs: mounted filesystem with ordered data mode.
Jan 1 01:00:58 fritz kern.warn kernel: eth: port 0 status 2 throttle 0
Jan 1 01:00:58 fritz kern.warn kernel: eth: port 1 status 1 throttle 1
Jan 1 01:00:58 fritz kern.warn kernel: eth: port 2 status 1 throttle 1
Jan 1 01:00:58 fritz kern.warn kernel: eth: port 3 status 1 throttle 1
Jan 1 01:00:58 fritz kern.warn kernel: system-load 100 % curr: ctlmgr runnable: 5
Jan 1 01:00:58 fritz kern.info kernel: ADDRCONF(NETDEV_UP): eth0: link is not ready
Jan 1 01:00:58 fritz kern.info kernel: device eth0 entered promiscuous mode
Jan 1 01:00:58 fritz kern.info kernel: device cpmac0 entered promiscuous mode
Jan 1 01:00:58 fritz kern.info kernel: [wlan_eeprom] calibration data blocks found = 2
Jan 1 01:00:58 fritz kern.info kernel: [wlan_eeprom] Got calibration data version 255 for instance #1
Jan 1 01:00:58 fritz kern.info kernel: [wlan_eeprom] Using complete eeprom from flash
Jan 1 01:00:58 fritz kern.info kernel: [wlan_eeprom] Got calibration data version 255 for instance #2
Jan 1 01:00:58 fritz kern.notice kernel: sd 1:0:0:0: [sdb] 732566528 4096-byte hardware sectors: (3.00 TB/2.72 TiB)
Jan 1 01:00:58 fritz kern.notice kernel: sd 1:0:0:0: [sdb] Write Protect is off
Jan 1 01:00:58 fritz kern.debug kernel: sd 1:0:0:0: [sdb] Mode Sense: 27 00 00 00
Jan 1 01:00:58 fritz kern.err kernel: sd 1:0:0:0: [sdb] Assuming drive cache: write through
Jan 1 01:00:58 fritz kern.info kernel: sdb: unknown partition table
Jan 1 01:00:58 fritz kern.notice kernel: sd 1:0:0:0: [sdb] Attached SCSI disk
Jan 1 01:00:58 fritz kern.info kernel: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Jan 1 01:00:58 fritz kern.info kernel: lan: topology change detected, propagating
Jan 1 01:00:58 fritz kern.info kernel: lan: port 1(eth0) entering forwarding state
Jan 1 01:00:58 fritz kern.err kernel: SQUASHFS error: Can't find a SQUASHFS superblock on sdb
Jan 1 01:00:58 fritz kern.info kernel: yaffs: dev is 8388624 name is "sdb" rw
Jan 1 01:00:58 fritz kern.info kernel: yaffs: passed flags ""
Jan 1 01:00:58 fritz kern.debug kernel: yaffs: yaffs: Attempting MTD mount of 8.16,"sdb"
Jan 1 01:00:58 fritz kern.warn kernel: system-load 100 % curr: pbd runnable: 4
Jan 1 01:00:58 fritz kern.debug kernel: vcc_release(0,0) done.AVM_WATCHDOG: System Init UEberwachung abgeschlossen (500180 ms noch verfuegbar)
Jan 1 01:00:58 fritz kern.debug kernel: [avm_power] pm_ressourceinfo_scriptparse: powerdevice_cpuclock: norm_power_rate=100 act_rate=100 mul=0 div=1 offset=0 NormP=0 mW -> SumNormP=0 mW
Jan 1 01:00:58 fritz kern.debug kernel: [avm_power] pm_ressourceinfo_scriptparse: powerdevice_systemclock: norm_power_rate=100 act_rate=100 mul=0 div=1 offset=3500 NormP=3500 mW -> SumNormP=3500 mW
Jan 1 01:00:58 fritz kern.debug kernel: [avm_power] pm_ressourceinfo_scriptparse: powerdevice_dspclock: norm_power_rate=100 act_rate=100 mul=0 div=1 offset=1500 NormP=1500 mW -> SumNormP=5000 mW
Jan 1 01:00:58 fritz kern.debug kernel: [avm_power] pm_ressourceinfo_scriptparse: powerdevice_loadrate: norm_power_rate=100 act_rate=100 mul=29 div=10 offset=-17 NormP=273 mW -> SumNormP=5273 mW
Jan 1 01:00:58 fritz kern.debug kernel: [avm_power] pm_ressourceinfo_scriptparse: powerdevice_analog: norm_power_rate=200 act_rate=0 mul=141 div=10 offset=100 NormP=2920 mW -> SumNormP=8193 mW
Jan 1 01:00:58 fritz kern.debug kernel: [avm_power] pm_ressourceinfo_scriptparse: powerdevice_isdnnt: norm_power_rate=100 act_rate=0 mul=1 div=1 offset=0 NormP=100 mW -> SumNormP=8293 mW
Jan 1 01:00:58 fritz kern.debug kernel: [avm_power] pm_ressourceinfo_scriptparse: powerdevice_isdnte: norm_power_rate=100 act_rate=0 mul=1 div=1 offset=0 NormP=100 mW -> SumNormP=8393 mW
Jan 1 01:00:58 fritz kern.debug kernel: [avm_power] pm_ressourceinfo_scriptparse: powerdevice_wlan: norm_power_rate=100 act_rate=100 mul=84 div=10 offset=100 NormP=940 mW -> SumNormP=9333 mW
Jan 1 01:00:58 fritz kern.debug kernel: [avm_power] pm_ressourceinfo_scriptparse: powerdevice_usb_host: norm_power_rate=500 act_rate=100 mul=55 div=10 offset=0 NormP=2750 mW -> SumNormP=12083 mW
Jan 1 01:00:58 fritz kern.debug kernel: [avm_power] pm_ressourceinfo_scriptparse: powerdevice_usb_host2: norm_power_rate=500 act_rate=100 mul=55 div=10 offset=0 NormP=2750 mW -> SumNormP=14833 mW
Jan 1 01:00:58 fritz kern.debug kernel: [avm_power] pm_ressourceinfo_scriptparse: powerdevice_dect: norm_power_rate=100 act_rate=0 mul=200 div=78 offset=150 NormP=406 mW -> SumNormP=15239 mW
Jan 1 01:00:58 fritz kern.debug kernel: [avm_power] pm_ressourceinfo_scriptparse: powerdevice_dsl: norm_power_rate=100 act_rate=100 mul=15 div=1 offset=0 NormP=1500 mW -> SumNormP=16739 mW
Jan 1 01:00:58 fritz kern.debug kernel: [avm_power] pm_ressourceinfo_scriptparse: powerdevice_ethernet: norm_power_rate=467 act_rate=50331922 mul=1 div=1 offset=50 NormP=517 mW -> SumNormP=17256 mW
Jan 1 01:00:58 fritz kern.info kernel: SysRq : Changing Loglevel
Jan 1 01:00:58 fritz kern.warn kernel: Loglevel set to 4
