What do you mean by 'sync'?
I run rsync on my box and make remote backups to the attached USB-drive using ssh and duplicity and that works flawless.
Note that rsync does need quite some memory.
i would like to see, how much is the sync of the dsl on my router. how much is the upload and the download. i have only the permisson, to go via ssh on the router, there is not be able to see the html side. i run the freetz and many of the freetz packs and i can install packs when i need that.
