(AVM) EVA Revision: 1.190 Version: 1190
(C) Copyright 2005 AVM Date: Nov 15 2006 Time: 16:53:42 (3) 2 0-1011
[FLASH:] MACRONIX Top-Flash 4MB
[FLASH:](Eraseregion [0] 63 sectors a 64kB)
[FLASH:](Eraseregion [1] 8 sectors a 8kB)
[SYSTEM:] OHIO on 211MHz/125MHz
Eva_AVM >AVM decompress Kernel:
...........done
start kernel
[ohio_pre_init] System Clk = 62500000 Hz
)�Linux version 2.6.13.1-ohio () (gcc version 3.4.6) #1 Sat Jun 13 17:42:34 CEST 2009
memsize=32 MByte
flashsize=4 MByte
&_end=0x94258b64 PFN_ALIGN(&_end)=0x94259000 CPHYSADDR(PFN_ALIGN(&_end))=0x14259000 memsize=0x2000000
CPU revision is: 00018448
[ohio_gpio_init]
Determined physical RAM map:
memory: 00259000 @ 14000000 (reserved)
memory: 01da7000 @ 14259000 (usable)
On node 0 totalpages: 8192
[alloc_node_mem_map] reduce size from 2883616 Bytes to 262176 Bytes
[alloc_node_mem_map]: (org) sizeof(mem_map) = 262176 mem_map=0x9425c000-0x9429c020
[alloc_node_mem_map]: sizeof(mem_map) = 2883616 mem_map=0x93fdc000-0x9429c020
zone=0 zone_size[j]=0x90112
realsize=8192
DMA zone: 8192 pages, LIFO batch:3
zone=1 zone_size[j]=0x0
realsize=0
Normal zone: 0 pages, LIFO batch:1
zone=2 zone_size[j]=0x0
realsize=0
HighMem zone: 0 pages, LIFO batch:1
Built 1 zonelists
Kernel command line: init=/etc/init.d/rc.usbroot usbroot=/dev/sda1:ext2:/rootfs rw,noatime,nodiratime console=ttyS0,38400n8r
[ld_mmu_r4xx0] memcpy((void *)(CAC_BASE + 0x100), &except_vec2_generic, 0x30)
Primary instruction cache 16kB, physically tagged, 4-way, linesize 16 bytes.
Primary data cache 8kB, 4-way, linesize 16 bytes.
Synthesized TLB refill handler (20 instructions). Base=0x9421af74
TLB synthesizer field overflow (simm)
Synthesized TLB load handler fastpath (34 instructions) Base=0x9421e620.
Synthesized TLB store handler fastpath (34 instructions) Base=0x9421e820.
Synthesized TLB modify handler fastpath (33 instructions) Base=0x9421ea20.
PID hash table entries: 256 (order: 8, 4096 bytes)
CPU frequency 211.97 MHz
Using 105.984 MHz high precision timer.
[setup_irq]: irq 255 irqaction->handler 0x94043050 (no_action+0x0/0x8 )
[register_console] enable commandline console 0
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Memory: 29988k/30364k available (1647k kernel code, 320k reserved, 396k data, 116k init, 0k highmem)
totalram_pages= 7511
Calibrating delay loop... 211.35 BogoMIPS (lpj=1056768)
loops_per_jiffy=1056768
Mount-cache hash table entries: 512
Checking for 'wait' instruction... available.
NET: Registered protocol family 16
Can't analyze prologue code at 9419a49c
squashfs: version 3.3 (2007/10/31) Phillip Lougher
Initializing Cryptographic API
avm_net_trace: Up and running.
[avm_power]Ohio250 detected -> overclocking possible
[avm] configured: watchdog eventled enable shift register enable direct gpio
gpio usage: reset=12 clock=13 store=10 data=9
AR7WDT: Watchdog Driver for AR7 Hardware (Version 1.0, build: Jun 13 2009 17:41:05)
Serial: 8250/16550 driver $Revision: 1.90 $ 1 ports, IRQ sharing disabled
[uart_add_one_port]
ttyS0 at MMIO 0x0 (irq = 15) is a OHIO_UART
[uart_add_one_port] dont register console port->type = 16
port->cons = 0x941de070 port->cons->flags = 0x7
[uart_add_one_port] success
io scheduler noop registered
[cpmac] [cpmac_if_register] dev cpmac0 (phy_id 0) registered
tun: Universal TUN/TAP device driver, 1.6
tun: (C) 1999-2004 Max Krasnyansky <[email protected]>
physmap flash device: 400000 at 10000000
phys_mapped_flash: Found 1 x16 devices at 0x0 in 16-bit bank
[genprobe_ident_chips] 4 i 0 j 0
[genprobe_ident_chips] 5 i 0 j 1
Amd/Fujitsu Extended Query Table at 0x0040
phys_mapped_flash: Swapping erase regions for broken CFI table.
number of CFI chips: 1
RedBoot partition parsing not available
Generic platform RAM MTD, (c) 2004 Simtec Electronics
Ohio flash driver (size->0x400000 mem->0x10000000)
flash_size=0x400000
flash_mask=0x7fffff
Ohio flash memory: Found 1 x16 devices at 0x0 in 16-bit bank
Ohio flash memory: Swapping erase regions for broken CFI table.
nuen_filesystem]: super block found: bytes_used: 0x0/3168983
[init_ohio_flash] find hidden filesystem size=0x306000 offset=0xba000
[mtd] configure jffs2 partition
[mtd] fs_size=0x3b0000 max=0x0 is=0x200000 max jffs2_size value 0
[mtd] ERROR jffs2_size too big, reduce to max
[mtd] ohio_flash_map: name=Ohio flash memory bankwidth=2 virt=0xb0000000 phys=0x10000000 size=0x400000
Creating 5 MTD partitions on "Ohio flash memory":
0x000ba000-0x003c0000 : "filesystem"
'nor-flash'
'Bits can be cleared (flash)'
'Has an erase function'
mtd: partition "filesystem" doesn't start on an erase block boundary -- force read-only
0x00010000-0x003c0000 : "kernel"
'nor-flash'
0x00000000-0x00010000 : "bootloader"
'nor-flash'
0x003c0000-0x003e0000 : "tffs (1)"
'nor-flash'
0x003e0000-0x00400000 : "tffs (2)"
'nor-flash'
partition_info[0]: name=filesystem offset=ba000 size=306000
partition_info[0]: 0xb00ba000: 0x73717368 0x5f9
partition_info[1]: name=kernel offset=10000 size=3b0000
partition_info[1]: 0xb0010000: 0xfeed1281 0xa9faf
partition_info[2]: name=bootloader offset=0 size=10000
partition_info[2]: 0xb0000000: 0x40809000 0x40809800
partition_info[3]: name=tffs (1) offset=3c0000 size=20000
partition_info[3]: 0xb03c0000: 0x40001 0x87f1ffff
partition_info[4]: name=tffs (2) offset=3e0000 size=20000
partition_info[4]: 0xb03e0000: 0x40001 0x86f1ffff
NET: Registered protocol family 2
IP route cache hash table entries: 512 (order: -1, 2048 bytes)
TCP established hash table entries: 2048 (order: 2, 16384 bytes)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 2048 bind 2048)
TCP reno registered
TCP bic registered
mcfw: IGMPv3 fast forwarding
NET: Registered protocol family 17
NET: Registered protocol family 8
NET: Registered protocol family 20
802.1Q VLAN Support v1.8 Ben Greear <[email protected]>
All bugs added by David S. Miller <[email protected]>
[setup_irq]: irq 1 irqaction->handler 0x94001590 (dummy_timer_irq+0x0/0x14 )
[setup_irq]: irq 6 irqaction->handler 0x940015a4 (dummy_system_irq_2+0x0/0x14 )
[ohio_late_init]
[avm_new] push_button_gpio=8 value=1 enabled
TFFS: tiny flash file system driver. GPL (c) AVM Berlin (Version 2.0)
mount on mtd4 and mtd5 (double buffering)
Adam2 environment variables API installed.
[prepare_namespace] new mount root /dev/mtdblock1
NumProbs = 7990 / 2 -> 15980
VFS: Mounted root (squashfs filesystem) readonly.
Freeing prom memory: 0kb freed
Freeing unused kernel memory: 116k freed (7540 free)
[setup_irq]: irq 15 irqaction->handler 0x940e0b2c (serial8250_interrupt+0x0/0x13c )
3*** /etc/init.d/rc.usbroot called as an init process, start setting up USB root ... ***
TFFS Name Table E
*** Mounting USB root ... ***
Piglet: module license '
(C) Copyright 2005 by AVM
' taints kernel.
[avm_new]push_button 'Wlan-Taster', released: GPIO=8 presses=2000 key=button_key_2
[setup_irq]: irq 9 irqaction->handler 0xc00c1490 (ahci_irq+0x0/0x880 [usbahcicore] )
sda: sda1 sda2 sda3
waiting 15 seconds for usb to come up
dev queue removable sda2 size
device range sda1 sda3 stat
*** Checking filesystem on /dev/sda1. ***
/dev/sda1: Superblock last mount time is in the future. FIXED.
/dev/sda1: Superblock last write time is in the future. FIXED.
/dev/sda1: clean, 2736/16064 files, 50075/64228 blocks
*** Pivoting to USB root ... ***
*** USB root pivoting succeeded, done. ***
*** Switching to init ... ***
init started: BusyBox v1.12.4 (2009-06-13 20:06:39 CEST)
rootdir=/
table='/etc/device.table'
makedevs: line 13: can't create node dev/console: File exists
AR7WDT: System Init UEberwachung 240 Sekunden
HWRevision 117
ProductID Fritz_Box_3170
SerialNumber 0000000000000000
annex B
autoload yes
bootloaderVersion 1.190
bootserport tty0
bluetooth
cpufrequency 211968000
firstfreeaddress 0x946AE878
firmware_version avm
firmware_info 49.04.70
flashsize 0x00400000
kernel_args init=/etc/init.d/rc.usbroot
kernel_args1 usbroot=/dev/sda1:ext2:/rootfs rw,noatime,nodiratime
maca 00:1F:3F:C8:8D:CF
macb 00:1F:3F:C8:8D:D0
macwlan 00:1F:3F:A6:6C:E7
macdsl 00:1F:3F:C8:8D:D1
memsize 0x02000000
modetty0 38400,n,8,1,hw
modetty1 38400,n,8,1,hw
mtd0 0x90000000,0x90000000
mtd1 0x90010000,0x903C0000
mtd2 0x90000000,0x90010000
mtd3 0x903C0000,0x903E0000
mtd4 0x903E0000,0x90400000
my_ipaddress 192.168.178.1
prompt Eva_AVM
ptest
reserved
req_fullrate_freq 125000000
sysfrequency 125000000
urlader-version 1190
usb_board_mac 00:1F:3F:C8:8D:D2
usb_rndis_mac 00:1F:3F:C8:8D:D3
usb_device_id 0x3C00
usb_revision_id 0x0300
usb_device_name USB DSL Device
usb_manufacturer_name AVM
wlan_key XXXXXXXXXXXXXXXXXX
wlan_cal bla,bla,blah,bla...
mknod: /var/flash/ar7.cfg: File exists
Loading /var/flash/freetz...done.
Loading users, groups and passwords...done.
Loading hosts...done.
Loading config...done.
Loading modules...done.
[jffs2] xx=
TAM: create JFFS2 directory /data/tam
TAM Defaults: /etc/default.Fritz_Box_3170/avm/config.tam not found!
attempting to load DSL Firmware '/lib/modules/microvoip-dsl.bin'
**** ANNEX: 'B'
setting DSL Firmware to Annex B
registered device TI Avalanche SAR
tiatm driver (patch_annex=0xc01670cc)
[tiatm] Set StrictPriority=0
DSP binary filesize = 329492 bytes
[dsl_ur8] dsl serial number successfully set to "465249545a21426f7820574c414e203331373000093030314633464338384444"
[tiatm] INFO V2U-BRIDGEREGISTER: 0x00000019
[avm_power]#### boostVoltage: DSP Core voltage set to 1,5 V ####
[setup_irq]: irq 23 irqaction->handler 0xc014d208 (tn7atm_sar_irq+0x0/0x30 [tiatm] )
[setup_irq]: irq 31 irqaction->handler 0xc014d238 (tn7atm_dsl_irq+0x0/0x28 [tiatm] )
[tiatm]: Powermanagment (States => 1,3,10) supported!
Texas Instruments ATM driver: version:[4.08.00.00]
[tiatm] AvmInterface length: 44
ubik2 driver (ubik2 - 0x10=0xc017cfd4)
atm_dsp_register_ubik2: ubik2_ToMIPS_notify=0xc016abfc
atm_dsp_register_ubik2: dsp mem pointer 0xa1c10b0c
ubik2_init_interface: DSP-Link Version v3 8480
/etc/init.d/rc.S: line 1209: /etc/hotplug/aura: not found
kdsldmod: init start (Feb 17 2009 09:12:31) sizeof(struct sk_buff)=176
kdsldmod: init done
MAC WLAN: 00:1F:3F:A6:6C:E7
WLAN is not enabled
ifconfig: SIOCGIFFLAGS: No such device
/etc/init.d/rc.net: line 413: websrv: not found
[avm_power] : ethernet port 0 status 2
[avm_power] : ethernet port 1 status 1
[avm_power] : ethernet port 2 status 1
[avm_power] : ethernet port 3 status 1
[setup_irq]: irq 27 irqaction->handler 0x940f183c (cpmac_main_isr+0x0/0x78 )
[cpmac] cpmac_main_ioctl, unknown ioctl 35142
device cpmac0 entered promiscuous mode
device eth0 entered promiscuous mode
lan: port 1(eth0) entering learning state
lan: topology change detected, propagating
lan: port 1(eth0) entering forwarding state
[tiatm] DSL in training!
checkempty: : No such file or directory
/etc/init.d/rc.net: line 1: tr069discover: not found
error: could not load /usr/bin/capiotcp_server
run_clock demoAR7WDT: System Init UEberwachung abgeschlossen (219640 ms noch verfuegbar)
n started
/etc/init.d/rc.S: /var/flash/debug.cfg: line 1: /var/media/ftp/MassStorageDevice-Partition-0-1/busybox: not found
SysRq : Changing Loglevel
Loglevel set to 4
Info: have to stop cat /dev/debug.
rc.mod version freetz-devel-3405M
crond is disabled
telnetd is started via inetd
httpd is started via inetd
Starting syslogd...done.
virtualip is disabled
Updating inetd config for dropbear: active.
Updating inetd config for rcapid: inactive.
Updating inetd config for telnetd: active.
Updating inetd config for vsftpd: active.
Updating inetd config for webcfg: active.
Updating inetd config for wol: active.
Reloading inetd...not running.
Writing /var/flash/freetz...done.
24064 bytes written.
Starting inetd...done.
Disk spindown is disabled
cifsmount is disabled
nfsd is disabled
checkmaild is disabled
/etc/init.d/rc.cpmaccfg: line 190: pre_config: not found
Setting switch_mode to 'normal' (1).
Setting WLAN to eth0
bridge wlan does not exist!
done.
Creating RSA and DSS host keys
Will output 1024 bit rsa secret key to '/tmp/flash/dropbear/rsa_host_key'
Generating key, this may take a while...
Exited: couldn't open random device
Will output 1024 bit dss secret key to '/tmp/flash/dropbear/dss_host_key'
dropbear is started via inetd
Privoxy is disabled
rcapid is disabled
Looking for group 'tor' ... found
Looking for user 'tor' ... found
tor is disabled
Looking for user 'ftp' ... found
vsftpd is started via inetd
httpd-wol is started via inetd
Looking for group 'openvpn' ... found
Looking for user 'openvpn' ... found
openvpn is disabled
Looking for user 'bittorrent' ... found
transmission is disabled
samba is disabled
rrdstats is disabled
WebDAV is disabled
hd-idle is disabled
inadyn-mt is disabled
Looking for group 'wwwrun' ... found
Looking for user 'wwwrun' ... found
lighttpd is disabled
ser2net is disabled
Starting swap...failed.
