# Aug 13 17:09:24 voipd[436]: incoming(5:appl=5 plci=0x1105 ncci=0x0 incoming): 10 0049711xxxx <- 0
Aug 13 17:09:24 voipd[436]: telapp_incoming - running (voip=0)
Aug 13 17:09:24 voipd[436]: 0: connected vcc 1/32/PPPoE/32 stay online 1
Aug 13 17:09:24 voipd[436]: 0: ip 217.9.27.154/217.9.24.1 mtu 1492 dns 217.9.16.25/217.9.16.24
Aug 13 17:09:24 voipd[436]: VoIP led value = 18
Aug 13 17:09:24 voipd[436]: allowed bandwidth 80000 for sip:[email protected]
Aug 13 17:09:24 voipd[436]: [email protected]: bandwidth left 80000
Aug 13 17:09:24 voipd[436]: >>>UDP Request: INVITE sip:[email protected]
Aug 13 17:09:24 voipd[436]: <<<UDP Status: 407 Proxy Authentication Required
Aug 13 17:09:24 voipd[436]: >>>UDP Request: ACK sip:[email protected]
Aug 13 17:09:24 voipd[436]: <<<UDP Status: 100 trying -- your call is important to us
Aug 13 17:09:25 voipd[436]: <<<UDP Status: 488 Not acceptable here
Aug 13 17:09:25 voipd[436]: >>>UDP Request: ACK sip:[email protected]
Aug 13 17:09:25 voipd[436]: VoIP led value = 1
Aug 13 17:09:25 voipd[436]: ocfree: fail 0 normal 0 small 0 large 0
Aug 13 17:09:25 voipd[436]: underrun 0 max_ackqueuelen 0
Aug 13 17:09:25 voipd[436]: small packets merged 0, output 0 and consumed from CNG 0
Aug 13 17:09:25 voipd[436]: ocmode: normal 0 merged 0 delayed 0
Aug 13 17:09:25 voipd[436]: dropped 0 packets with 0 samples and one sample in 0 packets
Aug 13 17:09:25 voipd[436]: generated noise: oben 0/unten <=0
Aug 13 17:09:25 voipd[436]: CONNECT_RESP with sip value 488
Aug 13 17:09:25 voipd[436]: call to sip:[email protected] terminated (488)
Aug 13 17:09:25 voipd[436]: EVENT(78): Internettelefonie mit 0049711xxxx ³ber sipsnip.com war nicht erfolgreich. Ursa
che: Not acceptable here (488)
Aug 13 17:09:26 voipd[436]: <<<UDP Status: 488 Not acceptable here
Aug 13 17:09:26 voipd[436]: >>>UDP Request: ACK sip:[email protected]
Aug 13 17:09:28 voipd[436]: <<<UDP Status: 488 Not acceptable here
Aug 13 17:09:28 voipd[436]: >>>UDP Request: ACK sip:[email protected]
Aug 13 17:09:32 voipd[436]: <<<UDP Status: 488 Not acceptable here
Aug 13 17:09:32 voipd[436]: no transaction for status: 488 Not acceptable here
Aug 13 17:09:35 voipd[436]: disconnected(appl=5 plci=0x1105 ncci=0x0 incoming): remote: 0x3490 (0x0000) -
Aug 13 17:09:36 voipd[436]: <<<UDP Status: 488 Not acceptable here
Aug 13 17:09:36 voipd[436]: no transaction for status: 488 Not acceptable here
Aug 13 17:09:40 voipd[436]: <<<UDP Status: 488 Not acceptable here
Aug 13 17:09:40 voipd[436]: no transaction for status: 488 Not acceptable here
Aug 13 17:09:44 voipd[436]: <<<UDP Status: 488 Not acceptable here
Aug 13 17:09:44 voipd[436]: no transaction for status: 488 Not acceptable here
Aug 13 17:09:48 voipd[436]: <<<UDP Status: 488 Not acceptable here
Aug 13 17:09:48 voipd[436]: no transaction for status: 488 Not acceptable here
Aug 13 17:09:52 voipd[436]: <<<UDP Status: 488 Not acceptable here
Aug 13 17:09:52 voipd[436]: no transaction for status: 488 Not acceptable here
BusyBox v1.8.2 (2008-11-26 13:15:43 CET) built-in shell (ash)
Enter 'help' for a list of built-in commands.
ermittle die aktuelle TTY
tty is "/dev/pts/0"
Console Ausgaben auf dieses Terminal umgelenkt
options:
-? - print this help
-f - run in forground. (NOTSET)
-s - stop daemon. (NOTSET)
-v - verbose. (NOTSET)
-p STRING - Pidfile. ("/var/run/voipd.pid")
-o INTEGER - osip2 debug. (0)
-M STRING - log memory debug to .... (NULL)
-C INTEGER - capi trace. (0)
-N - no higher priority. (NOTSET)
-R - tell voipd to register now. (NOTSET)
-U - tell voipd to unregister and disconnect all calls now. (NOTSET)
-B INTEGER - overwrite output bandwidth. (0)
-T - Test. (NOTSET)
-8 - CAPI nur mit 8 kHz. (NOTSET)
-A - Send AOC to CAPI. (NOTSET)
-D STRING - switch debug logs on. (NULL)
# voipd -
option missing after '-'
usage: voipd voipd [options]
options:
-T - Test. (NOTSET)
Du meist sicherlich den Modus -D STRING...Wie der "-D DEBUG" switch funktioiert weiss ich auch nicht!
Wer Infos hat moege sie mittteilen.
Dann evtl. so versuchen, wie es cando mit NHIPT macht:Dabei kommt leider nichts sinnvolles raus. "cat" bricht immer ab wenn das device "leer" gecattet ist, was meistens nach ein paar Zeilen der Fall ist.
Wenn es um die Log - Funktion von NHIPT geht: sie macht weiter nichts, als die Ausgaben von /dev/debug in eine Log-Datei umzuleiten:
[COLOR=red][B]cat /dev/debug > /var/tmp/system.log[/B][/COLOR]
Die datei wird in einem zweiten Schritt durchsucht, und nur die iptables Einträge in die endgültige FW-Logdatei umkopiert.
