Sent to Udp:192.168.178.1:5060 from Udp:192.168.178.83:5060 at Apr 6 17:02:15.177 (1326 bytes):
INVITE sip:**[email protected] SIP/2.0
Via: SIP/2.0/UDP 192.168.178.83:5060;branch=xxx-xxx;rport
From: "Kommandozentrale" <sip:[email protected]>;tag=xxx
To: <sip:**[email protected]>
Call-ID: xxx-xxx
CSeq: 1 INVITE
Max-Forwards: 70
User-Agent: snomD375/8.9.3.46
Contact: <sip:[email protected]:5060>;reg-id=1
X-Serialnumber: xxx
P-Key-Flags: resolution="31x13", keys="4"
Accept: application/sdp
Allow: INVITE, ACK, CANCEL, BYE, REFER, OPTIONS, NOTIFY, SUBSCRIBE, PRACK, MESSAGE, INFO, UPDATE
Allow-Events: talk, hold, refer, call-info
Supported: timer, replaces, from-change
Session-Expires: 3600
Min-SE: 90
Authorization: Digest username="620",realm="fritz.box",nonce="xxx",uri="sip:[email protected]",response="29b39f6bafd751f0aaaa1283bda8f694",algorithm=MD5
Content-Type: application/sdp
Content-Length: 405
v=0
o=root 879206329 879206329 IN IP4 192.168.178.83
s=call
c=IN IP4 192.168.178.83
t=0 0
m=audio 58990 RTP/AVP 9 0 8 3 99 112 18 101
a=rtpmap:9 G722/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:3 GSM/8000
a=rtpmap:99 G726-32/8000
a=rtpmap:112 AAL2-G726-32/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=ptime:20
a=sendrecv
Received from Udp:192.168.178.1:5060 on Udp:192.168.178.83:5060 at Apr 6 17:02:15.256 (403 bytes):
SIP/2.0 401 Unauthorized
Via: SIP/2.0/UDP 192.168.178.83:5060;branch=xxx-xxx;rport=5060
To: <sip:**[email protected]>;tag=xxx
Call-ID: xxx-xxx
CSeq: 1 INVITE
WWW-Authenticate: Digest realm="fritz.box", nonce="xxx"
User-Agent: FRITZ!OS
Content-Length: 0
Sent to Udp:192.168.178.1:5060 from Udp:192.168.178.83:5060 at Apr 6 17:02:15.268 (412 bytes):
ACK sip:**[email protected] SIP/2.0
Call-ID: xxx-xxx
CSeq: 1 ACK
Max-Forwards: 70
Content-Length: 0
Sent to Udp:192.168.178.1:5060 from Udp:192.168.178.83:5060 at Apr 6 17:02:15.276 (1320 bytes):
Call-ID: xxx-xxx
CSeq: 2 INVITE
Max-Forwards: 70
X-Serialnumber: xxx
Min-SE: 90
Authorization: Digest username="620",realm="fritz.box",nonce="xxx",uri="sip:**[email protected]",response="1fb8fe009174bfe8cf18c89222ada042",algorithm=MD5
Content-Length: 405
v=0
s=call
t=0 0
a=rtpmap:3 GSM/8000
a=fmtp:18 annexb=no
a=fmtp:101 0-15
a=ptime:20
a=sendrecv
Received from Udp:192.168.178.1:5060 on Udp:192.168.178.83:5060 at Apr 6 17:02:15.297 (352 bytes):
SIP/2.0 100 Trying
Call-ID: xxx-xxx
CSeq: 2 INVITE
User-Agent: AVM FRITZ!Box Fon WLAN 7390 84.06.51 TAL (Apr 11 2016)
Content-Length: 0
Received from Udp:192.168.178.1:5060 on Udp:192.168.178.83:5060 at Apr 6 17:02:15.327 (771 bytes):
SIP/2.0 183 Session Progress
Call-ID: xxx-xxx
CSeq: 2 INVITE
Contact: <sip:[email protected]>
Content-Length: 293
v=0
o=user 1988436 1988436 IN IP4 192.168.178.1
s=call
c=IN IP4 192.168.178.1
t=0 0
m=audio 7078 RTP/AVP 9 0 8 99 101
a=fmtp:101 0-15
a=sendrecv
a=rtcp:7079
Received from Udp:192.168.178.1:5060 on Udp:192.168.178.83:5060 at Apr 6 17:02:15.419 (1017 bytes):
SIP/2.0 200 OK
Call-ID: xxx-xxx
CSeq: 2 INVITE
Session-Expires: 3600;refresher=uac
Min-SE: 90
Supported: 100rel,replaces,timer
Allow-Events: telephone-event,refer
Allow: INVITE,ACK,OPTIONS,CANCEL,BYE,UPDATE,PRACK,INFO,SUBSCRIBE,NOTIFY,REFER,MESSAGE,PUBLISH
Accept: application/sdp, multipart/mixed
Accept-Encoding: identity
Content-Length: 269
v=0
o=user 1988436 1988437 IN IP4 192.168.178.1
s=call
t=0 0
m=audio 7078 RTP/AVP 0 8 99 101
a=fmtp:101 0-15
a=sendrecv
a=rtcp:7079
Sent to Udp:192.168.178.1:5060 from Udp:192.168.178.83:5060 at Apr 6 17:02:15.431 (436 bytes):
ACK sip:[email protected] SIP/2.0
Call-ID: xxx-xxx
CSeq: 2 ACK
Max-Forwards: 70
Content-Length: 0
Sent to Udp:192.168.178.1:5060 from Udp:192.168.178.83:5060 at Apr 6 17:02:15.847 (853 bytes):
REGISTER sip:192.168.178.1 SIP/2.0
To: "Kommandozentrale" <sip:[email protected]>
Call-ID: xxx-xxx
CSeq: 7703 REGISTER
Max-Forwards: 70
Contact: <sip:[email protected]:5060>;reg-id=1;q=1.0;audio;mobility="fixed";duplex="full";description="snomD375";actor="principal";events="dialog";methods="INVITE,ACK,CANCEL,BYE,REFER,OPTIONS,NOTIFY,SUBSCRIBE,PRACK,MESSAGE,INFO"
Allow-Events: dialog, talk, hold
X-Real-IP: 192.168.178.83
Supported: path
Authorization: Digest username="620",realm="fritz.box",nonce="xxx",uri="sip:192.168.178.1",response="b0612cfd5639e95435fbe71e11f4cf91",algorithm=MD5
Expires: 3600
Content-Length: 0
Received from Udp:192.168.178.1:5060 on Udp:192.168.178.83:5060 at Apr 6 17:02:15.855 (425 bytes):
To: "Kommandozentrale" <sip:[email protected]>;tag=xxx
Call-ID: xxx-xxx
CSeq: 7703 REGISTER
Content-Length: 0
Sent to Udp:192.168.178.1:5060 from Udp:192.168.178.83:5060 at Apr 6 17:02:15.865 (853 bytes):
Call-ID: xxx-xxx
CSeq: 7704 REGISTER
Max-Forwards: 70
Supported: path
Authorization: Digest username="620",realm="fritz.box",nonce="xxx",uri="sip:192.168.178.1",response="fa2a23fe210d226c96aa58a6d266a976",algorithm=MD5
Expires: 3600
Content-Length: 0
Received from Udp:192.168.178.1:5060 on Udp:192.168.178.83:5060 at Apr 6 17:02:15.871 (873 bytes):
SIP/2.0 200 OK
Call-ID: xxx-xxx
CSeq: 7704 REGISTER
Contact: <sip:[email protected]:5060>;reg-id=1;q=1.0;audio;mobility="fixed";duplex="full";description="snomD375";actor="principal";events="dialog";methods="INVITE,ACK,CANCEL,BYE,REFER,OPTIONS,NOTIFY,SUBSCRIBE,PRACK,MESSAGE,INFO";expires=300
Allow-Events: telephone-event,refer,reg
Content-Length: 0
Sent to Udp:192.168.178.1:5060 from Udp:192.168.178.83:5060 at Apr 6 17:02:47.520 (583 bytes):
BYE sip:[email protected] SIP/2.0
Call-ID: xxx-xxx
CSeq: 3 BYE
Max-Forwards: 70
RTP-RxStat: Total_Rx_Pkts=1602,Rx-Pkts=1578,Rx_Pkts_Lost=0,Remote_Rx_Pkts_Lost=0
RTP-TxStat: Total_Tx_Pkts=1579,Tx_Pkts=1579,Remote_Tx_Pkts=1579
Content-Length: 0
Received from Udp:192.168.178.1:5060 on Udp:192.168.178.83:5060 at Apr 6 17:02:47.532 (701 bytes):
SIP/2.0 200 OK
Call-ID: xxx-xxx
CSeq: 3 BYE
X-RTP-Stat: CS=0;PS=1461;ES=1611;OS=233760;SP=0/0;SO=0;QS=-;PR=1550;ER=1611;OR=248000;CR=0;SR=0;QR=-;PL=0,0;BL=0;LS=0;RB=0/0;SB=-/-;EN=PCMU,G722;DE=PCMU;JI=23,67;DL=8,1,43;IP=192.168.178.1:7078,192.168.178.83:58990
X-RTP-Stat-Add: DQ=1;DSS=0;DS=0;PLCS=2592;JS=0
Content-Length: 0
Sent to Udp:192.168.178.1:5060 from Udp:192.168.178.83:5060 at Apr 6 17:02:53.095 (1322 bytes):
Call-ID: xxx-xxx
CSeq: 1 INVITE
Max-Forwards: 70
X-Serialnumber: xxx
Min-SE: 90
Content-Length: 407
v=0
o=root 1224338313 1224338313 IN IP4 192.168.178.83
s=call
t=0 0
m=audio 57584 RTP/AVP 9 0 8 3 99 112 18 101
a=rtpmap:3 GSM/8000
a=fmtp:18 annexb=no
a=fmtp:101 0-15
a=ptime:20
a=sendrecv
Received from Udp:192.168.178.1:5060 on Udp:192.168.178.83:5060 at Apr 6 17:02:53.214 (403 bytes):
Call-ID: xxx-xxx
CSeq: 1 INVITE
Content-Length: 0
Sent to Udp:192.168.178.1:5060 from Udp:192.168.178.83:5060 at Apr 6 17:02:53.222 (412 bytes):
Call-ID: xxx-xxx
CSeq: 1 ACK
Max-Forwards: 70
Content-Length: 0
Sent to Udp:192.168.178.1:5060 from Udp:192.168.178.83:5060 at Apr 6 17:02:53.231 (1322 bytes):
Call-ID: xxx-xxx
CSeq: 2 INVITE
Max-Forwards: 70
X-Serialnumber: xxx
Min-SE: 90
Authorization: Digest username="620",realm="fritz.box",nonce="xxx",uri="sip:**[email protected]",response="ead5e3d865fc1e695b35106997b1bf91",algorithm=MD5
Content-Length: 407
v=0
s=call
t=0 0
a=rtpmap:3 GSM/8000
a=fmtp:18 annexb=no
a=fmtp:101 0-15
a=ptime:20
a=sendrecv
Received from Udp:192.168.178.1:5060 on Udp:192.168.178.83:5060 at Apr 6 17:02:53.248 (352 bytes):
SIP/2.0 100 Trying
Call-ID: xxx-xxx
CSeq: 2 INVITE
Content-Length: 0
Received from Udp:192.168.178.1:5060 on Udp:192.168.178.83:5060 at Apr 6 17:02:53.275 (771 bytes):
Call-ID: xxx-xxx
CSeq: 2 INVITE
Content-Length: 293
v=0
o=user 8757821 8757821 IN IP4 192.168.178.1
s=call
t=0 0
m=audio 7082 RTP/AVP 9 0 8 99 101
a=fmtp:101 0-15
a=sendrecv
a=rtcp:7083
Received from Udp:192.168.178.1:5060 on Udp:192.168.178.83:5060 at Apr 6 17:02:53.371 (1017 bytes):
SIP/2.0 200 OK
Call-ID: xxx-xxx
CSeq: 2 INVITE
Min-SE: 90
Content-Length: 269
v=0
o=user 8757821 8757822 IN IP4 192.168.178.1
s=call
t=0 0
m=audio 7082 RTP/AVP 0 8 99 101
a=fmtp:101 0-15
a=sendrecv
a=rtcp:7083
Sent to Udp:192.168.178.1:5060 from Udp:192.168.178.83:5060 at Apr 6 17:02:53.383 (436 bytes):
Call-ID: xxx-xxx
CSeq: 2 ACK
Max-Forwards: 70
Content-Length: 0
Sent to Udp:192.168.178.1:5060 from Udp:192.168.178.83:5060 at Apr 6 17:03:10.401 (578 bytes):
Call-ID: xxx-xxx
CSeq: 3 BYE
Max-Forwards: 70
RTP-RxStat: Total_Rx_Pkts=849,Rx-Pkts=825,Rx_Pkts_Lost=0,Remote_Rx_Pkts_Lost=0
RTP-TxStat: Total_Tx_Pkts=825,Tx_Pkts=825,Remote_Tx_Pkts=825
Content-Length: 0
Received from Udp:192.168.178.1:5060 on Udp:192.168.178.83:5060 at Apr 6 17:03:10.413 (695 bytes):
SIP/2.0 200 OK
Call-ID: xxx-xxx
CSeq: 3 BYE
X-RTP-Stat: CS=0;PS=831;ES=857;OS=132960;SP=0/0;SO=0;QS=-;PR=815;ER=857;OR=130400;CR=0;SR=0;QR=-;PL=0,0;BL=0;LS=0;RB=0/0;SB=-/-;EN=PCMU,G722;DE=PCMU;JI=23,0;DL=1,1,2;IP=192.168.178.1:7082,192.168.178.83:57584
X-RTP-Stat-Add: DQ=7;DSS=0;DS=0;PLCS=1664;JS=0
Content-Length: 0
