Welche FW für welchen T-Offline-Bug?
HermannB
2 Nov 2005
Auszug aus den Log-Daten (natürlich bin ich successfully registered):
2006-03-28 10:39:45 Calling number sip:[email protected] via account #2(tel.t-online.de)
2006-03-28 10:39:45 <<<<<<<<<< New Call >>>>>>>>>>
2006-03-28 10:39:45 Server Error: Global failure: 606 Not Acceptable
2006-03-28 10:39:45 Closing call because of local hangup
2006-03-28 10:39:45 <<<<<<<<<< Call End >>>>>>>>>>
2006-03-28 12:12:01 Calling number sip:[email protected] via account #2(tel.t-online.de)
2006-03-28 12:12:01 <<<<<<<<<< New Call >>>>>>>>>>
2006-03-28 12:12:01 Server Error: Global failure: 606 Not Acceptable
2006-03-28 12:12:01 Closing call because of local hangup
2006-03-28 12:12:01 <<<<<<<<<< Call End >>>>>>>>>>
2006-03-28 12:13:33 Calling number sip:[email protected] via account #2(tel.t-online.de)
2006-03-28 12:13:33 <<<<<<<<<< New Call >>>>>>>>>>
2006-03-28 12:13:33 Server Error: Global failure: 606 Not Acceptable
2006-03-28 12:13:33 Closing call because of local hangup
2006-03-28 12:13:33 <<<<<<<<<< Call End >>>>>>>>>>
Welche FW empfiehlt sich derzeit für T-Offline?
Mit welchen Risiken und Nebenwirkungen?
Genervt grüßt
HermannB
Ein besonderer Gruß an alle T-Online-Mitarbeitenden - ich freue mich, wenn Ihr dies lest und reagiert! Fragt nach, wenn Ihr mehr über meine Konfiguration wissen müsst!
Hallo, eine Woche nicht da, und nun das:
2006-03-28 11:51:48 Successfully registered with SIP server account #2(sip.web.de)
2006-03-28 11:53:38 Registering with SIP server account #1(tel.t-online.de)
2006-03-28 11:53:38 Registering with SIP server account #2(sip.web.de)
2006-03-28 11:53:38 Register rejected by server on account #1(tel.t-online.de). Please correct config: 403 Voicemail is the only allowed service
2006-03-28 11:53:38 Register rejected by server on account #2(sip.web.de). Please correct config: 401 Unauthorized
2006-03-28 12:18:09 Calling number sip:[email protected] via account #1(tel.t-online.de)
2006-03-28 12:18:09 <<<<<<<<<< New Call >>>>>>>>>>
2006-03-28 12:18:10 Outgoing call failed: 403 Voicemail is the only allowed service
2006-03-28 12:18:10 <<<<<<<<<< Call End >>>>>>>>>>
2006-03-28 12:19:34 Calling number sip:[email protected] via account #1(tel.t-online.de)
2006-03-28 12:19:34 <<<<<<<<<< New Call >>>>>>>>>>
2006-03-28 12:19:34 Outgoing call failed: 403 Voicemail is the only allowed service
2006-03-28 12:19:34 <<<<<<<<<< Call End >>>>>>>>>>
2006-03-28 12:19:53 Calling number sip:[email protected] via account #1(tel.t-online.de)
2006-03-28 12:19:53 <<<<<<<<<< New Call >>>>>>>>>>
2006-03-28 12:19:53 Outgoing call failed: 403 Voicemail is the only allowed service
2006-03-28 12:19:53 <<<<<<<<<< Call End >>>>>>>>>>
Was ist denn nun wieder los?
T-Online hat wohl nux zu tun und bastelt wieder irgendwas?
403 oder 606?
Ist das nicht klasse? Jetzt kriegt jede(r) eine persönliche Fehlernummer... Aber die 403 hatte ich auch schon ein paarmal diese Woche...
Wer weiß was da wieder los war, habe jetzt die 2.53 drauf gebügelt und es geht.
Hat sicherlich nix mit dem Fehler zu tun, aber warten wir es einfach ab, die 2.54 ist ja in Arbeit.
Ich hatte heute morgen bei T-Online "503 Service unavailable" und das mit dem Snom-Softphone.
Gruß,
Gunnar
Geht wieder - aber Uhr geht falsch...
Bei mir geht T-Online wieder (seit heute morgen), und meine Flat für März wurde auch erstattet.
Aber jetzt geht die Uhr der OC 1 Stunde nach - kann sie keine Sommerzeit oder was? Muss ich bei Zeitzone manuell "2" eingeben? SNTP Client ist aktiviert.
HermannB
du hast recht, das ist ein Bug. Die Umschaltung wird erst übermorgen
stattfinden. Ursache ist ein Fehler in der Wochentagsberechnung.
Gruss,
Gunnar
Andii11
