>>> auth.log <<<
Dec 27 09:45:05 asterisk ipsec_starter[12772]: Starting strongSwan 4.5.2 IPsec [starter]...
Dec 27 09:45:05 asterisk ipsec_starter[12772]: no netkey IPsec stack detected
Dec 27 09:45:05 asterisk ipsec_starter[12772]: no KLIPS IPsec stack detected
Dec 27 09:45:05 asterisk ipsec_starter[12772]: no known IPsec stack detected, ignoring!
Dec 27 09:45:05 asterisk pluto[12780]: Starting IKEv1 pluto daemon (strongSwan 4.5.2) THREADS SMARTCARD VENDORID
Dec 27 09:45:05 asterisk pluto[12780]: | plugin 'test-vectors': loaded successfully
Dec 27 09:45:05 asterisk pluto[12780]: | plugin 'curl': loaded successfully
Dec 27 09:45:05 asterisk pluto[12780]: | plugin 'ldap': loaded successfully
Dec 27 09:45:05 asterisk pluto[12780]: | plugin 'aes': loaded successfully
Dec 27 09:45:05 asterisk pluto[12780]: | plugin 'des': loaded successfully
Dec 27 09:45:05 asterisk pluto[12780]: | plugin 'sha1': loaded successfully
Dec 27 09:45:05 asterisk pluto[12780]: | plugin 'sha2': loaded successfully
Dec 27 09:45:05 asterisk pluto[12780]: | plugin 'md5': loaded successfully
Dec 27 09:45:05 asterisk pluto[12780]: | plugin 'random': loaded successfully
Dec 27 09:45:05 asterisk pluto[12780]: | plugin 'x509': loaded successfully
Dec 27 09:45:05 asterisk pluto[12780]: | plugin 'pkcs1': loaded successfully
Dec 27 09:45:05 asterisk pluto[12780]: | plugin 'pgp': loaded successfully
Dec 27 09:45:05 asterisk pluto[12780]: | plugin 'dnskey': loaded successfully
Dec 27 09:45:05 asterisk pluto[12780]: | plugin 'pem': loaded successfully
Dec 27 09:45:05 asterisk pluto[12780]: | plugin 'openssl': loaded successfully
Dec 27 09:45:05 asterisk pluto[12780]: | plugin 'gmp': loaded successfully
Dec 27 09:45:05 asterisk pluto[12780]: | plugin 'hmac': loaded successfully
Dec 27 09:45:05 asterisk pluto[12780]: | plugin 'xauth': loaded successfully
Dec 27 09:45:05 asterisk pluto[12780]: | plugin 'attr': loaded successfully
Dec 27 09:45:05 asterisk pluto[12780]: listening on interfaces:
Dec 27 09:45:05 asterisk pluto[12780]: venet0
Dec 27 09:45:05 asterisk pluto[12780]: 127.0.0.2
Dec 27 09:45:05 asterisk pluto[12780]: 84.200.77.111
Dec 27 09:45:05 asterisk pluto[12780]: 2001:1608:10:39::c30:ccc
Dec 27 09:45:05 asterisk pluto[12780]: | plugin 'kernel-netlink': loaded successfully
Dec 27 09:45:05 asterisk pluto[12780]: | plugin 'resolve': loaded successfully
Dec 27 09:45:05 asterisk pluto[12780]: loaded plugins: test-vectors curl ldap aes des sha1 sha2 md5 random x509 pkcs1 pgp dnskey pem openssl gmp hmac xauth attr kernel-netlink resolve
Dec 27 09:45:05 asterisk pluto[12780]: | inserting event EVENT_REINIT_SECRET, timeout in 3600 seconds
Dec 27 09:45:05 asterisk pluto[12780]: including NAT-Traversal patch (Version 0.6c) [disabled]
Dec 27 09:45:05 asterisk pluto[12780]: | pkcs11 module '/usr/lib/opensc-pkcs11.so' loading...
Dec 27 09:45:05 asterisk pluto[12780]: failed to load pkcs11 module '/usr/lib/opensc-pkcs11.so'
Dec 27 09:45:05 asterisk pluto[12780]: FATAL ERROR: socket() in init_pfkeyfd(). Errno 97: Address family not supported by protocol
Dec 27 09:45:05 asterisk pluto[12780]: | certs and keys locked by 'free_preshared_secrets'
Dec 27 09:45:05 asterisk pluto[12780]: | certs and keys unlocked by 'free_preshard_secrets'
Dec 27 09:45:05 asterisk pluto[12780]: | crl fetch request list locked by 'free_crl_fetch'
Dec 27 09:45:05 asterisk pluto[12780]: | crl fetch request list unlocked by 'free_crl_fetch'
Dec 27 09:45:05 asterisk pluto[12780]: | ocsp fetch request list locked by 'free_ocsp_fetch'
Dec 27 09:45:05 asterisk pluto[12780]: | ocsp fetch request list unlocked by 'free_ocsp_fetch'
Dec 27 09:45:05 asterisk pluto[12780]: | authcert list locked by 'free_authcerts'
Dec 27 09:45:05 asterisk pluto[12780]: | authcert list unlocked by 'free_authcerts'
Dec 27 09:45:05 asterisk pluto[12780]: | crl list locked by 'free_crls'
Dec 27 09:45:05 asterisk pluto[12780]: | crl list unlocked by 'free_crls'
Dec 27 09:45:05 asterisk pluto[12780]: | ocsp cache locked by 'free_ocsp_cache'
Dec 27 09:45:05 asterisk pluto[12780]: | ocsp cache unlocked by 'free_ocsp_cache'
Dec 27 09:45:05 asterisk pluto[12780]: | pkcs11 module finalized and unloaded
Dec 27 09:45:05 asterisk ipsec_starter[12779]: pluto has died -- restart scheduled (5sec)
Dec 27 09:45:05 asterisk ipsec_starter[12779]: pluto refused to be started
Dec 27 09:45:05 asterisk ipsec_starter[12779]: charon (12781) started after 20 ms
Dec 27 09:45:10 asterisk pluto[12798]: Starting IKEv1 pluto daemon (strongSwan 4.5.2) THREADS SMARTCARD VENDORID
; das wiederholt sich dann
Dec 27 09:45:05 asterisk charon: 00[DMN] Starting IKEv2 charon daemon (strongSwan 4.5.2)
Dec 27 09:45:05 asterisk charon: 00[LIB] Padlock not found, CPU is GenuineIntel
Dec 27 09:45:05 asterisk charon: 00[LIB] plugin 'padlock': failed to load - padlock_plugin_create returned NULL
Dec 27 09:45:05 asterisk charon: 00[KNL] listening on interfaces:
Dec 27 09:45:05 asterisk charon: 00[KNL] venet0
Dec 27 09:45:05 asterisk charon: 00[KNL] 127.0.0.2
Dec 27 09:45:05 asterisk charon: 00[KNL] 84.200.77.111
Dec 27 09:45:05 asterisk charon: 00[KNL] 2001:1608:10:39::c30:ccc
Dec 27 09:45:05 asterisk charon: 00[KNL] unable to set IPSEC_POLICY on socket: Invalid argument
Dec 27 09:45:05 asterisk charon: 00[NET] installing bypass policy on receive socket failed
Dec 27 09:45:05 asterisk charon: 00[NET] installing bypass policy on send socket failed
Dec 27 09:45:05 asterisk charon: 00[CFG] loading ca certificates from '/etc/ipsec.d/cacerts'
Dec 27 09:45:05 asterisk charon: 00[CFG] loading aa certificates from '/etc/ipsec.d/aacerts'
Dec 27 09:45:05 asterisk charon: 00[CFG] loading ocsp signer certificates from '/etc/ipsec.d/ocspcerts'
Dec 27 09:45:05 asterisk charon: 00[CFG] loading attribute certificates from '/etc/ipsec.d/acerts'
Dec 27 09:45:05 asterisk charon: 00[CFG] loading crls from '/etc/ipsec.d/crls'
Dec 27 09:45:05 asterisk charon: 00[CFG] loading secrets from '/etc/ipsec.secrets'
Dec 27 09:45:05 asterisk charon: 00[CFG] loaded IKE secret for %any
Dec 27 09:45:05 asterisk charon: 00[CFG] sql plugin: database URI not set
Dec 27 09:45:05 asterisk charon: 00[LIB] plugin 'sql': failed to load - sql_plugin_create returned NULL
Dec 27 09:45:05 asterisk charon: 00[CFG] loaded 0 RADIUS server configurations
Dec 27 09:45:05 asterisk charon: 00[LIB] plugin 'medsrv' failed to load: /usr/lib/ipsec/plugins/libstrongswan-medsrv.so: cannot open shared object file: No such file or directory
Dec 27 09:45:05 asterisk charon: 00[CFG] mediation client database URI not defined, skipped
Dec 27 09:45:05 asterisk charon: 00[LIB] plugin 'medcli': failed to load - medcli_plugin_create returned NULL
Dec 27 09:45:05 asterisk charon: 00[LIB] plugin 'nm' failed to load: /usr/lib/ipsec/plugins/libstrongswan-nm.so: cannot open shared object file: No such file or directory
Dec 27 09:45:05 asterisk charon: 00[CFG] HA config misses local/remote address
Dec 27 09:45:05 asterisk charon: 00[LIB] plugin 'ha': failed to load - ha_plugin_create returned NULL
Dec 27 09:45:05 asterisk charon: 00[DMN] loaded plugins: test-vectors curl ldap aes des sha1 sha2 md5 random x509 revocation constraints pubkey pkcs1 pgp pem openssl fips-prf gmp agent pkcs11 xcbc hmac ctr ccm gcm attr kernel-netlink resolve socket-raw farp stroke updown eap-identity eap-aka eap-md5 eap-gtc eap-mschapv2 eap-radius eap-tls eap-ttls eap-tnc dhcp led addrblock
Dec 27 09:45:05 asterisk charon: 00[JOB] spawning 16 worker threads
Dec 27 09:45:05 asterisk charon: 08[CFG] received stroke: add connection 'test'
Dec 27 09:45:05 asterisk charon: 08[CFG] added configuration 'test'
Dec 27 09:45:10 asterisk charon: 12[CFG] received stroke: add connection 'test'
Dec 27 09:45:10 asterisk charon: 12[CFG] added child to existing configuration 'test'
Dec 27 09:45:10 asterisk charon: 14[CFG] received stroke: initiate 'test'
Dec 27 09:45:10 asterisk charon: 14[CFG] ignoring initiation request for IKEv1 config
Dec 27 09:45:15 asterisk charon: 16[CFG] received stroke: add connection 'test'
Dec 27 09:45:15 asterisk charon: 16[CFG] added child to existing configuration 'test'
Dec 27 09:45:20 asterisk charon: 16[CFG] received stroke: add connection 'test'
Dec 27 09:45:20 asterisk charon: 16[CFG] added child to existing configuration 'test'
Dec 27 09:45:25 asterisk charon: 16[CFG] received stroke: add connection 'test'
traceroute to 192.251.226.11 (192.251.226.11) from 192.168.176.4, 64 hops max, 40 byte packets
1 gw.berlin.uu.org (192.168.176.2) 1 ms 1 ms 1 ms
2 FB-VDSL-BRLN.uu.org (192.168.176.1) 1 ms 1 ms 1 ms
3 susan.uu.org (192.251.226.11) 32 ms 32 ms 33 ms
traceroute to 192.251.226.11 (192.251.226.11), 64 hops max, 40 byte packets
1 gw.berlin.uu.org (193.26.120.113) 2 ms 3 ms 5 ms
2 susan.uu.org (192.251.226.11) 54 ms 61 ms 54 ms
right=fritte.dyn.dns.service
[email protected]
rightsubnet=192.168.178.0/24
Wenn Du nach der Anleitung bei layer9 den "main mode" verwendest, mußt Du die Identität der Gegenstelle vorher über den DNS-Namen auflösen können. Dabei geht es nicht nur darum, den richtigen Server (anhand seiner Adresse) auf der anderen Seite zu "treffen" ...Beide Richtungen klappt (wenn strongSwan die aktuelle DNS-Auflösung hat, dafür nehme ich "ipsec reload" derzeit).
Ausgehend von seinen vorherigen Posts würde ich auf eine geplante Verbindung "Fritz!Box<>vServer mit Asterisk" tippen. In so einer Konstellation reicht es dann - bei meinen Boxen - in der Regel aus, auf der Fritz!Box eine "Eigene Rufnummer" einzutragen, die auf den Asterisk-Server zeigt (und möglichst auch funktioniert, sonst ist's mit 'Offenhalten' des VPN irgendwann Essig).Achtung, die FB (und auch strongSwan IIRC) baut das VPN nur auf, wenn Traffic darüber laufen soll. Also im Zweifel braucht's für den Automatismus 'n periodischen ping oder sowas.
vpncfg {
connections {
enabled = yes;
conn_type = conntype_lan;
name = "VPN zum V-Server";
always_renew = yes;
reject_not_encrypted = no;
dont_filter_netbios = yes;
localip = 0.0.0.0;
local_virtualip = 0.0.0.0;
remoteip = 84.200.111.222;
remote_virtualip = 0.0.0.0;
localid {
fqdn = "meindyndns.selfhost.bz";
remoteid {
ipaddr = 84.200.111.222;
mode = phase1_mode_idp;
phase1ss = "all/all/all";
keytype = connkeytype_pre_shared;
key = "geheim";
cert_do_server_auth = no;
use_nat_t = yes;
use_xauth = no;
use_cfgmode = no;
phase2localid {
ipnet {
ipaddr = 192.168.176.0;
mask = 255.255.255.0;
phase2remoteid {
ipnet {
ipaddr = 192.168.96.1;
mask = 255.255.255.255;
phase2ss = "esp-all-all/ah-none/comp-all/pfs";
accesslist = "permit ip any 192.168.96.1 255.255.255.255";
ike_forward_rules = "udp 0.0.0.0:500 0.0.0.0:500",
"udp 0.0.0.0:4500 0.0.0.0:4500";
// EOF
# /etc/ipsec.conf - strongSwan IPsec configuration file
config setup
plutodebug=all
crlcheckinterval=180
strictcrlpolicy=no
charonstart=no
conn berlin
aggressive=no
ikelifetime=4h
keylife=1h
keyingtries=1
keyexchange=ikev1
left=84.200.111.222
leftsubnet=192.168.96.1/32
ike=aes256-sha-modp1024
esp=aes256-sha1
pfs=yes
right=meindyndns.selfhost.bz
[email protected]
rightsubnet=192.168.176.0/24
authby=secret
auto=add
: PSK geheim
Jun 28 16:56:00 psychomantis ipsec_starter[8334]: Starting strongSwan 5.1.2 IPsec [starter]...
Jun 28 16:56:00 psychomantis ipsec_starter[8334]: # deprecated keyword 'plutodebug' in config setup
Jun 28 16:56:00 psychomantis ipsec_starter[8334]: # deprecated keyword 'crlcheckinterval' in config setup
Jun 28 16:56:00 psychomantis ipsec_starter[8334]: # deprecated keyword 'charonstart' in config setup
Jun 28 16:56:00 psychomantis ipsec_starter[8334]: # deprecated keyword 'pfs' in conn 'berlin'
Jun 28 16:56:00 psychomantis ipsec_starter[8334]: PFS is enabled by specifying a DH group in the 'esp' cipher suite
Jun 28 16:56:00 psychomantis ipsec_starter[8334]: ### 4 parsing errors (0 fatal) ###
Jun 28 16:56:00 psychomantis ipsec_starter[8334]: no netkey IPsec stack detected
Jun 28 16:56:00 psychomantis ipsec_starter[8334]: no KLIPS IPsec stack detected
Jun 28 16:56:00 psychomantis ipsec_starter[8334]: no known IPsec stack detected, ignoring!
Jun 28 16:56:00 psychomantis ipsec_starter[8341]: charon (8342) started after 20 ms
Jun 28 16:56:01 psychomantis CRON[8360]: pam_unix(cron:session): session opened for user root by (uid=0)
Jun 28 16:56:01 psychomantis CRON[8360]: pam_unix(cron:session): session closed for user root
Jun 28 16:56:02 psychomantis charon: 10[IKE] 188.99.11.22 is initiating a Main Mode IKE_SA
Jun 28 16:56:04 psychomantis charon: 12[IKE] IKE_SA berlin[1] established between 84.200.111.222[84.200.111.222]...188.99.11.22[meindyndns.selfhost.bz]
Jun 28 16:56:34 psychomantis charon: 08[IKE] deleting IKE_SA berlin[1] between 84.200.111.222[84.200.111.222]...188.99.11.22[meindyndns.selfhost.bz]
Jun 28 16:56:34 psychomantis charon: 10[IKE] 188.99.11.22 is initiating a Main Mode IKE_SA
Jun 28 16:56:35 psychomantis charon: 12[IKE] IKE_SA berlin[2] established between 84.200.111.222[84.200.111.222]...188.99.11.22[meindyndns.selfhost.bz]
Jun 28 16:57:01 psychomantis CRON[8370]: pam_unix(cron:session): session opened for user root by (uid=0)
root@psychomantis:~# ipsec statusall
Status of IKE charon daemon (strongSwan 5.1.2, Linux 2.6.32-042stab084.3, i686):
uptime: 12 minutes, since Jun 28 16:56:00 2014
malloc: sbrk 540672, mmap 0, used 181360, free 359312
worker threads: 11 of 16 idle, 5/0/0/0 working, job queue: 0/0/0/0, scheduled: 4
loaded plugins: charon test-vectors aes rc2 sha1 sha2 md4 md5 random nonce x509 revocation constraints pkcs1 pkcs7 pkcs8 pkcs12 pem openssl xcbc cmac hmac ctr ccm gcm attr kernel-netlink resolve socket-default stroke updown eap-identity addrblock
Listening IP addresses:
84.200.77.3
84.200.111.222
Connections:
berlin: 84.200.111.222...meindyndns.selfhost.bz IKEv1
berlin: local: [84.200.111.222] uses pre-shared key authentication
berlin: remote: [meindyndns.selfhost.bz] uses pre-shared key authentication
berlin: child: 192.168.96.1/32 === 192.168.176.0/24 TUNNEL
Security Associations (1 up, 0 connecting):
berlin[2]: ESTABLISHED 11 minutes ago, 84.200.111.222[84.200.111.222]...188.99.11.22[meindyndns.selfhost.bz]
berlin[2]: IKEv1 SPIs: 4073807aec1e91b9_i 0a025cb27d46c1d0_r*, pre-shared key reauthentication in 3 hours
berlin[2]: IKE proposal: AES_CBC_256/HMAC_SHA1_96/PRF_HMAC_SHA1/MODP_1024
HTH ...Code:vpncfg { connections { enabled = yes; conn_type = conntype_lan; name = "[COLOR="#FF0000"]84.200.111.222[/COLOR]"; always_renew = [COLOR="#FF0000"]no[/COLOR]; reject_not_encrypted = no; dont_filter_netbios = yes; [...]
Code:# /etc/ipsec.conf - strongSwan IPsec configuration file config setup [COLOR="#FF0000"]#plutodebug=all[/COLOR] [COLOR="#FF0000"]#crlcheckinterval=600[/COLOR] [COLOR="#FF0000"]#strictcrlpolicy=yes[/COLOR] [COLOR="#FF0000"]# nat_traversal=yes[/COLOR] charonstart=no [COLOR="#FF0000"]# plutostart=yes[/COLOR] conn berlin [COLOR="#FF0000"]#[/COLOR]aggressive=no ikelifetime=4h keylife=1h [COLOR="#FF0000"]#[/COLOR]keyingtries=1 [COLOR="#FF0000"]#[/COLOR]keyexchange=ikev1 left=84.200.111.222 leftsubnet=192.168.96.1/32 ike=aes[COLOR="#FF0000"]128[/COLOR]-sha-modp1024 esp=aes[COLOR="#FF0000"]128[/COLOR]-sha1 [COLOR="#FF0000"]#[/COLOR]pfs=yes right=meindyndns.selfhost.bz [email protected] rightsubnet=192.168.176.0/24 authby=secret auto=add
Code:[COLOR="#FF0000"]@meindyndns.selfhost.bz 84.200.111.222[/COLOR]: PSK [COLOR="#FF0000"]"[/COLOR]geheim[COLOR="#FF0000"]"[/COLOR]
Es gibt bei IPSec mehrere Modi (Beispiel-Konfigurationen dafür findest Du hier). Da die Anleitung bei layer9 auch schon etwas älter ist und sich im VPN der Box seit 04.80 einiges getan hat, würde ich auch eher für "Verstehen" anstelle von "Probieren" plädieren.Sieht vielleicht jemand einen Fehler oder gibt es Ideen, was ich noch als Parameter probieren kann?
Was wird eigentlich bei 'ip xfrm policy show' angezeigt, wenn der vServer die Verbindung für "aktiv" hält ?.
# ip xfrm policy show | sed -e 's/192.xxx.xxx/192.0.2/g' -e 's/193.xxx.xxx/198.51.100/g'
src 192.168.176.0/24 dst 192.0.2.0/27
dir in priority 2248
tmpl src 84.128.172.65 dst 198.51.100.231
proto comp reqid 16446 mode tunnel
level use
tmpl src 0.0.0.0 dst 0.0.0.0
proto esp reqid 16445 mode transport
dir fwd priority 2248
level use
src 192.0.2.0/27 dst 192.168.176.0/24
dir out priority 2248
tmpl src 198.51.100.231 dst 84.128.172.65
2014-06-29 00:35:08 avmike:< add(appl=dsld,cname=VPN zum V-Server,localip=77.191.9.6, remoteip=84.200.111.222, p1ss=all/all/all, p2ss=esp-all-all/ah-none/comp-all/no-pfs p1mode=2 keepalive_ip=0.0.0.0 flags=0x40001 tunnel no_xauth no_cfgmode no_nat_t no_certsrv_server_auth)
2014-06-29 00:35:08 avmike:new neighbour VPN zum V-Server:
2014-06-29 00:35:08 avmike:mainmode VPN zum V-Server: selected lifetime: 3600 sec(no notify)
2014-06-29 00:35:08 avmike:VPN zum V-Server remote peer supported XAUTH
2014-06-29 00:35:08 avmike:VPN zum V-Server remote peer supported DPD
2014-06-29 00:35:09 avmike:mainmode VPN zum V-Server: add SA 1
2014-06-29 00:35:09 avmike:VPN zum V-Server: Phase 1 ready
2014-06-29 00:35:09 avmike:VPN zum V-Server: start waiting connections
2014-06-29 00:35:09 avmike:VPN zum V-Server: Phase 2 starting (start waiting)
2014-06-29 00:35:09 avmike:< cb_sa_create_failed(name=VPN zum V-Server,reason=IKE-Error 0x2026)
2014-06-29 00:35:10 avmike:mainmode VPN zum V-Server: del SA 1
2014-06-29 00:35:30 avmike:< add(appl=dsld,cname=VPN zum V-Server,localip=77.191.40.2, remoteip=84.200.111.222, p1ss=all/all/all, p2ss=esp-all-all/ah-none/comp-all/no-pfs p1mode=2 keepalive_ip=0.0.0.0 flags=0x40001 tunnel no_xauth no_cfgmode no_nat_t no_certsrv_server_auth)
2014-06-29 00:35:30 avmike:new neighbour VPN zum V-Server:
2014-06-29 00:35:32 avmike:mainmode VPN zum V-Server: selected lifetime: 3600 sec(no notify)
2014-06-29 00:35:32 avmike:VPN zum V-Server remote peer supported XAUTH
2014-06-29 00:35:32 avmike:VPN zum V-Server remote peer supported DPD
2014-06-29 00:35:32 avmike:mainmode VPN zum V-Server: add SA 1
2014-06-29 00:35:32 avmike:VPN zum V-Server: Phase 1 ready
2014-06-29 00:35:32 avmike:VPN zum V-Server: start waiting connections
2014-06-29 00:35:32 avmike:VPN zum V-Server: Phase 2 starting (start waiting)
2014-06-29 00:35:33 avmike:< cb_sa_create_failed(name=VPN zum V-Server,reason=IKE-Error 0x2026)
Code:2014-06-29 00:35:09 avmike:< cb_sa_create_failed(name=VPN zum V-Server,reason=IKE-Error 0x2026) 2014-06-29 00:35:33 avmike:< cb_sa_create_failed(name=VPN zum V-Server,reason=IKE-Error 0x2026)
[IKE-Error 0x2026 "no proposal chosen"]
Deutet darauf hin, dass die beiden sich in der IKE-Phase (Austausch des PSK) nicht einig sind, mit welcher Verschlüsselung der Key-Exchange laufen soll.
Welche Proposals sich bei der Fritz!Box hinter der Auswahl (phase1ss/phase2ss im jeweiligen vpn.cfg-Abschnitt für eine VPN-Verbindung) verbergen, kann man in der Datei /etc/default/avm/ipsec.cfg nachlesen, getrennt nach Phase1 (ike_strategien) und Phase2 (ipsec_strategien).Hast Du mal auf aes128 geändert (Deine Config hat aes256)?
Das, was man im IKE-Protokoll landläufig unter "XAuth" und "IKE-Config-Mode" versteht (zwei ursprünglich proprietäre Erweiterungen von Cisco zur Authentifizierung von Benutzern innerhalb einer Gruppe (von Leuten, die den PSK des Gateways kennen) und zur Konfiguration von Netzwerkeinstellungen (so eine Art DHCP für IPSec-Verbindungen)), ist bei IKEv2 direkt als Anforderung berücksichtigt worden.PsychoMantis schrieb:Fritzbox kann xauth und xauth geht nur mit ikev1, also ist meine Schlussfolgerung, dass der avmike sehr wohl ikev1 (und vermutlich kein ikev2) kann.
Trage ich in die ipsec.conf keyexchange=ikev2 ein, kommt keine Verbindung zustande.
Wie muß man sich das denn jetzt vorstellen ? Hast Du strongSwan 5 (daß es da gewaltige Unterschiede gibt, habe sogar ich begriffen) deinstalliert ? Beide IKE-Implementierungen wirst Du schwerlich parallel betreiben können, da nur eine gleichzeitig die UDP-Ports 500 und/oder 4500 "belegen" kann.PsychoMantis schrieb:Habe auch versucht manuell strongswan 4.3 zu installieren, aber ipsec statusall liefert da nur leere Zeile.
config setup
charondebug=ike
conn berlin
keyexchange=ikev1
left=84.200.111.222
leftsubnet=192.168.1.0/24
ike=aes-camellia #hier habe ich auch alles andere versucht
esp=aes-camellia-null #und da
[email protected]
authby=psk
auto=route
root@psychomantis:~# ipsec start
root@psychomantis:~# ipsec up berlin
initiating Main Mode IKE_SA berlin[1] to 188.105.24.8
generating ID_PROT request 0 [ SA V V V V ]
sending packet: from 84.200.111.222[500] to 188.105.24.8[500] (180 bytes)
received packet: from 188.105.24.8[500] to 84.200.111.222[500] (148 bytes)
parsed ID_PROT response 0 [ SA N((24576)) V V ]
received XAuth vendor ID
received DPD vendor ID
generating ID_PROT request 0 [ KE No ]
sending packet: from 84.200.111.222[500] to 188.105.24.8[500] (196 bytes)
received packet: from 188.105.24.8[500] to 84.200.111.222[500] (180 bytes)
parsed ID_PROT response 0 [ KE No ]
generating ID_PROT request 0 [ ID HASH ]
sending packet: from 84.200.111.222[500] to 188.105.24.8[500] (68 bytes)
received packet: from 188.105.24.8[500] to 84.200.111.222[500] (84 bytes)
parsed ID_PROT response 0 [ ID HASH ]
IKE_SA berlin[1] established between 84.200.111.222[84.200.111.222]...188.105.24.8[meindyndns.selfhost.bz]
scheduling reauthentication in 9733s
maximum IKE_SA lifetime 10273s
allocating SPI failed: Invalid argument (22)
unable to get SPI for reqid {1}
allocating SPI from kernel failed
establishing connection 'berlin' failed
Denkbar, aber nicht zwingend ... https://openvz.org/IPsecNur warum verstehe ich nicht. Es fehlt was im Kernel und ich kann nichts tun, weil es nur ein V-Server ist auf OpenVZ?
