# Automatically generated file; DO NOT EDIT.
# Freetz Configuration
FREETZ_HAVE_DOT_CONFIG=y
# General --------------------------------
FREETZ_AVM_VERSION_7270_05_21=y
FREETZ_TYPE_FON_WLAN_7270_16=y
# FREETZ_TYPE_300IP_AS_FON is not set
# FREETZ_TYPE_2170 is not set
# FREETZ_TYPE_6840 is not set
# FREETZ_TYPE_FON is not set
# FREETZ_TYPE_FON_5010 is not set
# FREETZ_TYPE_FON_5050 is not set
# FREETZ_TYPE_FON_5124 is not set
# FREETZ_TYPE_FON_5140 is not set
# FREETZ_TYPE_FON_WLAN is not set
# FREETZ_TYPE_FON_WLAN_7050 is not set
# FREETZ_TYPE_FON_WLAN_7112 is not set
# FREETZ_TYPE_FON_WLAN_7113 is not set
# FREETZ_TYPE_FON_WLAN_7140 is not set
# FREETZ_TYPE_FON_WLAN_7141 is not set
# FREETZ_TYPE_FON_7150 is not set
# FREETZ_TYPE_FON_WLAN_7170 is not set
# FREETZ_TYPE_FON_WLAN_7240 is not set
# FREETZ_TYPE_FON_WLAN_7270_V1 is not set
# FREETZ_TYPE_FON_WLAN_7270_V2 is not set
FREETZ_TYPE_FON_WLAN_7270_V3=y
# FREETZ_TYPE_FON_WLAN_7320 is not set
# FREETZ_TYPE_FON_WLAN_7330_XL is not set
# FREETZ_TYPE_FON_WLAN_7330_SL is not set
# FREETZ_TYPE_FON_WLAN_7340 is not set
# FREETZ_TYPE_FON_WLAN_7360_XL is not set
# FREETZ_TYPE_FON_WLAN_7360_SL is not set
# FREETZ_TYPE_FON_WLAN_7390 is not set
# FREETZ_TYPE_FON_WLAN_7570 is not set
# FREETZ_TYPE_WLAN_3020 is not set
# FREETZ_TYPE_WLAN_3030 is not set
# FREETZ_TYPE_WLAN_3130 is not set
# FREETZ_TYPE_WLAN_3131 is not set
# FREETZ_TYPE_WLAN_3170 is not set
# FREETZ_TYPE_WLAN_3270 is not set
# FREETZ_TYPE_WLAN_3270_V3 is not set
# FREETZ_TYPE_WLAN_3370 is not set
# FREETZ_TYPE_SPEEDPORT_W501V is not set
# FREETZ_TYPE_CUSTOM is not set
FREETZ_TYPE_FON_WLAN_7270=y
FREETZ_TYPE_LANG_DE=y
# FREETZ_TYPE_LANG_EN is not set
FREETZ_TYPE_LANGUAGE="de"
# FREETZ_TYPE_LABOR is not set
# FREETZ_TYPE_ALIEN_HARDWARE is not set
FREETZ_AVM_VERSION_STRING="7270_05.21"
FREETZ_FILESYSTEM_MTD_SIZE=0
FREETZ_TYPE_PREFIX="7270_v3"
FREETZ_INSTALL_BASE=y
FREETZ_REPLACE_BUSYBOX=y
FREETZ_SHOW_ADVANCED=y
FREETZ_REPLACE_KERNEL_AVAILABLE=y
FREETZ_REPLACE_KERNEL=y
FREETZ_TARGET_IPV6_SUPPORT=y
FREETZ_TARGET_REF_16MB=y
FREETZ_TARGET_REF="16mb"
FREETZ_KERNEL_REF_16MB=y
FREETZ_KERNEL_REF="16mb"
FREETZ_KERNEL_MTD_SIZE=246
# FREETZ_HAS_AVM_CDROM_ISO is not set
FREETZ_HAS_AVM_AURA_USB=y
# FREETZ_HAS_AVM_MINID is not set
FREETZ_HAS_AVM_NTFS=y
FREETZ_HAS_AVM_IPV6=y
FREETZ_HAS_AVM_WEBDAV=y
FREETZ_HAS_AVM_INETD=y
FREETZ_HAS_AVM_EXT3=y
FREETZ_HAS_AVM_TR069=y
FREETZ_HAS_AVM_CHRONYD=y
FREETZ_HAS_AVM_DECT=y
FREETZ_HAS_AVM_OPENSSL_LIBS=y
FREETZ_HAS_AVM_LSOF=y
FREETZ_HAS_AVM_NAS=y
FREETZ_HAS_AVM_PHONE=y
# FREETZ_HAS_AVM_STRACE is not set
FREETZ_HAS_AVM_TAM=y
FREETZ_HAS_AVM_UDEV=y
# FREETZ_HAS_UPDATE_FILESYSTEM_IMAGE is not set
# FREETZ_HAS_USB_CLIENT is not set
FREETZ_HAS_AVM_USB_HOST=y
# FREETZ_HAS_AVM_USB_HOST_AHCI is not set
FREETZ_HAS_AVM_E2FSPROGS=y
FREETZ_HAS_AVM_WLAN=y
FREETZ_HAS_AVM_UMTS=y
FREETZ_HAS_AVM_JFFS2=y
# FREETZ_HAS_AVM_JUNK_BYTES is not set
FREETZ_HAS_AVM_MULTI_ANNEX=y
FREETZ_HAS_AVM_CTLMGR_STRUCT_V3=y
# Mod ------------------------------------
FREETZ_LANG_DE=y
# FREETZ_LANG_EN is not set
FREETZ_LANG_STRING="de"
# Patches
# Web menu patches -----------------------
# FREETZ_PATCH_VCC is not set
# FREETZ_PATCH_ATA is not set
# FREETZ_PATCH_DSL_EXPERT is not set
# FREETZ_ADD_REGEXT_GUI is not set
# FREETZ_PATCH_GSMVOICE is not set
# FREETZ_PATCH_SIGNED is not set
# USB patches --------------------
FREETZ_PATCH_FREETZMOUNT=y
FREETZ_USBSTORAGE_AUTOMOUNT=y
# FREETZ_AUTOMOUNT_EXT2 is not set
FREETZ_AUTOMOUNT_EXT3=y
# FREETZ_AUTOMOUNT_EXT4 is not set
FREETZ_AUTOMOUNT_FAT=y
# FREETZ_AUTOMOUNT_HFS is not set
# FREETZ_AUTOMOUNT_HFS_PLUS is not set
# FREETZ_AUTOMOUNT_LUKS is not set
FREETZ_AUTOMOUNT_NTFS=y
# FREETZ_AUTOMOUNT_REISER_FS is not set
# FREETZ_AUTOMOUNT_LINUXSWAP is not set
# FREETZ_PATCH_MAXDEVCOUNT is not set
# FREETZ_MODIFY_UMTSD is not set
# FREETZ_CUSTOM_UDEV_RULES is not set
# Removal patches ------------------------
# FREETZ_REMOVE_MULTI_ANNEX_FIRMWARE is not set
FREETZ_REMOVE_ASSISTANT=y
FREETZ_REMOVE_ASSISTANT_SIP=y
# FREETZ_REMOVE_AURA_USB is not set
# FREETZ_REMOVE_NAS is not set
FREETZ_REMOVE_AVM_VPN=y
# Remove brandings
FREETZ_REMOVE_BRANDING_1und1=y
# FREETZ_REMOVE_BRANDING_avm is not set
FREETZ_REMOVE_BRANDING_otwo=y
FREETZ_REMOVE_CAPIOVERTCP=y
FREETZ_REMOVE_CHRONYD=y
FREETZ_REMOVE_DECT=y
# FREETZ_REMOVE_DSLD is not set
# FREETZ_REMOVE_SHOWDSLDSTAT is not set
FREETZ_REMOVE_DTRACE=y
# FREETZ_REMOVE_FTPD is not set
# FREETZ_REMOVE_HELP is not set
# FREETZ_REMOVE_JFFS2 is not set
# FREETZ_REMOVE_LSOF is not set
# FREETZ_REMOVE_MEDIASRV is not set
# FREETZ_REMOVE_NTFS is not set
# FREETZ_REMOVE_PRINTSERV is not set
# FREETZ_REMOVE_RUNCLOCK is not set
# FREETZ_REMOVE_SUPPORT is not set
FREETZ_REMOVE_TR069=y
FREETZ_REMOVE_TR069_FWUPDATE=y
# FREETZ_REMOVE_UMTSD is not set
# FREETZ_REMOVE_UPNP is not set
# FREETZ_REMOVE_USERMAN is not set
# FREETZ_REMOVE_AVM_E2FSPROGS is not set
# FREETZ_REMOVE_VOIPD is not set
# FREETZ_REMOVE_VOIP_ISDN is not set
# FREETZ_REMOVE_WEBDAV is not set
# FREETZ_REMOVE_WLAN is not set
# Replacement patches --------------------
# FREETZ_REPLACE_SSL_LIBS is not set
# FREETZ_REPLACE_DTRACE is not set
# FREETZ_REPLACE_ONLINECHANGED is not set
# Additional patches ---------------------
# FREETZ_ENFORCE_URLADER_SETTINGS is not set
# Misc patches ---------------------------
# FREETZ_DISABLE_SERIAL_CONSOLE is not set
# AVM daemons ----------------------------
# FREETZ_AVMDAEMON_DISABLE_IGD is not set
# FREETZ_AVMDAEMON_DISABLE_NTP is not set
# FREETZ_AVMDAEMON_DISABLE_IGM is not set
FREETZ_AVMDAEMON_DISABLE_TR069=y
# FREETZ_AVMDAEMON_DISABLE_MULTIDPORTS is not set
# Package selection
# Debug helpers
# FREETZ_PACKAGE_GDB is not set
# FREETZ_PACKAGE_INOTIFY_TOOLS is not set
# FREETZ_PACKAGE_LDD is not set
# FREETZ_PACKAGE_LSOF is not set
# FREETZ_PACKAGE_LTRACE is not set
# FREETZ_PACKAGE_NANO_SHELL is not set
# FREETZ_PACKAGE_PCIUTILS is not set
# FREETZ_PACKAGE_STRACE is not set
# FREETZ_PACKAGE_USBUTILS is not set
# Standard packages
# FREETZ_PACKAGE_AICCU is not set
# FREETZ_PACKAGE_BFTPD is not set
# FREETZ_PACKAGE_BIRD is not set
FREETZ_PACKAGE_BRIDGE_UTILS=y
# FREETZ_PACKAGE_CALLMONITOR is not set
# FREETZ_PACKAGE_CHECKMAILD is not set
# FREETZ_PACKAGE_CIFSMOUNT is not set
# FREETZ_PACKAGE_CPMACCFG is not set
# FREETZ_PACKAGE_CURL is not set
# FREETZ_PACKAGE_DECO is not set
# FREETZ_PACKAGE_DNS2TCP is not set
# FREETZ_PACKAGE_DNSMASQ is not set
FREETZ_PACKAGE_DROPBEAR=y
FREETZ_PACKAGE_DROPBEAR_SFTP_SERVER=y
# FREETZ_PACKAGE_DROPBEAR_SERVER_ONLY is not set
FREETZ_PACKAGE_DROPBEAR_WITH_ZLIB=y
FREETZ_PACKAGE_DROPBEAR_DISABLE_HOST_LOOKUP=y
# FREETZ_PACKAGE_DROPBEAR_STATIC is not set
FREETZ_PACKAGE_ESPEAK=y
FREETZ_PACKAGE_ESPEAK_ALL_LANGUAGES=y
# FREETZ_PACKAGE_FORTUNE is not set
# FREETZ_PACKAGE_FUSE is not set
FREETZ_PACKAGE_HASERL=y
# FREETZ_PACKAGE_HASERL_WITH_LUA is not set
FREETZ_PACKAGE_INETD=y
# FREETZ_PACKAGE_KNOCK is not set
# FREETZ_PACKAGE_MC is not set
# FREETZ_PACKAGE_MINI_FO is not set
# FREETZ_PACKAGE_MTR is not set
# FREETZ_PACKAGE_NANO is not set
# FREETZ_PACKAGE_NETCAT is not set
# FREETZ_PACKAGE_NC6 is not set
# FREETZ_PACKAGE_NETSNMP is not set
# FREETZ_PACKAGE_NFS_UTILS is not set
# FREETZ_PACKAGE_NTFS is not set
# FREETZ_PACKAGE_OPENNTPD is not set
FREETZ_PACKAGE_OPENVPN=y
# FREETZ_PACKAGE_OPENVPN_STATIC is not set
FREETZ_PACKAGE_OPENVPN_WITH_LZO=y
FREETZ_PACKAGE_OPENVPN_WITH_MGMNT=y
FREETZ_PACKAGE_OPENVPN_ENABLE_SMALL=y
# FREETZ_PACKAGE_PHP is not set
# FREETZ_PACKAGE_PINGTUNNEL is not set
# FREETZ_PACKAGE_PORTMAP is not set
# Point-to-Point
# FREETZ_PACKAGE_PPPD is not set
# FREETZ_PACKAGE_PPPD_CHAT is not set
# FREETZ_PACKAGE_PPTP is not set
# FREETZ_PACKAGE_PPTPD is not set
# FREETZ_PACKAGE_PRIVOXY is not set
# FREETZ_PACKAGE_RADVD is not set
# FREETZ_PACKAGE_RCAPID is not set
FREETZ_PACKAGE_SAMBA=y
FREETZ_PACKAGE_NMBD=y
FREETZ_SAMBA_VERSION_3_0=y
# FREETZ_SAMBA_VERSION_3_6 is not set
FREETZ_PACKAGE_SAMBA_MAX_DEBUG_LEVEL=-1
# FREETZ_PACKAGE_SCREEN is not set
# FREETZ_PACKAGE_STUNNEL is not set
# FREETZ_PACKAGE_TCPDUMP is not set
# FREETZ_PACKAGE_TINYPROXY is not set
# FREETZ_PACKAGE_TOR is not set
# FREETZ_PACKAGE_TRANSMISSION is not set
# FREETZ_PACKAGE_VNSTAT is not set
# FREETZ_PACKAGE_VPNC is not set
FREETZ_PACKAGE_VSFTPD=y
FREETZ_PACKAGE_VSFTPD_WITH_SSL=y
# FREETZ_PACKAGE_VSFTPD_STATIC is not set
# FREETZ_PACKAGE_XMAIL is not set
# Testing
# FREETZ_PACKAGE_APACHE is not set
# FREETZ_PACKAGE_APACHE2 is not set
# FREETZ_PACKAGE_AUTOFS is not set
# FREETZ_PACKAGE_AVAHI is not set
# FREETZ_PACKAGE_BASH is not set
# FREETZ_PACKAGE_BFUSB is not set
# FREETZ_PACKAGE_BIND is not set
# FREETZ_PACKAGE_BIP is not set
# FREETZ_PACKAGE_BITTWIST is not set
# FREETZ_PACKAGE_BLUEZ_UTILS is not set
# FREETZ_PACKAGE_BR2684CTL is not set
# FREETZ_PACKAGE_CLASSPATH is not set
# FREETZ_PACKAGE_CRYPTSETUP is not set
# FREETZ_PACKAGE_CTORRENT is not set
# FREETZ_PACKAGE_DAVFS2 is not set
# FREETZ_PACKAGE_DBUS is not set
# FREETZ_PACKAGE_DEBOOTSTRAP is not set
# FREETZ_PACKAGE_DIGITEMP is not set
# FREETZ_PACKAGE_DOSFSTOOLS is not set
# FREETZ_PACKAGE_DTACH is not set
# FREETZ_PACKAGE_E2FSPROGS is not set
# FREETZ_PACKAGE_EMPTY is not set
# FREETZ_PACKAGE_FFMPEG is not set
# FREETZ_PACKAGE_FOWSR is not set
# FREETZ_PACKAGE_FSTYP is not set
# FREETZ_PACKAGE_GIT is not set
# FREETZ_PACKAGE_GNU_MAKE is not set
# FREETZ_PACKAGE_GNUTLS is not set
# FREETZ_PACKAGE_GOCR is not set
# FREETZ_PACKAGE_HAPROXY is not set
# FREETZ_PACKAGE_HD_IDLE is not set
# FREETZ_PACKAGE_HOL is not set
# FREETZ_PACKAGE_HTOP is not set
# FREETZ_PACKAGE_HTPDATE is not set
# FREETZ_PACKAGE_HTTPRY is not set
# FREETZ_PACKAGE_HTTPTUNNEL is not set
# FREETZ_PACKAGE_IFSTAT is not set
# FREETZ_PACKAGE_IFTOP is not set
# FREETZ_PACKAGE_IGMPPROXY is not set
# FREETZ_PACKAGE_INADYN_MT is not set
# FREETZ_PACKAGE_IODINE is not set
# FREETZ_PACKAGE_IPTRAF is not set
# FREETZ_PACKAGE_IPUTILS is not set
# FREETZ_PACKAGE_IRSSI is not set
# FREETZ_PACKAGE_JAMVM is not set
# FREETZ_PACKAGE_LFTP is not set
# FREETZ_PACKAGE_LIGHTTPD is not set
# FREETZ_PACKAGE_LYNX is not set
# FREETZ_PACKAGE_LUA is not set
# FREETZ_PACKAGE_MADPLAY is not set
# FREETZ_PACKAGE_MATRIXTUNNEL is not set
# FREETZ_PACKAGE_MCABBER is not set
# FREETZ_PACKAGE_MEDIATOMB is not set
# FREETZ_PACKAGE_MICROPERL is not set
# FREETZ_PACKAGE_MINI_SNMPD is not set
# FREETZ_PACKAGE_MINICOM is not set
# FREETZ_PACKAGE_MINIDLNA is not set
# FREETZ_PACKAGE_MODULE_INIT_TOOLS is not set
# FREETZ_PACKAGE_NAGIOS is not set
# FREETZ_PACKAGE_NCFTP is not set
# FREETZ_PACKAGE_NETATALK is not set
# FREETZ_PACKAGE_NETPBM is not set
# FREETZ_PACKAGE_NOIP is not set
# FREETZ_PACKAGE_NDAS is not set
# FREETZ_PACKAGE_NFSROOT is not set
# FREETZ_PACKAGE_NGIRCD is not set
# FREETZ_PACKAGE_NMAP is not set
# FREETZ_PACKAGE_OBEXFTP is not set
# FREETZ_PACKAGE_OIDENTD is not set
# FREETZ_PACKAGE_OPENCONNECT is not set
# FREETZ_PACKAGE_OPENDD is not set
# OpenSSH
FREETZ_PACKAGE_OPENSSH=y
# FREETZ_PACKAGE_OPENSSH_sshd is not set
# FREETZ_PACKAGE_OPENSSH_ssh is not set
# FREETZ_PACKAGE_OPENSSH_scp is not set
# FREETZ_PACKAGE_OPENSSH_CLIENTUTILS is not set
# FREETZ_PACKAGE_OPENSSH_KEYUTILS is not set
# FREETZ_PACKAGE_OPENSSH_sftp is not set
FREETZ_PACKAGE_OPENSSH_sftp_server=y
# Build statically linked binaries ---
# FREETZ_PACKAGE_OPENSSH_STATIC is not set
# FREETZ_PACKAGE_OWFS is not set
# FREETZ_PACKAGE_POLIPO is not set
# FREETZ_PACKAGE_QUAGGA is not set
# FREETZ_PACKAGE_RIPMIME is not set
# FREETZ_PACKAGE_RRDTOOL is not set
# FREETZ_PACKAGE_RSYNC is not set
# FREETZ_PACKAGE_RUBY is not set
# FREETZ_PACKAGE_SABLEVM_SDK is not set
# FREETZ_PACKAGE_SER2NET is not set
# FREETZ_PACKAGE_SIPROXD is not set
# FREETZ_PACKAGE_SISPMCTL is not set
# FREETZ_PACKAGE_SLANG is not set
# FREETZ_PACKAGE_SLURM is not set
# FREETZ_PACKAGE_SMUSBUTIL is not set
# FREETZ_PACKAGE_SOCAT is not set
# FREETZ_PACKAGE_SPAWN_FCGI is not set
# FREETZ_PACKAGE_SQLITE is not set
# FREETZ_PACKAGE_SQUID is not set
# FREETZ_PACKAGE_SSHFS_FUSE is not set
# FREETZ_PACKAGE_STREAMRIPPER is not set
# FREETZ_PACKAGE_SUBVERSION is not set
# FREETZ_PACKAGE_SYNCE_DCCM is not set
# FREETZ_PACKAGE_SYNCE_SERIAL is not set
# FREETZ_PACKAGE_TCP_WRAPPERS is not set
# FREETZ_PACKAGE_TCPPROXY is not set
# FREETZ_PACKAGE_TREE is not set
# FREETZ_PACKAGE_TRICKLE is not set
# FREETZ_PACKAGE_TMUX is not set
# FREETZ_PACKAGE_UDPXY is not set
# FREETZ_PACKAGE_UMURMUR is not set
# FREETZ_PACKAGE_UNRAR is not set
# FREETZ_PACKAGE_USBIP is not set
# FREETZ_PACKAGE_USBROOT is not set
# FREETZ_PACKAGE_UTIL_LINUX_NG is not set
# FREETZ_PACKAGE_VIM is not set
# FREETZ_PACKAGE_VTUN is not set
# FREETZ_PACKAGE_WGET is not set
# FREETZ_PACKAGE_WOL is not set
# FREETZ_PACKAGE_WPUT is not set
# FREETZ_PACKAGE_XPDF is not set
# FREETZ_PACKAGE_XRELAYD is not set
# FREETZ_PACKAGE_XSLTPROC is not set
# Web interfaces
FREETZ_PACKAGE_AUTHORIZED_KEYS=y
FREETZ_PACKAGE_AVM_FIREWALL=y
# FREETZ_PACKAGE_CPMACCFG_CGI is not set
# FREETZ_PACKAGE_DNSD_CGI is not set
# FREETZ_PACKAGE_DOWNLOADER is not set
# FREETZ_PACKAGE_NFSD_CGI is not set
# FREETZ_PACKAGE_ONLINECHANGED_CGI is not set
# FREETZ_PACKAGE_PHPXMAIL is not set
# FREETZ_PACKAGE_PPP_CGI is not set
# FREETZ_PACKAGE_RRDSTATS is not set
# FREETZ_PACKAGE_SPINDOWN_CGI is not set
FREETZ_PACKAGE_SYSLOGD_CGI=y
# FREETZ_PACKAGE_TRANSMISSION_CGI is not set
# FREETZ_PACKAGE_VNSTAT_CGI is not set
# FREETZ_PACKAGE_WOL_CGI is not set
FREETZ_SHOW_UNSTABLE_PACKAGES=y
# Unstable packages
# FREETZ_PACKAGE_COLLECTD is not set
FREETZ_PACKAGE_DTMFBOX=y
# CAPI/SIP
FREETZ_PACKAGE_DTMFBOX_WITH_CAPI=y
FREETZ_PACKAGE_DTMFBOX_WITH_VOIP=y
FREETZ_PACKAGE_DTMFBOX_WITH_ICE=y
# Codecs
FREETZ_PACKAGE_DTMFBOX_WITH_G711_CODEC=y
# FREETZ_PACKAGE_DTMFBOX_WITH_SPEEX_CODEC is not set
# FREETZ_PACKAGE_DTMFBOX_WITH_GSM_CODEC is not set
# Misc
# FREETZ_PACKAGE_DTMFBOX_USE_DIFF_PATCH is not set
FREETZ_PACKAGE_DTMFBOX_WITH_ESPEAK=y
# FREETZ_PACKAGE_DTMFBOX_WITH_MADPLAY is not set
# FREETZ_PACKAGE_DTMFBOX_CGI is not set
# FREETZ_PACKAGE_GW6 is not set
# FREETZ_PACKAGE_HP_UTILS is not set
# FREETZ_PACKAGE_HPLIP is not set
FREETZ_PACKAGE_IPTABLES=y
FREETZ_PACKAGE_IPTABLES_IS_SELECTABLE=y
FREETZ_PACKAGE_IPTABLES_SAVE_RESTORE=y
FREETZ_PACKAGE_IPTABLES_XML=y
FREETZ_PACKAGE_IPTABLES_CGI=y
# FREETZ_PACKAGE_NHIPT is not set
FREETZ_PACKAGE_IPTABLES_STANDARD_MODULES=y
FREETZ_PACKAGE_IPTABLES_KERNEL_MODULES=y
# Select kernel modules (IPv4)
FREETZ_MODULE_nf_conntrack=y
FREETZ_MODULE_nf_conntrack_ftp=y
# FREETZ_MODULE_nf_conntrack_h323 is not set
# FREETZ_MODULE_nf_conntrack_irc is not set
FREETZ_MODULE_nf_conntrack_ipv4=y
# FREETZ_MODULE_nf_conntrack_pptp is not set
# FREETZ_MODULE_nf_conntrack_proto_gre is not set
FREETZ_MODULE_nf_conntrack_tftp=y
FREETZ_MODULE_nf_defrag_ipv4=y
FREETZ_MODULE_nf_nat=y
FREETZ_MODULE_nf_nat_ftp=y
# FREETZ_MODULE_nf_nat_h323 is not set
# FREETZ_MODULE_nf_nat_irc is not set
# FREETZ_MODULE_nf_nat_pptp is not set
FREETZ_MODULE_nf_nat_tftp=y
FREETZ_MODULE_iptable_filter=y
FREETZ_MODULE_iptable_mangle=y
FREETZ_MODULE_iptable_nat=y
FREETZ_MODULE_iptable_raw=y
FREETZ_MODULE_ip_tables=y
FREETZ_MODULE_ipt_LOG=y
FREETZ_MODULE_ipt_REJECT=y
FREETZ_MODULE_ipt_ttl=y
FREETZ_MODULE_ipt_TTL=y
# x_tables (both IPv4 and IPv6)
FREETZ_MODULE_x_tables=y
# FREETZ_MODULE_xt_CLASSIFY is not set
# FREETZ_MODULE_xt_comment is not set
# FREETZ_MODULE_xt_esp is not set
FREETZ_MODULE_xt_length=y
FREETZ_MODULE_xt_limit=y
FREETZ_MODULE_xt_mac=y
FREETZ_MODULE_xt_multiport=y
FREETZ_MODULE_xt_mark=y
FREETZ_MODULE_xt_MARK=y
# FREETZ_MODULE_xt_NFQUEUE is not set
FREETZ_MODULE_xt_iprange=y
FREETZ_MODULE_xt_pkttype=y
FREETZ_MODULE_xt_physdev=y
# FREETZ_MODULE_xt_quota is not set
# FREETZ_MODULE_xt_realm is not set
# FREETZ_MODULE_xt_statistic is not set
# FREETZ_MODULE_xt_string is not set
FREETZ_MODULE_xt_tcpudp=y
# FREETZ_MODULE_xt_tcpmss is not set
# Select kernel modules (IPv6)
# FREETZ_MODULE_ip6_queue is not set
# FREETZ_MODULE_ip6_tables is not set
# FREETZ_MODULE_nf_conntrack_ipv6 is not set
FREETZ_PACKAGE_IPTABLES_SHARED_LIBS=y
# Select shared libraries (IPv4)
FREETZ_LIB_libipt_addrtype=y
# FREETZ_LIB_libipt_ah is not set
# FREETZ_LIB_libipt_CLUSTERIP is not set
FREETZ_LIB_libipt_DNAT=y
# FREETZ_LIB_libipt_ecn is not set
# FREETZ_LIB_libipt_ECN is not set
FREETZ_LIB_libipt_icmp=y
FREETZ_LIB_libipt_LOG=y
FREETZ_LIB_libipt_MASQUERADE=y
# FREETZ_LIB_libipt_MIRROR is not set
# FREETZ_LIB_libipt_NETMAP is not set
# FREETZ_LIB_libipt_realm is not set
FREETZ_LIB_libipt_REDIRECT=y
FREETZ_LIB_libipt_REJECT=y
# FREETZ_LIB_libipt_SAME is not set
FREETZ_LIB_libipt_SNAT=y
# FREETZ_LIB_libipt_ttl is not set
# FREETZ_LIB_libipt_TTL is not set
FREETZ_LIB_libipt_ULOG=y
# FREETZ_LIB_libipt_unclean is not set
# Select shared libraries (both IPv4 and IPv6)
FREETZ_LIB_libxt_CLASSIFY=y
# FREETZ_LIB_libxt_comment is not set
FREETZ_LIB_libxt_connbytes=y
FREETZ_LIB_libxt_connmark=y
FREETZ_LIB_libxt_CONNMARK=y
# FREETZ_LIB_libxt_CONNSECMARK is not set
# FREETZ_LIB_libxt_conntrack is not set
# FREETZ_LIB_libxt_dscp is not set
# FREETZ_LIB_libxt_DSCP is not set
# FREETZ_LIB_libxt_esp is not set
# FREETZ_LIB_libxt_hashlimit is not set
# FREETZ_LIB_libxt_helper is not set
FREETZ_LIB_libxt_iprange=y
FREETZ_LIB_libxt_length=y
FREETZ_LIB_libxt_limit=y
FREETZ_LIB_libxt_mac=y
FREETZ_LIB_libxt_mark=y
FREETZ_LIB_libxt_MARK=y
FREETZ_LIB_libxt_multiport=y
# FREETZ_LIB_libxt_NFLOG is not set
# FREETZ_LIB_libxt_NFQUEUE is not set
# FREETZ_LIB_libxt_NOTRACK is not set
# FREETZ_LIB_libxt_owner is not set
FREETZ_LIB_libxt_physdev=y
FREETZ_LIB_libxt_pkttype=y
# FREETZ_LIB_libxt_quota is not set
# FREETZ_LIB_libxt_rateest is not set
# FREETZ_LIB_libxt_RATEEST is not set
# FREETZ_LIB_libxt_sctp is not set
# FREETZ_LIB_libxt_SECMARK is not set
FREETZ_LIB_libxt_standard=y
FREETZ_LIB_libxt_state=y
# FREETZ_LIB_libxt_statistic is not set
# FREETZ_LIB_libxt_string is not set
# FREETZ_LIB_libxt_tcpmss is not set
FREETZ_LIB_libxt_TCPMSS=y
FREETZ_LIB_libxt_tcp=y
# FREETZ_LIB_libxt_time is not set
# FREETZ_LIB_libxt_tos is not set
# FREETZ_LIB_libxt_TOS is not set
# FREETZ_LIB_libxt_TRACE is not set
# FREETZ_LIB_libxt_u32 is not set
FREETZ_LIB_libxt_udp=y
# Select shared libraries (IPv6)
# FREETZ_LIB_libip6t_ah is not set
# FREETZ_LIB_libip6t_dst is not set
# FREETZ_LIB_libip6t_eui64 is not set
# FREETZ_LIB_libip6t_frag is not set
# FREETZ_LIB_libip6t_hbh is not set
# FREETZ_LIB_libip6t_hl is not set
# FREETZ_LIB_libip6t_HL is not set
FREETZ_LIB_libip6t_icmp6=y
# FREETZ_LIB_libip6t_ipv6header is not set
# FREETZ_LIB_libip6t_LOG is not set
# FREETZ_LIB_libip6t_mh is not set
# FREETZ_LIB_libip6t_REJECT is not set
# FREETZ_LIB_libip6t_rt is not set
# SANE
# FREETZ_PACKAGE_SANE_BACKENDS is not set
# FREETZ_PACKAGE_TINC is not set
# truecrypt (unavailable, needs libstdc++ as the standard C++ library)
# FREETZ_PACKAGE_VIRTUALIP_CGI is not set
FREETZ_PACKAGE_MOD=y
FREETZ_PACKAGE_MOD_ETCSERVICES=y
FREETZ_PACKAGE_MODCGI=y
# Advanced options
# FREETZ_DL_OVERRIDE is not set
FREETZ_DL_KERNEL_SITE="@AVM/fritzbox.fon_wlan_7270_v3/x_misc/opensrc"
FREETZ_DL_KERNEL_SOURCE="fritzbox7270-source-files-05.21.tar.gz"
FREETZ_DL_KERNEL_SOURCE_MD5="6975d65be957cd12f5df3633e3848495"
FREETZ_DL_SITE="@AVM/fritzbox.fon_wlan_7270_v3/firmware/deutsch"
FREETZ_DL_SOURCE="FRITZ.Box_Fon_WLAN_7270_v3.74.05.21.image"
FREETZ_DL_SOURCE_MD5="b53ac853ae3dc9ec5a9f1fccdd776c79"
# Build system options
FREETZ_VERBOSITY_LEVEL=2
FREETZ_SIZEINFO_COMPRESSED=y
# FREETZ_SIZEINFO_UNCOMPRESSED is not set
# Firmware packaging (fwmod) special options
# FREETZ_FWMOD_SKIP_UNPACK is not set
# FREETZ_FWMOD_SKIP_MODIFY is not set
# FREETZ_FWMOD_SKIP_PACK is not set
# FREETZ_FWMOD_SDK is not set
# FREETZ_FWMOD_USBROOT is not set
# FREETZ_FWMOD_NFSROOT is not set
# ATTENTION: target folder name must not be empty
FREETZ_JLEVEL=2
FREETZ_CHECK_CHANGED=y
# FREETZ_BACKUP_CONFIG_CACHE is not set
FREETZ_DL_SITE_USER=""
# Freetz customisation
FREETZ_OPTIONS_ETCSERVICES=y
FREETZ_SECURITY_LEVEL=1
FREETZ_STYLE_COLORED=y
# FREETZ_STYLE_GREY is not set
FREETZ_STYLE="colored"
# Webinterface skins
FREETZ_SKIN_legacy=y
# FREETZ_SKIN_newfreetz is not set
# FREETZ_SKIN_phoenix is not set
FREETZ_FAVICON_NONE=y
# FREETZ_FAVICON_ATOMPHIL is not set
# FREETZ_FAVICON_CUMA is not set
# FREETZ_FAVICON_DSL123 is not set
# FREETZ_FAVICON_HANSOLO is not set
FREETZ_FAVICON_STRING="none"
FREETZ_TAGGING_NONE=y
# FREETZ_TAGGING_CUMA is not set
FREETZ_TAGGING_STRING="none"
# Additional image/box information
FREETZ_DEVELOPER_VERSION_STRING=y
# FREETZ_MODIFY_AVM_VERSION is not set
FREETZ_USER_DEFINED_COMMENT=""
# FREETZ_CUSTOM_IMAGE_NAME is not set
# FREETZ_REMOVE_BOX_INFO is not set
# FREETZ_REMOVE_FREETZ_INFO is not set
FREETZ_CREATE_SEPARATE_OPTIONS_CFG=y
# FREETZ_REMOVE_DOT_CONFIG is not set
# FREETZ_SQUASHFS_BLOCKSIZE_ORIG is not set
FREETZ_SQUASHFS_BLOCKSIZE_65536=y
FREETZ_SQUASHFS_BLOCKSIZE=65536
# FREETZ_KERNEL_VERSION_2_6_13 is not set
# FREETZ_KERNEL_VERSION_2_6_19 is not set
# FREETZ_KERNEL_VERSION_2_6_28 is not set
FREETZ_KERNEL_VERSION_2_6_32=y
FREETZ_KERNEL_VERSION="2.6.32"
FREETZ_KERNEL_VERSION_2_6_13_MIN=y
FREETZ_KERNEL_VERSION_2_6_19_MIN=y
FREETZ_KERNEL_VERSION_2_6_28_MIN=y
FREETZ_KERNEL_VERSION_2_6_32_MIN=y
# FREETZ_KERNEL_VERSION_2_6_13_MAX is not set
# FREETZ_KERNEL_VERSION_2_6_19_MAX is not set
# FREETZ_KERNEL_VERSION_2_6_28_MAX is not set
FREETZ_KERNEL_VERSION_2_6_32_MAX=y
FREETZ_KERNEL_LAYOUT_UR8=y
FREETZ_KERNEL_LAYOUT="ur8"
FREETZ_MODULES_KVER="2.6.32.41"
# Kernel modules
# FREETZ_MODULES_ALL is not set
# block
# FREETZ_MODULE_block2mtd is not set
# FREETZ_MODULE_ramzswap is not set
# FREETZ_MODULE_xvmalloc is not set
# ndas
# FREETZ_MODULE_ndas_block is not set
# FREETZ_MODULE_ndas_core is not set
# FREETZ_MODULE_ndas_sal is not set
# crypto
# FREETZ_MODULE_arc4 is not set
# FREETZ_MODULE_cbc is not set
# FREETZ_MODULE_sha1_generic is not set
# FREETZ_MODULE_sha256_generic is not set
# drivers
# FREETZ_MODULE_loop is not set
# FREETZ_MODULE_nbd is not set
# FREETZ_MODULE_cdrom is not set
# FREETZ_MODULE_capiconn is not set
# FREETZ_MODULE_nand is not set
# FREETZ_MODULE_ohio_nand is not set
# FREETZ_MODULE_dummy is not set
# FREETZ_MODULE_ppp_async is not set
# FREETZ_MODULE_ppp_deflate is not set
# FREETZ_MODULE_ppp_generic is not set
# FREETZ_MODULE_pppoe is not set
# FREETZ_MODULE_pppox is not set
# FREETZ_MODULE_ppp_mppe_mppc is not set
# FREETZ_MODULE_scsi_mod is not set
# FREETZ_MODULE_sd_mod is not set
# FREETZ_MODULE_sg is not set
# FREETZ_MODULE_sr_mod is not set
# FREETZ_MODULE_slhc is not set
# FREETZ_MODULE_usblp is not set
# FREETZ_MODULE_usb_storage is not set
# FREETZ_MODULE_usbmon is not set
# FREETZ_MODULE_usbcore is not set
# FREETZ_MODULE_usbip is not set
# FREETZ_MODULE_usbip_common_mod is not set
# FREETZ_MODULE_usbserial is not set
# FREETZ_MODULE_ipaq is not set
# FREETZ_MODULE_cp210x is not set
# FREETZ_MODULE_pl2303 is not set
# FREETZ_MODULE_ftdi_sio is not set
# FREETZ_MODULE_hci_usb is not set
# FREETZ_MODULE_bfusb is not set
# FREETZ_MODULE_firmware_class is not set
# FREETZ_MODULE_dm_mod is not set
# FREETZ_MODULE_dm_crypt is not set
# FREETZ_MODULE_option is not set
# fs
# FREETZ_MODULE_autofs4 is not set
# FREETZ_MODULE_cifs is not set
# FREETZ_MODULE_coda is not set
# FREETZ_MODULE_ext2 is not set
# FREETZ_MODULE_ext4 is not set
FREETZ_MODULE_fat=y
# FREETZ_MODULE_hfs is not set
# FREETZ_MODULE_hfsplus is not set
FREETZ_MODULE_fuse=y
# FREETZ_MODULE_iso9660 is not set
# FREETZ_MODULE_jbd2 is not set
# FREETZ_MODULE_lockd is not set
# FREETZ_MODULE_mini_fo is not set
# FREETZ_MODULE_minix is not set
# FREETZ_MODULE_nfsd is not set
# FREETZ_MODULE_exportfs is not set
# FREETZ_MODULE_nfs is not set
# FREETZ_MODULE_nls_cp437 is not set
# FREETZ_MODULE_nls_cp852 is not set
# FREETZ_MODULE_nls_iso8859_15 is not set
# FREETZ_MODULE_nls_iso8859_1 is not set
# FREETZ_MODULE_nls_utf8 is not set
# FREETZ_MODULE_reiserfs is not set
# FREETZ_MODULE_udf is not set
# FREETZ_MODULE_unionfs is not set
FREETZ_MODULE_vfat=y
FREETZ_MODULE_msdos=y
# FREETZ_MODULE_jffs2 is not set
# FREETZ_MODULE_mbcache is not set
# lib
# FREETZ_MODULE_crc16 is not set
# FREETZ_MODULE_crc_ccitt is not set
# FREETZ_MODULE_lzo_compress is not set
# FREETZ_MODULE_lzo_decompress is not set
# net
# FREETZ_MODULE_bluetooth is not set
# FREETZ_MODULE_bnep is not set
# FREETZ_MODULE_cls_u32 is not set
# FREETZ_MODULE_l2cap is not set
# network scheduler
# FREETZ_MODULE_sch_cbq is not set
# FREETZ_MODULE_sch_htb is not set
# FREETZ_MODULE_sch_llq is not set
# FREETZ_MODULE_sch_sfq is not set
# FREETZ_MODULE_sch_tbf is not set
# FREETZ_MODULE_rfcomm is not set
# FREETZ_MODULE_sunrpc is not set
# BusyBox options
# FREETZ_BUSYBOX_AR is not set
# FREETZ_BUSYBOX_BLKID is not set
# FREETZ_BUSYBOX_BZIP2 is not set
# FREETZ_BUSYBOX_CHGRP is not set
# FREETZ_BUSYBOX_FEATURE_DD_IBS_OBS is not set
# FREETZ_BUSYBOX_FINDFS is not set
# FREETZ_BUSYBOX_DNSD is not set
# FREETZ_BUSYBOX_DIFF is not set
# FREETZ_BUSYBOX_DOS2UNIX is not set
FREETZ_BUSYBOX_ETHER_WAKE=y
# FREETZ_BUSYBOX_FAKEIDENTD is not set
# FREETZ_BUSYBOX_FANCY_KEYS is not set
# FREETZ_BUSYBOX_FUSER is not set
FREETZ_BUSYBOX_INETD=y
FREETZ_BUSYBOX_IP=y
FREETZ_BUSYBOX_FEATURE_IP_ADDRESS=y
FREETZ_BUSYBOX_FEATURE_IP_LINK=y
# FREETZ_BUSYBOX_FEATURE_IP_RULE is not set
FREETZ_BUSYBOX_FEATURE_IP_ROUTE=y
FREETZ_BUSYBOX_FEATURE_IP_TUNNEL=y
# FREETZ_BUSYBOX_LAST is not set
# FREETZ_BUSYBOX_LESS is not set
# FREETZ_BUSYBOX_LONG_OPTS is not set
# FREETZ_BUSYBOX_LS_COLOR is not set
FREETZ_BUSYBOX_MD5SUM=y
# FREETZ_BUSYBOX_MDEV is not set
# FREETZ_BUSYBOX_MODINFO is not set
# FREETZ_BUSYBOX_MOUNT_HELPERS is not set
# FREETZ_BUSYBOX_MOUNT_LABEL is not set
# FREETZ_BUSYBOX_NICE is not set
# FREETZ_BUSYBOX_PATCH is not set
# FREETZ_BUSYBOX_PSCAN is not set
FREETZ_BUSYBOX_REALPATH=y
# FREETZ_BUSYBOX_RENICE is not set
# FREETZ_BUSYBOX_SEQ is not set
# FREETZ_BUSYBOX_SHA1SUM is not set
# FREETZ_BUSYBOX_SPLIT is not set
# FREETZ_BUSYBOX_START_STOP_DAEMON is not set
FREETZ_BUSYBOX_STUN_IP=y
# FREETZ_BUSYBOX_TAC is not set
FREETZ_BUSYBOX_TAR_OLDGNU_COMPATIBILITY=y
# FREETZ_BUSYBOX_UDHCPC is not set
# FREETZ_BUSYBOX_UDHCPD is not set
# FREETZ_BUSYBOX_UNIX2DOS is not set
# FREETZ_BUSYBOX_UNZIP is not set
# FREETZ_BUSYBOX_FEATURE_USERNAME_COMPLETION is not set
# FREETZ_BUSYBOX_USLEEP is not set
FREETZ_BUSYBOX_VOLUMEID=y
FREETZ_BUSYBOX_VOLUMEID_EXT=y
FREETZ_BUSYBOX_VOLUMEID_FAT=y
# FREETZ_BUSYBOX_VOLUMEID_HFS is not set
# FREETZ_BUSYBOX_VOLUMEID_LINUXRAID is not set
# FREETZ_BUSYBOX_VOLUMEID_LINUXSWAP is not set
# FREETZ_BUSYBOX_VOLUMEID_LUKS is not set
FREETZ_BUSYBOX_VOLUMEID_NTFS=y
# FREETZ_BUSYBOX_VOLUMEID_REISERFS is not set
FREETZ_BUSYBOX_WGET=y
# FREETZ_BUSYBOX_WHO is not set
# FREETZ_BUSYBOX_WHOAMI is not set
# IPv6 Options
FREETZ_BUSYBOX_FEATURE_PREFER_IPV4_ADDRESS=y
# FREETZ_BUSYBOX_PING6 is not set
# FREETZ_BUSYBOX_TRACEROUTE6 is not set
# Shared Libraries
# Apache Portable Runtime libs
# FREETZ_LIB_libapr is not set
# FREETZ_LIB_libapr_WITH_DSO is not set
# FREETZ_LIB_libaprutil is not set
# FREETZ_LIB_libaprutil_WITH_LIBDB is not set
# Avahi libraries
# FREETZ_LIB_libavahi_common is not set
# FREETZ_LIB_libavahi_core is not set
# FREETZ_LIB_libavahi_client is not set
# C++
FREETZ_LIB_STDCXXLIB=y
# FREETZ_LIB_STDCXXLIB_WITH_WCHAR is not set
# FREETZ_LIB_libstdc__ is not set
FREETZ_LIB_libuClibc__=y
# FREETZ_LIB_libuClibc__WITH_WCHAR is not set
# Charsets & Internationalization
# FREETZ_LIB_libiconv is not set
# FREETZ_LIB_libintl is not set
# Crypto & SSL
# GnuPG ----------------------------------
# FREETZ_LIB_libgpg_error is not set
# FREETZ_LIB_libgcrypt is not set
# Digests ---
# Symmetric ciphers ---
# Asymmetric ciphers ---
# GnuTLS ---------------------------------
# FREETZ_LIB_libgnutls is not set
# FREETZ_LIB_libtasn1 is not set
# SSL ------------------------------------
# FREETZ_LIB_libcyassl is not set
# FREETZ_LIB_libmatrixssl is not set
# FREETZ_LIB_libpolarssl is not set
FREETZ_LIB_libcrypto=y
FREETZ_LIB_libssl=y
# Data compression
FREETZ_LIB_liblzo2=y
FREETZ_LIB_libz=y
# Database
# FREETZ_LIB_libdb is not set
# FREETZ_LIB_libsqlite3 is not set
# File systems
# e2fsprogs libraries
# FREETZ_LIB_libblkid is not set
# FREETZ_LIB_libcom_err is not set
# FREETZ_LIB_libe2p is not set
# FREETZ_LIB_libext2fs is not set
# FREETZ_LIB_libss is not set
# FREETZ_LIB_libuuid is not set
# FREETZ_LIB_libfuse is not set
# FREETZ_LIB_libntfs is not set
# GLib
# FREETZ_LIB_libglib_2 is not set
# FREETZ_LIB_libgio_2 is not set
# FREETZ_LIB_libgobject_2 is not set
# FREETZ_LIB_libgmodule_2 is not set
# FREETZ_LIB_libgthread_2 is not set
# Graphics & fonts
# FREETZ_LIB_libfreetype is not set
# FREETZ_LIB_libart_lgpl_2 is not set
# FREETZ_LIB_libexif is not set
# FREETZ_LIB_libjpeg is not set
# FREETZ_LIB_libpng12 is not set
# FREETZ_LIB_libgd is not set
# FREETZ_LIB_libopenjpeg is not set
# FREETZ_LIB_libnetpbm is not set
# Multi precision arithmetic libs
# FREETZ_LIB_libgmp is not set
# FREETZ_LIB_libmpfr is not set
# FREETZ_LIB_libmpc is not set
# Multimedia
# Audio and video codecs
# Audio codecs
# FREETZ_LIB_libFLAC is not set
# FREETZ_LIB_libmad is not set
# FREETZ_LIB_libogg is not set
# FFmpeg libraries
# FREETZ_LIB_libavcodec is not set
# FREETZ_LIB_libavdevice is not set
# FREETZ_LIB_libavfilter is not set
# FREETZ_LIB_libavformat is not set
# FREETZ_LIB_libavutil is not set
# FREETZ_LIB_libpostproc is not set
# FREETZ_LIB_libswresample is not set
# FREETZ_LIB_libswscale is not set
# Video codecs
# Vorbis video codec ---------------------
# FREETZ_LIB_libvorbis is not set
# FREETZ_LIB_libvorbisenc is not set
# FREETZ_LIB_libvorbisfile is not set
# ID3 tag reading libs
# FREETZ_LIB_libid3tag is not set
# FREETZ_LIB_libtag is not set
# ncurses
# FREETZ_LIB_libncurses is not set
# terminfo database
# Select terminfo database entries to install (see help of 'Show all items')
# FREETZ_SHARE_terminfo is not set
# FREETZ_LIB_libform is not set
# FREETZ_LIB_libmenu is not set
# FREETZ_LIB_libpanel is not set
# Networking
# ATM ------------------------------------
# FREETZ_LIB_libatm is not set
# Bluetooth ------------------------------
# FREETZ_LIB_libbluetooth is not set
# FREETZ_LIB_libopenobex is not set
# ISDN & CAPI ----------------------------
FREETZ_LIB_libcapi20=y
# Misc networking ------------------------
# FREETZ_LIB_libdnet is not set
# FREETZ_LIB_libpcap is not set
# FREETZ_LIB_libnet is not set
# FREETZ_LIB_liboping is not set
# FREETZ_LIB_libosip2 is not set
# FREETZ_LIB_libosipparser2 is not set
# Readline
# FREETZ_LIB_libreadline is not set
# FREETZ_LIB_libhistory is not set
# Regular expressions
# FREETZ_LIB_libpcre is not set
# FREETZ_LIB_libpcreposix is not set
# uClibc
FREETZ_LIB_ld_uClibc=y
FREETZ_LIB_libcrypt=y
FREETZ_LIB_libdl=y
FREETZ_LIB_libm=y
FREETZ_LIB_libnsl=y
FREETZ_LIB_libpthread=y
FREETZ_LIB_libresolv=y
FREETZ_LIB_librt=y
# FREETZ_LIB_libthread_db is not set
FREETZ_LIB_libuClibc=y
FREETZ_LIB_libutil=y
# USB & FTDI
# FREETZ_LIB_libusb is not set
# FREETZ_LIB_libusb_1 is not set
# FREETZ_LIB_libftdi is not set
# Web and WebDAV
# FREETZ_LIB_libcurl is not set
# FREETZ_LIB_libcurl_WITH_ZLIB is not set
# FREETZ_LIB_libjs is not set
# FREETZ_LIB_libneon is not set
# FREETZ_LIB_libneon_WITH_SSL is not set
# FREETZ_LIB_libneon_WITH_ZLIB is not set
# XML & XSLT
# FREETZ_LIB_libexpat is not set
# FREETZ_LIB_libxml2 is not set
# FREETZ_LIB_libxml2_WITH_HTML is not set
# FREETZ_LIB_libxslt is not set
# FREETZ_LIB_libexslt is not set
# FREETZ_LIB_libattr is not set
# FREETZ_LIB_libdbus is not set
FREETZ_LIB_libgcc_s=y
# FREETZ_LIB_libconfig is not set
# FREETZ_LIB_libdaemon is not set
# FREETZ_LIB_libdevmapper is not set
# FREETZ_LIB_libelf is not set
# FREETZ_LIB_libevent is not set
# FREETZ_LIB_libffi is not set
FREETZ_LIB_libctlmgr=y
FREETZ_LIB_libctlmgr_WITH_STRUCT_V3=y
# FREETZ_LIB_libmultid is not set
# FREETZ_LIB_libltdl is not set
# FREETZ_LIB_liblua is not set
FREETZ_LIB_libpopt=y
# FREETZ_LIB_libprotobuf_c is not set
# FREETZ_LIB_librrd is not set
# FREETZ_LIB_librrd_th is not set
# FREETZ_LIB_libslang is not set
# FREETZ_LIB_libsynce is not set
# FREETZ_LIB_libsysfs is not set
# FREETZ_LIB_libwx_baseu is not set
# Strip binaries, libs, modules and scripts
FREETZ_STRIP_BINARIES=y
# FREETZ_STRIP_LIBRARIES is not set
# FREETZ_STRIP_MODULES_NONE is not set
FREETZ_STRIP_MODULES_FREETZ=y
# FREETZ_STRIP_MODULES_ALL is not set
# FREETZ_STRIP_SCRIPTS is not set
# External
# EXTERNAL_ENABLED is not set
FREETZ_TARGET_ARCH_LE=y
FREETZ_TARGET_ARCH="mipsel"
FREETZ_TARGET_CROSS="mipsel-linux-uclibc-"
FREETZ_KERNEL_CROSS="mipsel-unknown-linux-gnu-"
# Toolchain options
FREETZ_DOWNLOAD_TOOLCHAIN=y
# FREETZ_BUILD_TOOLCHAIN is not set
# FREETZ_UCLIBC_0_9_28_BASED_BOX is not set
# FREETZ_UCLIBC_0_9_29_BASED_BOX is not set
# FREETZ_UCLIBC_0_9_30_BASED_BOX is not set
# FREETZ_UCLIBC_0_9_31_BASED_BOX is not set
FREETZ_UCLIBC_0_9_32_BASED_BOX=y
# Kernel toolchain options ----------------------------------
FREETZ_KERNEL_COMPILER_GCC_4_4=y
FREETZ_KERNEL_GCC_VERSION="4.4.7"
FREETZ_KERNEL_BINUTILS_VERSION="2.22"
# Target toolchain options ----------------------------------
FREETZ_TARGET_UCLIBC_VERSION_0_9_32=y
FREETZ_TARGET_COMPILER_GCC_4_5=y
# FREETZ_TARGET_COMPILER_GCC_4_6 is not set
FREETZ_STDCXXLIB_USE_UCLIBCXX=y
# FREETZ_STDCXXLIB_USE_GNULIBSTDCXX is not set
FREETZ_TARGET_UCLIBC_VERSION="0.9.32.1"
FREETZ_TARGET_GCC_VERSION="4.5.3"
FREETZ_GNULIBSTDCXX_VERSION="6.0.14"
FREETZ_STDCXXLIB="uclibcxx"
FREETZ_TARGET_BINUTILS_VERSION="2.22"
FREETZ_TARGET_UCLIBC_REF="mod"
FREETZ_TARGET_CFLAGS="-Os -pipe -Wa,--trap"
# FREETZ_TARGET_UCLIBC_REDUCED_LOCALE_SET is not set
# FREETZ_TARGET_NLS is not set
FREETZ_TARGET_LFS=y
# FREETZ_TARGET_TOOLCHAIN is not set
# Both kernel and target toolchain related options ----------
# FREETZ_TOOLCHAIN_STATIC is not set
FREETZ_TOOLCHAIN_MINIMIZE_REQUIRED_GLIBC_VERSION=y
# FREETZ_TOOLCHAIN_32BIT is not set
# FREETZ_TOOLCHAIN_CCACHE is not set
