Remote management (Fernwartung) does't work?
You have to build an image without replacing the openssl-libs from AVM. So disable the depending packages and everything should work.
Greets, Oliver
I doubt that it will work. As I described in the first post, I reloaded AVM firmware after observing the problem, but it didn't help.
:confused:
