Probleme mit transmission auf freetz-trunk
e-r-a-n
4 Okt 2012
Ich benutze freetz-trunk für meine fritzbox 7390 und sehr glücklich mit ihm.
Ich habe es mit der Übertragung Paket installiert ist.
es war perfekt arbeiten, bis recenty, wo es beginnt zu downloads at 99.something% stoppen und sagt, ich brauche, um Daten zu überprüfen.
oder ich hatte einige 20GB torrent und es war bereits bei 100% und dann fiel er auf 65% ..
Und die ganze Zeit torrents, die suddendly abgeschlossen haben geht zurück auf etwas weniger als 100%
Irgendwelche Ideen, was die Ursache sein?
Ich haben keine Einstellungen geändert, und die hardrive hat atleast 120gb kostenlos.
sure. i didnt want to disrespect anyone by not trying my luck with forum's native language..
I use freetz-trunk for my fritzbox 7390 and very happy with it.
I have it installed with the transfer package.
it was perfectly working until recenty, where it begins to stop downloads at 99.something% and says I need to verify data.
I had some torrent or 20GB and it was already at 100% and then it dropped to 65% ..
And all the time torrents that have completed suddendly goes back to something less than 100%
Any ideas what may be the cause?
I have not changed any settings, and the hardrive has atleast 120gb free.
You are talking about transmission or another package?
Are there any logfiles? I'm not familar with transmission..
Regards
Oliver
Hello Oliver,
Im talking about transmission package, its available in the installation process. i have it as external.
i have syslog, i pasted it in pastebin where the ticket id is xraVesVx
look for "transmission" to see the faulty behavior
Could you please be more precise where I can find your report?
Oliver, an example would be this: Dec 18 16:14:38 fritz daemon.err transmission-daemon[3329]: Dexter.S07E12.720p.HDTV.x264-IMMERSE.mkv Please Verify Local Data! Piece #611 is corrupt. (torrent.c:492)
I looked a bit before & after, there're no other logs which seem related.
er13, with no doubt, you think its just my hdd failing?
its a seagate 1tb very unique model that is used mainly for ongoing activity such as security cameras...sad that it happens only after 2 years.
