cat ar7.cfg
* /var/flash/ar7.cfg
* Sat Jan 1 01:01:37 2000
ar7cfg {
mode = dsldmode_bridge;
tsdisabled = no;
igddenabled = yes;
igdd_control_enabled = no;
wan_bridge_with_dhcpc = no;
wan_bridge_gateway = 192.168.0.1;
dhcpc_use_static_dns = yes;
ethmode = ethmode_bridge;
StatisticStartOfMonth = 1;
macdsl_override = 00:00:00:00:00:00;
ethinterfaces {
name = "eth0";
dhcp = no;
ipaddr = 192.168.0.10;
netmask = 255.255.255.0;
dstipaddr = 0.0.0.0;
dhcpenabled = yes;
dhcpstart = 0.0.0.0;
dhcpend = 0.0.0.0;
name = "eth0:0";
dhcp = no;
ipaddr = 192.168.178.254;
dhcpenabled = yes;
dhcpend = 0.0.0.0;
name = "eth1";
dhcp = no;
ipaddr = 192.168.181.1;
dhcpenabled = yes;
dhcpend = 0.0.0.0;
name = "usbrndis";
dhcp = no;
ipaddr = 192.168.179.1;
dhcpenabled = yes;
dhcpend = 0.0.0.0;
name = "wlan";
dhcp = no;
ipaddr = 192.168.182.1;
interfaces = "tiwlan0", "wdsup0", "wdsdw0", "wdsdw1",
"wdsdw2", "wdsdw3";
dhcpenabled = yes;
dhcpend = 0.0.0.0;
brinterfaces {
name = "lan";
dhcp = no;
interfaces = "eth0", "usbrndis", "eth1", "tiwlan0", "wdsup0",
"wdsdw0", "wdsdw1", "wdsdw2", "wdsdw3";
dhcpenabled = yes;
dhcpend = 0.0.0.0;
name = "lan:0";
dhcp = no;
ipaddr = 192.168.2.254;
dhcpenabled = yes;
dhcpend = 0.0.0.0;
dslinterface {
name = "dsl";
dhcp = no;
netmask = 255.255.255.255;
dstipaddr = 192.168.179.1;
dhcpenabled = yes;
dhcpend = 0.0.0.0;
dslinterface_metric = 2;
ipbridge {
enabled = no;
pppoefw {
interfaces = "usbrndis", "eth0", "eth1", "tiwlan0", "wdsup0",
nofirewall = yes;
ipnetbiosfilter = yes;
dnsfilter_for_active_directory = yes;
hostuniq_filter = "";
dpconfig {
security = dpsec_host;
lowinput {
policy = "reject";
accesslist =
"permit ip any any connection outgoing-related",
"permit ip any any connection incoming-related",
"permit icmp any any";
lowoutput {
policy = "permit";
highinput {
policy = "permit";
highoutput {
policy = "permit";
accesslist =
"reject ip any 242.0.0.0 255.0.0.0",
"deny ip any host 255.255.255.255",
"reject ip any 169.254.0.0 255.255.0.0",
"reject udp any any eq 135",
"reject tcp any any eq 135",
"reject udp any any range 137 139",
"reject tcp any any range 137 139",
"reject udp any any range 161 162",
"reject udp any any eq 520",
"reject udp any any eq 111",
"reject udp any any eq 22289",
"reject udp any any eq 1710",
"reject udp any any eq 1048",
"reject udp any any eq 158",
"reject udp any any eq 515",
"reject icmp any 149.1.1.0 255.255.255.0";
shaper = "globalshaper";
budget {
Enabled = no;
Period = 2;
VolumeLow = 0;
VolumeHigh = 0;
ConnectionTime = 0;
WarnOnly = yes;
vccs {
VPI = 1;
VCI = 32;
traffic_class = atm_traffic_class_UBR;
pcr = 0;
scr = 0;
priority = 0;
dsl_encap = dslencap_pppoe;
ipbridgeing = no;
pppoeforwarding = no;
connections = "internet", "voip";
mcupstream = "internet";
dslifaces {
enabled = yes;
name = "internet";
dsl_encap = dslencap_inherit;
dslinterfacename = "dsl";
pppoevlanauto = no;
pppoevlanauto_startwithvlan = no;
ppptarget = "internet";
etherencapcfg {
use_dhcp = yes;
ipaddr = 0.0.0.0;
netmask = 0.0.0.0;
gateway = 0.0.0.0;
dns1 = 0.0.0.0;
dns2 = 0.0.0.0;
mtu = 0;
is_mcupstream = yes;
stay_always_online = no;
only_route_when_connected = no;
redial_delay_after_auth_failure = 1m;
redial_limit = 3;
redial_after_limit_reached = 1h;
redial_after_limit_reached_variance = 30m;
username_prefix_after_auth_failure = "";
redial_delay_after_low_error = 10s;
routes_only_for_local = no;
dsldpconfig {
security = dpsec_firewall;
lowinput {
policy = "permit";
accesslist =
"deny ip any 242.0.0.0 255.0.0.0",
"deny udp any any eq 135",
"deny tcp any any eq 135",
"deny udp any any range 137 139",
"deny tcp any any range 137 139",
"deny udp any any range 161 162",
"deny udp any any eq 520",
"deny udp any any eq 111",
"deny udp any any eq 22289",
"deny udp any any eq 1710",
"deny udp any any eq 1048",
"deny udp any any eq 158",
"deny udp any any eq 515";
lowoutput {
policy = "permit";
highinput {
policy = "permit";
highoutput {
policy = "permit";
accesslist =
forwardrules = "udp 0.0.0.0:5060 0.0.0.0:5060",
"udp 0.0.0.0:7078 0.0.0.0:7078",
"udp 0.0.0.0:7079 0.0.0.0:7079",
"udp 0.0.0.0:7080 0.0.0.0:7080",
"udp 0.0.0.0:7081 0.0.0.0:7081",
"udp 0.0.0.0:7082 0.0.0.0:7082",
"udp 0.0.0.0:7083 0.0.0.0:7083",
"udp 0.0.0.0:7084 0.0.0.0:7084",
"udp 0.0.0.0:7085 0.0.0.0:7085",
"udp 0.0.0.0:7086 0.0.0.0:7086",
"udp 0.0.0.0:7087 0.0.0.0:7087",
"udp 0.0.0.0:7089 0.0.0.0:7089",
"udp 0.0.0.0:7090 0.0.0.0:7090",
"udp 0.0.0.0:7091 0.0.0.0:7091",
"udp 0.0.0.0:7092 0.0.0.0:7092",
"udp 0.0.0.0:7093 0.0.0.0:7093",
"udp 0.0.0.0:7094 0.0.0.0:7094",
"udp 0.0.0.0:7095 0.0.0.0:7095",
"udp 0.0.0.0:7096 0.0.0.0:7096",
"udp 0.0.0.0:7097 0.0.0.0:7097",
"tcp 0.0.0.0:8089 0.0.0.0:8089";
enabled = yes;
name = "voip";
pppoevlanauto = no;
ppptarget = "voip";
etherencapcfg {
use_dhcp = yes;
ipaddr = 0.0.0.0;
netmask = 0.0.0.0;
gateway = 0.0.0.0;
dns1 = 0.0.0.0;
dns2 = 0.0.0.0;
mtu = 0;
is_mcupstream = no;
stay_always_online = yes;
redial_limit = 3;
tcclassroutes = "sipdns", "sip", "rtp";
dsldpconfig {
lowinput {
policy = "permit";
accesslist = "permit udp any any",
"permit icmp any any",
"reject ip any any";
lowoutput {
policy = "permit";
highinput {
policy = "permit";
highoutput {
policy = "permit";
"udp 0.0.0.0:7097 0.0.0.0:7097";
targets {
type = pppcfg_target_internet;
name = "internet";
only_crypt_auth = no;
local {
username = "";
passwd = "";
remoteauth = pppcfg_authtype_chap;
remoteauth_only_on_incoming = yes;
remote {
inactivity_timeout = 5m;
bUseChargeInterval = no;
nChargeInterval = 1m;
logicaldisconnect_with_physical = yes;
disconnect_timeout = 0w;
finaldisconnectcall = no;
ipnetbiosspoofing = no;
dnsfilter_for_active_directory = no;
no_outgoing_calls = no;
coso = pppcfg_coso_caller;
callback_delay = 1s;
icbmode = pppcfg_icbmode_none;
ocbmode = pppcfg_ocbmode_none;
mscbprefered = no;
multilink {
extra_static_channels = 0;
max_channels = 1;
automatic = no;
automatic_param {
window = 20s;
add_percent = 85;
drop_percent = 70;
sportlich = no;
header_compression = yes;
data_compression = pppcfg_datacomp_auto;
stac_reset_with_history_number = no;
encryption = pppcfg_crypt_none;
inactivity_prevention_interval = 0w;
new_ipaddr_on_connect = no;
my_ipaddr = 0.0.0.0;
his_ipaddr = 0.0.0.0;
overwrite_dns1 = 192.168.0.1;
overwrite_dns2 = 0.0.0.0;
bVolumeRoundUp = no;
VolumeRoundUpBytes = 0;
bProviderDisconnectPrevention = yes;
ProviderDisconnectPreventionInterval = 1d;
ProviderDisconnectPreventionHour = 1;
bProviderDisconnectPreventionHourSet = yes;
passiv_on_outgoing = no;
name = "voip";
local {
username = "";
passwd = "";
remote {
inactivity_timeout = 0w;
mscbprefered = no;
multilink {
max_channels = 1;
automatic = no;
automatic_param {
window = 20s;
add_percent = 85;
drop_percent = 70;
sportlich = no;
overwrite_dns1 = 0.0.0.0;
dslglobalconfig {
autodetect = no;
pppoeiface = "eth0";
speed_in_netto = 6000;
speed_out_netto = 600;
manual_speed = no;
connect_delay_when_synced = 10s;
default_tcom_vlan = 7;
templates {
VPI = 1;
VCI = 32;
manu = 0;
shapers {
name = "globalshaper";
OutFragmentWhenVoIP = 0;
shaperconnection {
enabled = yes;
targets = "";
name = "Fritz!Box";
limiters {
name = "default-out";
bps_limit {
limit_total = 100;
limit_p0 = 0;
limit_p1 = 95;
limit_p2 = 95;
limit_p3 = 0;
pps_limit {
limit_total = 0;
limit_p0 = 0;
limit_p1 = 0;
limit_p2 = 0;
limit_p3 = 0;
min_priority = 0;
max_priority = 3;
grouping_by_source_ip = no;
grouping_by_dest_ip = no;
grouping_by_source_port = no;
grouping_by_dest_port = no;
dynamic_balancing = no;
bps_child_limit {
limit_total = 0;
limit_p0 = 0;
limit_p1 = 0;
limit_p2 = 0;
limit_p3 = 0;
pps_child_limit {
limit_total = 0;
limit_p0 = 0;
limit_p1 = 0;
limit_p2 = 0;
limit_p3 = 0;
shapeOutgoingOnIncomingCounters = no;
name = "default-in";
bps_limit {
limit_total = 0;
limit_p0 = 0;
limit_p1 = 0;
limit_p2 = 0;
limit_p3 = 0;
pps_limit {
limit_total = 0;
limit_p0 = 0;
limit_p1 = 0;
limit_p2 = 0;
limit_p3 = 0;
min_priority = 0;
max_priority = 0;
bps_child_limit {
limit_total = 0;
limit_p0 = 0;
limit_p1 = 0;
limit_p2 = 0;
limit_p3 = 0;
pps_child_limit {
limit_total = 0;
limit_p0 = 0;
limit_p1 = 0;
limit_p2 = 0;
limit_p3 = 0;
out_rules {
name = "fon-rtp";
filter = "tc:rtp,sip";
priority = 3;
limiters = "default-out";
name = "download-tcp-ack";
filter = "tc:tcp_ack";
priority = 2;
name = "dns";
filter = "tc:dns,sipdns,ntpdns,tr069dns";
priority = 1;
name = "http-requests";
filter = "tc:http_req,tr069";
priority = 1;
name = "pri-out";
filter = "tc:icmp";
priority = 1;
name = "default";
filter = "";
priority = 0;
in_rules {
name = "default";
filter = "";
priority = 0;
limiters = "default-in";
demasquerade = no;
RunVoIPDSLAutodetect = 0;
saved_non_ata_ip_config {
ipaddr = 192.168.2.1;
dns1 = 192.168.180.1;
dns2 = 192.168.180.2;
servercfg {
hostname = "(none)";
dns1 = 192.168.0.1;
dns2 = 192.168.180.1;
websrv {
port = "80";
read_timeout = 15m;
request_timeout = 30s;
keepalive_timeout = 5m;
nokeepalive = "*";
errordir = "/usr/lib/websrv/errors";
webdir = "/usr/www";
cgidir = "cgi-bin";
indexfn = "index.var", "index.htm", "index.html";
url_redirects {
from_url = "/top_budget.htm";
to_url = "/cgi-bin/webcm?getpage=../html/top_budget.html";
from_url = "/top_freischalten.htm";
to_url = "/cgi-bin/webcm?getpage=../html/top_freischalten.html";
from_url = "/top_sperren.htm";
to_url = "/cgi-bin/webcm?getpage=../html/top_sperren.html";
from_url = "/index.htm";
to_url = "/index.html";
from_url = "/cgi-bin/disconnect.exe";
to_url = "/cgi-bin/webcm?connection0:settings/cmd_disconnect=1";
from_url = "/cgi-bin/connect.exe";
to_url = "/cgi-bin/webcm?connection0:settings/cmd_connect=1";
from_url = "/hcti_status_ocontrol.htm";
to_url = "/cgi-bin/webcm?getpage=../html/hcti_status_ocontrol.html";
dhcpserver {
saveinterval = 1h;
generic {
default_lease_time = 10d;
max_lease_time = 13d;
dhcpclient {
metric = 9;
dnsserver {
cache_maxKB = 16;
negative_ttl = 5m;
ddns {
accounts {
enabled = no;
domain = "";
iface = 0;
username = "";
passwd = "";
ddnsprovider = "dyndns.org";
types {
type = "dyndns";
url = "/nic/update?system=dyndns&hostname=<domain>&myip=<ipaddr>&wildcard=NOCHG";
type = "dyndns-custom";
url = "/nic/update?system=custom&hostname=<domain>&myip=<ipaddr>&wildcard=NOCHG";
type = "dyndns-statdns";
url = "/nic/update?system=statdns&hostname=<domain>&myip=<ipaddr>&wildcard=NOCHG";
type = "noip";
url = "/ducupdate.php?update=<b64>username=<username>&pass=<pass>&h[]=<domain>&ip=<ipaddr></b64>";
type = "2mydns";
url = "/dyn.asp?username=<username>&password=<pass>&hostname=<domain>&myip=<ipaddr>";
type = "dns4biz";
url = "/nic/update?hostname=<domain>&myip=<ipaddr>";
type = "selfhost";
url = "/nic/update?myip=<ipaddr>&host=<domain>&textmodi=1&http_status=1";
type = "userdefined";
url = "";
type = "strato";
url = "/nic/update?hostname=<domain>";
provider {
name = "dyndns.org";
type = "dyndns";
livedelay = 0w;
touchtime = 30d;
server = "members.dyndns.org";
infourl = "http://www.dyndns.org/";
name = "dyndns.org-custom";
livedelay = 0w;
touchtime = 30d;
name = "dyndns.org-statdns";
livedelay = 0w;
touchtime = 30d;
name = "No-IP.com";
type = "noip";
livedelay = 4m;
touchtime = 0w;
server = "dynupdate.no-ip.com:8245";
infourl = "http://www.no-ip.com/";
name = "2myDNS";
type = "2mydns";
livedelay = 0w;
touchtime = 0w;
server = "dyn.2mydns.com";
infourl = "http://www.2mydns.com/";
name = "DNS4BIZ.DE Premium";
type = "dns4biz";
livedelay = 0w;
touchtime = 0w;
server = "au-eu.dns4biz.net";
infourl = "http://www.dns4biz.com/services_avm.php3";
name = "DNS4BIZ.DE Business";
type = "dns4biz";
livedelay = 0w;
touchtime = 0w;
server = "au-eu.dns4biz.biz";
name = "selfhost.de";
type = "selfhost";
livedelay = 0w;
touchtime = 0w;
server = "carol.selfhost.de";
infourl = "http://www.selfhost.de";
name = "Benutzerdefiniert";
livedelay = 4m;
touchtime = 0w;
server = "";
infourl = "http://";
name = "STRATO AG";
type = "strato";
livedelay = 4m;
touchtime = 0w;
server = "dyndns.strato.com";
infourl = "http://www.strato.de/webhosting/index.html";
webui {
username = "";
password = "$$$$";
expertmode = yes;
wizard_completed = no;
event_filter = 3;
capiovertcp {
enabled = no;
maxctrl = 1;
port = 5031;
emailnotify {
enabled = no;
interval = daily;
From = "";
To = "";
SMTPServer = "";
accountname = "";
passwd = "";
show_eventlist = no;
show_voipstat = no;
usbhost {
readonly = no;
password = "";
autoprov_enabled = yes;
ftp_internet_enabled = no;
aura_config = 0;
ftp_server_enabled = yes;
samba_server_enabled = yes;
night_time_control {
enabled = no;
time_on = "";
time_off = "";
ring_blocked = no;
ntpclient {
server_list = "0.europe.pool.ntp.org";
led {
infoled_reason = 0;
timezone_manual {
enabled = no;
offset = 0;
dst_enabled = no;
TZ_string = "";
mrouter {
igmp_version_for_upstream = 3;
igmp_version_for_other = 3;
igmp_prio = 48;
rip {
cpu_schedule {
dsl_token = 5000;
lan_token = 20000;
media {
enabled = yes;
max_entries = 5000;
TR_064 {
enabled = no;
username = "";
password = "";
persistent_data = "";
landevices {
qos {
always_set_tos = no;
rules {
tcclass = "sip";
rules = "udp.dport 5060";
tcclass = "dns";
rules = "udp.dport 53";
tcclass = "http_req";
rules = "tcp.dport 80 ip.len <= 800",
"tcp.dport 8080 ip.len <= 800",
"tcp.dport 3128 ip.len <= 800";
tcclass = "tcp_ack";
rules = "ip.proto == tcp ip.len <= 64";
tcclass = "icmp";
rules = "ip.proto == icmp";
ethernet_eco {
eth0_mode = 2;
eth1_mode = 1;
eth2_mode = 1;
eth3_mode = 1;
// EOF
