H
HabNeFritzbox
Guest
hat noch wer Problem dass nach Update auf aktuelle Version von Tor dieser nicht mehr erreichbar ist?
Ich nutze ganze im Docker mit Alpine, mit Repo von 3.12 oder 3.13 kommt man auf 0.4.4.9 und ist erreichbar, jedoch nicht mehr unterstützt.
Wenn ich auf neuere Version gehe, egal ob auf aktuelle 3.14 oder edge Repo, dann ist Version unterstützt aber nicht mehr erreichbar.
Aug 29 13:58:56.982 [notice] Tor 0.4.4.9 running on Linux with Libevent 2.1.12-stable, OpenSSL 1.1.1l, Zlib 1.2.11, Liblzma 5.2.5, and Libzstd 1.4.9.
Aug 29 13:59:00.000 [warn] Please upgrade! This version of Tor (0.4.4.9) is not recommended, according to the directory authorities. Recommended versions are: 0.3.5.10,0.3.5.11,0.3.5.12,0.3.5.13,0.3.5.14,0.3.5.15,0.3.5.16,0.4.5.1-alpha,0.4.5.2-alpha,0.4.5.3-rc,0.4.5.4-rc,0.4.5.5-rc,0.4.5.6,0.4.5.7,0.4.5.8,0.4.5.9,0.4.5.10,0.4.6.1-alpha,0.4.6.2-alpha,0.4.6.3-rc,0.4.6.4-rc,0.4.6.5,0.4.6.6,0.4.6.7
Aug 29 13:59:17.000 [notice] Starting with guard context "default"
Aug 29 13:59:18.000 [notice] Guessed our IP address as x.x.x.x (source: y.y.y.y).
Aug 29 13:59:18.000 [notice] Bootstrapped 5% (conn): Connecting to a relay
Aug 29 13:59:19.000 [notice] Bootstrapped 100% (done): Done
Aug 29 13:59:19.000 [notice] Now checking whether ORPort x.x.x.x:9001 is reachable... (this may take up to 20 minutes -- look for log messages indicating success)
Aug 29 13:59:20.000 [notice] Self-testing indicates your ORPort is reachable from the outside. Excellent. Publishing server descriptor.
Aug 29 13:59:22.000 [notice] Performing bandwidth self-test...done.
Aug 29 14:31:45.422 [notice] Tor 0.4.5.10 running on Linux with Libevent 2.1.12-stable, OpenSSL 1.1.1l, Zlib 1.2.11, Liblzma 5.2.5, Libzstd 1.4.9 and Unknown N/A as libc.
Aug 29 14:31:47.000 [notice] Bootstrapped 0% (starting): Starting
Aug 29 14:32:07.000 [notice] Starting with guard context "default"
Aug 29 14:32:08.000 [notice] Bootstrapped 5% (conn): Connecting to a relay
Aug 29 14:32:08.000 [notice] Unable to find IPv4 address for ORPort 9001. You might want to specify IPv6Only to it or set an explicit address or set Address.
Aug 29 14:32:08.000 [notice] External address seen and suggested by a directory authority: x.x.x.x
Aug 29 14:34:08.000 [notice] Now checking whether IPv4 ORPort x.x.x.x:9001 is reachable... (this may take up to 20 minutes -- look for log messages indicating success)
[warn]Your server has not managed to confirm reachability for its ORPort(s) at x.x.x.x:9001. Relays do not publish descriptors until their ORPort and DirPort are reachable. Please check your firewalls, ports, address, /etc/hosts file
