Hello,
Sometimes, after i upgrade my 7270 with a fresh new freetz firmware I cannot get access to it via telnet.
The message is:
"login incorrent"...
This is using "root" as username and "freetz" for password.
I try a reset to factory defaults, i try to build the firmware again and i try touse a recovery firmware and after upgrade with my freetz firmware, but the result is the same.
My config file:
Can someone help me?
Thanks in advance
Best regards
The message is:
My config file:
mainmenu "Freetz Configuration"
config FREETZ_HAVE_DOT_CONFIG
bool
default y
comment "General --------------------------------"
config FREETZ_AVM_VERSION_04_29
bool
config FREETZ_AVM_VERSION_04_30
bool
config FREETZ_AVM_VERSION_04_33
bool
config FREETZ_AVM_VERSION_04_40
bool
config FREETZ_AVM_VERSION_04_49
bool
config FREETZ_AVM_VERSION_04_57
bool
config FREETZ_AVM_VERSION_04_67
bool
config FREETZ_AVM_VERSION_04_70
bool
config FREETZ_AVM_VERSION_7270_04_67
bool
config FREETZ_AVM_VERSION_7270_04_70
bool
config FREETZ_AVM_VERSION_12043
bool
bool
config FREETZ_AVM_VERSION_r4884
bool
config FREETZ_AVM_VERSION_r7203
bool
config FREETZ_AVM_VERSION_r8508
bool
choice
prompt "Hardware type"
default FREETZ_TYPE_FON_WLAN_7270
help
Select your box type here.
config FREETZ_TYPE_300IP_AS_FON
select FREETZ_AVM_VERSION_04_49
bool "300IP as Fon"
config FREETZ_TYPE_2170
select FREETZ_AVM_VERSION_04_57
bool "2170"
config FREETZ_TYPE_FON
select FREETZ_AVM_VERSION_04_33 if FREETZ_TYPE_LANG_DE
select FREETZ_AVM_VERSION_04_49 if ! FREETZ_TYPE_LANG_DE
bool "Fon"
config FREETZ_TYPE_FON_5010
select FREETZ_AVM_VERSION_04_40
bool "Fon 5010"
config FREETZ_TYPE_FON_5050
bool "Fon 5050"
config FREETZ_TYPE_FON_5140
bool "Fon 5140"
config FREETZ_TYPE_FON_WLAN
bool "Fon WLAN"
config FREETZ_TYPE_FON_WLAN_7050
bool "Fon WLAN 7050"
config FREETZ_TYPE_FON_WLAN_7113
select FREETZ_AVM_VERSION_04_67
bool "Fon WLAN 7113"
config FREETZ_TYPE_FON_WLAN_7140
select FREETZ_AVM_VERSION_04_57 if FREETZ_TYPE_LANG_A_CH
select FREETZ_AVM_VERSION_04_67 if FREETZ_TYPE_LANG_EN
bool "Fon WLAN 7140"
config FREETZ_TYPE_FON_WLAN_7141
select FREETZ_AVM_VERSION_04_70
bool "Fon WLAN 7141"
config FREETZ_TYPE_FON_7150
bool "Fon 7150"
config FREETZ_TYPE_FON_WLAN_7170
select FREETZ_AVM_VERSION_04_70 if FREETZ_TYPE_LANG_DE
select FREETZ_AVM_VERSION_04_67 if ! FREETZ_TYPE_LANG_DE
bool "Fon WLAN 7170"
config FREETZ_TYPE_FON_WLAN_7240
select FREETZ_AVM_VERSION_7270_04_70
bool "Fon WLAN 7240"
config FREETZ_TYPE_FON_WLAN_7270
select FREETZ_AVM_VERSION_7270_04_70 if FREETZ_TYPE_LANG_DE
select FREETZ_AVM_VERSION_7270_04_67 if ! FREETZ_TYPE_LANG_DE
select FREETZ_TYPE_FON_WLAN_7270_16MB if ! FREETZ_TYPE_LANG_DE
bool "Fon WLAN 7270"
config FREETZ_TYPE_WLAN_3020
bool "WLAN 3020"
config FREETZ_TYPE_WLAN_3030
bool "WLAN 3030"
config FREETZ_TYPE_WLAN_3130
bool "WLAN 3130"
config FREETZ_TYPE_WLAN_3131
bool "WLAN 3131"
config FREETZ_TYPE_WLAN_3170
bool "WLAN 3170"
config FREETZ_TYPE_WLAN_3270
bool "WLAN 3270"
config FREETZ_TYPE_SPEEDPORT_W501V
select FREETZ_AVM_VERSION_r7203
bool "Speedport W501V"
config FREETZ_TYPE_SPEEDPORT_W701V
select FREETZ_AVM_VERSION_r8508
bool "Speedport W701V"
# config FREETZ_TYPE_SPEEDPORT_W900V
# select FREETZ_AVM_VERSION_r4884
# bool "Speedport W900V"
config FREETZ_TYPE_CUSTOM
bool "Custom"
depends on FREETZ_SHOW_ADVANCED
select FREETZ_DL_OVERRIDE
endchoice
config FREETZ_TYPE_FON_WLAN_7270_16MB
bool "16 MB flash"
depends on \
default n
help
Enable this to build an image for boxes with 16 MB flash.
config FREETZ_TYPE_LABOR
bool "Beta/Labor"
depends on \
FREETZ_TYPE_FON_WLAN_7170 || \
FREETZ_TYPE_FON_WLAN_7240 || \
default n
help
Enable this to compile the mod based on an AVM "beta/labor" firmware.
choice
prompt "Labor version"
depends on FREETZ_TYPE_LABOR
default FREETZ_TYPE_LABOR_AIO
# config FREETZ_TYPE_LABOR_AIO
# bool "AiO"
# depends on \
# FREETZ_TYPE_FON_WLAN_7170
config FREETZ_TYPE_LABOR_AURA
bool "Aura"
depends on \
config FREETZ_TYPE_LABOR_DSL
bool "DSL"
depends on \
FREETZ_TYPE_FON_WLAN_7270 \
config FREETZ_TYPE_LABOR_IPV6
bool "IPv6"
depends on \
select FREETZ_TARGET_IPV6_SUPPORT
config FREETZ_TYPE_LABOR_PHONE
bool "PHONE"
depends on \
config FREETZ_TYPE_LABOR_WLAN
bool "WLAN"
depends on \
endchoice
config FREETZ_TYPE_ALIEN_HARDWARE
bool "Compile image for \"alien\" hardware"
depends on \
default n
help
Enable this to compile the mod image for another hardware type
choice
prompt "Alien hardware type"
depends on FREETZ_TYPE_ALIEN_HARDWARE
#default FREETZ_TYPE_SINUS_W500V_7150 if FREETZ_TYPE_FON_7150
default FREETZ_TYPE_SPEEDPORT_W701V_7170 if FREETZ_TYPE_FON_WLAN_7170
#config FREETZ_TYPE_SINUS_W500V_7150
# bool "Sinus W500V"
# depends on FREETZ_TYPE_FON_7150
# select FREETZ_MODULE_jffs2
# help
# Enable this to compile a mod image for T-Com Sinus W500V based
# on a 7150 image.
config FREETZ_TYPE_SPEEDPORT_W701V_7170
bool "W701V"
depends on FREETZ_TYPE_FON_WLAN_7170
help
Enable this to compile a mod image for T-Com Speedport W701V based
on a 7170 image.
config FREETZ_TYPE_SPEEDPORT_W900V_7170
bool "W900V"
help
Enable this to compile a mod image for T-Com Speedport W900V based
on a 7170 image.
config FREETZ_TYPE_3170_7170
bool "3170"
help
Enable this to compile a mod image for FritzBox FON WLAN 3170 based
on a 7170 image.
config FREETZ_TYPE_7140_7170
bool "7140"
help
Enable this to compile a mod image for FritzBox FON WLAN 7140 based
on a 7170 image.
config FREETZ_TYPE_7141_7170
bool "7141"
help
Enable this to compile a mod image for FritzBox FON WLAN 7141 based
on a 7170 image.
endchoice
config FREETZ_AVM_VERSION_STRING
string
default "04.29" if FREETZ_AVM_VERSION_04_29
default "04.30" if FREETZ_AVM_VERSION_04_30
default "04.33" if FREETZ_AVM_VERSION_04_33
default "04.40" if FREETZ_AVM_VERSION_04_40
default "04.49" if FREETZ_AVM_VERSION_04_49
default "04.57" if FREETZ_AVM_VERSION_04_57
default "04.67" if FREETZ_AVM_VERSION_04_67
default "04.70" if FREETZ_AVM_VERSION_04_70
default "7270" if FREETZ_AVM_VERSION_7270
default "12043" if FREETZ_AVM_VERSION_12043
default "7270_04.67" if FREETZ_AVM_VERSION_7270_04_67
default "7270_04.70" if FREETZ_AVM_VERSION_7270_04_70
default "r4884" if FREETZ_AVM_VERSION_r4884
default "r7203" if FREETZ_AVM_VERSION_r7203
default "r8508" if FREETZ_AVM_VERSION_r8508
choice
prompt "Firmware language"
default FREETZ_TYPE_LANG_DE
config FREETZ_TYPE_LANG_DE
bool "de - deutsch"
depends on \
! FREETZ_TYPE_FON_5010
config FREETZ_TYPE_LANG_A_CH
bool "a-ch - deutsch"
depends on \
! FREETZ_TYPE_LABOR && \
! FREETZ_TYPE_ALIEN_HARDWARE && \
FREETZ_TYPE_FON_5010 || \
FREETZ_TYPE_FON_WLAN_7140 || \
config FREETZ_TYPE_LANG_EN
bool "en - international"
depends on \
FREETZ_TYPE_FON || \
FREETZ_TYPE_300IP_AS_FON || \
FREETZ_TYPE_FON_WLAN || \
endchoice
config FREETZ_TYPE_LANG_STRING
string
default "de" if FREETZ_TYPE_LANG_DE
default "a-ch" if FREETZ_TYPE_LANG_A_CH
default "en" if FREETZ_TYPE_LANG_EN
choice
prompt "Annex"
depends on FREETZ_TYPE_LANG_EN && \
! FREETZ_TYPE_FON_WLAN_7270
default FREETZ_TYPE_ANNEX_B
config FREETZ_TYPE_ANNEX_A
bool "A"
config FREETZ_TYPE_ANNEX_B
bool "B"
endchoice
config FREETZ_TYPE_STRING
string
default "300ip_as_fon" if FREETZ_TYPE_300IP_AS_FON
default "2170" if FREETZ_TYPE_2170 && ! FREETZ_TYPE_LABOR
default "3020" if FREETZ_TYPE_WLAN_3020
default "3030" if FREETZ_TYPE_WLAN_3030
default "3130" if FREETZ_TYPE_WLAN_3130
default "3131" if FREETZ_TYPE_WLAN_3131
default "3170" if FREETZ_TYPE_WLAN_3170
default "3270" if FREETZ_TYPE_WLAN_3270
default "fon" if FREETZ_TYPE_FON
default "5010" if FREETZ_TYPE_FON_5010
default "5050" if FREETZ_TYPE_FON_5050
default "5140" if FREETZ_TYPE_FON_5140
default "fon_wlan" if FREETZ_TYPE_FON_WLAN
default "7050" if FREETZ_TYPE_FON_WLAN_7050
default "7113" if FREETZ_TYPE_FON_WLAN_7113
default "7140" if FREETZ_TYPE_FON_WLAN_7140
default "7141" if FREETZ_TYPE_FON_WLAN_7141
default "7150" if FREETZ_TYPE_FON_7150
default "7170" if FREETZ_TYPE_FON_WLAN_7170 && ! FREETZ_TYPE_LABOR
default "7170_labor_aio" if FREETZ_TYPE_FON_WLAN_7170 && FREETZ_TYPE_LABOR_AIO
default "7170_labor_dsl" if FREETZ_TYPE_FON_WLAN_7170 && FREETZ_TYPE_LABOR_DSL
default "7240" if FREETZ_TYPE_FON_WLAN_7240 && ! FREETZ_TYPE_LABOR
default "7240_labor_phone" if FREETZ_TYPE_FON_WLAN_7240 && FREETZ_TYPE_LABOR_PHONE
default "7270" if FREETZ_TYPE_FON_WLAN_7270 && ! FREETZ_TYPE_LABOR
default "7270_labor_aura" if FREETZ_TYPE_FON_WLAN_7270 && FREETZ_TYPE_LABOR_AURA
default "7270_labor_dsl" if FREETZ_TYPE_FON_WLAN_7270 && FREETZ_TYPE_LABOR_DSL
default "7270_labor_ipv6" if FREETZ_TYPE_FON_WLAN_7270 && FREETZ_TYPE_LABOR_IPV6
default "7270_labor_phone" if FREETZ_TYPE_FON_WLAN_7270 && FREETZ_TYPE_LABOR_PHONE
default "7270_labor_wlan" if FREETZ_TYPE_FON_WLAN_7270 && FREETZ_TYPE_LABOR_WLAN
default "W501V" if FREETZ_TYPE_SPEEDPORT_W501V
default "W701V" if FREETZ_TYPE_SPEEDPORT_W701V
default "W900V" if FREETZ_TYPE_SPEEDPORT_W900V
default "custom" if FREETZ_TYPE_CUSTOM
config FREETZ_TYPE_STRING2
string
default "W500V_" if FREETZ_TYPE_SINUS_W500V_7150
default "W701V_" if FREETZ_TYPE_SPEEDPORT_W701V_7170
default "W900V_" if FREETZ_TYPE_SPEEDPORT_W900V_7170
default "3170_" if FREETZ_TYPE_3170_7170
default "7140_" if FREETZ_TYPE_7140_7170
default "7141_" if FREETZ_TYPE_7141_7170
comment "Custom options -------------------------"
depends on FREETZ_TYPE_CUSTOM
config FREETZ_INSTALL_BASE
bool
select FREETZ_LIB_ld_uClibc
select FREETZ_LIB_libcrypt
select FREETZ_LIB_libdl
select FREETZ_LIB_libgcc_s
select FREETZ_LIB_libm
select FREETZ_LIB_libnsl
select FREETZ_LIB_libpthread
select FREETZ_LIB_librt
select FREETZ_LIB_libuClibc
select FREETZ_LIB_libfreetz if FREETZ_HAS_USB_HOST
default y
help
This is mandatory
config FREETZ_REPLACE_BUSYBOX
bool
default y
help
This is mandatory
config FREETZ_REPLACE_KERNEL_AVAILABLE
bool
depends on \
( ! FREETZ_TYPE_LABOR || \
FREETZ_TYPE_LABOR_AIO && \
(FREETZ_TYPE_FON_WLAN_7170 || FREETZ_TYPE_FON_WLAN_7270) ) && \
! (FREETZ_TYPE_FON && FREETZ_TYPE_LANG_EN)
default y
bool "Replace kernel"
depends on \
FREETZ_SHOW_ADVANCED && \
default n
help
Replace AVM kernel with self-built kernel.
comment "Replace kernel (currently not available)"
depends on \
! FREETZ_REPLACE_KERNEL_AVAILABLE
config FREETZ_SHOW_ADVANCED
bool "Show advanced options"
default n
help
Show advanced Options for patching the firmware. This is only useful
for experienced users who really know what they are doing
config FREETZ_TARGET_IPV6_SUPPORT
bool "Enable IPv6 support"
depends on \
FREETZ_TYPE_LABOR_IPV6 || \
(FREETZ_SHOW_ADVANCED && \
FREETZ_REPLACE_KERNEL_AVAILABLE)
select FREETZ_REPLACE_KERNEL if ! FREETZ_TYPE_LABOR_IPV6
select FREETZ_MODULE_ipv6 if FREETZ_REPLACE_KERNEL
select FREETZ_BUILD_TOOLCHAIN
default n
help
Copies the ipv6 kernel module to the firmware and enables ipv6 support
in uClibc and busybox.
Shows additional options for busybox and iptables and other packages.
To use IPv6 with Fritz!Box, at least the kernel, ucLibc and busybox
have to be recompiled with IPv6 enabled.
The toolchain will automatically be rebuild to achieve this.
It is also recommended to include the package iptables/ip6tables for
firewall settings.
config FREETZ_TARGET_REF
string "Target ref" if FREETZ_TYPE_CUSTOM
default "8mb_26" if \
FREETZ_TYPE_SPEEDPORT_W701V || \
FREETZ_TYPE_SPEEDPORT_W900V || \
FREETZ_TYPE_FON_WLAN_7113 || \
FREETZ_TYPE_FON_WLAN_7141 || \
FREETZ_TYPE_FON_7150 || \
FREETZ_TYPE_FON_WLAN_7270 || \
default "4mb_26" if \
FREETZ_TYPE_2170 || \
FREETZ_TYPE_SPEEDPORT_W501V || \
FREETZ_TYPE_WLAN_3020 || \
FREETZ_TYPE_WLAN_3030 || \
FREETZ_TYPE_WLAN_3130 || \
FREETZ_TYPE_WLAN_3131 || \
FREETZ_TYPE_WLAN_3170 || \
FREETZ_TYPE_FON_5050 || \
FREETZ_TYPE_FON_5140 || \
config FREETZ_KERNEL_REF
string "Kernel ref" if FREETZ_TYPE_CUSTOM
config FREETZ_KERNEL_LAYOUT
default "ohio" if \
default "ar7" if \
FREETZ_TYPE_FON_WLAN_7050 || \
default "ur8" if \
config FREETZ_KERNEL_MTD_SIZE
int "Kernel (64K blocks)" if FREETZ_TYPE_CUSTOM
default 59 if \
FREETZ_TYPE_3170_7170 || \
default 119 if \
(FREETZ_TYPE_FON_WLAN_7270 && ! FREETZ_TYPE_FON_WLAN_7270_16MB) || \
FREETZ_TYPE_CUSTOM && FREETZ_HIDDEN_ROOT
default 246 if \
FREETZ_TYPE_WLAN_3270 || \
help
Number of 64K blocks in the kernel mtd device.
config FREETZ_FILESYSTEM_MTD_SIZE
int "Filesystem (64K blocks)" if FREETZ_TYPE_CUSTOM
depends on ! FREETZ_HIDDEN_ROOT || FREETZ_CONTIGUOUS_HIDDEN_ROOT
default 48 if FREETZ_TYPE_CUSTOM
help
Number of 64K blocks in the filesystem mtd device.
config FREETZ_HAS_PHONE
bool "Has Phone" if FREETZ_TYPE_CUSTOM
default y if \
FREETZ_TYPE_CUSTOM
default n if \
help
Select this if you have a box with phone support.
config FREETZ_HAS_TAM
bool "Has TAM" if FREETZ_TYPE_CUSTOM
depends on FREETZ_HAS_PHONE
default y if \
default n if \
FREETZ_TYPE_CUSTOM
help
Select this if you have a box with TAM (Telephone Answering Machine) support.
config FREETZ_HAS_WLAN
bool "Has WLAN" if FREETZ_TYPE_CUSTOM
default y if \
FREETZ_TYPE_CUSTOM
default n if \
help
Select this if you have a box with WLAN.
config FREETZ_HAS_USB_CLIENT
bool "USB client" if FREETZ_TYPE_CUSTOM
default y if \
default n if \
FREETZ_TYPE_CUSTOM
help
Select this if you have a box with USB.
config FREETZ_HAS_USB_HOST
bool "USB host" if FREETZ_TYPE_CUSTOM
default y if \
FREETZ_TYPE_FON_7150 && ! FREETZ_TYPE_SINUS_W500V_7150 || \
FREETZ_TYPE_FON_WLAN_7170 && ! FREETZ_TYPE_SPEEDPORT_W701V_7170 || \
default n if \
help
Select this if your USB port is a host adapter.
config FREETZ_HAS_AVM_INETD
bool "AVM inetd" if FREETZ_TYPE_CUSTOM
select FREETZ_BUSYBOX_INETD
default y if \
default n
help
Select this if your original firmware has inetd support.
comment "Mod ------------------------------------"
choice
prompt "Language"
default FREETZ_LANG_DE if FREETZ_TYPE_LANG_DE
default FREETZ_LANG_DE if FREETZ_TYPE_LANG_A_CH
default FREETZ_LANG_EN if FREETZ_TYPE_LANG_EN
config FREETZ_LANG_DE
bool "de - deutsch"
config FREETZ_LANG_EN
bool "en - english"
endchoice
config FREETZ_LANG_STRING
string
default "de" if FREETZ_LANG_DE
default "en" if FREETZ_LANG_EN
menu "Patches"
comment "No Brandings available to remove"
depends on \
menu "Remove Brandings"
depends on \
! FREETZ_TYPE_SPEEDPORT_W501V && \
! FREETZ_TYPE_SPEEDPORT_W701V && \
! FREETZ_TYPE_SPEEDPORT_W900V
comment "avm and tcom branding can't be removed"
depends on \
config FREETZ_REMOVE_BRANDING_1und1
bool "1&1"
depends on \
FREETZ_TYPE_LANG_DE && \
FREETZ_TYPE_CUSTOM \
default n
help
1&1 branding
Each branding provides the web UI templates for a certain manufacturer or OEM.
NOTE: Make sure not to remove the branding corresponding to the one defined
in your box's boot loader environment. It can be determined by calling the
following command from the box's shell prompt:
echo $(cat /proc/sys/urlader/firmware_version)
config FREETZ_REMOVE_BRANDING_avm
bool "AVM"
depends on \
FREETZ_TYPE_LANG_A_CH || \
FREETZ_TYPE_LANG_DE || \
&& ! FREETZ_TYPE_ALIEN_HARDWARE
default n
help
AVM branding
config FREETZ_REMOVE_BRANDING_avme
bool "AVM international"
depends on \
FREETZ_TYPE_LANG_EN || \
default n
help
AVM international branding
config FREETZ_REMOVE_BRANDING_aol
bool "AOL"
depends on \
default n
help
AOL branding
config FREETZ_REMOVE_BRANDING_arcor
bool "Arcor"
default n
help
Arcor branding
config FREETZ_REMOVE_BRANDING_congstar
bool "Congstar"
depends on \
default n
help
Congstar branding
config FREETZ_REMOVE_BRANDING_freenet
bool "Freenet"
depends on \
default n
help
Freenet branding
#config FREETZ_REMOVE_BRANDING_tcom
# bool "T-Com"
# depends on \
# FREETZ_TYPE_LANG_DE && \
# FREETZ_TYPE_300IP_AS_FON || \
# FREETZ_TYPE_SPEEDPORT_W501V || \
# FREETZ_TYPE_SPEEDPORT_W701V || \
# FREETZ_TYPE_SPEEDPORT_W900V || \
# FREETZ_TYPE_ALIEN_HARDWARE \
# default n
# help
# T-Com branding
# Each branding provides the web UI templates for a certain manufacturer or OEM.
# NOTE: Make sure not to remove the branding corresponding to the one defined
# in your box's boot loader environment. It can be determined by calling the
# following command from the box's shell prompt:
# echo $(cat /proc/sys/urlader/firmware_version)
config FREETZ_REMOVE_BRANDING_versatel
bool "Versatel"
depends on \
default n
help
Versatel branding
endmenu
config FREETZ_REMOVE_HELP
bool "Remove help"
default n
help
Removes the help pages from the web menu.
config FREETZ_REMOVE_ASSISTANT
bool "Remove assistant"
default n
depends on \
( ! ( FREETZ_TYPE_FON_WLAN_7140 && FREETZ_TYPE_LANG_EN ) ) && \
( ! ( FREETZ_TYPE_FON_WLAN_7170 && FREETZ_TYPE_LANG_EN ) )
help
Removes the installation assistant from the web menu.
config FREETZ_REMOVE_TR069
bool "Remove tr069 stuff"
depends on \
default n
help
Removes libtr069 to save space.
WARNING: Removing tr069-stuff without disabling it
on the box causes permanent reboots until the box
is recovered
config FREETZ_REMOVE_USB_MODULE
bool "Remove avalanche_usb.ko"
depends on \
FREETZ_TYPE_FON_WLAN_7050 \
default n
help
Removes avalanche_usb.ko to save space.
config FREETZ_REMOVE_CDROM_ISO
bool "Remove cdrom.iso"
depends on \
FREETZ_HAS_USB_CLIENT && \
! FREETZ_TYPE_2170 && \
! FREETZ_TYPE_FON_WLAN_7050 && \
! FREETZ_TYPE_WLAN_3130 && \
! FREETZ_TYPE_WLAN_3131 && \
! FREETZ_TYPE_WLAN_3170 \
default n
help
Removes the file /lib/modules/cdrom.iso.
config FREETZ_PATCH_ATA
bool "Patch ATA"
depends on \
default n
help
Patches the ATA mode configuration pages into the web menu.
config FREETZ_PATCH_DSL_EXPERT
bool "Patch extended DSL-Settings"
depends on \
! FREETZ_TYPE_LABOR_DSL && \
! FREETZ_REMOVE_DSLD && \
(FREETZ_TYPE_FON_WLAN_7170 || FREETZ_TYPE_FON_WLAN_7240 || FREETZ_TYPE_FON_WLAN_7270)
default n
help
Patches the extended dsl-settings from labor-dsl into all-in-one-firmwares.
config FREETZ_PATCH_VCC
bool "Patch 2. VCC"
depends on FREETZ_HAS_PHONE && \
(FREETZ_TYPE_FON_WLAN_7141 || FREETZ_TYPE_FON_WLAN_7170)
default n
help
Patches the setting for 2. VCC into web menu. This patch also replaces
and activates "Patch enum" feature for brandings 1und1 and tcom.
Be aware that enum section is not displayed if you switch to avm
branding!
config FREETZ_PATCH_ENUM
bool "Patch enum"
depends on FREETZ_HAS_PHONE && ! FREETZ_PATCH_VCC
default n
help
Patches the enum configuration pages into the web menu.
#config FREETZ_PATCH_INTERNATIONAL
# bool "Patch international"
# depends on FREETZ_HAS_PHONE && FREETZ_TYPE_LANG_DE && ! FREETZ_TYPE_SPEEDPORT_W900V
# default y
# help
# Reveals some options from the international firmware in the web menu.
config FREETZ_PATCH_SIGNED
bool "Patch web menu signed message"
default n
help
Hides the "unsupported changes" message from the web interface.
config FREETZ_PATCH_USBSTORAGE
bool "Patch USB storage names, make FAT filesystems world-writable, automount feature"
depends on \
FREETZ_HAS_USB_HOST #&& \
#! FREETZ_TYPE_SPEEDPORT_W701V_7170
default y
help
1. Change the name of USB storage dir to uStorXY
2. Auto-mounted USB storage devices will be fully accessible, i.e. it
is now possible to put user home directories for (e.g. for FTP) on a
FAT32-formatted partition and permit shell and FTP users to actually
write to their own home directories.
3. Avoid deleting whole filesystem on usb devices.
It is highly recommended to select this patch.
config FREETZ_USBSTORAGE_AUTOMOUNT
bool "Automount filesystems"
depends on FREETZ_PATCH_USBSTORAGE
select FREETZ_PACKAGE_FSTYP
default y
help
ext2, ext3, fat and ntfs filesystems are mounted automatically. Detection is done
by fstyp utility (adds about 8KB uncompressed size). It depends on the original
firmware wich of the following points you have to select.
config FREETZ_AUTOMOUNT_EXT2
bool "ext2"
depends on FREETZ_USBSTORAGE_AUTOMOUNT
select FREETZ_MODULE_ext2
default n
help
This adds ext2 module to your firmware.
config FREETZ_AUTOMOUNT_EXT3
bool "ext3"
select FREETZ_MODULE_ext3
default n
help
This adds ext3 module to your firmware.
config FREETZ_AUTOMOUNT_NTFS
bool "NTFS"
select FREETZ_PACKAGE_NTFS
default n
help
This adds ntfs-3g mount helper to your firmware.
config FREETZ_AUTOMOUNT_REISER_FS
bool "ReiserFS"
select FREETZ_MODULE_reiserfs
default n
help
This adds reiserfs module to your firmware.
config FREETZ_AUTORUN_AUTOEND
bool "Execute autorun.sh/autoend.sh script on (un)mount"
depends on FREETZ_HAS_USB_HOST
default n
help
Useful to start/terminate applications located on USB devices, eg apache,
samba or even swapfiles.
config FREETZ_PATCH_MAXDEVCOUNT
bool "Raise the count of connectable usb device to 9"
default n
help
Use this patch if you would connect more than 3 device to the box
config FREETZ_PATCH_GETCONS
bool "Don't redirect console messages"
default n
help
Patch /etc/profile so that console messages are not redirected to
/dev/pts/0. These can sometimes be very anoying.
config FREETZ_REMOVE_WEBSRV
bool "Replace AVM web server by httpd"
depends on \
! FREETZ_TYPE_2170 \
&& ! FREETZ_TYPE_FON_5140 \
&& ! ( FREETZ_TYPE_FON_WLAN_7140 && FREETZ_TYPE_LANG_EN ) \
&& ! ( FREETZ_TYPE_FON_WLAN_7140 && FREETZ_TYPE_LANG_A_CH ) \
&& ! ( FREETZ_TYPE_FON && FREETZ_TYPE_LANG_EN ) \
&& ! ( FREETZ_TYPE_300IP_AS_FON && FREETZ_TYPE_LANG_EN ) \
&& ! ( FREETZ_TYPE_FON_WLAN && FREETZ_TYPE_LANG_EN ) \
&& ! FREETZ_TYPE_FON_WLAN_7141 \
&& ! FREETZ_TYPE_FON_WLAN_7170 \
&& ! FREETZ_TYPE_FON_WLAN_7240 \
&& ! FREETZ_TYPE_FON_WLAN_7270 \
&& ! FREETZ_TYPE_WLAN_3131 \
&& ! FREETZ_TYPE_WLAN_3170
default n
help
Patch init scripts so BusyBox's httpd is used instead of AVM's websrv.
The websrv binary will be removed from the firmware image.
If "Remove UPnP daemon (igdd)" patch is also selected and "Integrate
Media Server from USB Labor firmware" is not selected, 'libwebsrv.so'
will also be removed, because only those three binaries use it.
config FREETZ_REMOVE_UPNP
bool "Remove UPnP daemon (igdd)"
select FREETZ_REMOVE_UPNP_LIBS if \
&& ! FREETZ_TYPE_WLAN_3170 \
default n
help
Remove Universal Plug'n'Play daemon 'igdd' and some more files used by
it from firmware. Patch init scripts so they can cope with the
non-existent binary.
ATTENTION: Fritz!Fax relies on UPnP.
Make sure you deactivate all UPnP features in the web menu
before updating the firmware with this option. It may not be harmful
not to deactivate it, but there is no guarantee. You can find the
settings in the German web UI under
Einstellungen
System
Netzwerkeinstellungen
Statusinformationen über UPnP übertragen (empfohlen)
config FREETZ_REMOVE_UPNP_LIBS
bool
depends on FREETZ_REMOVE_UPNP
default n
config FREETZ_REMOVE_USERMAN
bool "Remove usermand and userman.ko - EXPERIMENTAL"
depends on \
&& ! FREETZ_TYPE_FON_WLAN_7113 \
&& ! FREETZ_TYPE_SPEEDPORT_W501V \
default n
help
Remove userman files (Kindersicherung)
config FREETZ_REMOVE_FTPD
bool "Remove ftpd"
depends on \
FREETZ_HAS_USB_HOST && \
! FREETZ_TYPE_SPEEDPORT_W701V_7170 \\
default n
help
Remove FTP deamon (ftpd)
This patch removes AVM's ftp daemon. The regular options in AVM's Webinterface
are still present. If you select this item your USB drives won't be accessible
through ftp anymore. But you can use Freetz bftpd/vsftpd package to grant ftp
access to the devices.
config FREETZ_REMOVE_MEDIASRV
bool "Remove mediasrv"
depends on \
! FREETZ_TYPE_FON_WLAN_7240 && \
! FREETZ_TYPE_FON_WLAN_7270 && \
default n
help
Remove MediaServer daemon (mediasrv)
This patch removes only the deamon. The regular options in AVM's webinterface
are still present.
config FREETZ_REMOVE_SMBD
bool "Remove smbd"
depends on \
! FREETZ_PACKAGE_SAMBA && \
! FREETZ_TYPE_FON_7150 && \
default n
help
Remove Samba daemon (smbd)
This patch removes only the daemon. The regular options in AVM's webinterface
are still present.
config FREETZ_REMOVE_MINID
bool "Remove minid - EXPERIMENTAL"
default n
depends on \
FREETZ_TYPE_WLAN_3270 \
help
Remove the mini-daemon (minid) and some other related files.
This patch removes Fritz!Mini support but only the files,
not the settings in AVM's webinterface.
config FREETZ_REMOVE_AURA_USB
bool "Remove aura usb - EXPERIMENTAL"
default n
depends on \
help
Remove the aura-usb-daemon (USB-Fernanschluss) and some related files.
This patch only removes the files, not the settings in AVM's webinterface
config FREETZ_REMOVE_AVM_VPN
bool "Remove AVM vpn - EXPERIMENTAL"
default n
depends on \
(FREETZ_TYPE_FON_WLAN_7170 && FREETZ_TYPE_LANG_DE) || \
help
Remove AVM's vpn and some other related files
config FREETZ_REMOVE_DSLD
bool "Remove dsld (for boxes in IP client mode) - EXPERIMENTAL"
default n
select FREETZ_REMOVE_USERMAN if ! (FREETZ_TYPE_FON_5140 || FREETZ_TYPE_FON_WLAN_7113 || FREETZ_TYPE_SPEEDPORT_W501V || FREETZ_TYPE_SPEEDPORT_W900V)
help
Remove DSL deamon (dsld), if you are planning to use your box as a simple
IP client in ATA mode.
ATTENTION: You won't be able to use your box as a modem nor a router anymore.
As well do *not* use this option if your ATA mode box uses PPoE passthrough,
because in this case dsld is still needed! Furthermore, selecting this patch
also selects the UPnP patch, because UPnP must be deactivated anyway for
IP clients, otherwise dsld will be used again.
You can find the UPnP settings in the German web UI under
Einstellungen
System
Thirdly, the usermand patch will also be selected if you activate this option,
because kernel module userman.ko always depends on kdsldmod.ko which is
stripped by this patch.
EXPERIMENTAL FEATURE, USE AT OWN RISK!
config FREETZ_REMOVE_CAPIOVERTCP
bool "Remove CAPIoverTCP (used for Fritz!Fax) - EXPERIMENTAL"
default n
help
Remove CAPIoverTCP (capiotcp_server). Use this if you don't wat to use
Fritz!Fax or any other program that uses AVM's CAPIoverTCP. This is similar
to rcapid, but independant.
This will save about 15kB uncompressed size.
config FREETZ_REMOVE_DECT
bool "Remove DECT files - EXPERIMENTAL"
depends on \
default n
help
Remove dect files (modules, firmware and dect_manager an maybe Config-files).
(saves roundabout 20K compressed size on W900V and 200k on 7270)
config FREETZ_REMOVE_DECT_UPDATE
bool"Remove dect_update - EXPERIMENTAL"
depends on \
default n
help
Remove /usr/bin/dect_update. This utility is only needed to
update the dect firmware.
This will save about 32kB uncompressed size.
config FREETZ_REMOVE_DTRACE
bool"Remove dtrace"
depends on \
default n
help
Remove /usr/bin/dtrace. This utility is only needed to
trace ISDN D-channel.
This will save about 87kB uncompressed size.
config FREETZ_REMOVE_VOIP_ISDN
bool "Remove VoIP & ISDN files (for non-telephony boxes) - EXPERIMENTAL"
depends on \
FREETZ_HAS_PHONE
select FREETZ_REMOVE_DECT if FREETZ_TYPE_FON_WLAN_7240 || FREETZ_TYPE_FON_WLAN_7270
default n
help
Radically remove a lot of telephony-related files. This patch saves about
2.370 KB or 2.3 MB of uncompressed data size in the firmware image. This
means savings of about 700 KB of compressed firmware size.
ATTENTION: Currently there have not been a whole lot of tests concerning
side effects. The patch was successfully tested on a W701V IP client with
removed UPnP/dsld/userman. If it still works for boxes including those
functionalities, is unknown. Feel free to test it.
NOTE: Corresponding web UI files will also be removed, so you will
encounter several empty web pages or submenus.
config FREETZ_REMOVE_WLAN
bool "Remove WLAN files (for non-wlan boxes) - EXPERIMENTAL"
depends on \
FREETZ_HAS_WLAN
default n
help
Radically remove a lot of wlan-related files. This patch saves about
700 kb of uncomrpessed data size in the firmware image.
EXPERMINTAL FEATURE, USE AT OWN RISK!
config FREETZ_REMOVE_ANNEX_A_FIRMWARE
bool "Remove Annex A firmware file"
depends on \
FREETZ_TYPE_LANG_EN \
default n
help
Remove lib/modules/dsp_ur8/ur8-A-dsl.bin. This saves about 400 KB of
uncompressed data size.
config FREETZ_REMOVE_ANNEX_B_FIRMWARE
bool "Remove Annex B firmware file"
depends on \
default n
help
Remove lib/modules/dsp_ur8/ur8-B-dsl.bin. This saves about 400 KB of
config FREETZ_ADD_ANNEX_A_FIRMWARE
bool "Add Annex A firmware file"
depends on FREETZ_TYPE_FON_WLAN_7270 && FREETZ_TYPE_LANG_DE
default n
help
Add lib/modules/dsp_ur8/ur8-A-dsl.bin. This costs about 400 KB of
uncompressed data size. But you can remove Annex B file if you
plan to use Annex A.
endmenu
menu "Package selection"
#config FREETZ_BUILD_DYNAMIC_PACKAGES
# bool "Build dynamic packages (NOT SUPPORTED YET)"
# default n
# help
# If this is selected, all packages, which are not
# selected, will be build as dynamic packages.
source make/Config.in
endmenu
menu "Advanced options"
config FREETZ_DL_OVERRIDE
bool "Override firmware source"
default n
help
Enable this to override automatically generated entries.
config FREETZ_DL_SITE
string "Firmware site" if FREETZ_DL_OVERRIDE
depends on ! FREETZ_TYPE_LABOR
default "ftp://ftp.avm.de/fritz.box/fritzbox.2170/firmware/deutsch" if FREETZ_TYPE_2170
default "ftp://ftp.avm.de/fritz.box/fritzbox.fon/firmware/deutsch" if FREETZ_TYPE_300IP_AS_FON && FREETZ_TYPE_LANG_DE
default "ftp://ftp.avm.de/fritz.box/fritzbox.fon/firmware/english/annex_a" if FREETZ_TYPE_300IP_AS_FON && FREETZ_TYPE_LANG_EN && FREETZ_TYPE_ANNEX_A
default "ftp://ftp.avm.de/fritz.box/fritzbox.fon/firmware/english/annex_b" if FREETZ_TYPE_300IP_AS_FON && FREETZ_TYPE_LANG_EN && FREETZ_TYPE_ANNEX_B
default "ftp://ftp.avm.de/fritz.box/fritzbox.fon/firmware/deutsch" if FREETZ_TYPE_FON && FREETZ_TYPE_LANG_DE
default "ftp://ftp.avm.de/fritz.box/fritzbox.fon/firmware/english/annex_a" if FREETZ_TYPE_FON && FREETZ_TYPE_LANG_EN && FREETZ_TYPE_ANNEX_A
default "ftp://ftp.avm.de/fritz.box/fritzbox.fon/firmware/english/annex_b" if FREETZ_TYPE_FON && FREETZ_TYPE_LANG_EN && FREETZ_TYPE_ANNEX_B
default "ftp://ftp.avm.de/fritz.box/fritzbox.fon_5010/firmware/deutsch_a-ch" if FREETZ_TYPE_FON_5010 && FREETZ_TYPE_LANG_A_CH
default "ftp://ftp.avm.de/fritz.box/fritzbox.fon_5050/firmware" if FREETZ_TYPE_FON_5050
default "ftp://ftp.avm.de/fritz.box/fritzbox.fon_5140/firmware" if FREETZ_TYPE_FON_5140
default "ftp://ftp.avm.de/fritz.box/fritzbox.fon_wlan/firmware/deutsch" if FREETZ_TYPE_FON_WLAN && FREETZ_TYPE_LANG_DE
default "ftp://ftp.avm.de/fritz.box/fritzbox.fon_wlan/firmware/english/annex_a" if FREETZ_TYPE_FON_WLAN && FREETZ_TYPE_LANG_EN && FREETZ_TYPE_ANNEX_A
default "ftp://ftp.avm.de/fritz.box/fritzbox.fon_wlan/firmware/english/annex_b" if FREETZ_TYPE_FON_WLAN && FREETZ_TYPE_LANG_EN && FREETZ_TYPE_ANNEX_B
default "ftp://ftp.avm.de/fritz.box/fritzbox.fon_wlan_7050/firmware" if FREETZ_TYPE_FON_WLAN_7050
default "ftp://ftp.avm.de/fritz.box/fritzbox.fon_wlan_7113/firmware/deutsch" if FREETZ_TYPE_FON_WLAN_7113
default "ftp://ftp.avm.de/fritz.box/fritzbox.fon_wlan_7140/firmware/deutsch" if FREETZ_TYPE_FON_WLAN_7140 && FREETZ_TYPE_LANG_DE
default "ftp://ftp.avm.de/fritz.box/fritzbox.fon_wlan_7140/firmware/deutsch_a-ch" if FREETZ_TYPE_FON_WLAN_7140 && FREETZ_TYPE_LANG_A_CH
default "ftp://ftp.avm.de/fritz.box/fritzbox.fon_wlan_7140/firmware/english/annex_a" if FREETZ_TYPE_FON_WLAN_7140 && FREETZ_TYPE_LANG_EN && FREETZ_TYPE_ANNEX_A
default "ftp://ftp.avm.de/fritz.box/fritzbox.fon_wlan_7140/firmware/english/annex_b" if FREETZ_TYPE_FON_WLAN_7140 && FREETZ_TYPE_LANG_EN && FREETZ_TYPE_ANNEX_B
default "ftp://ftp.avm.de/fritz.box/fritzbox.fon_wlan_7141/firmware/deutsch" if FREETZ_TYPE_FON_WLAN_7141
default "ftp://ftp.avm.de/fritz.box/fritzfon.7150/firmware" if FREETZ_TYPE_FON_7150
default "ftp://ftp.avm.de/fritz.box/fritzbox.fon_wlan_7170/firmware/deutsch" if FREETZ_TYPE_FON_WLAN_7170 && FREETZ_TYPE_LANG_DE
default "ftp://ftp.avm.de/fritz.box/fritzbox.fon_wlan_7170/firmware/deutsch_a-ch" if FREETZ_TYPE_FON_WLAN_7170 && FREETZ_TYPE_LANG_A_CH
default "ftp://ftp.avm.de/fritz.box/fritzbox.fon_wlan_7170/firmware/english/annex_a" if FREETZ_TYPE_FON_WLAN_7170 && FREETZ_TYPE_LANG_EN && FREETZ_TYPE_ANNEX_A
default "ftp://ftp.avm.de/fritz.box/fritzbox.fon_wlan_7170/firmware/english/annex_b" if FREETZ_TYPE_FON_WLAN_7170 && FREETZ_TYPE_LANG_EN && FREETZ_TYPE_ANNEX_B
default "ftp://ftp.avm.de/fritz.box/fritzbox.fon_wlan_7240/firmware/deutsch" if FREETZ_TYPE_FON_WLAN_7240
default "ftp://ftp.avm.de/fritz.box/fritzbox.fon_wlan_7270/firmware/deutsch" if FREETZ_TYPE_FON_WLAN_7270 && FREETZ_TYPE_LANG_DE
default "ftp://ftp.avm.de/fritz.box/fritzbox.fon_wlan_7270/firmware/deutsch_a-ch" if FREETZ_TYPE_FON_WLAN_7270 && FREETZ_TYPE_LANG_A_CH
default "ftp://ftp.avm.de/fritz.box/fritzbox.fon_wlan_7270/firmware/english" if FREETZ_TYPE_FON_WLAN_7270 && FREETZ_TYPE_LANG_EN
default "ftp://ftp.avm.de/fritz.box/fritzbox.sl_wlan/firmware" if FREETZ_TYPE_WLAN_3020
default "ftp://ftp.avm.de/fritz.box/fritzbox.wlan_3030/firmware" if FREETZ_TYPE_WLAN_3030
default "ftp://ftp.avm.de/fritz.box/fritzbox.wlan_3130/firmware" if FREETZ_TYPE_WLAN_3130
default "ftp://ftp.avm.de/fritz.box/fritzbox.wlan_3131/firmware/deutsch" if FREETZ_TYPE_WLAN_3131
default "ftp://ftp.avm.de/fritz.box/fritzbox.wlan_3170/firmware/deutsch" if FREETZ_TYPE_WLAN_3170
default "ftp://ftp.avm.de/fritz.box/fritzbox.wlan_3270/firmware/deutsch" if FREETZ_TYPE_WLAN_3270
default "http://www.t-home.de/dlp/eki/downloads/Speedport/Speedport_W501V" if FREETZ_TYPE_SPEEDPORT_W501V
default "http://www.t-home.de/dlp/eki/downloads/Speedport/Speedport%20W%20701%20V" if FREETZ_TYPE_SPEEDPORT_W701V
default "http://www.t-home.de/dlp/eki/downloads/Speedport/Speedport%20W%20900V" if FREETZ_TYPE_SPEEDPORT_W900V
default "ftp://ftp.avm.de/fritz.box/..." if FREETZ_TYPE_CUSTOM
config FREETZ_DL_SOURCE
string "Firmware source" if FREETZ_DL_OVERRIDE
default "FRITZ.Box_2170.51.04.57.image" if FREETZ_TYPE_2170 && ! FREETZ_TYPE_LABOR
default "fritz.box_fon.06.04.33.image" if FREETZ_TYPE_300IP_AS_FON && FREETZ_TYPE_LANG_DE
default "fritz.box_fon.annexa.en.06.04.49.image" if FREETZ_TYPE_300IP_AS_FON && FREETZ_TYPE_LANG_EN && FREETZ_TYPE_ANNEX_A
default "fritz.box_fon.en.06.04.49.image" if FREETZ_TYPE_300IP_AS_FON && FREETZ_TYPE_LANG_EN && FREETZ_TYPE_ANNEX_B
default "fritz.box_fon.06.04.33.image" if FREETZ_TYPE_FON && FREETZ_TYPE_LANG_DE
default "fritz.box_fon.annexa.en.06.04.49.image" if FREETZ_TYPE_FON && FREETZ_TYPE_LANG_EN && FREETZ_TYPE_ANNEX_A
default "fritz.box_fon.en.06.04.49.image" if FREETZ_TYPE_FON && FREETZ_TYPE_LANG_EN && FREETZ_TYPE_ANNEX_B
default "fritz.box_fon_5010.annexa.48.04.43.image" if FREETZ_TYPE_FON_5010 && FREETZ_TYPE_LANG_A_CH
default "fritz.box_fon_5050.12.04.31.image" if FREETZ_TYPE_FON_5050
default "FRITZ.Box_Fon_5140.43.04.59.image" if FREETZ_TYPE_FON_5140
default "fritz.box_fon_wlan.08.04.34.image" if FREETZ_TYPE_FON_WLAN && FREETZ_TYPE_LANG_DE
default "FRITZ.Box_Fon_WLAN.AnnexA.en.08.04.49.image" if FREETZ_TYPE_FON_WLAN && FREETZ_TYPE_LANG_EN && FREETZ_TYPE_ANNEX_A
default "FRITZ.Box_Fon_WLAN.AnnexB.en.08.04.49.image" if FREETZ_TYPE_FON_WLAN && FREETZ_TYPE_LANG_EN && FREETZ_TYPE_ANNEX_B
default "fritz.box_fon_wlan_7050.14.04.33.image" if FREETZ_TYPE_FON_WLAN_7050
default "FRITZ.Box_Fon_WLAN_7113.60.04.67.image" if FREETZ_TYPE_FON_WLAN_7113
default "fritz.box_fon_wlan_7140.annexb.30.04.33.image" if FREETZ_TYPE_FON_WLAN_7140 && FREETZ_TYPE_LANG_DE
default "FRITZ.Box_Fon_WLAN_7140.AnnexA.en.39.04.67.image" if FREETZ_TYPE_FON_WLAN_7140 && FREETZ_TYPE_LANG_EN && FREETZ_TYPE_ANNEX_A
default "FRITZ.Box_Fon_WLAN_7140.AnnexB.en.30.04.67.image" if FREETZ_TYPE_FON_WLAN_7140 && FREETZ_TYPE_LANG_EN && FREETZ_TYPE_ANNEX_B
default "FRITZ.Box_Fon_WLAN_7140.AnnexA.39.04.59.image" if FREETZ_TYPE_FON_WLAN_7140 && FREETZ_TYPE_LANG_A_CH
default "FRITZ.Box_Fon_WLAN_7141.40.04.70.image" if FREETZ_TYPE_FON_WLAN_7141
default "FRITZ.Fon_7150.AnnexB.38.04.56.image" if FREETZ_TYPE_FON_7150
default "FRITZ.Box_Fon_WLAN_7170.29.04.70.image" if FREETZ_TYPE_FON_WLAN_7170 && ! FREETZ_TYPE_LABOR && FREETZ_TYPE_LANG_DE
default "FRITZ.Box_Fon_WLAN_7170.AnnexA.58.04.59.image" if FREETZ_TYPE_FON_WLAN_7170 && FREETZ_TYPE_LANG_A_CH
default "FRITZ.Box_Fon_WLAN_7170.AnnexA.en.58.04.67.image" if FREETZ_TYPE_FON_WLAN_7170 && FREETZ_TYPE_LANG_EN && FREETZ_TYPE_ANNEX_A
default "FRITZ.Box_Fon_WLAN_7170.AnnexB.en.29.04.67.image" if FREETZ_TYPE_FON_WLAN_7170 && FREETZ_TYPE_LANG_EN && FREETZ_TYPE_ANNEX_B
default "FRITZ.Box_Fon_WLAN_7170.Labor.29.04.70-13679.image" if FREETZ_TYPE_FON_WLAN_7170 && FREETZ_TYPE_LABOR_AIO
default "FRITZ.Box_Fon_WLAN_7170.Labor.29.04.99-14119.image" if FREETZ_TYPE_FON_WLAN_7170 && FREETZ_TYPE_LABOR_DSL
default "FRITZ.Box_Fon_WLAN_7240.AnnexB.73.04.70.image" if FREETZ_TYPE_FON_WLAN_7240 && ! FREETZ_TYPE_LABOR
default "fritz_box-labor-7240-14067.image" if FREETZ_TYPE_FON_WLAN_7240 && FREETZ_TYPE_LABOR_PHONE
default "FRITZ.Box_Fon_WLAN_7270.54.04.70.image" if FREETZ_TYPE_FON_WLAN_7270 && ! FREETZ_TYPE_LABOR && FREETZ_TYPE_LANG_DE
default "FRITZ.Box_Fon_WLAN_7270_16.AnnexB.en-de-es-it.54.04.67.image" if FREETZ_TYPE_FON_WLAN_7270 && FREETZ_TYPE_LANG_A_CH
default "FRITZ.Box_Fon_WLAN_7270.en-de-es-it.54.04.67.image" if FREETZ_TYPE_FON_WLAN_7270 && FREETZ_TYPE_LANG_EN
default "FRITZ.Box_Fon_WLAN_7270_LabAURA.AnnexB.54.04.95-14142.image" if FREETZ_TYPE_FON_WLAN_7270 && FREETZ_TYPE_LABOR_AURA
default "FRITZ.Box_Fon_WLAN_7270.Labor.54.04.99-14000.image" if FREETZ_TYPE_FON_WLAN_7270 && FREETZ_TYPE_LABOR_DSL
default "fritz_box-labor-7270-14067.image" if FREETZ_TYPE_FON_WLAN_7270 && FREETZ_TYPE_LABOR_PHONE
default "FRITZ.Box_Fon_WLAN_7270_WLAN_Labor_54.04.98-14080.image" if FREETZ_TYPE_FON_WLAN_7270 && FREETZ_TYPE_LABOR_WLAN
default "FRITZ.Box_Fon_WLAN_7270_LabIPV6.AnnexB.54.04.94-13992.image" if FREETZ_TYPE_FON_WLAN_7270 && FREETZ_TYPE_LABOR_IPV6
default "fritz.box_sl_wlan.09.04.34.image" if FREETZ_TYPE_WLAN_3020
default "fritz.box_wlan_3030.21.04.34.image" if FREETZ_TYPE_WLAN_3030
default "fritz.box_wlan_3130.44.04.34.image" if FREETZ_TYPE_WLAN_3130
default "fritz.box_wlan_3131.50.04.57.image" if FREETZ_TYPE_WLAN_3131
default "fritz.box_wlan_3170.49.04.58.image" if FREETZ_TYPE_WLAN_3170
default "fritz.box_wlan_3270.67.04.70.image" if FREETZ_TYPE_WLAN_3270
default "fw_Speedport_W501V_v_28.04.38.image" if FREETZ_TYPE_SPEEDPORT_W501V
default "fw_Speedport_W701V_v33.04.57.image" if FREETZ_TYPE_SPEEDPORT_W701V
default "fw_Speedport_W900V_v34.04.57.image" if FREETZ_TYPE_SPEEDPORT_W900V
default "fritz.box..." if FREETZ_TYPE_CUSTOM
config FREETZ_DL_SITE2
string "AVM web interface DL Site" if FREETZ_DL_OVERRIDE
depends on \
FREETZ_TYPE_7140_7170 || \
FREETZ_TYPE_7141_7170 || \
FREETZ_TYPE_SPEEDPORT_W900V_7170 || \
(FREETZ_TYPE_FON_WLAN_7270 && FREETZ_ADD_ANNEX_A_FIRMWARE)
default "ftp://ftp.avm.de/fritz.box/fritzbox.wlan_3170/firmware/deutsch" if FREETZ_TYPE_3170_7170
default "ftp://ftp.avm.de/fritz.box/fritzbox.fon_wlan_7140/firmware/deutsch" if FREETZ_TYPE_7140_7170
default "ftp://ftp.avm.de/fritz.box/fritzbox.fon_wlan_7141/firmware/deutsch" if FREETZ_TYPE_7141_7170
default "http://www.t-home.de/dlp/eki/downloads/Sinus%20W%20500%20V" if FREETZ_TYPE_SINUS_W500V_7150
default "ftp://ftp.avm.de/fritz.box/fritzbox.fon_wlan_7141/firmware/deutsch" if FREETZ_TYPE_SPEEDPORT_W501V
default "ftp://ftp.avm.de/fritz.box/fritzbox.fon_wlan_7141/firmware/deutsch" if FREETZ_TYPE_SPEEDPORT_W701V
default "http://www.t-home.de/dlp/eki/downloads/Speedport/Speedport%20W%20701%20V" if FREETZ_TYPE_SPEEDPORT_W701V_7170
default "ftp://ftp.avm.de/fritz.box/fritzfon.7150/firmware" if FREETZ_TYPE_SPEEDPORT_W900V
default "http://www.t-home.de/dlp/eki/downloads/Speedport/Speedport%20W%20900V" if FREETZ_TYPE_SPEEDPORT_W900V_7170
default "ftp://ftp.avm.de/fritz.box/fritzbox.fon_wlan_7270/x_misc/deutsch" if FREETZ_TYPE_FON_WLAN_7270
config FREETZ_DL_SOURCE2
string "AVM web interface firmware source" if FREETZ_DL_OVERRIDE
depends on \
default "fritz.box_wlan_3170.49.04.58.image" if FREETZ_TYPE_3170_7170
default "fritz.box_fon_wlan_7140.annexb.30.04.33.image" if FREETZ_TYPE_7140_7170
default "FRITZ.Box_Fon_WLAN_7141.40.04.70.image" if FREETZ_TYPE_7141_7170
default "fritz.box_fon_wlan_7141.40.04.37.image" if FREETZ_TYPE_SPEEDPORT_W501V
default "fritz.box_fon_wlan_7141.40.04.37.image" if FREETZ_TYPE_SPEEDPORT_W701V
default "fw_Speedport_W701V_v33.04.57.image" if FREETZ_TYPE_SPEEDPORT_W701V_7170
default "fritz.fon_7150.annexb.38.04.32.image" if FREETZ_TYPE_SPEEDPORT_W900V
default "fw_Speedport_W900V_v34.04.57.image" if FREETZ_TYPE_SPEEDPORT_W900V_7170
default "Sinus_W_500V.27.04.27.image" if FREETZ_TYPE_SINUS_W500V_7150
default "FRITZ.Box_Fon_WLAN_7270.54.04.59.image" if FREETZ_TYPE_FON_WLAN_7270
config FREETZ_DL_SOURCE2_CONTAINER
string
depends on \
default "fw_SinusW500V_27_04_27.zip" if FREETZ_TYPE_SINUS_W500V_7150
menu "Freetz package download sites"
# This is a fixed entry, it is invisible and cannot be changed by the user
config FREETZ_MOD_DL_NUM_SITES
string
default "5"
comment "Download site #1 - default: http://freetz.3dfxatwork.de"
config FREETZ_MOD_DL_SITE_1
string ""
default "http://freetz.3dfxatwork.de"
help
Download site #1 for Freetz packages like 'mc-4.5.0-freetz-0.2.tar.bz2',
*not* for original software packages like 'mc-4.5.0.tar.gz'. During the
build process, all mirrors defined here are triggered on a random basis,
so as not to always use a certain mirror first. This is a cheap kind of
load balancing.
Note: We recommend you to only set #5 to a user-defined value, if
necessary. Necessary means that #1 - #4 are currently unavailable or
the desired package cannot be found on either of them. In addition to
the default servers #1 and #2, many packages have another server name
in their make file, so a user-defined mirror should rarely be necessary.
comment "Download site #2 - default: http://freetz.wirsind.info"
config FREETZ_MOD_DL_SITE_2
string ""
default "http://freetz.wirsind.info"
help
Download site #2 for Freetz packages like 'mc-4.5.0-freetz-0.2.tar.bz2',
load balancing.
comment "Download site #3 - default: http://freetz.magenbrot.net"
config FREETZ_MOD_DL_SITE_3
string ""
default "http://freetz.magenbrot.net"
help
Download site #3 for Freetz packages like 'mc-4.5.0-freetz-0.2.tar.bz2',
load balancing.
comment "Download site #4 - default: empty (reserved for later use)"
config FREETZ_MOD_DL_SITE_4
string ""
help
Download site #4 for Freetz packages like 'mc-4.5.0-freetz-0.2.tar.bz2',
load balancing.
comment "Download site #5 - user-defined"
config FREETZ_MOD_DL_SITE_5
string ""
help
Download site #5 for Freetz packages like 'mc-4.5.0-freetz-0.2.tar.bz2',
load balancing.
endmenu
config FREETZ_SECURITY_LEVEL
int "Default Security level (0-2)"
default 1
help
There are several security levels.
0 : no restrictions
1 : only configuration files without shell commands might be edited
2 : no configuration files might be edited.
config FREETZ_VERBOSITY_LEVEL
int "Verbosity level (0-2)"
default 2
help
Verbosity level of the fwmod script and tar.
0 is the least and 2 the most information.
choice
prompt "Favicon"
default FREETZ_FAVICON_NONE
help
Adds small favicons to the document root.
config FREETZ_FAVICON_NONE
bool "none"
config FREETZ_FAVICON_DSL123
bool "dsl123's favicons"
config FREETZ_FAVICON_CUMA
bool "cuma's favicons"
config FREETZ_FAVICON_HANSOLO
bool "han-solo's favicons"
endchoice
config FREETZ_FAVICON_STRING
string
default "none" if FREETZ_FAVICON_NONE
default "dsl123" if FREETZ_FAVICON_DSL123
default "cuma" if FREETZ_FAVICON_CUMA
default "hansolo" if FREETZ_FAVICON_HANSOLO
config FREETZ_SUBVERSION_STRING
bool "Add Freetz version to subversion string"
default y if ! FREETZ_TYPE_FON_WLAN_7270
default n
help
Add Freetz version to subversion string, e.g. -11945-freetz-devel-2417.
Disable this if you have trouble with your isp or plugin downloads from
AVM don't work.
Please only disable this option if you really need to!
config FREETZ_DEVELOPER_VERSION_STRING
bool "Developer version string"
depends on FREETZ_SUBVERSION_STRING
default y
help
Add SVN (Subversion) repository revision number to firmware image name
and to /etc/.subversion, /etc/version within firmware itself.
The revision number string is generated by the client command line tool
svnversion and may include switch/modify flags and/or a range of
version numbers, depending on the current state of the working
directory at the time of generation. See 'svnversion --help' for
details.
ATTENTION! This option is for developers working on checked-out
versions of the Freetz source code only and requires svnversion to be
installed.
config FREETZ_STATUS_STYLE
bool "New style for status-bars and cache-usage"
default n
help
Changes the style of the Freetz status-bars and also adds the
cache-usage to these bars.
config FREETZ_AVMPLUGINS_ENABLED
bool "Integrate AVM Plugins into image"
default y if FREETZ_TYPE_FON_WLAN_7270_16MB
default n
help
This feature disables AVM's plugin download and handling.
You could integrate these plugins directly into the firmware image by
selecting them below. This saves some resources because plugins are not
copied into RAM nor mounted with loop-devices.
Default behaviour for boxes with 16 MB flash.
menu "Plugin selection"
depends on FREETZ_AVMPLUGINS_ENABLED
comment "Select plugin(s) for insertion"
config FREETZ_AVMPLUGINS_MEDIASRV
bool "MEDIASRV"
default n
help
Integrates UPNP Mediaserver
config FREETZ_AVMPLUGINS_MINI
bool "MINI"
default n
help
Integrates FRITZ! Mini support
config FREETZ_AVMPLUGINS_NTFS
bool "NTFS"
default n
help
Integrates NTFS filesystem support
Not recommended if you are using Freetz-NTFS!
config FREETZ_AVMPLUGINS_SAMBA
bool "SAMBA"
default n
help
Integrates AVM's Samba Fileserver
Not recommended if you are using Freetz-Samba!
config FREETZ_AVMPLUGINS_TAM
bool "TAM"
default n
help
Integrates Telephone Answering Machine (TAM)
config FREETZ_AVMPLUGINS_WEBDAV
bool "WEBDAV"
depends on FREETZ_TYPE_LABOR_AURA
default n
help
Integrates AVM's webdav
endmenu
menu External
config EXTERNAL_ENABLED
bool "Enable external processing"
default n
help
Enable this to move (big) files out of the firmware-image onto
an attached USB device or a mounted network share like SMB or NFS.
-------------------------- WARNING ----------------------------------
Move all the files from build/modified/external to your choosen
directory on the box BEFORE you flash the reduced image!
Do NOT external files needed to boot up Freetz!
------------------------- ADVANCED ----------------------------------
You could external services (like Samba) too. First set the service
startup to "manual". Then enable the autorun/autoend feature of
Freetz and create these files in the root of your device:
[autorun.sh]
/etc/init.d/rc.XYZ start
[autoend.sh]
/etc/init.d/rc.XYZ stop
config EXTERNAL_DOWNLOADER
bool "Prepare files for Downloader"
default n
depends on EXTERNAL_ENABLED && FREETZ_PACKAGE_DOWNLOADER
help
Prepare files for Downloader package.
Downloader loads usualy files from a http or ftp server into the RAM of the box.
config EXTERNAL_SUBDIRS
bool "Keep subdirectories"
default n if ! EXTERNAL_DOWNLOADER
default y if EXTERNAL_DOWNLOADER
help
Keep the original directory structure
config EXTERNAL_CREATEPAK
bool "Create file for upload" if ! EXTERNAL_DOWNLOADER
default y
depends on EXTERNAL_ENABLED && ! EXTERNAL_DOWNLOADER
help
Creates a file for upload with the webinterface
choice
prompt "external directory"
default EXTERNAL_DIR1 if ! EXTERNAL_DOWNLOADER
default EXTERNAL_DIR3 if EXTERNAL_DOWNLOADER
help
The directory on the Freetz Box with the externald files
config EXTERNAL_DIR1
depends on ! EXTERNAL_DOWNLOADER
bool "/var/media/ftp/uStor01/external/"
config EXTERNAL_DIR2
bool "/var/media/ftp/uStor02/external/"
config EXTERNAL_DIR3
depends on EXTERNAL_DOWNLOADER
bool "/mod/"
config EXTERNAL_CUSTOM_DIR
bool "custom directory"
endchoice
config EXTERNAL_CUSTOM_DIRNAME
string "custom directory" if EXTERNAL_CUSTOM_DIR
default "/var/media/ftp/uStor01/external/"
depends on EXTERNAL_ENABLED && EXTERNAL_CUSTOM_DIR
help
Custom directory on the Freetz Box with the externald files
config EXTERNAL_DIRECTORY
string
default "/var/media/ftp/uStor01/external/" if EXTERNAL_DIR1
default "/var/media/ftp/uStor02/external/" if EXTERNAL_DIR2
default "/mod/" if EXTERNAL_DIR3
default EXTERNAL_CUSTOM_DIRNAME if EXTERNAL_CUSTOM_DIR
config EXTERNAL_OWN_FILES
string "own files"
default ""
depends on EXTERNAL_ENABLED && FREETZ_SHOW_ADVANCED
help
Put your own files/directorys here (space seperated)
source make/external.in
endmenu
choice
prompt "SquashFS block size"
default FREETZ_SQUASHFS_BLOCKSIZE_65536
config FREETZ_SQUASHFS_BLOCKSIZE_ORIG
bool "original (usually 64 KB)"
help
Block size of the root filesystem. SquashFS 2.x can use block sizes
up to 64 KB, SquashFS 3.x (only available for 7270 firmware or with
"replace kernel") up to 1024 KB. Bigger block sizes achieve better
compression ratios than smaller ones.
64 KB is the default for kernel 2.6 firmwares, we recommend not to use
anything smaller because your firmware image will grow unnecessarily.
Note: Currently anything above 128 KB will result in a kernel panic, thus
we do not allow it.
config FREETZ_SQUASHFS_BLOCKSIZE_16384
bool "16 KB"
help
we do not allow it.
config FREETZ_SQUASHFS_BLOCKSIZE_32768
bool "32 KB"
help
we do not allow it.
config FREETZ_SQUASHFS_BLOCKSIZE_65536
bool "64 KB"
help
we do not allow it.
config FREETZ_SQUASHFS_BLOCKSIZE_131072
bool "128 KB (EXPERIMENTAL)"
depends on FREETZ_REPLACE_KERNEL
help
we do not allow it.
# config FREETZ_SQUASHFS_BLOCKSIZE_262144
# bool "256 KB"
# depends on FREETZ_REPLACE_KERNEL
# config FREETZ_SQUASHFS_BLOCKSIZE_524288
# bool "512 KB"
# config FREETZ_SQUASHFS_BLOCKSIZE_1048576
# bool "1024 KB"
endchoice
menu "BusyBox options"
depends on FREETZ_REPLACE_BUSYBOX
source make/busybox/Config.in
endmenu
menu "Kernel modules"
source kernel/Config.in
endmenu
menu "Shared libraries"
config FREETZ_STRIP_LIBRARIES
bool "Run mklibs on the built root filesystem (Experimental)"
default n
help
Recompiles all the shared libraries to only include the
symbols actually needed to run the binaries on the target.
Caution: Because symbols are different in every AVM image
you have to update the list of missing symbols in fwmod
by hand.
comment "Libraries -------------------------------"
source make/libs/Config.in
endmenu
menu "Compiler options"
choice
prompt "Toolchains"
default FREETZ_DOWNLOAD_TOOLCHAIN if ! FREETZ_TARGET_IPV6_SUPPORT
default FREETZ_BUILD_TOOLCHAIN if FREETZ_TARGET_IPV6_SUPPORT
help
Download Toolchain, build toolchain
config FREETZ_DOWNLOAD_TOOLCHAIN
bool "Download and use precompiled toolchain" if ! FREETZ_TARGET_IPV6_SUPPORT
config FREETZ_BUILD_TOOLCHAIN
bool "Build toolchain (requires 4GB diskspace)"
endchoice
config FREETZ_TARGET_CROSS
string
default "mipsel-linux-uclibc-"
config FREETZ_TARGET_MAKE_PATH
string
default "toolchain/target/usr/bin"
config FREETZ_TARGET_CFLAGS
string "Target compiler flags"
default "-Os -pipe -march=4kc -Wa,--trap"
config FREETZ_JLEVEL
int "Number of jobs to run simultaneously"
default "2"
help
Number of jobs to run simultanesouly
config FREETZ_KERNEL_CROSS
string
default "mipsel-unknown-linux-gnu-"
config FREETZ_KERNEL_MAKE_PATH
string
default "toolchain/kernel/bin"
source toolchain/Config.in
endmenu
endmenu
Thanks in advance
Best regards
