Ich denke das liegt an dem Security Update vom Februar.
Du kannst ja testweise downgraden und es dann für ein bis zwei Tage versuchen. Dann weißt du es genauer.
Mfg
vccs {
VPI = 1;
VCI = 32;
traffic_class = atm_traffic_class_UBR;
pcr = 0;
scr = 0;
priority = 0;
dsl_encap = dslencap_mixed;
ipbridgeing = no;
ipbridgeing_igmp = no;
pppoeforwarding = no;
connections = "internet", "voip", "mstv", "iptv";
mcupstream = "iptv", "mstv";
voip_forwardrules = "udp 0.0.0.0:5060 0.0.0.0:5060",
"tcp 0.0.0.0:5060 0.0.0.0:5060",
"udp 0.0.0.0:7078+32 0.0.0.0:7078";
tr069_forwardrules = "tcp 0.0.0.0:8089 0.0.0.0:8089";
voip_ip6_forwardrules = "udp 5060,7078-7110", "tcp 5060";
tr069_ip6_forwardrules = "tcp 8089";
internet_in_nat_rules_enabled = yes;
internet_out_nat_rules_enabled = yes;
dslifaces {
enabled = yes;
name = "internet";
weight = 50;
dsl_encap = dslencap_pppoe;
dslinterfacename = "dsl";
no_masquerading = no;
use_fixed_masqaddr_if_no_masquerading = no;
no_firewall = no;
stackmode = stackmode_ipv4only;
pppoevlanauto = no;
pppoevlanauto_startwithvlan = no;
vlancfg {
vlanencap = vlanencap_fixed_prio;
vlanid = 132;
vlanprio = 0;
ppptarget = "internet";
fixed_masqaddr = 0.0.0.0;
mtu = 0;
etherencapcfg {
use_dhcp = yes;
use_dhcp_if_not_encap_ether = no;
ipaddr = 0.0.0.0;
netmask = 0.0.0.0;
gateway = 0.0.0.0;
dns1 = 0.0.0.0;
dns2 = 0.0.0.0;
is_mcupstream = no;
ap2ap = ap2ap_auto;
ap2ap_qos = yes;
stay_always_online = yes;
disable_ondemand = no;
reconnect_delay_after_conn_abort = 30s;
only_route_when_connected = no;
redial_delay_after_auth_failure = 1m;
redial_limit = 3;
redial_after_limit_reached = 10m;
redial_after_limit_reached_variance = 5m;
redial_delay_after_low_error = 10s;
redial_delay_after_ppp_timeout = 10s;
redial_delay_after_ppp_error = 0w;
routes_only_for_local = no;
dproutes_only_for_local = no;
disable_staticroutes_on_dhcproutes = no;
ripv2receiver_enabled = no;
ripv2_update_timer = 30s;
ripv2authmode = ripv2_auth_none;
ripv2md5_keyid = 0;
ripv2passwd = "";
set_replicate_dhcpoptions_in_parameter_request_list = no;
unset_ignored_dhcpoptions_in_parameter_request_list = yes;
dsldpconfig {
security = dpsec_firewall;
filter_teredo = yes;
filter_netbios = yes;
lowinput {
policy = "permit";
accesslist =
"deny ip any 242.0.0.0 255.0.0.0",
"deny ip any host 255.255.255.255";
lowoutput {
policy = "permit";
highinput {
policy = "permit";
highoutput {
policy = "permit";
accesslist =
"reject ip any 242.0.0.0 255.0.0.0",
"deny ip any host 255.255.255.255",
"reject ip any 169.254.0.0 255.255.0.0";
dhcp_auth_mode = auth_none;
dhcp_requests_with_client_id = yes;
enabled = yes;
name = "voip";
weight = 50;
no_firewall = no;
pppoevlanauto = no;
vlancfg {
vlanid = 232;
vlanprio = 0;
ppptarget = "voip";
mtu = 0;
etherencapcfg {
use_dhcp = yes;
ipaddr = 0.0.0.0;
netmask = 0.0.0.0;
gateway = 0.0.0.0;
dns1 = 0.0.0.0;
dns2 = 0.0.0.0;
is_mcupstream = no;
ap2ap = ap2ap_auto;
ap2ap_qos = yes;
redial_limit = 3;
ripv2md5_keyid = 0;
ripv2passwd = "";
dsldpconfig {
lowinput {
policy = "permit";
lowoutput {
policy = "permit";
highinput {
policy = "permit";
highoutput {
policy = "permit";
enabled = yes;
name = "mstv";
weight = 50;
dsl_encap = dslencap_ether;
no_firewall = no;
pppoevlanauto = no;
vlancfg {
vlanid = 332;
vlanprio = 0;
ppptarget = "mstv";
mtu = 0;
etherencapcfg {
use_dhcp = yes;
ipaddr = 0.0.0.0;
netmask = 0.0.0.0;
gateway = 0.0.0.0;
dns1 = 0.0.0.0;
dns2 = 0.0.0.0;
is_mcupstream = yes;
ap2ap = ap2ap_auto;
ap2ap_qos = yes;
redial_limit = 3;
tcclassroutes = "iptv";
ripv2md5_keyid = 0;
ripv2passwd = "";
dsldpconfig {
lowinput {
policy = "permit";
lowoutput {
policy = "permit";
highinput {
policy = "permit";
highoutput {
policy = "permit";
enabled = yes;
name = "iptv";
weight = 50;
no_firewall = no;
pppoevlanauto = no;
vlancfg {
vlanid = 332;
vlanprio = 0;
ppptarget = "iptv";
mtu = 0;
etherencapcfg {
use_dhcp = yes;
ipaddr = 0.0.0.0;
netmask = 0.0.0.0;
gateway = 0.0.0.0;
dns1 = 0.0.0.0;
dns2 = 0.0.0.0;
ap2ap = ap2ap_auto;
ap2ap_qos = yes;
stay_always_online = no;
redial_limit = 3;
ripv2md5_keyid = 0;
ripv2passwd = "";
dsldpconfig {
lowinput {
policy = "permit";
lowoutput {
policy = "permit";
highinput {
policy = "permit";
highoutput {
policy = "permit";
targets {
type = pppcfg_target_internet;
name = "internet";
only_crypt_auth = no;
local {
username = "$$$$L4P5DBN534AJCE6A6YCMKJYNSZSIYCC1UN5NN1DNWECQ14QGH6JNLIYDD5LWNZMMI4SVCJV2WZRU1663";
passwd = "$$$$X4H31N1L5DDJO6C1OUIIURQUYTVQDCG4AFUWTE43WA4AI1ZBI1XMWAZPU6HK53M1CLCQPUDIP3XA3663";
remoteauth = pppcfg_authtype_chap;
remoteauth_only_on_incoming = yes;
remote {
inactivity_timeout = 5m;
bUseChargeInterval = no;
nChargeInterval = 1m;
lcpecho_disconnect_mode = lcpecho_auto;
logicaldisconnect_with_physical = yes;
disconnect_timeout = 0w;
finaldisconnectcall = no;
ipnetbiosspoofing = no;
dnsfilter_for_active_directory = no;
no_outgoing_calls = no;
coso = pppcfg_coso_caller;
callback_delay = 1s;
icbmode = pppcfg_icbmode_none;
ocbmode = pppcfg_ocbmode_none;
mscbprefered = no;
multilink {
extra_static_channels = 0;
max_channels = 1;
automatic = no;
automatic_param {
window = 20s;
add_percent = 85;
drop_percent = 70;
sportlich = no;
header_compression = yes;
data_compression = pppcfg_datacomp_auto;
stac_reset_with_history_number = no;
encryption = pppcfg_crypt_none;
inactivity_prevention_interval = 0w;
new_ipaddr_on_connect = no;
my_ipaddr = 0.0.0.0;
his_ipaddr = 0.0.0.0;
overwrite_dns1 = 0.0.0.0;
overwrite_dns2 = 0.0.0.0;
bVolumeRoundUp = no;
VolumeRoundUpBytes = 0;
bProviderDisconnectPrevention = yes;
ProviderDisconnectPreventionInterval = 1d;
ProviderDisconnectPreventionHour = 2;
bProviderDisconnectPreventionHourSet = yes;
passiv_on_outgoing = no;
mode6 = mode6_off;
mode4 = mode4_normal;
name = "voip";
local {
username = "";
passwd = "";
remote {
inactivity_timeout = 0w;
mscbprefered = no;
multilink {
max_channels = 1;
automatic = no;
automatic_param {
window = 20s;
add_percent = 85;
drop_percent = 70;
sportlich = no;
mode6 = mode6_off;
name = "mstv";
local {
username = "";
passwd = "";
remote {
mscbprefered = no;
multilink {
max_channels = 1;
automatic = no;
automatic_param {
window = 20s;
add_percent = 85;
drop_percent = 70;
sportlich = no;
bProviderDisconnectPrevention = no;
ProviderDisconnectPreventionHour = 5;
mode6 = mode6_off;
name = "iptv";
local {
username = "";
passwd = "";
remoteauth = pppcfg_authtype_none;
remote {
mscbprefered = no;
multilink {
max_channels = 1;
automatic = no;
automatic_param {
window = 20s;
add_percent = 85;
drop_percent = 70;
sportlich = no;
mode6 = mode6_off;
dslglobalconfig {
autodetect = no;
also mit den neueren Firmware-Versionen braucht man doch die ganzen manuellen Einstellungen nicht mehr, man muss nur bei den Zugangsdaten das Richtige einstellen (z.B. Vodafone/Arcor VDSL II). Da sollte es in der Regel keine Problem geben.
Bei mir läuft Vodafone TV zumindest auf der FB 7490 auch mit den aktuellen Labors ohne Probleme.
Einfach mal mutig sein ;-)
VG
Zum FBEditor: Den brauchst du zum Ändern der Config und um die Prüfsumme zu aktualisieren. Importieren der geänderten Datei am Besten über die FB-eigene Funktion "System/Sicherung/Wiederherstellen".
