sudo tail -f /var/log/openvpn
Sun Aug 31 14:40:14 2014 Diffie-Hellman initialized with 1024 bit key
Sun Aug 31 14:40:14 2014 TLS-Auth MTU parms [ L:1544 D:140 EF:40 EB:0 ET:0 EL:0 ]
Sun Aug 31 14:40:14 2014 Cannot create TCP6 socket: Address family not supported by protocol (errno=97)
Sun Aug 31 14:40:14 2014 Exiting
Sun Aug 31 14:59:35 2014 OpenVPN 2.2.1 arm-linux-gnueabihf [SSL] [LZO2] [EPOLL] [PKCS11] [eurephia] [MH] [PF_INET6] [IPv6 payload 20110424-2 (2.2RC2)] built on Oct 12 2013
Sun Aug 31 14:59:35 2014 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
Sun Aug 31 14:59:35 2014 Diffie-Hellman initialized with 1024 bit key
Sun Aug 31 14:59:35 2014 TLS-Auth MTU parms [ L:1544 D:140 EF:40 EB:0 ET:0 EL:0 ]
Sun Aug 31 14:59:35 2014 Cannot create TCP6 socket: Address family not supported by protocol (errno=97)
Sun Aug 31 14:59:35 2014 Exiting
Das steht bisher drin.
Gestartet wird das ganze automatisch.
Aber auch wenn ich es manuell start, mit "service openvpn start" kommt der selbe fehler.
Jetzt habe ich noch einen Fehler entdeckt:
[FAIL] startpar: service(s) returned failure: openvpn... failed!
