Several issues after installing freetz-trunk for 7390 ver. 04.22
e-r-a-n
4 Okt 2012
Hello everyone,
I managed to install the firmware on my fritzbox 7390. the 85.05.22 devel 9445
i added few modules, some of them are external as the image was too big
its working ok at the moment except several issues..
1. disk sharing issues
I have two HDD plugged in via HUB, the first is Seagate with 80gb hfs partition, and another 900~gb ntfs partition.
the second drive is samsung 1tb ntfs drive
both were working amazing before, on the genuine 05.22 firmware,
but now i can only see them in FTP, and not all of them..only the seagate, the samsung isnt shown in FTP.
i mainly using mac, but i tried also in windows and the situation is the same..
in mac when i try to connect to smb://fritz.box there're no drives available,
in ftp://fritz.box only seagate and other local folders on the internal memory
2. I cant understand how to make the freetz understand to use the .external file and make the modules available, for example the transmission i added.
3. The user/pass for the telnet..nothing seems to work
Hi e-r-a-n.
3. root/freetz?
2. You have to load it in Freetz Webinterface->Update->external
1. Please show us your .config, the ouput of "mount", "cat /proc/partitions" and your syslog
Regards
Oliver
syslogd wasnt activated, but mount gives the following:
root@fritz:/var/mod/root# mount
rootfs on / type rootfs (rw)
/dev/root on / type squashfs (ro)
proc on /proc type proc (rw)
tmpfs on /var type tmpfs (rw)
dev on /dev type tmpfs (rw,nosuid)
sysfs on /sys type sysfs (rw)
devpts on /dev/pts type devpts (rw,mode=600)
/var/dev/nand on /var/media/ftp type yaffs2 (rw,sync)
usbfs on /proc/bus/usb type usbfs (rw)
/dev/sdb1 on /var/media/ftp/Seagate type fuseblk (rw,user_id=0,group_id=0,allow_other,blksize=4096)
/dev/sdb5 on /var/media/ftp/TimeMachine type hfsplus (ro,umask=0,uid=0,gid=0,nls=utf8)
and cat /proc/partitions:
root@fritz:/var/mod/root# cat /proc/partitions
major minor #blocks name
31 0 13895 mtdblock0
31 1 1336 mtdblock1
31 2 128 mtdblock2
31 3 512 mtdblock3
31 4 512 mtdblock4
31 5 16384 mtdblock5
31 6 524288 mtdblock6
254 0 16384 ramzswap0
8 0 976762584 sda
8 1 976759808 sda1
8 16 976762584 sdb
8 17 892803318 sdb1
8 18 1 sdb2
8 21 83955658 sdb5
EDIT:
I managed to run the .external file and now i have transmission, ssamba and nfs-server in my freetz menu.
however, enabling the nfs-server works after i added to shares "/var/media/" but even then, i try to connect to nfs://fritz.box and get an error.
the new mount and cat/proc/partitions in here:
http://**********com/vsMseagW
I do have samba running however (but i understand that nfs is better), but only after adding Seagate & TimeMachine to shares submenu, i could mount them and even then, only for read, not for write
