- Mitglied seit
- 30 Mai 2007
- Beiträge
- 26
- Punkte für Reaktionen
- 0
- Punkte
- 0
Hi everyone, Is two days I'm trying to restore this fritz with official recovery and is successful but the problems of boot persists.
Env is affixed:
I connected the serial cable and this is what comes out:
Do you have any idea?
Thanks in advance
Env is affixed:
Eva_AVM >printenv
HWRevision 203
HWSubRevision 1
ProductID Fritz_Box_HW203
SerialNumber 0000000000000000
annex B
autoload yes
bootloaderVersion 1.1904
bootserport tty0
cpufrequency 500000000
firstfreeaddress 0x81114144
firmware_info 131.06.30
firmware_version avm
flashsize nor_size=0MB sflash_size=1024KB nand_size=128MB
linux_fs_start 0
maca xx:xx:xx:xx:xx:00
macb xx:xx:xx:xx:xx:01
macwlan xx:xx:xx:xx:xx:02
macdsl xx:xx:xx:xx:xx:03
memsize 0x08000000
modetty0 38400,n,8,1,hw
modetty1 38400,n,8,1,hw
mtd0 0x400000,0x3400000
mtd1 0x0,0x400000
mtd2 0x0,0x40000
mtd3 0x40000,0xA0000
mtd4 0xA0000,0x100000
mtd5 0x0,0x200000
my_ipaddress 192.168.178.1
prompt Eva_AVM
ptest
req_fullrate_freq 250000000
sysfrequency 250000000
urlader-version 2904
usb_board_mac xx:xx:xx:xx:xx:04
usb_device_id 0x0000
usb_device_name USB DSL Device
usb_manufacturer_name AVM
usb_revision_id 0x0000
usb_rndis_mac xx:xx:xx:xx:xx:05
wlan_key 01234567891234567890
(AVM) EVA Revision: 1.1904 Version: 2904
(C) Copyright 2005 AVM Date: Oct 15 2013 Time: 13:57:18 (0) 3 0x0-0x740D
[FLASH:] WINBOND Uniform-Flash 1MB 256 Bytes WriteBuffer
[FLASH:](Eraseregion [0] 16 sectors a 64kB)
[NAND:] 128MB MICRON 2048 Pagesize 128k Blocksize 1024 Blocks 8Bit 1 CS HW
[SYSTEM:] VR9 on 500MHz/250MHz/250MHz
.Atheros 8030/35 detected
Eva_AVM >##....................................
Lantiq xDSL CPE VR9
[ 0.000000] Linux version 2.6.32.61 (hjortmann@EmbeddedVM) (gcc version 4.8.1 (Buildroot 2013.05) ) #1 SMP Tue May 5 11:31:15 CEST 2015
[ 0.000000] phym = 08000000, mem = 08000000, max_pfn = 00008000
[ 0.000000] Reserving memory for CP1 @0xa8000000, size 0x00000000
[ 0.000000] [init_avm_kernel_config] AVM Kernel Config (ptr 806c6000)
[ 0.000000] [init_avm_kernel_config] AVM Kernel Config: module memory entry
[ 0.000000] bootconsole [early0] enabled
[ 0.000000] CPU revision is: 00019556 (MIPS 34Kc)
[ 0.000000] Determined physical RAM map:
[ 0.000000] Initrd not found or empty - disabling initrd
[ 0.000000] Zone PFN ranges:
[ 0.000000] Normal 0x00000000 -> 0x00008000
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] early_node_map[1] active PFN ranges
[ 0.000000] 0: 0x00000000 -> 0x00008000
[ 0.000000] [module-alloc-by-name] 'modulemem' not in use, use AVM Kernel Config (8675328 bytes, reserved for module mem)
[ 0.000000] [module-alloc] use 0x846000 bytes at 0x81101000
[ 0.000000] 1 available secondary CPU TC(s)
[ 0.000000] PERCPU: Embedded 7 pages/cpu @8194b000 s5760 r8192 d14720 u65536
[ 0.000000] pcpu-alloc: s5760 r8192 d14720 u65536 alloc=16*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512
[ 0.000000] Kernel command line: console=ttyS0,115200n8r nor_size=0MB sflash_size=1024KB nand_size=128MB ethaddr=34:81:C4:2F:27:00
[ 0.000000] [NAND] nand_size = 0x8000000
[ 0.000000] PID hash table entries: 512 (order: -1, 2048 bytes)
[ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] wait instruction: r4k_wait_irqoff
[ 0.000000] [avm_cache_set_coherency]: setting cache coherency for HWRevision=203 to write back allocate
[ 0.000000] Primary instruction cache 32kB, VIPT, 4-way, linesize 32 bytes.
[ 0.000000] Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
[ 0.000000] Writing ErrCtl register=00031864
[ 0.000000] Readback ErrCtl register=00031864
[ 0.000000] Memory: 113548k/131072k available (4744k kernel code, 17340k reserved, 2187k data, 212k init, 0k highmem)
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] NR_IRQS:181
[ 0.000000] [mips_cpu_irq_init] irq_base 0
[ 0.000000] SRSConf0 0x3feffbfe: SRS1: 0xffffffff, SRS2 0xffffffff, SRS3 0xffffffff
[ 0.000000] Console: colour dummy device 80x25
[ 0.000000] console [ttyS0] enabled, bootconsole disabled
[ 0.020000] Calibrating delay loop... 332.59 BogoMIPS (lpj=1662976)
[ 0.240000] Security Framework initialized
[ 0.240000] Mount-cache hash table entries: 512
[ 0.250000] kernel_init: started
[ 0.250000] kernel_init: kernel locked
[ 0.250000] Limit of 2 TCs set
[ 0.250000] TLB of 32 entry pairs shared by 2 VPEs
[ 0.250000] VPE 0: TC 0, VPE 1: TC 1
[ 0.250000] IPI buffer pool of 8 buffers
[ 0.260000] CPU revision is: 00019556 (MIPS 34Kc)
[ 0.490000] TC 1 going on-line as CPU 1
[ 0.500000] Brought up 2 CPUs
[ 0.510000] [yield_context_init] cpu=1 tc=2 mask=300
[ 0.510000] [yield_context_init] cpu=0 tc=3 mask=410
[power_managment_setup] reset 'DSL, DFE, AFE, VOICE, DSLTC, ARC'
[power_managment_setup] reset 'LDO'
[power_managment_setup] power down 'PPE TC, PPE EMA, LEDC, DFEV1, DFEV0'
[power_managment_setup] power down 'MSI1, PDI1 PCIE1 PCIE1_PHY'
[power_managment_setup] power down 'USB CTRL'
[power_managment_setup] power down 'GPHY'
[power_managment_setup] disable power domain 'DSL + DFE'
[final_setup_dcdc] start
*((volatile unsigned char *)0xBF106A17) = 0x5A;
*((volatile unsigned char *)0xBF106A18) = 0x46;
*((volatile unsigned char *)0xBF106A11) = 0x13;
*((volatile unsigned char *)0xBf106a00) = 0;
*((volatile unsigned char *)0xBf106a01) = 0;
*((volatile unsigned char *)0xBf106a02) = 0xFF;
*((volatile unsigned char *)0xBf106a03) = 0xE6;
*((volatile unsigned char *)0xBf106a04) = 0;
*((volatile unsigned char *)0xBf106a05) = 0x1B;
*((volatile unsigned char *)0xBf106a15) = 0x8b;
*((volatile unsigned char *)0xBf106a17) = 0x80;
*((volatile unsigned char *)0xBf106a18) = 0x28;
*((volatile unsigned char *)0xBf106a06) = 0x52;
[final_setup_dcdc] done
[ 0.620000] NET: Registered protocol family 16
[ 0.620000] Lantiq GPIO driver, version 1.3.2, (c) 2001-2013 Lantiq Deutschland GmbH
[ 0.630000] Reboot Status is: Power-On
[ 0.630000] [avmnet] [avmnet_cfg_init] Driver version: 6.136 - Revision 1496:2706 - Di 5. Mai 11:30:48 CEST 2015
[ 1.250000] ifx_pcie_wait_phy_link_up port 0 timeout
[ 1.860000] ifx_pcie_wait_phy_link_up port 0 timeout
[ 2.470000] ifx_pcie_wait_phy_link_up port 0 timeout
[ 3.090000] ifx_pcie_wait_phy_link_up port 0 timeout
[ 3.700000] ifx_pcie_wait_phy_link_up port 0 timeout
[ 3.700000] pcie_rc_initialize port 0 link up failed!!!!!
[ 3.710000] Lantiq PCIe Root Complex driver, version 2.0.0, (c) 2001-2013 Lantiq Deutschland GmbH
[ 3.720000] bio: create slab <bio-0> at 0
[ 3.730000] NET: Registered protocol family 8
[ 3.730000] NET: Registered protocol family 20
[ 3.740000] NET: Registered protocol family 2
[ 3.740000] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 3.740000] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[ 3.740000] TCP bind hash table entries: 4096 (order: 4, 81920 bytes)
[ 3.750000] TCP: Hash tables configured (established 4096 bind 4096)
[ 3.760000] TCP reno registered
[ 3.760000] NET: Registered protocol family 1
[ 3.770000] IFX DMA driver, version ifxmips_dma_core.c:v1.0.17 ,(c)2009 Infineon Technologies AG
[ 3.770000] skb_shared_size:344
[ 3.780000] Lantiq CGU driver, version 1.1.32, (c) 2001-2013 Lantiq Deutschland GmbH
[ 3.790000] squashfs: version 3.4 (2008/08/26) Phillip Lougher
[ 3.790000] fuse init (API version 7.13)
[ 3.800000] msgmni has been set to 222
[ 3.800000] io scheduler noop registered (default)
[ 3.810000] [avm_membench_init]
[ 4.060000] avm_net_trace: Up and running.
[ 4.060000] [loadcontrol] set auto - scale=1
[ 4.070000] [avm] configured: watchdog event debug
[ 4.070000] AVM_WATCHDOG: Watchdog Driver for AR7 Hardware (Version 1.0, build: May 5 2015 11:30:17)
[ 4.090000] ifx_pmu_init: Major 247
[ 4.090000] Lantiq PMU driver, version 1.2.6, (c) 2001-2013 Lantiq Deutschland GmbH
[ 4.100000] Infineon Technologies RCU driver version 1.0.7
[ 4.100000] Lantiq Thermal Sensor driver, version 1.0.3, (c) 2001-2013 Lantiq Deutschland GmbH
[ 4.110000] ttyS0 at MMIO 0x1e100c00 (irq = 107) is a PORT_IFX_ASC
[ 4.120000] loop: module loaded
[ 4.130000] nbd: registered device at major 43
[ 4.140000] Generic platform RAM MTD, (c) 2004 Simtec Electronics
[ 4.150000] Platform NOR MTD, (c) AVM 2010
[ 4.150000] [HSNAND] Hardware-ECC activated
[ 4.150000] NAND device: Manufacturer ID: 0x2c, Chip ID: 0xf1 (Micron NAND 128MiB 3,3V 8-bit)
[ 4.160000] Scanning device for bad blocks
[ 4.250000] Creating 6 MTD partitions on "ifx_hsnand":
[ 4.250000] 0x000000000000-0x000000400000 : "kernel"
[ 4.260000] {ifx_mtd_add_notifier} name kernel
[ 4.270000] 0x000000400000-0x000003400000 : "filesystem"
[ 4.270000] {ifx_mtd_add_notifier} name filesystem
[ 4.280000] 0x000003400000-0x000003800000 : "reserved-kernel"
[ 4.280000] {ifx_mtd_add_notifier} name reserved-kernel
[ 4.290000] 0x000003800000-0x000006800000 : "reserved-filesystem"
[ 4.300000] {ifx_mtd_add_notifier} name reserved-filesystem
[ 4.300000] 0x000006800000-0x000006a00000 : "config"
[ 4.310000] {ifx_mtd_add_notifier} name config
[ 4.310000] 0x000006a00000-0x000008000000 : "nand-filesystem"
[ 4.320000] {ifx_mtd_add_notifier} name nand-filesystem
[ 4.320000] Lantiq SSC driver, version 2.4.1, (c) 2001-2013 Lantiq Deutschland GmbH
[ 4.330000] Creating 3 MTD partitions on "ifx_sflash":
[ 4.330000] 0x000000000000-0x000000040000 : "urlader"
[ 4.340000] {ifx_mtd_add_notifier} name urlader
[ 4.340000] 0x000000040000-0x0000000a0000 : "tffs (1)"
[ 4.350000] {ifx_mtd_add_notifier} name tffs (1)
[ 4.350000] 0x0000000a0000-0x000000100000 : "tffs (2)"
[ 4.360000] {ifx_mtd_add_notifier} name tffs (2)
[ 4.360000] Lantiq SPI flash driver, version 1.1.9, (c) 2001-2013 Lantiq Deutschland GmbH
[ 4.370000] tun: Universal TUN/TAP device driver, 1.6
[ 4.370000] tun: (C) 1999-2004 Max Krasnyansky <[email protected]>
[ 4.380000] IFX SWITCH API, Version 1.1.8.5
[ 4.380000] SWAPI: Registered character device [switch_api] with major no [81]
[ 4.390000] Switch API: PCE MicroCode loaded !!
[ 4.400000] res = 87926500
[ 4.400000] i2c /dev entries driver
[ 4.400000] CAPI Subsystem Rev 1.1.2.8
[ 4.410000] AVM PA 4.3.10 2014-09-21
[ 4.410000] AVM PA skb pktinfo at offset 128 size 196
[ 4.420000] [loadcontrol]module avm_pa registered
[ 4.420000] IPv4 over IPv4 tunneling driver
[ 4.430000] TCP cubic registered
[ 4.430000] mcfw: IGMPv3 fast forwarding
[ 4.430000] NET: Registered protocol family 10
[ 4.440000] IPv6 over IPv4 tunneling driver
[ 4.440000] NET: Registered protocol family 17
[ 4.440000] NET: Registered protocol family 8
[ 4.450000] atmpvc_init() failed with -17
[ 4.450000] KOAM is loaded successfully.
[ 4.460000] l2tp_core: L2TP core driver, V2.0
[ 4.460000] l2tp_ip: L2TP IP encapsulation support (L2TPv3)
[ 4.460000] l2tp_netlink: L2TP netlink interface
[ 4.470000] l2tp_eth: L2TP ethernet pseudowire support (L2TPv3)
[ 4.480000] l2tp_ip6: L2TP IP encapsulation support for IPv6 (L2TPv3)
[ 4.480000] 802.1Q VLAN Support v1.8 Ben Greear <[email protected]>
[ 4.490000] All bugs added by David S. Miller <[email protected]>
[ 4.490000] <ifx_fix_timing>
[ 4.500000] TFFS: tiny flash file system driver. GPL (c) AVM Berlin (Version 2.0)
[ 4.510000] mount on mtd7 and mtd8 (double buffering)
[ 4.510000] Adam2 environment variables API installed.
[ 4.520000] [simple-profiling]: 2 performance counters implemented, NEW_34K
[ 4.520000] Enable Performance Counter 0 for Data cache load/stores (User-Mode enabled Supervisor-Mode enabled Kernel-Mode enabled Exeption-Mode disable)
[ 4.540000] Setup tcs=0x1 current_tc_mask=0x1, reg=0
[ 4.540000] [simple-profiling]: 2 performance counters implemented, NEW_34K
[ 4.550000] Enable Performance Counter 1 for Data cache load/store misses (User-Mode enabled Supervisor-Mode enabled Kernel-Mode enabled Exeption-Mode disable)
[ 4.560000] Setup tcs=0x1 current_tc_mask=0x1, reg=1
[ 4.570000] AVM Simple Profiling enabled Version 3.0
[ 4.570000] {avmnet_cfg_netinit}
[ 4.580000] [avmnet] No config found for HWRev 203, HWSubRev 1, Profile-ID 0, trying base config for HWSubRev
[ 4.590000] [avmnet] No config found for HWRev 203, HWSubRev 1, trying base config for HWRev
[ 4.600000] [avmnet] [avmnet_swi_7port_init] Init on module swi_vr9 called.
[ 5.020000] Loading AVM Net Common Datapath Driver for 7Port Switch......
[ 5.030000] [ppe_eth_init] init_hw()
[ 5.030000] [init_hw] ppe_hw_init=0xff successful
[ 5.040000] [ppe_eth_init] ifx_proc_file_create()
[ 5.040000] [ppe_eth_init] dma_setup_init()
[ 5.050000] [avmnet] [avmnet_swi_7port_disable_learning] Configuring CPU-port to receive all unknown unicast frames 0x68
[ 5.060000] [avmnet] [avmnet_swi_7port_disable_learning] Configuring CPU-port to receive all unknown multicast frames 0x68
[ 5.170000] [avmnet] [avmnet_links_port_update] Maximum port number 0 exceeded with 2!
[ 5.170000] [avm_event_source_trigger]: not registered
[ 5.180000] [avmnet] [avmnet_links_port_update] Maximum port number 0 exceeded with 2!
[ 7.840000] [avm_pa_multiplexer_init] start
[ 7.840000] [avm_pa_multiplexer_init] init complete
[ 7.850000] [avm_pa_multiplexer_register_instance]
[ 7.850000] add:avmnet_7port_pce_add_session+0x0/0x5a0
[ 7.850000] remove:avmnet_7port_pce_remove_session+0x0/0x80
[ 7.870000] kernel_init: basic setup done
[ 7.870000] SQUASHFS error: Can't find a SQUASHFS superblock on mtdblock1
[ 7.880000] yaffs: dev is 32505857 name is "mtdblock1" ro
[ 7.880000] yaffs: passed flags ""
[ 7.910000] VFS: Mounted root (yaffs filesystem) readonly on device 31:1.
[ 7.920000] Freeing unused kernel memory: 212k freed
[ 7.970000] trying /sbin/init
[ 8.170000] [squashfs] use zip compression
[VR9-flash] -- Test --
starting pid 140, tty '/dev/ttyS0': '/etc/init.d/rc.S'
mount: mounting proc on /proc failed: Device or resource busy
tar: removing leading '/' from member names
source files in group 0 ...
/etc/init.d/S00-signal /etc/init.d/S05-watchdog /etc/init.d/S09-rtc
/etc/init.d/S01-head /etc/init.d/S08-tffs
/etc/init.d/S02-led /etc/init.d/S09-config
[ 8.690000] TFFS Name Table K
[config-space] detected mtdmtd4: size '2097152'
modprobe: module nand not found in modules.dep
[config-space][yaffs] driver is loaded
[config-space] using mtd4 for /var/flash
[ 8.790000] yaffs: dev is 32505860 name is "mtdblock4" rw
[ 8.790000] yaffs: passed flags ""
[config-space] /var/flash assigned @ /dev/mtdblock4
[ 9.760000] [ifx_hsnand_command] read block is critical (status: 0xe8, column: 0x0 page: 0xecb)
[ 9.770000] {ifx_hsnand_read_page_hwecc} page 0xecb Sector 2 1 Biterror 0 OOB-Biterror 0 ECC-Biterror
[ 10.010000] [module-alloc-by-name] give 0x1a000 bytes at 0x81101000 to module 'led_modul_Fritz_Box_HW203' (0x82c000 bytes left)
[ 10.020000] led_modul_Fritz_Box_HW203: module license '
[ 10.020000] (C) Copyright 2012 by AVM
[ 10.020000] ' taints kernel.
[ 10.040000] Disabling lock debugging due to kernel taint
[ 10.070000] [LED] use GPIO 32 for 'gpio_avm_led_power'
[ 10.070000] [LED] use GPIO 38 for 'gpio_avm_led_internet'
[ 10.070000] [LED] use GPIO 35 for 'gpio_avm_led_dect'
[ 10.080000] [LED] use GPIO 36 for 'gpio_avm_led_wlan'
[ 10.080000] [LED] use GPIO 47 for 'gpio_avm_led_info'
[ 10.090000] [LED] use GPIO 34 for 'gpio_avm_led_info_red'
[ 10.100000] [BUTTON] use GPIO 29 for 'gpio_avm_button_wlan'
[ 10.100000] [BUTTON] use GPIO 1 for 'gpio_avm_button_dect'
[ 10.110000] [register_bug_debug_table] name='led-modul' 0x8110de24 - 0x8110de38
[ 10.120000] AVM_WATCHDOG: System Init UEberwachung 120 Sekunden
P-Defaults: not configured - skip.
[ 10.670000] [module-alloc-by-name] give 0x2000 bytes at 0x8111b000 to module 'rtc_avm' (0x82a000 bytes left)
[ 10.700000] rtc-avm rtc-avm.0: rtc core: registered avm as rtc0
[ 10.700000] [avm-rtc]: avm_rtc_probe: register: ret=0x87343a00
[ 10.710000] [avm-rtc]: avm_rtc_probe: success
exceute files in group 0 ...
/etc/init.d/E05-basemodules
group 0 done ...
source files in group 1 ...
/etc/init.d/S10-html /etc/init.d/S12-default
/etc/init.d/S10-vm /etc/init.d/S15-filesys
/etc/init.d/S11-config_def /etc/init.d/S17-capi
/etc/init.d/S11-piglet /etc/init.d/S17-tam
[ 10.900000]
[ 10.900000] [avm_debug] redirecting kernel-messages (/dev/debug)
[ 10.930000][1] [module-alloc-by-name] give 0xd000 bytes at 0x8111d000 to module 'Piglet_noemif' (0x81d000 bytes left)
[ 10.930000][1] [module-alloc-by-name] 0xd000 bytes used, 0xeb80 bytes expected
[ 10.950000][1] [piglet]use default-settings (1 gpio from hw_config)
[ 11.030000][1] patch_dectfw: c0193000, totallen = 44879(af4f)
[ 11.030000][1] patch_dectfw: patch_adress: a0 max_len: 26 with Version 2 Len: 17
[ 11.030000][1] patch_dectfw: dectmode 1
[ 11.030000][1] dect_loader: slow-bootmode
[ 12.080000][1] [1]system-load 2 loadavg 0.23 0.5 0.2 - 38 tasks:79 % curr:modprobe(8 %) max:init(65 %, pid:1), readytorun: 3, pgfault 1447/s (max 2 avg 1.0)
[ 13.000000][0] dect_loader: slow-bootmode
[ 14.040000][0] [0]system-load 5 loadavg 0.23 0.5 0.2 - 38 tasks:14 % curr:modprobe(14 %) max:modprobe(14 %, pid:348), readytorun: 2, pgfault 846/s (max 1 avg 0.9)
[ 15.600000][1] dect_loader: slow-bootmode
[ 17.570000][0] dect_loader: slow-bootmode
[ 20.170000][1] dect_loader: slow-bootmode
[ 22.140000][0] dect_loader: slow-bootmode
[ 24.190000][0] [0]system-load 5 loadavg 0.89 0.20 0.6 - 39 tasks:98 % curr:modprobe(98 %) max:modprobe(98 %, pid:348), readytorun: 3, pgfault 0/s (max 0 avg 0.0)
[ 24.740000][1] dect_loader: fast-bootmode
[ 25.790000][1] [1]system-load 3 loadavg 1.13 0.26 0.8 - 39 tasks:11 % curr:modprobe(11 %) max:modprobe(11 %, pid:348), readytorun: 3, pgfault 0/s (max 0 avg 0.0)
[ 26.710000][0] dect_loader: fast-bootmode
[ 29.310000][1] dect_loader: fast-bootmode
[ 31.280000][0] dect_loader: fast-bootmode
[ 33.880000][1] dect_loader: fast-bootmode
[ 35.850000][0] dect_loader: fast-bootmode
[ 36.890000][0] [0]system-load 5 loadavg 1.57 0.38 0.13 - 39 tasks:85 % curr:modprobe(85 %) max:modprobe(85 %, pid:348), readytorun: 3, pgfault 0/s (max 0 avg 0.0)
[ 38.450000][1] dect_loader: fast-bootmode
[ 39.500000][1] [1]system-load 3 loadavg 1.57 0.38 0.13 - 39 tasks:18 % curr:modprobe(18 %) max:modprobe(18 %, pid:348), readytorun: 3, pgfault 0/s (max 0 avg 0.0)
[ 40.420000][0] dect_loader: fast-bootmode
[ 43.020000][1] dect_loader: fast-bootmode
[ 44.990000][0] dect_loader: fast-bootmode
[ 45.040000]
[ 45.040000] ---- start avmdebug(suppress 0 bytes) ----
[ 45.040000] [ 45.040000][0] dect144xx_file_process: error on upload firstloader '/lib/modules/dectfw_firstlevel_441.hex'
[ 45.040000]
[ 45.040000] ---- eof avmdebug ----
[ 45.060000] Call Trace:
[ 45.060000] [<800296a8>] dump_stack+0x8/0x40
[ 45.060000] [<80060024>] panic+0x64/0x1a0
[ 45.070000] [<c00f8228>] init_module+0x228/0x900 [Piglet_noemif]
[ 45.070000] [<80011a9c>] do_one_initcall+0x3c/0x260
[ 45.080000] [<800a2b78>] sys_init_module+0xd8/0x280
[ 45.080000] [<800059dc>] stack_done+0x20/0x40
[ 45.090000]
[ 45.090000] Kernel panic - not syncing: [piglet]bye bye - can't load dect-fw!
[ 45.090000]
[ 45.100000] Rebooting in 5 seconds..
[ 47.040000] [0]system-load 5 loadavg 1.95 0.50 0.17 - 39 tasks:73 % curr:modprobe(72 %) max:modprobe(72 %, pid:348), readytorun: 8, pgfault 0/s (max 0 avg 0.0)
ROM VER: 1.1.4
CFG 05
** START
RVEC bf200000
Thanks in advance
