[Problem] USB-Port wird nicht richtig angesprochen bei den 7560,7580 und 7590
emil70
17 Okt 2012
Hi All
Bei den 3 Boxen wird der FTDI_SIO Treiber nicht Richtig geladen und der Port nicht angesprochen
Habe hier mehrer Konsolenbefehle
7490
lsmod
root@fritz:/var/mod/root# lsmod
Module Size Used by Tainted: P
ftdi_sio 38926 1
usbserial 34630 3 ftdi_sio
kspeedtest 20552 0
sch_sfq 11201 4
sch_llq 10006 1
sch_tbf 5889 1
ifx_ppa_mini_qos 5131 0
ifx_ppa_mini_sessions 89100 0
ifxmips_ppa_hal_vr9_a5 79325 0
krtp 148593 0
atd 169964 1
fwd 18385 1 atd
athlogger 8786 0
hif_gmac 13823 3 atd,fwd,athlogger
adf 147108 2 atd,fwd
aae 135504 4 atd,fwd,hif_gmac,adf
userman_mod 92203 4
kdsldmod 1892344 9 userman_mod
ifxmips_ppa_datapath_vr9_a5 192372 2
dsl_vr9 324674 2
mei_vr9 183377 4 ifxmips_ppa_datapath_vr9_a5,dsl_vr9
xhci_hcd 105584 0
usbcore 209371 3 ftdi_sio,usbserial,xhci_hcd
usb_common 1678 1 usbcore
vfat 12353 0
fat 63716 1 vfat
dect_io 13176 2
avm_dect 322567 1 dect_io
capi_codec 425737 0
isdn_fbox_fon5 840087 6 krtp
pcmlink 476539 4 avm_dect,capi_codec,isdn_fbox_fon5
Piglet_noemif 53759 0
rtc_avm 6054 1 pcmlink
led_modul_Fritz_Box_HW185 192256 8
7560
root@Testbox-7560:/var/mod/root# lsmod
ftdi_sio 29312 0
usbserial 22375 1 ftdi_sio
spdmon 17658 0
hwmon 1049 1 spdmon
ath_pktlog 15814 0
krtp 138412 0
umac 3060723 1 ath_pktlog
ath_dev 366823 2 ath_pktlog,umac
ath_dfs 65621 1 umac
ath_spectral 34558 3 umac,ath_dev
hst_tx99 8594 2 umac,ath_dev
ath_rate_atheros 24988 3 ath_pktlog,umac,ath_dev
ath_hal 729802 5 ath_pktlog,umac,ath_dev,hst_tx99,ath_rate_athero s
asf 7502 6 ath_pktlog,umac,ath_dev,ath_dfs,ath_spectral,ath _hal
adf 14315 5 umac,ath_dev,ath_dfs,hst_tx99,ath_hal
aae 122337 3 umac,ath_dev,ath_hal
kdsldmod 1560658 4
vrx318_tc 190076 0
xhci_hcd 91671 0
sch_tbf 4963 1
sch_hw 6411 0
ppa_api_proc 32810 0
ppa_api 373910 1 ppa_api_proc
ltq_directpath_datapath 28361 0
ltq_tmu_hal_drv 148040 1 ltq_directpath_datapath
ltq_pae_hal 63538 0
nls_utf8 1024 0
vfat 10529 0
dect_io 11271 0
avm_dect 284042 1 dect_io
capi_codec 380014 0
isdn_fbox_fon5 733313 6 krtp
pcmlink 396031 4 avm_dect,capi_codec,isdn_fbox_fon5
Piglet_noemif 41493 0
rtc_avm 4428 1 pcmlink
led_modul_Fritz_Box_HW221 159828 6
cat /proc/tty/driver/usbserial
7490
root@fritz:/var/mod/root# cat /proc/tty/driver/usbserial
usbserinfo:1.0 driver:2.0
0: module:ftdi_sio name:"FTDI USB Serial Device" vendor:0403 product:6001 num_ports:1 port:1 path:usb-0000:01:00.0-2
7560
root@Testbox-7560:/var/mod/root# cat /proc/tty/driver/usbserial
cat /proc/partitions
7490
root@fritz:/var/mod/root# cat /proc/partitions
major minor #blocks name
7 0 21976 loop0
31 0 4096 mtdblock0
31 1 49152 mtdblock1
31 2 4096 mtdblock2
31 3 49152 mtdblock3
31 4 2048 mtdblock4
31 5 415744 mtdblock5
31 6 256 mtdblock6
31 7 384 mtdblock7
31 8 384 mtdblock8
7560
root@Testbox-7560:/var/mod/root# cat /proc/partitions
31 0 8192 mtdblock0
31 1 1024 mtdblock1
31 2 4096 mtdblock2
31 3 8192 mtdblock3
31 4 109568 mtdblock4
31 5 45108 mtdblock5
31 6 45108 mtdblock6
31 7 2142 mtdblock7
31 8 12474 mtdblock8
cat /proc/diskstats
7490
root@fritz:/var/mod/root# cat /proc/diskstats
7 0 loop0 0 0 0 0 0 0 0 0 0 0 0
7 1 loop1 0 0 0 0 0 0 0 0 0 0 0
7 2 loop2 0 0 0 0 0 0 0 0 0 0 0
7 3 loop3 0 0 0 0 0 0 0 0 0 0 0
7 4 loop4 0 0 0 0 0 0 0 0 0 0 0
7 5 loop5 0 0 0 0 0 0 0 0 0 0 0
7 6 loop6 0 0 0 0 0 0 0 0 0 0 0
7 7 loop7 0 0 0 0 0 0 0 0 0 0 0
43 0 nbd0 0 0 0 0 0 0 0 0 0 0 0
43 1 nbd1 0 0 0 0 0 0 0 0 0 0 0
43 2 nbd2 0 0 0 0 0 0 0 0 0 0 0
43 3 nbd3 0 0 0 0 0 0 0 0 0 0 0
43 4 nbd4 0 0 0 0 0 0 0 0 0 0 0
43 5 nbd5 0 0 0 0 0 0 0 0 0 0 0
43 6 nbd6 0 0 0 0 0 0 0 0 0 0 0
43 7 nbd7 0 0 0 0 0 0 0 0 0 0 0
43 8 nbd8 0 0 0 0 0 0 0 0 0 0 0
43 9 nbd9 0 0 0 0 0 0 0 0 0 0 0
43 10 nbd10 0 0 0 0 0 0 0 0 0 0 0
43 11 nbd11 0 0 0 0 0 0 0 0 0 0 0
43 12 nbd12 0 0 0 0 0 0 0 0 0 0 0
43 13 nbd13 0 0 0 0 0 0 0 0 0 0 0
43 14 nbd14 0 0 0 0 0 0 0 0 0 0 0
43 15 nbd15 0 0 0 0 0 0 0 0 0 0 0
31 0 mtdblock0 0 0 0 0 0 0 0 0 0 0 0
31 1 mtdblock1 4 0 14 0 0 0 0 0 0 0 0
31 2 mtdblock2 0 0 0 0 0 0 0 0 0 0 0
31 3 mtdblock3 0 0 0 0 0 0 0 0 0 0 0
31 4 mtdblock4 0 0 0 0 0 0 0 0 0 0 0
31 5 mtdblock5 0 0 0 0 0 0 0 0 0 0 0
31 6 mtdblock6 0 0 0 0 0 0 0 0 0 0 0
31 7 mtdblock7 0 0 0 0 0 0 0 0 0 0 0
31 8 mtdblock8 0 0 0 0 0 0 0 0 0 0 0
7560
root@Testbox-7560:/var/mod/root# cat /proc/diskstats
31 1 mtdblock1 0 0 0 0 0 0 0 0 0 0 0
254 0 zram0 0 0 0 0 0 0 0 0 0 0 0
31 5 mtdblock5 730 12087 25634 10312 0 0 0 0 0 10160 10308
cat /proc/mounts
7490
root@fritz:/var/mod/root# cat /proc/mounts
rootfs / rootfs rw 0 0
/dev/root /wrapper yaffs ro,relatime 0 0
devtmpfs /wrapper/dev devtmpfs rw,relatime,size=119444k,nr_inodes=29861,mode=755 0 0
/dev/loop0 / squashfs ro,relatime 0 0
devtmpfs /dev devtmpfs rw,relatime,size=119444k,nr_inodes=29861,mode=755 0 0
proc /proc proc rw,relatime 0 0
tmpfs /var tmpfs rw,relatime 0 0
sysfs /sys sysfs rw,relatime 0 0
devpts /dev/pts devpts rw,relatime,mode=600,ptmxmode=000 0 0
none /sys/kernel/debug debugfs rw,relatime 0 0
/dev/mtdblock4 /var/flash yaffs2 rw,sync,relatime 0 0
/var/dev/nand /var/media/ftp yaffs2 rw,sync,relatime 0 0
debug /debug debugfs rw,relatime 0 0
7560
root@Testbox-7560:/var/mod/root# cat /proc/mounts
/dev/root / squashfs ro,relatime 0 0
devtmpfs /dev devtmpfs rw,relatime,size=84332k,nr_inodes=21083,mode=755 0 0
devpts /dev/pts devpts rw,relatime,mode=600 0 0
/dev/ubi0_3 /var/media/ftp ubifs rw,sync,relatime 0 0
Woran kann das liegen?
Benutzt wird er Trunk 14425
Keiner eine Idee??
Gesendet von meinem SM-A510F mit Tapatalk
Keiner eine Idee??
interessant wären die Messages beim Laden des Kernelmodules, d.h.
# rmmod ftdi_sio
# modprobe ftdi_sio   # oder insmod ftdi_sio
# dmesg
ggf. sieht man dann mehr.
Bei der 7560 kommt das ,siehe Anhang
Bei der 7490 so, siehe Anhang
  • test.txt
  • test7490.txt
Bei der 7490 so, ...
ich sehe kein "rmmod ftdi_sio" (deregister ftdi_sio) oder "modprobe ftdi_sio" bzw. "insmod ftdi_sio" im Logfile der FB7560
FB7560:
[  311.844000][0]usbserial: USB Serial deregistering driver FTDI USB Serial Device
[  311.844000][0]usbcore: deregistering interface driver ftdi_sio
[  322.756000][3]usbcore: registered new interface driver ftdi_sio
[  322.760000][3]usbserial: USB Serial support registered for FTDI USB Serial Device
[   61.876000][0]MEI_DRV: Module will be unloaded
[   61.876000][0]
[  357.448000][3]usbserial: USB Serial deregistering driver FTDI USB Serial Device
[  357.452000][3]usbcore: deregistering interface driver ftdi_sio
[  387.064000][3]usbcore: registered new interface driver ftdi_sio
[  387.068000][3]usbserial: USB Serial support registered for FTDI USB Serial Device
[  399.520000][0]usbserial: USB Serial deregistering driver FTDI USB Serial Device
[  399.524000][0]usbcore: deregistering interface driver ftdi_sio
[  402.844000][3]usbcore: registered new interface driver ftdi_sio
[  402.844000][3]usbserial: USB Serial support registered for FTDI USB Serial Device
FB7490:
[325955.810000][0]usbcore: registered new interface driver usbserial
[325955.820000][0]usbcore: registered new interface driver ftdi_sio
[325955.830000][0]usbserial: USB Serial support registered for FTDI USB Serial Device
[325955.830000][0]ftdi_sio 1-2:1.0: FTDI USB Serial Device converter detected
[325955.830000][0]usb 1-2: Detected FT232BM
[325955.830000][0]usb 1-2: Number of endpoints 2
[325955.830000][0]usb 1-2: Endpoint 1 MaxPacketSize 16384
[325955.830000][0]usb 1-2: Endpoint 2 MaxPacketSize 16384
[325955.830000][0]usb 1-2: Setting MaxPacketSize 64
[325955.830000][0]ftdi_sio ttyUSB0: Unable to read latency timer: -32
[325955.830000][0]usb 1-2: FTDI USB Serial Device converter now attached to ttyUSB0
[326127.640000][1]usbserial: USB Serial deregistering driver FTDI USB Serial Device
[326127.640000][1]ftdi_sio ttyUSB0: FTDI USB Serial Device converter now disconnected from ttyUSB0
[326127.640000][1]usbcore: deregistering interface driver ftdi_sio
[326127.640000][1]ftdi_sio 1-2:1.0: device disconnected
[326127.680000][1]usbcore: deregistering interface driver usbserial
[326148.570000][1]usbcore: registered new interface driver usbserial
[326148.580000][1]usbcore: registered new interface driver ftdi_sio
[326148.580000][1]usbserial: USB Serial support registered for FTDI USB Serial Device
[326148.580000][1]ftdi_sio 1-2:1.0: FTDI USB Serial Device converter detected
[326148.590000][1]usb 1-2: Detected FT232BM
[326148.590000][1]usb 1-2: Number of endpoints 2
[326148.590000][1]usb 1-2: Endpoint 1 MaxPacketSize 16384
[326148.590000][1]usb 1-2: Endpoint 2 MaxPacketSize 16384
[326148.590000][1]usb 1-2: Setting MaxPacketSize 64
[326148.590000][1]ftdi_sio ttyUSB0: Unable to read latency timer: -32
[326148.590000][0]usb 1-2: FTDI USB Serial Device converter now attached to ttyUSB0
[326282.550000][1]usbserial: USB Serial deregistering driver FTDI USB Serial Device
[326282.550000][1]ftdi_sio ttyUSB0: FTDI USB Serial Device converter now disconnected from ttyUSB0
[326282.550000][1]usbcore: deregistering interface driver ftdi_sio
[326282.550000][1]ftdi_sio 1-2:1.0: device disconnected
[326701.410000][0]usbcore: registered new interface driver ftdi_sio
[326701.410000][0]usbserial: USB Serial support registered for FTDI USB Serial Device
[326701.410000][0]ftdi_sio 1-2:1.0: FTDI USB Serial Device converter detected
[326701.410000][0]usb 1-2: Detected FT232BM
[326701.410000][0]usb 1-2: Number of endpoints 2
[326701.410000][0]usb 1-2: Endpoint 1 MaxPacketSize 16384
[326701.410000][0]usb 1-2: Endpoint 2 MaxPacketSize 16384
[326701.410000][0]usb 1-2: Setting MaxPacketSize 64
[326701.410000][0]ftdi_sio ttyUSB0: Unable to read latency timer: -32
[326701.420000][1]usb 1-2: FTDI USB Serial Device converter now attached to ttyUSB0
IMHO: da passt was mit dem Kernel und Kernelmodule nicht zusammen;
Bitte wie opto beschrieben hat, mehr Inputs liefern. Was/Wie das Freetz-Image, Kerrnelmodule, .config file usw. gemacht wurde.
Auch "lsusb" Output wäre hilfreich.
Die runtergeladene .config sieht so aus
FREETZ_HAVE_DOT_CONFIG=y
FREETZ_USER_LEVEL_EXPERT=y
FREETZ_SHOW_ADVANCED=y
FREETZ_SHOW_EXPERT=y
FREETZ_TYPE_7560=y
FREETZ_TYPE_LANG_DE=y
FREETZ_TYPE_FIRMWARE_06_9X=y
FREETZ_TYPE_FIRMWARE_FINAL=y
FREETZ_TYPE_LANGUAGE="de"
FREETZ_TARGET_IPV6_SUPPORT=y
FREETZ_PATCH_SIGNED=y
FREETZ_PATCH_FREETZMOUNT=y
FREETZ_USBSTORAGE_AUTOMOUNT=y
FREETZ_AUTOMOUNT_EXT3=y
FREETZ_AUTOMOUNT_EXT4=y
FREETZ_AUTOMOUNT_FAT=y
FREETZ_AUTOMOUNT_NTFS=y
FREETZ_PATCH_MAXDEVCOUNT=y
FREETZ_CUSTOM_UDEV_RULES=y
FREETZ_ADD_ETCSERVICES=y
FREETZ_RESTORE_DEBUG_CFG_SUPPORT=y
FREETZ_AVMDAEMON_DISABLE_NTP=y
FREETZ_PACKAGE_USBUTILS=y
FREETZ_PACKAGE_DROPBEAR=y
FREETZ_PACKAGE_DROPBEAR_DISABLE_HOST_LOOKUP=y
FREETZ_PACKAGE_HASERL=y
FREETZ_PACKAGE_INETD=y
FREETZ_PACKAGE_MOD=y
FREETZ_PACKAGE_MOD_ETCSERVICES=y
FREETZ_PACKAGE_MODCGI=y
FREETZ_BOX_CERTIFICATE_SUPPORT_AVAILABLE=y
FREETZ_PACKAGE_USBIDS=y
FREETZ_PACKAGE_USBIDS_FORCE_DOWNLOAD=y
FREETZ_WGET=y
FREETZ_PACKAGE_AUTHORIZED_KEYS=y
FREETZ_PACKAGE_AVM_FORWARDING=y
FREETZ_PACKAGE_SYSLOGD_CGI=y
FREETZ_OPENSSL_LIBCRYPTO_EXTRA_LIBS="-ldl"
FREETZ_LIB_libfuse=y
FREETZ_LIB_libntfs=y
FREETZ_LIB_ld_uClibc=y
FREETZ_LIB_libcrypt=y
FREETZ_LIB_libdl=y
FREETZ_LIB_libm=y
FREETZ_LIB_libpthread=y
FREETZ_LIB_librt=y
FREETZ_LIB_libubacktrace=y
FREETZ_LIB_libuClibc=y
FREETZ_LIB_libutil=y
FREETZ_LIB_libusb_0=y
FREETZ_LIB_libusb_0_WITH_LEGACY=y
FREETZ_LIB_libusb_1=y
FREETZ_LIB_libftdi=y
FREETZ_LIB_libgcc_s=y
FREETZ_LIB_libctlmgr=y
FREETZ_MODULE_usbserial=y
FREETZ_MODULE_pl2303=y
FREETZ_MODULE_ftdi_sio=y
FREETZ_BUSYBOX__MANDATORY=y
FREETZ_BUSYBOX__MANDATORY_05_XX=y
FREETZ_BUSYBOX__NOEXEC_NOFORK_OPTIMIZATIONS=y
FREETZ_BUSYBOX__IPV6_UTILS=y
FREETZ_BUSYBOX_HAVE_DOT_CONFIG=y
FREETZ_BUSYBOX_PLATFORM_LINUX=y
FREETZ_BUSYBOX_FEATURE_BUFFERS_GO_ON_STACK=y
FREETZ_BUSYBOX_SHOW_USAGE=y
FREETZ_BUSYBOX_FEATURE_VERBOSE_USAGE=y
FREETZ_BUSYBOX_FEATURE_DEVPTS=y
FREETZ_BUSYBOX_FEATURE_PIDFILE=y
FREETZ_BUSYBOX_PID_FILE_PATH="/var/run"
FREETZ_BUSYBOX_FEATURE_SUID=y
FREETZ_BUSYBOX_FEATURE_PREFER_APPLETS=y
FREETZ_BUSYBOX_BUSYBOX_EXEC_PATH="/bin/busybox"
FREETZ_BUSYBOX_FEATURE_SYSLOG=y
FREETZ_BUSYBOX_FEATURE_HAVE_RPC=y
FREETZ_BUSYBOX_LFS=y
FREETZ_BUSYBOX_CROSS_COMPILER_PREFIX=""
FREETZ_BUSYBOX_SYSROOT=""
FREETZ_BUSYBOX_EXTRA_CFLAGS=""
FREETZ_BUSYBOX_EXTRA_LDFLAGS=""
FREETZ_BUSYBOX_EXTRA_LDLIBS=""
FREETZ_BUSYBOX_NO_DEBUG_LIB=y
FREETZ_BUSYBOX_INSTALL_APPLET_SYMLINKS=y
FREETZ_BUSYBOX_PREFIX="./_install"
FREETZ_BUSYBOX_PASSWORD_MINLEN=6
FREETZ_BUSYBOX_MD5_SMALL=1
FREETZ_BUSYBOX_SHA3_SMALL=1
FREETZ_BUSYBOX_FEATURE_USE_TERMIOS=y
FREETZ_BUSYBOX_FEATURE_EDITING=y
FREETZ_BUSYBOX_FEATURE_EDITING_MAX_LEN=1024
FREETZ_BUSYBOX_FEATURE_EDITING_HISTORY=255
FREETZ_BUSYBOX_FEATURE_TAB_COMPLETION=y
FREETZ_BUSYBOX_FEATURE_EDITING_FANCY_PROMPT=y
FREETZ_BUSYBOX_FEATURE_NON_POSIX_CP=y
FREETZ_BUSYBOX_FEATURE_COPYBUF_KB=64
FREETZ_BUSYBOX_FEATURE_SKIP_ROOTFS=y
FREETZ_BUSYBOX_MONOTONIC_SYSCALL=y
FREETZ_BUSYBOX_IOCTL_HEX2STR_ERROR=y
FREETZ_BUSYBOX_FEATURE_HWIB=y
FREETZ_BUSYBOX_FEATURE_SEAMLESS_GZ=y
FREETZ_BUSYBOX_GUNZIP=y
FREETZ_BUSYBOX_BUNZIP2=y
FREETZ_BUSYBOX_UNXZ=y
FREETZ_BUSYBOX_XZ=y
FREETZ_BUSYBOX_BZIP2=y
FREETZ_BUSYBOX_GZIP=y
FREETZ_BUSYBOX_GZIP_FAST=0
FREETZ_BUSYBOX_TAR=y
FREETZ_BUSYBOX_FEATURE_TAR_CREATE=y
FREETZ_BUSYBOX_FEATURE_TAR_FROM=y
FREETZ_BUSYBOX_FEATURE_TAR_OLDGNU_COMPATIBILITY=y
FREETZ_BUSYBOX_FEATURE_TAR_GNU_EXTENSIONS=y
FREETZ_BUSYBOX_UNZIP=y
FREETZ_BUSYBOX_BASENAME=y
FREETZ_BUSYBOX_CAT=y
FREETZ_BUSYBOX_DATE=y
FREETZ_BUSYBOX_FEATURE_DATE_ISOFMT=y
FREETZ_BUSYBOX_FEATURE_DATE_COMPAT=y
FREETZ_BUSYBOX_DD=y
FREETZ_BUSYBOX_FEATURE_DD_SIGNAL_HANDLING=y
FREETZ_BUSYBOX_FEATURE_DD_IBS_OBS=y
FREETZ_BUSYBOX_ID=y
FREETZ_BUSYBOX_GROUPS=y
FREETZ_BUSYBOX_SYNC=y
FREETZ_BUSYBOX_TEST=y
FREETZ_BUSYBOX_FEATURE_TEST_64=y
FREETZ_BUSYBOX_TOUCH=y
FREETZ_BUSYBOX_FEATURE_TOUCH_SUSV3=y
FREETZ_BUSYBOX_TR=y
FREETZ_BUSYBOX_FEATURE_TR_CLASSES=y
FREETZ_BUSYBOX_FEATURE_TR_EQUIV=y
FREETZ_BUSYBOX_CHGRP=y
FREETZ_BUSYBOX_CHMOD=y
FREETZ_BUSYBOX_CHOWN=y
FREETZ_BUSYBOX_CHROOT=y
FREETZ_BUSYBOX_CP=y
FREETZ_BUSYBOX_CUT=y
FREETZ_BUSYBOX_DF=y
FREETZ_BUSYBOX_DIRNAME=y
FREETZ_BUSYBOX_DU=y
FREETZ_BUSYBOX_FEATURE_DU_DEFAULT_BLOCKSIZE_1K=y
FREETZ_BUSYBOX_ECHO=y
FREETZ_BUSYBOX_FEATURE_FANCY_ECHO=y
FREETZ_BUSYBOX_ENV=y
FREETZ_BUSYBOX_EXPR=y
FREETZ_BUSYBOX_EXPR_MATH_SUPPORT_64=y
FREETZ_BUSYBOX_FALSE=y
FREETZ_BUSYBOX_HEAD=y
FREETZ_BUSYBOX_FEATURE_FANCY_HEAD=y
FREETZ_BUSYBOX_LN=y
FREETZ_BUSYBOX_LOGNAME=y
FREETZ_BUSYBOX_LS=y
FREETZ_BUSYBOX_FEATURE_LS_FILETYPES=y
FREETZ_BUSYBOX_FEATURE_LS_FOLLOWLINKS=y
FREETZ_BUSYBOX_FEATURE_LS_RECURSIVE=y
FREETZ_BUSYBOX_FEATURE_LS_SORTFILES=y
FREETZ_BUSYBOX_FEATURE_LS_TIMESTAMPS=y
FREETZ_BUSYBOX_FEATURE_LS_USERNAME=y
FREETZ_BUSYBOX_MD5SUM=y
FREETZ_BUSYBOX_MKDIR=y
FREETZ_BUSYBOX_MKFIFO=y
FREETZ_BUSYBOX_MKNOD=y
FREETZ_BUSYBOX_MV=y
FREETZ_BUSYBOX_NICE=y
FREETZ_BUSYBOX_NOHUP=y
FREETZ_BUSYBOX_PRINTENV=y
FREETZ_BUSYBOX_PRINTF=y
FREETZ_BUSYBOX_PWD=y
FREETZ_BUSYBOX_READLINK=y
FREETZ_BUSYBOX_FEATURE_READLINK_FOLLOW=y
FREETZ_BUSYBOX_REALPATH=y
FREETZ_BUSYBOX_RM=y
FREETZ_BUSYBOX_RMDIR=y
FREETZ_BUSYBOX_SEQ=y
FREETZ_BUSYBOX_SLEEP=y
FREETZ_BUSYBOX_FEATURE_FANCY_SLEEP=y
FREETZ_BUSYBOX_SORT=y
FREETZ_BUSYBOX_STAT=y
FREETZ_BUSYBOX_FEATURE_STAT_FORMAT=y
FREETZ_BUSYBOX_STTY=y
FREETZ_BUSYBOX_TAIL=y
FREETZ_BUSYBOX_FEATURE_FANCY_TAIL=y
FREETZ_BUSYBOX_TEE=y
FREETZ_BUSYBOX_FEATURE_TEE_USE_BLOCK_IO=y
FREETZ_BUSYBOX_TRUE=y
FREETZ_BUSYBOX_TTY=y
FREETZ_BUSYBOX_UNAME=y
FREETZ_BUSYBOX_UNAME_OSNAME="GNU/Linux"
FREETZ_BUSYBOX_UNIQ=y
FREETZ_BUSYBOX_UUDECODE=y
FREETZ_BUSYBOX_WC=y
FREETZ_BUSYBOX_YES=y
FREETZ_BUSYBOX_FEATURE_AUTOWIDTH=y
FREETZ_BUSYBOX_FEATURE_HUMAN_READABLE=y
FREETZ_BUSYBOX_FEATURE_MD5_SHA1_SUM_CHECK=y
FREETZ_BUSYBOX_FGCONSOLE=y
FREETZ_BUSYBOX_RESET=y
FREETZ_BUSYBOX_SETCONSOLE=y
FREETZ_BUSYBOX_WHICH=y
FREETZ_BUSYBOX_AWK=y
FREETZ_BUSYBOX_CMP=y
FREETZ_BUSYBOX_SED=y
FREETZ_BUSYBOX_VI=y
FREETZ_BUSYBOX_FEATURE_VI_MAX_LEN=1024
FREETZ_BUSYBOX_FEATURE_VI_8BIT=y
FREETZ_BUSYBOX_FEATURE_VI_COLON=y
FREETZ_BUSYBOX_FEATURE_VI_YANKMARK=y
FREETZ_BUSYBOX_FEATURE_VI_SEARCH=y
FREETZ_BUSYBOX_FEATURE_VI_USE_SIGNALS=y
FREETZ_BUSYBOX_FEATURE_VI_DOT_CMD=y
FREETZ_BUSYBOX_FEATURE_VI_READONLY=y
FREETZ_BUSYBOX_FEATURE_VI_SETOPTS=y
FREETZ_BUSYBOX_FEATURE_VI_SET=y
FREETZ_BUSYBOX_FEATURE_VI_WIN_RESIZE=y
FREETZ_BUSYBOX_FEATURE_VI_ASK_TERMINAL=y
FREETZ_BUSYBOX_FEATURE_ALLOW_EXEC=y
FREETZ_BUSYBOX_FIND=y
FREETZ_BUSYBOX_FEATURE_FIND_PRINT0=y
FREETZ_BUSYBOX_FEATURE_FIND_MTIME=y
FREETZ_BUSYBOX_FEATURE_FIND_MMIN=y
FREETZ_BUSYBOX_FEATURE_FIND_PERM=y
FREETZ_BUSYBOX_FEATURE_FIND_TYPE=y
FREETZ_BUSYBOX_FEATURE_FIND_XDEV=y
FREETZ_BUSYBOX_FEATURE_FIND_MAXDEPTH=y
FREETZ_BUSYBOX_FEATURE_FIND_NEWER=y
FREETZ_BUSYBOX_FEATURE_FIND_INUM=y
FREETZ_BUSYBOX_FEATURE_FIND_EXEC=y
FREETZ_BUSYBOX_FEATURE_FIND_USER=y
FREETZ_BUSYBOX_FEATURE_FIND_GROUP=y
FREETZ_BUSYBOX_FEATURE_FIND_NOT=y
FREETZ_BUSYBOX_FEATURE_FIND_DEPTH=y
FREETZ_BUSYBOX_FEATURE_FIND_PAREN=y
FREETZ_BUSYBOX_FEATURE_FIND_SIZE=y
FREETZ_BUSYBOX_FEATURE_FIND_PRUNE=y
FREETZ_BUSYBOX_FEATURE_FIND_PATH=y
FREETZ_BUSYBOX_FEATURE_FIND_REGEX=y
FREETZ_BUSYBOX_GREP=y
FREETZ_BUSYBOX_FEATURE_GREP_EGREP_ALIAS=y
FREETZ_BUSYBOX_FEATURE_GREP_FGREP_ALIAS=y
FREETZ_BUSYBOX_FEATURE_GREP_CONTEXT=y
FREETZ_BUSYBOX_XARGS=y
FREETZ_BUSYBOX_FEATURE_XARGS_SUPPORT_CONFIRMATION=y
FREETZ_BUSYBOX_FEATURE_XARGS_SUPPORT_QUOTES=y
FREETZ_BUSYBOX_FEATURE_XARGS_SUPPORT_TERMOPT=y
FREETZ_BUSYBOX_FEATURE_XARGS_SUPPORT_ZERO_TERM=y
FREETZ_BUSYBOX_HALT=y
FREETZ_BUSYBOX_INIT=y
FREETZ_BUSYBOX_FEATURE_USE_INITTAB=y
FREETZ_BUSYBOX_FEATURE_KILL_REMOVED=y
FREETZ_BUSYBOX_FEATURE_KILL_DELAY=0
FREETZ_BUSYBOX_FEATURE_INIT_SYSLOG=y
FREETZ_BUSYBOX_INIT_TERMINAL_TYPE="linux"
FREETZ_BUSYBOX_FEATURE_SHADOWPASSWDS=y
FREETZ_BUSYBOX_USE_BB_CRYPT=y
FREETZ_BUSYBOX_ADDUSER=y
FREETZ_BUSYBOX_LAST_ID=60000
FREETZ_BUSYBOX_FIRST_SYSTEM_ID=100
FREETZ_BUSYBOX_LAST_SYSTEM_ID=999
FREETZ_BUSYBOX_ADDGROUP=y
FREETZ_BUSYBOX_FEATURE_ADDUSER_TO_GROUP=y
FREETZ_BUSYBOX_DELUSER=y
FREETZ_BUSYBOX_DELGROUP=y
FREETZ_BUSYBOX_FEATURE_DEL_USER_FROM_GROUP=y
FREETZ_BUSYBOX_LOGIN=y
FREETZ_BUSYBOX_PASSWD=y
FREETZ_BUSYBOX_FEATURE_PASSWD_WEAK_CHECK=y
FREETZ_BUSYBOX_CRYPTPW=y
FREETZ_BUSYBOX_FEATURE_DEFAULT_PASSWD_ALGO="des"
FREETZ_BUSYBOX_INSMOD=y
FREETZ_BUSYBOX_RMMOD=y
FREETZ_BUSYBOX_LSMOD=y
FREETZ_BUSYBOX_FEATURE_LSMOD_PRETTY_2_6_OUTPUT=y
FREETZ_BUSYBOX_MODPROBE=y
FREETZ_BUSYBOX_FEATURE_CHECK_TAINTED_MODULE=y
FREETZ_BUSYBOX_DEFAULT_MODULES_DIR="/lib/modules"
FREETZ_BUSYBOX_DEFAULT_DEPMOD_FILE="modules.dep"
FREETZ_BUSYBOX_MOUNT=y
FREETZ_BUSYBOX_FEATURE_MOUNT_VERBOSE=y
FREETZ_BUSYBOX_FEATURE_MOUNT_NFS=y
FREETZ_BUSYBOX_FEATURE_MOUNT_CIFS=y
FREETZ_BUSYBOX_FEATURE_MOUNT_FLAGS=y
FREETZ_BUSYBOX_FEATURE_MOUNT_FSTAB=y
FREETZ_BUSYBOX_DMESG=y
FREETZ_BUSYBOX_FEATURE_DMESG_PRETTY=y
FREETZ_BUSYBOX_FLOCK=y
FREETZ_BUSYBOX_GETOPT=y
FREETZ_BUSYBOX_FEATURE_GETOPT_LONG=y
FREETZ_BUSYBOX_MKSWAP=y
FREETZ_BUSYBOX_MORE=y
FREETZ_BUSYBOX_PIVOT_ROOT=y
FREETZ_BUSYBOX_SWAPONOFF=y
FREETZ_BUSYBOX_SWITCH_ROOT=y
FREETZ_BUSYBOX_UMOUNT=y
FREETZ_BUSYBOX_FEATURE_UMOUNT_ALL=y
FREETZ_BUSYBOX_FEATURE_MOUNT_LOOP=y
FREETZ_BUSYBOX_FEATURE_MOUNT_LOOP_CREATE=y
FREETZ_BUSYBOX_VOLUMEID=y
FREETZ_BUSYBOX_FEATURE_VOLUMEID_EXT=y
FREETZ_BUSYBOX_FEATURE_VOLUMEID_FAT=y
FREETZ_BUSYBOX_FEATURE_VOLUMEID_NTFS=y
FREETZ_BUSYBOX_CROND=y
FREETZ_BUSYBOX_FEATURE_CROND_DIR="/var/spool/cron"
FREETZ_BUSYBOX_SETSERIAL=y
FREETZ_BUSYBOX_CRONTAB=y
FREETZ_BUSYBOX_MAKEDEVS=y
FREETZ_BUSYBOX_FEATURE_MAKEDEVS_TABLE=y
FREETZ_BUSYBOX_TIME=y
FREETZ_BUSYBOX_NBDCLIENT=y
FREETZ_BUSYBOX_NC=y
FREETZ_BUSYBOX_NC_EXTRA=y
FREETZ_BUSYBOX_PING=y
FREETZ_BUSYBOX_PING6=y
FREETZ_BUSYBOX_FEATURE_FANCY_PING=y
FREETZ_BUSYBOX_STUN_IP=y
FREETZ_BUSYBOX_WGET=y
FREETZ_BUSYBOX_FEATURE_WGET_STATUSBAR=y
FREETZ_BUSYBOX_FEATURE_WGET_AUTHENTICATION=y
FREETZ_BUSYBOX_FEATURE_WGET_TIMEOUT=y
FREETZ_BUSYBOX_WHOIS=y
FREETZ_BUSYBOX_FEATURE_IPV6=y
FREETZ_BUSYBOX_FEATURE_PREFER_IPV4_ADDRESS=y
FREETZ_BUSYBOX_ARP=y
FREETZ_BUSYBOX_ARPING=y
FREETZ_BUSYBOX_BRCTL=y
FREETZ_BUSYBOX_FEATURE_BRCTL_FANCY=y
FREETZ_BUSYBOX_FEATURE_BRCTL_SHOW=y
FREETZ_BUSYBOX_ETHER_WAKE=y
FREETZ_BUSYBOX_FTPGET=y
FREETZ_BUSYBOX_FTPPUT=y
FREETZ_BUSYBOX_HOSTNAME=y
FREETZ_BUSYBOX_HTTPD=y
FREETZ_BUSYBOX_FEATURE_HTTPD_BASIC_AUTH=y
FREETZ_BUSYBOX_FEATURE_HTTPD_AUTH_MD5=y
FREETZ_BUSYBOX_FEATURE_HTTPD_CGI=y
FREETZ_BUSYBOX_FEATURE_HTTPD_CONFIG_WITH_SCRIPT_INTERPR=y
FREETZ_BUSYBOX_FEATURE_HTTPD_ENCODE_URL_STR=y
FREETZ_BUSYBOX_IFCONFIG=y
FREETZ_BUSYBOX_FEATURE_IFCONFIG_STATUS=y
FREETZ_BUSYBOX_FEATURE_IFCONFIG_HW=y
FREETZ_BUSYBOX_FEATURE_IFCONFIG_BROADCAST_PLUS=y
FREETZ_BUSYBOX_IFUPDOWN=y
FREETZ_BUSYBOX_IFUPDOWN_IFSTATE_PATH="/var/run/ifstate"
FREETZ_BUSYBOX_FEATURE_IFUPDOWN_IFCONFIG_BUILTIN=y
FREETZ_BUSYBOX_FEATURE_IFUPDOWN_IPV4=y
FREETZ_BUSYBOX_FEATURE_IFUPDOWN_IPV6=y
FREETZ_BUSYBOX_FEATURE_IFUPDOWN_MAPPING=y
FREETZ_BUSYBOX_INETD=y
FREETZ_BUSYBOX_IP=y
FREETZ_BUSYBOX_FEATURE_IP_ADDRESS=y
FREETZ_BUSYBOX_FEATURE_IP_LINK=y
FREETZ_BUSYBOX_FEATURE_IP_ROUTE=y
FREETZ_BUSYBOX_FEATURE_IP_ROUTE_DIR="/etc/iproute2"
FREETZ_BUSYBOX_FEATURE_IP_TUNNEL=y
FREETZ_BUSYBOX_FEATURE_IP_RULE=y
FREETZ_BUSYBOX_FEATURE_IP_SHORT_FORMS=y
FREETZ_BUSYBOX_NETSTAT=y
FREETZ_BUSYBOX_FEATURE_NETSTAT_PRG=y
FREETZ_BUSYBOX_NSLOOKUP=y
FREETZ_BUSYBOX_ROUTE=y
FREETZ_BUSYBOX_TELNETD=y
FREETZ_BUSYBOX_FEATURE_TELNETD_STANDALONE=y
FREETZ_BUSYBOX_TFTP=y
FREETZ_BUSYBOX_FEATURE_TFTP_GET=y
FREETZ_BUSYBOX_FEATURE_TFTP_PUT=y
FREETZ_BUSYBOX_TRACEROUTE=y
FREETZ_BUSYBOX_VCONFIG=y
FREETZ_BUSYBOX_IOSTAT=y
FREETZ_BUSYBOX_MPSTAT=y
FREETZ_BUSYBOX_PMAP=y
FREETZ_BUSYBOX_PSTREE=y
FREETZ_BUSYBOX_PWDX=y
FREETZ_BUSYBOX_SMEMCAP=y
FREETZ_BUSYBOX_TOP=y
FREETZ_BUSYBOX_FEATURE_TOP_CPU_USAGE_PERCENTAGE=y
FREETZ_BUSYBOX_FEATURE_TOP_CPU_GLOBAL_PERCENTS=y
FREETZ_BUSYBOX_UPTIME=y
FREETZ_BUSYBOX_FREE=y
FREETZ_BUSYBOX_KILL=y
FREETZ_BUSYBOX_KILLALL=y
FREETZ_BUSYBOX_KILLALL5=y
FREETZ_BUSYBOX_PIDOF=y
FREETZ_BUSYBOX_FEATURE_PIDOF_SINGLE=y
FREETZ_BUSYBOX_FEATURE_PIDOF_OMIT=y
FREETZ_BUSYBOX_PS=y
FREETZ_BUSYBOX_FEATURE_PS_WIDE=y
FREETZ_BUSYBOX_FEATURE_PS_LONG=y
FREETZ_BUSYBOX_RENICE=y
FREETZ_BUSYBOX_BB_SYSCTL=y
FREETZ_BUSYBOX_FEATURE_SHOW_THREADS=y
FREETZ_BUSYBOX_ASH=y
FREETZ_BUSYBOX_ASH_BASH_COMPAT=y
FREETZ_BUSYBOX_ASH_JOB_CONTROL=y
FREETZ_BUSYBOX_ASH_ALIAS=y
FREETZ_BUSYBOX_ASH_GETOPTS=y
FREETZ_BUSYBOX_ASH_BUILTIN_ECHO=y
FREETZ_BUSYBOX_ASH_BUILTIN_PRINTF=y
FREETZ_BUSYBOX_ASH_BUILTIN_TEST=y
FREETZ_BUSYBOX_ASH_CMDCMD=y
FREETZ_BUSYBOX_ASH_OPTIMIZE_FOR_SIZE=y
FREETZ_BUSYBOX_ASH_EXPAND_PRMT=y
FREETZ_BUSYBOX_FEATURE_SH_IS_ASH=y
FREETZ_BUSYBOX_FEATURE_BASH_IS_NONE=y
FREETZ_BUSYBOX_SH_MATH_SUPPORT=y
FREETZ_BUSYBOX_SH_MATH_SUPPORT_64=y
FREETZ_BUSYBOX_FEATURE_SH_STANDALONE=y
FREETZ_BUSYBOX_FEATURE_SH_NOFORK=y
FREETZ_BUSYBOX_SYSLOGD=y
FREETZ_BUSYBOX_FEATURE_ROTATE_LOGFILE=y
FREETZ_BUSYBOX_FEATURE_REMOTE_LOG=y
FREETZ_BUSYBOX_FEATURE_SYSLOGD_DUP=y
FREETZ_BUSYBOX_FEATURE_SYSLOGD_READ_BUFFER_SIZE=256
FREETZ_BUSYBOX_FEATURE_IPC_SYSLOG=y
FREETZ_BUSYBOX_FEATURE_IPC_SYSLOG_BUFFER_SIZE=16
FREETZ_BUSYBOX_LOGREAD=y
FREETZ_BUSYBOX_FEATURE_LOGREAD_REDUCED_LOCKING=y
FREETZ_BUSYBOX_KLOGD=y
FREETZ_BUSYBOX_FEATURE_KLOGD_KLOGCTL=y
FREETZ_BUSYBOX_LOGGER=y
FREETZ_LANG_DE=y
FREETZ_LANG_STRING="de"
FREETZ_SECURITY_LEVEL=0
FREETZ_STYLE_COLORED=y
FREETZ_STYLE="colored"
FREETZ_SKIN_legacy=y
FREETZ_FAVICON_NONE=y
FREETZ_FAVICON_STRING="none"
FREETZ_TAGGING_NONE=y
FREETZ_TAGGING_STRING="none"
FREETZ_USER_DEFINED_COMMENT="test7560"
FREETZ_CUSTOM_IMAGE_NAME=y
FREETZ_CUSTOM_IMAGE_NAME_PREFIX=y
FREETZ_CREATE_SEPARATE_OPTIONS_CFG=y
FREETZ_DOWNLOAD_TOOLCHAIN=y
FREETZ_KERNEL_BINUTILS_2_24=y
FREETZ_KERNEL_GCC_5=y
FREETZ_KERNEL_BINUTILS_VERSION="2.24"
FREETZ_KERNEL_GCC_VERSION="5.4.0"
FREETZ_TARGET_UCLIBC_0_9_33=y
FREETZ_TARGET_UCLIBC_SUPPORTS_libubacktrace=y
FREETZ_TARGET_UCLIBC_REQUIRES_libubacktrace=y
FREETZ_TARGET_BINUTILS_2_24=y
FREETZ_TARGET_GCC_5=y
FREETZ_TARGET_GCC_DEFAULT_AS_NEEDED=y
FREETZ_STDCXXLIB_USE_UCLIBCXX=y
FREETZ_TARGET_UCLIBC_VERSION="0.9.33.2"
FREETZ_TARGET_BINUTILS_VERSION="2.24"
FREETZ_TARGET_GCC_MAJOR_VERSION="5"
FREETZ_TARGET_GCC_MINOR_VERSION="4.0"
FREETZ_TARGET_GCC_VERSION="${FREETZ_TARGET_GCC_MAJOR_VERSION}.${FREETZ_TARGET_GCC_MINOR_VERSION}"
FREETZ_GNULIBSTDCXX_VERSION="6.0.21"
FREETZ_STDCXXLIB="uclibcxx"
FREETZ_TARGET_CFLAGS="-Os -pipe -Wa,--trap"
FREETZ_RPATH="/usr/lib/freetz"
FREETZ_TARGET_UCLIBC_REDUCED_LOCALE_SET=y
FREETZ_TOOLCHAIN_MINIMIZE_REQUIRED_GLIBC_VERSION=y
FREETZ_VERBOSITY_LEVEL=2
FREETZ_SIZEINFO_COMPRESSED=y
FREETZ_JLEVEL=2
FREETZ_CHECK_CHANGED=y
FREETZ_SQUASHFS_BLOCKSIZE_65536=y
FREETZ_SQUASHFS_BLOCKSIZE=65536
FREETZ_STRIP_BINARIES=y
FREETZ_STRIP_MODULES_FREETZ=y
FREETZ_DL_SITE_USER=""
FREETZ_DL_TOOLCHAIN_SITE=""
FREETZ_DL_KERNEL_TOOLCHAIN_VERSION="r14286"
FREETZ_DL_KERNEL_TOOLCHAIN_MD5="66691149c7c353adf2b0d57c70148ace"
FREETZ_DL_TARGET_TOOLCHAIN_VERSION="r14286"
FREETZ_DL_TARGET_TOOLCHAIN_MD5="520ba0e3ee2a6807e7a7475b64fdd43d"
FREETZ_DL_TOOLCHAIN_SUFFIX="shared-glibc"
FREETZ_DL_KERNEL_SITE=""
FREETZ_DL_KERNEL_SOURCE_ID="7580_06.81"
FREETZ_DL_KERNEL_SOURCE="${FREETZ_DL_KERNEL_SOURCE_ID}-release_kernel.tar.xz"
FREETZ_DL_KERNEL_SOURCE_MD5="350317ac647aae7ad39645353581aff2"
FREETZ_DL_SITE="@AvM/fritzbox.7560/firmware/deutsch,@1&1/7560"
FREETZ_DL_SOURCE="FRITZ.Box_7560.149.06.90.image"
FREETZ_DL_SOURCE_MD5="d36780b29d4d1b6270932319fcb4943e"
FREETZ_DL_SOURCE_CONTAINER=""
FREETZ_DL_SOURCE_CONTAINER_MD5=""
FREETZ_PACKAGE_BOARDIMAGE=y
FREETZ_PACKAGE_READERTREIBER=y
FREETZ_PACKAGE_Eigener_Name=y
FREETZ_REAL_DEVELOPER_ONLY=y
FREETZ_AVM_HAS_FIRMWARE_06_5X=y
FREETZ_AVM_HAS_FIRMWARE_06_8X=y
FREETZ_AVM_HAS_FIRMWARE_06_9X=y
FREETZ_AVM_HAS_LANG_DE=y
FREETZ_AVM_HAS_LANG_EN=y
FREETZ_AVM_HAS_AHA=y
FREETZ_AVM_HAS_DECT=y
FREETZ_AVM_HAS_MYFRITZ=y
FREETZ_AVM_HAS_MULTI_ANNEX=y
FREETZ_AVM_HAS_NAS=y
FREETZ_AVM_HAS_NTFS=y
FREETZ_AVM_HAS_PHONE=y
FREETZ_AVM_HAS_TAM=y
FREETZ_AVM_HAS_TEMPERATURE_SENSOR=y
FREETZ_AVM_HAS_TR069=y
FREETZ_AVM_HAS_TR069_FWUPDATE=y
FREETZ_AVM_HAS_UDEV=y
FREETZ_AVM_HAS_UMTS=y
FREETZ_AVM_HAS_USB_HOST=y
FREETZ_AVM_HAS_AURA_USB=y
FREETZ_AVM_HAS_WEBDAV=y
FREETZ_AVM_HAS_WLAN=y
FREETZ_AVM_SERIAL_CONSOLE_DEVICE="/dev/ttyLTQ0"
FREETZ_AVM_HAS_IPV6=y
FREETZ_AVM_HAS_PTY_SUPPORT=y
FREETZ_AVM_HAS_PRINTK=y
FREETZ_AVM_HAS_AUTOFS4_BUILTIN=y
FREETZ_AVM_HAS_EXT2_BUILTIN=y
FREETZ_AVM_HAS_EXT3_BUILTIN=y
FREETZ_AVM_HAS_EXT4_BUILTIN=y
FREETZ_AVM_HAS_RAMZSWAP=y
FREETZ_AVM_HAS_CRYPTO_ALGAPI_BUILTIN=y
FREETZ_AVM_HAS_CRYPTO_AEAD_BUILTIN=y
FREETZ_AVM_HAS_CRYPTO_AES_BUILTIN=y
FREETZ_AVM_HAS_CRYPTO_ARC4_BUILTIN=y
FREETZ_AVM_HAS_CRYPTO_BLKCIPHER_BUILTIN=y
FREETZ_AVM_HAS_CRYPTO_CBC_BUILTIN=y
FREETZ_AVM_HAS_CRYPTO_HASH_BUILTIN=y
FREETZ_AVM_HAS_CRYPTO_MANAGER_BUILTIN=y
FREETZ_AVM_HAS_CRYPTO_RNG_BUILTIN=y
FREETZ_AVM_HAS_CRYPTO_SHA1_BUILTIN=y
FREETZ_AVM_HAS_CRYPTO_WORKQUEUE_BUILTIN=y
FREETZ_AVM_HAS_CHRONYD=y
FREETZ_AVM_HAS_E2FSPROGS=y
FREETZ_AVM_HAS_INETD=y
FREETZ_AVM_HAS_LSOF=y
FREETZ_AVM_HAS_OPENSSL=y
FREETZ_AVM_HAS_OPENSSL_VERSION_1=y
FREETZ_AVM_HAS_AR7CFG_V12_MIN=y
FREETZ_AVM_HAS_MULTID_LEASES_FORMAT_V2=y
FREETZ_AVM_SQUASHFS_VERSION=4
FREETZ_SQUASHFS_VERSION=4
FREETZ_AVM_SQUASHFS_COMPRESSION="xz"
FREETZ_AVM_HAS_SEPARATE_FILESYSTEM_IMAGE=y
FREETZ_AVM_VERSION_06_9X=y
FREETZ_AVM_VERSION_04_XX_MIN=y
FREETZ_AVM_VERSION_05_2X_MIN=y
FREETZ_AVM_VERSION_05_5X_MIN=y
FREETZ_AVM_VERSION_06_0X_MIN=y
FREETZ_AVM_VERSION_06_2X_MIN=y
FREETZ_AVM_VERSION_06_5X_MIN=y
FREETZ_AVM_VERSION_06_8X_MIN=y
FREETZ_AVM_VERSION_06_9X_MIN=y
FREETZ_AVM_VERSION_06_9X_MAX=y
FREETZ_TARGET_ARCH_BE=y
FREETZ_TARGET_ARCH_MIPS=y
FREETZ_TARGET_ARCH="mips"
FREETZ_TARGET_ARCH_ENDIANNESS_DEPENDENT="mips"
FREETZ_TARGET_CROSS="${FREETZ_TARGET_ARCH_ENDIANNESS_DEPENDENT}-linux-uclibc-"
FREETZ_KERNEL_CROSS="${FREETZ_TARGET_ARCH_ENDIANNESS_DEPENDENT}-unknown-linux-gnu-"
FREETZ_AVM_GCC_5=y
FREETZ_AVM_GCC_3_4_MIN=y
FREETZ_AVM_GCC_4_6_MIN=y
FREETZ_AVM_GCC_4_7_MIN=y
FREETZ_AVM_GCC_4_8_MIN=y
FREETZ_AVM_GCC_4_9_MIN=y
FREETZ_AVM_GCC_5_MIN=y
FREETZ_AVM_GCC_5_MAX=y
FREETZ_KERNEL_VERSION_3_10_12=y
FREETZ_KERNEL_VERSION_3_10=y
FREETZ_KERNEL_VERSION="3.10"
FREETZ_KERNEL_VERSION_MAJOR="3.10"
FREETZ_KERNEL_VERSION_2_6_13_MIN=y
FREETZ_KERNEL_VERSION_2_6_19_MIN=y
FREETZ_KERNEL_VERSION_2_6_28_MIN=y
FREETZ_KERNEL_VERSION_2_6_32_MIN=y
FREETZ_KERNEL_VERSION_3_10_MIN=y
FREETZ_KERNEL_VERSION_3_10_MAX=y
FREETZ_KERNEL_LAYOUT_GRX5=y
FREETZ_KERNEL_LAYOUT="grx5"
FREETZ_MODULES_KVER="3.10.12"
FREETZ_KERNEL_PATCHES="3.10.12"
FREETZ_AVM_KERNEL_CONFIG_AREA_SIZE=96
FREETZ_AVM_UCLIBC_0_9_33=y
FREETZ_AVM_UCLIBC_NPTL_ENABLED=y
FREETZ_AVM_SOURCE_7580_06_81=y
FREETZ_AVM_SOURCE_ID="7580_06.81"
FREETZ_AVM_SOURCE_FOR_KERNEL_LAYOUT_GRX5=y
FREETZ_GCC_ABI="32"
FREETZ_GCC_ARCH="mips32r2"
FREETZ_GCC_TUNE="24kc"
FREETZ_GCC_FLOAT_ABI="soft"
FREETZ_REPLACE_KERNEL_EXPERIMENTAL=y
FREETZ_REPLACE_MODULE_AVAILABLE=y
FREETZ_TYPE_PREFIX="7560"
FREETZ_TYPE_PREFIX_SERIES_SUBDIR="06_9X"
FREETZ_INSTALL_BASE=y
FREETZ_REPLACE_BUSYBOX=y
FREETZ_CIFS_SUPPORT_AVAILABLE=y
FREETZ_NFS_SUPPORT_AVAILABLE=y
FREETZ_NFS_SUPPORT_AVAILABLE_AS_MODULE=y
# FREETZ_REMOVE_DTRACE is not set
# FREETZ_REMOVE_AVM_E2FSPROGS is not set
FREETZ_LIBRARY_DIR="/usr/lib/freetz"
Bei lsusb" Output kommt das
7560
root@Testbox-7560:/var/mod/root# lsusb output
BUS=002
DEV=001
VID=1d6b
PID=0003
CLS=09
SCL=00
SPEED='super'
VER='3.0'
ISOC=0
INUM=1
ICLS1=09
ISCL1=00
BUS=001
DEV=001
VID=1d6b
PID=0002
CLS=09
SCL=00
SPEED='hi'
VER='2.0'
ISOC=0
INUM=1
ICLS1=09
ISCL1=00
BUS=001
DEV=002
VID=1a40
PID=0101
CLS=09
SCL=00
SPEED='hi'
VER='2.0'
ISOC=0
INUM=1
ICLS1=09
ISCL1=00
BUS=001
DEV=003
VID=13fe
PID=3d00
CLS=00
SCL=00
SPEED='hi'
VER='2.0'
ISOC=0
INUM=1
ICLS1=08
ISCL1=06
BUS=001
DEV=004
VID=0403
PID=6001
CLS=00
SCL=00
SPEED='full'
VER='2.0'
ISOC=0
INUM=1
ICLS1=255
ISCL1=255
Könnte es nicht einfach daran liegen, siehe Bild
könntest Du Bitte noch den Befehl "cat /debug/usb/devices" bei der FB7490 sowie FB7560 eingeben und den Output hier posten,
dann sieht man mehr (Product, Manufacturer, Driver, Device-Class, ...)
Da sehe ich als Unterschied:
7362SL=7490?:
Product=Lantiq USB Controller
7580=7560?:
Product=xHCI Host Controller
es geht doch primär um das USB-Device mit (VID=0403, PID=6001, FTDI USB Serial Device, FT232BM)
und welche DeviceClass, Treiber usw. bei FB7490, FB7560 selektiert werden, wenn dieses Device am USB-Bus hängt.
Beispiel: FB7490 ohne Device FT232BM
# cat /debug/usb/devices
T:  Bus=02 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#=  1 Spd=5000 MxCh= 2
B:  Alloc=  0/800 us ( 0%), #Int=  0, #Iso=  0
D:  Ver= 3.00 Cls=09(hub  ) Sub=00 Prot=03 MxPS= 9 #Cfgs=  1
P:  Vendor=1d6b ProdID=0003 Rev= 3.10
S:  Manufacturer=Linux 3.10.73 xhci_hcd
S:  Product=xHCI Host Controller
S:  SerialNumber=0000:01:00.0
C:* #Ifs= 1 Cfg#= 1 Atr=e0 MxPwr=  0mA
I:* If#= 0 Alt= 0 #EPs= 1 Cls=09(hub  ) Sub=00 Prot=00 Driver=hub
E:  Ad=81(I) Atr=03(Int.) MxPS=   4 Ivl=256ms
T:  Bus=01 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#=  1 Spd=480  MxCh= 2
D:  Ver= 2.00 Cls=09(hub  ) Sub=00 Prot=01 MxPS=64 #Cfgs=  1
P:  Vendor=1d6b ProdID=0002 Rev= 3.10
OK, ich dachte ich könnte helfen.
Aber interessant, daß deine 7490 doch nicht gleich meiner 7360SL ist, sondern meiner 7580 gleicht.
die Problemanalyse Hardware (VID=0403, PID=6001, FTDI USB Serial Device, FT232BM) und "Device-Treiber ftdi_sio" läuft noch
7490
root@fritz-7490:/# lsmod
ftdi_sio 38926 1
SNIP
root@fritz-7490:/# cat /proc/tty/driver/usbserial
7560:
root@Testbox-7560:/# lsmod
ftdi_sio 29312 0
SNIP
root@Testbox-7560:/# cat /proc/tty/driver/usbserial
daher die Nachfrage nach weiteren Inputs "cat /debug/usb/devices", siehe #10
Frage: Ist die FB7490 mit FW 06.90 betankt und gefreezt ? wenn ja, dann Bitte auch .config beifügen.
bei meiner FB7490 FW 06.90 gibt es kein Kernelmodul "ftdi_sio.ko":
# pwd
/lib/modules
# find .|grep usb
./3.10.73/kernel/drivers/net/usb
./3.10.73/kernel/drivers/net/usb/cdc_ether.ko
./3.10.73/kernel/drivers/net/usb/cdc_ncm.ko
./3.10.73/kernel/drivers/net/usb/rndis_host.ko
./3.10.73/kernel/drivers/net/usb/usbnet.ko
./3.10.73/kernel/drivers/usb
./3.10.73/kernel/drivers/usb/class
./3.10.73/kernel/drivers/usb/class/cdc-acm.ko
./3.10.73/kernel/drivers/usb/class/usblp.ko
./3.10.73/kernel/drivers/usb/core
./3.10.73/kernel/drivers/usb/core/usbcore.ko
./3.10.73/kernel/drivers/usb/host
./3.10.73/kernel/drivers/usb/host/xhci-hcd.ko
./3.10.73/kernel/drivers/usb/musb
./3.10.73/kernel/drivers/usb/serial
./3.10.73/kernel/drivers/usb/serial/option.ko
./3.10.73/kernel/drivers/usb/serial/usb_wwan.ko
./3.10.73/kernel/drivers/usb/serial/usbserial.ko
./3.10.73/kernel/drivers/usb/storage
./3.10.73/kernel/drivers/usb/storage/usb-storage.ko
./3.10.73/kernel/drivers/usb/usb-common.ko
# find .|grep ftdi
# lsmod | grep usb
usb_storage            51614  1
scsi_mod              142872  2 usb_storage,sd_mod
usbcore               209371  2 usb_storage,xhci_hcd
Besten dank für eure Hilfe
Beide Boxen haben die 06.90 drauf und mit Freetz bestückt
Hier die gewünschen Ausgaben
7490
T: Bus=01 Lev=01 Prnt=01 Port=01 Cnt=01 Dev#= 3 Spd=12 MxCh= 0
D: Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS= 8 #Cfgs= 1
P: Vendor=0403 ProdID=6001 Rev= 4.00
S: SerialNumber=Reader A24EC2A
C:* #Ifs= 1 Cfg#= 1 Atr=a0 MxPwr=100mA
I:* If#= 0 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=ftdi_sio
E: Ad=01(O) Atr=02(Bulk) MxPS= 64 Ivl=0ms
E: Ad=82(I) Atr=02(Bulk) MxPS= 64 Ivl=0ms
7560
T: Bus=02 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=5000 MxCh= 1
S: Manufacturer=Linux 3.10.12 xhci-hcd
S: SerialNumber=xhci-hcd.0.auto
T: Bus=01 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=480 MxCh= 1
T: Bus=01 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 2 Spd=480 MxCh= 4
P: Vendor=1a40 ProdID=0101 Rev= 1.11
S: Product=USB 2.0 Hub
C:* #Ifs= 1 Cfg#= 1 Atr=e0 MxPwr=100mA
E: Ad=81(I) Atr=03(Int.) MxPS= 1 Ivl=256ms
T: Bus=01 Lev=02 Prnt=02 Port=01 Cnt=01 Dev#= 3 Spd=480 MxCh= 0
D: Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=13fe ProdID=3d00 Rev= 1.00
S: Manufacturer=
S: Product=USB DISK 2.0
S: SerialNumber=070B3991A05C9253
C:* #Ifs= 1 Cfg#= 1 Atr=80 MxPwr=200mA
I:* If#= 0 Alt= 0 #EPs= 2 Cls=08(stor.) Sub=06 Prot=50 Driver=usb-storage
E: Ad=81(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=02(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
T: Bus=01 Lev=02 Prnt=02 Port=02 Cnt=02 Dev#= 4 Spd=12 MxCh= 0
S: Manufacturer=Argolis BV
S: Product=Smartreader plus
S: SerialNumber=01
I:* If#= 0 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none)
7490
find .|grep usb
root@fritz:/lib/modules# find .|grep usb
./3.10.73/kernel/drivers/usb/serial/ftdi_sio.ko
./3.10.73/kernel/drivers/usb/serial/pl2303.ko
7560
root@Testbox-7560:/lib/modules# find .|grep usb
./3.10.12/kernel/drivers/net/usb
./3.10.12/kernel/drivers/net/usb/cdc_ether.ko
./3.10.12/kernel/drivers/net/usb/cdc_ncm.ko
./3.10.12/kernel/drivers/net/usb/rndis_host.ko
./3.10.12/kernel/drivers/net/usb/usbnet.ko
./3.10.12/kernel/drivers/usb
./3.10.12/kernel/drivers/usb/class
./3.10.12/kernel/drivers/usb/class/cdc-acm.ko
./3.10.12/kernel/drivers/usb/class/usblp.ko
./3.10.12/kernel/drivers/usb/host
./3.10.12/kernel/drivers/usb/host/xhci-hcd.ko
./3.10.12/kernel/drivers/usb/serial
./3.10.12/kernel/drivers/usb/serial/ftdi_sio.ko
./3.10.12/kernel/drivers/usb/serial/option.ko
./3.10.12/kernel/drivers/usb/serial/pl2303.ko
./3.10.12/kernel/drivers/usb/serial/usb_wwan.ko
./3.10.12/kernel/drivers/usb/serial/usbserial.ko
[/spolier]
Bei der 7490 ist de rReader direkt angesteckt, bei der 7560 ist ein Hub mit Stick und Reader dran
  • config7490.txt
und wo ist das USB-Serial-Device (VID=0403, PID=6001, FTDI USB Serial Device, FT232BM)
das fehlt in den Outputs "cat /debug/usb/devices" #13:
root@Testbox-7560:/# lsusb
BUS=002
DEV=001
VID=1d6b # Linux Foundation 3.0 root hub
PID=0003
BUS=001
DEV=001
VID=1d6b # Linux Foundation 2.0 root hub
PID=0002
BUS=001
DEV=002
VID=1a40 # USB Hub, Terminus Technology Inc.
PID=0101
CLS=09
SCL=00
SPEED='hi'
VER='2.0'
ISOC=0
INUM=1
ICLS1=09
ISCL1=00
BUS=001
DEV=003
VID=13fe # Kingston Technology Company Inc, integral Neon USB Flash Drive 4GB
PID=3d00
BUS=001
DEV=004
VID=0403
PID=6001 # FTDI USB Serial Device, FT232BM
CLS=00
SCL=00
SPEED='full'
VER='2.0'
ISOC=0
INUM=1
ICLS1=255
ISCL1=255
War das USB-Serial-Device nicht am USB-Bus angeschlossen ?
Inputs in #14 gefunden:
Freetz_FB7490:/# cat /debug/usb/devices
SNIP
Freetz_FB7560:/# cat /debug/usb/devices
SNIP
S: SerialNumber=01
der Driver ftdi_sio ist nicht für das Device "Argolis BV Smartreader plus" geladen
Bitte das Kernel-Modul ftdi_sio nochmals mit Debug-Option bei FB7560 laden.
modprobe -vr ftdi_sio # Unload original driver
modprobe -vr usbserial
insmod /lib/modules/3.10.12/kernel/drivers/usb/serial/usbserial.ko
modprobe ftdi_sio debug
# oder
# insmod /lib/modules/3.10.12/kernel/drivers/usb/serial/ftdi_sio.ko
dmesg
ls -la /dev/ttyUSB*
grep -i usb /proc/devices
Ferner "ls -la /dev/ttyUSB*" und "grep -i usb /proc/devices" bei der FB7490 eingeben;
Geht es hier um einen "Smartcard reader mit USB-2-Serial Schnittstelle" ?
Wie verwendest Du den TTY-to-USB bei FB7490 ?
mit "screen /dev/ttyUSB0" ?
So hier die geforderten Ausgaben
7560
root@Testbox-7560:/var/mod/root# modprobe -vr ftdi_sio
root@Testbox-7560:/var/mod/root# modprobe -vr usbserial
root@Testbox-7560:/var/mod/root# insmod /lib/modules/3.10.12/kernel/drivers/usb/
serial/usbserial.ko
root@Testbox-7560:/var/mod/root# modprobe ftdi_sio debug
modprobe: can't load module ftdi_sio (kernel/drivers/usb/serial/ftdi_sio.ko): Invalid argument
Ist die Eingabe
so richtig??
7560
ls -la /dev/ttyUSB*
root@Testbox-7560:/var/mod/root# ls -la /dev/ttyUSB*
crw-r--r-- 1 root root 188, 0 Oct 10 21:50 /dev/ttyUSB0
crw-r--r-- 1 root root 188, 1 Oct 10 21:50 /dev/ttyUSB1
crw-r--r-- 1 root root 188, 2 Oct 10 21:50 /dev/ttyUSB2
crw-r--r-- 1 root root 188, 3 Oct 10 21:50 /dev/ttyUSB3
crw-r--r-- 1 root root 188, 4 Oct 10 21:50 /dev/ttyUSB4
crw-r--r-- 1 root root 188, 5 Oct 10 21:50 /dev/ttyUSB5
crw-r--r-- 1 root root 188, 6 Oct 10 21:50 /dev/ttyUSB6
crw-r--r-- 1 root root 188, 7 Oct 10 21:50 /dev/ttyUSB7
7560
root@Testbox-7560:/var/mod/root# grep -i usb /proc/devices
180 usb
188 ttyUSB
189 usb_device
7490
ls -la /dev/ttyUSB*
root@fritz:/var/mod/root# ls -la /dev/ttyUSB*
crw------- 1 root root 188, 0 Oct 9 21:06 /dev/ttyUSB0
crw-r--r-- 1 root root 188, 1 Oct 1 11:58 /dev/ttyUSB1
crw-r--r-- 1 root root 188, 2 Oct 1 11:58 /dev/ttyUSB2
crw-r--r-- 1 root root 188, 3 Oct 1 11:58 /dev/ttyUSB3
crw-r--r-- 1 root root 188, 4 Oct 1 11:58 /dev/ttyUSB4
crw-r--r-- 1 root root 188, 5 Oct 1 11:58 /dev/ttyUSB5
crw-r--r-- 1 root root 188, 6 Oct 1 11:58 /dev/ttyUSB6
crw-r--r-- 1 root root 188, 7 Oct 1 11:58 /dev/ttyUSB7
7490
root@fritz:/var/mod/root# grep -i usb /proc/devices
180 usb
188 ttyUSB
189 usb_device
  • dmseg.txt
Fehlt noch etwas oder weiss niemand Rat?
Stripi
