Probleme Fritzbox 3270 mit Freetz 1.0.1
Hab nochmal compelliert, hier der Fehler:
STEP 2: MODIFY
applying patches
applying patches (2170-de)
applying patch file ./patches/100-profile.patch
patching file etc/profile
applying patch file ./patches/110-multid-wait.patch
patching file etc/init.d/rc.net
Hunk #1 succeeded at 63 (offset -3 lines).
applying patch file ./patches/110-system_status.patch
patching file usr/bin/system_status
applying patch file ./patches/120-inittab_console.patch
patching file etc/inittab
applying patch file ./patches/130-fstab.patch
patching file etc/fstab
applying patch file ./patches/2170/100-rc.net-dnsmasq.patch
Hunk #1 succeeded at 7 (offset 3 lines).
applying patch file ./patches/2170/110-rc.S-mknod.patch
patching file etc/init.d/rc.S
Hunk #1 FAILED at 221.
1 out of 1 hunk FAILED -- saving rejects to file etc/init.d/rc.S.rej
ERROR: modpatch: Error in patch-file ./patches/2170/110-rc.S-mknod.patch
make: *** [firmware-nocompile] Fehler 2
[Edit frank_m24: Bitte benutzt CODE Tags für solche Ausgaben.]
Und hier die .config
set
# FREETZ_PACKAGE_STREAMRIPPER is not set
# FREETZ_PACKAGE_TINYPROXY is not set
# FREETZ_PACKAGE_TRANSMISSION is not set
# FREETZ_PACKAGE_USBIP is not set
# FREETZ_PACKAGE_USBROOT is not set
# FREETZ_PACKAGE_VIM is not set
# FREETZ_PACKAGE_WGET is not set
# FREETZ_PACKAGE_XRELAYD is not set
FREETZ_PACKAGE_HASERL=y
FREETZ_PACKAGE_MODCGI=y
# Advanced options
# FREETZ_DL_OVERRIDE is not set
FREETZ_DL_SITE="ftp://ftp.avm.de/fritz.box/fritzbox.2170/firmware/deutsch"
FREETZ_DL_SOURCE="FRITZ.Box_2170.51.04.57.image"
# Freetz package download sites
FREETZ_MOD_DL_NUM_SITES="5"
# Download site #1 - default: [url]http://freetz.3dfxatwork.de[/url]
FREETZ_MOD_DL_SITE_1="http://freetz.3dfxatwork.de"
# Download site #2 - default: [url]http://freetz.wirsind.info[/url]
FREETZ_MOD_DL_SITE_2="http://freetz.wirsind.info"
# Download site #3 - default: [url]http://freetz.magenbrot.net[/url]
FREETZ_MOD_DL_SITE_3="http://freetz.magenbrot.net"
# Download site #4 - default: empty (reserved for later use)
FREETZ_MOD_DL_SITE_4=""
# Download site #5 - user-defined
FREETZ_MOD_DL_SITE_5=""
FREETZ_VERBOSITY_LEVEL=2
FREETZ_FAVICON_NONE=y
# FREETZ_FAVICON_DSL123 is not set
# FREETZ_FAVICON_CUMA is not set
# FREETZ_FAVICON_HANSOLO is not set
FREETZ_FAVICON_STRING="none"
FREETZ_SUBVERSION_STRING=y
FREETZ_DEVELOPER_VERSION_STRING=y
# FREETZ_SQUASHFS_BLOCKSIZE_ORIG is not set
# FREETZ_SQUASHFS_BLOCKSIZE_16384 is not set
# FREETZ_SQUASHFS_BLOCKSIZE_32768 is not set
FREETZ_SQUASHFS_BLOCKSIZE_65536=y
# FREETZ_SQUASHFS_BLOCKSIZE_131072 is not set
# BusyBox options
# FREETZ_BUSYBOX_AR is not set
# FREETZ_BUSYBOX_DIFF is not set
# FREETZ_BUSYBOX_INETD is not set
# FREETZ_BUSYBOX_PATCH is not set
# FREETZ_BUSYBOX_START_STOP_DAEMON is not set
FREETZ_BUSYBOX_WGET=y
# FREETZ_BUSYBOX_LESS is not set
# FREETZ_BUSYBOX_NICE is not set
# FREETZ_BUSYBOX_LS_COLOR is not set
# FREETZ_BUSYBOX_FASTPROC is not set
# FREETZ_BUSYBOX_KEYS is not set
# FREETZ_BUSYBOX_BRCTL is not set
# FREETZ_BUSYBOX_UDHCPD is not set
# FREETZ_BUSYBOX_SEQ is not set
# Kernel modules
# crypto
# FREETZ_MODULE_aes is not set
# FREETZ_MODULE_arc4 is not set
# FREETZ_MODULE_sha1 is not set
# FREETZ_MODULE_sha256 is not set
# drivers
# FREETZ_MODULE_loop is not set
# FREETZ_MODULE_nbd is not set
# FREETZ_MODULE_cdrom is not set
# FREETZ_MODULE_capiconn is not set
# FREETZ_MODULE_nand is not set
# FREETZ_MODULE_ohio_nand is not set
# FREETZ_MODULE_dummy is not set
# FREETZ_MODULE_ppp_async is not set
# FREETZ_MODULE_ppp_deflate is not set
# FREETZ_MODULE_ppp_generic is not set
# FREETZ_MODULE_ppp_mppe_mppc is not set
# FREETZ_MODULE_scsi_mod is not set
# FREETZ_MODULE_sd_mod is not set
# FREETZ_MODULE_sg is not set
# FREETZ_MODULE_sr_mod is not set
# FREETZ_MODULE_slhc is not set
# FREETZ_MODULE_usblp is not set
# FREETZ_MODULE_usb_storage is not set
# FREETZ_MODULE_usbmon is not set
# FREETZ_MODULE_usbcore is not set
# FREETZ_MODULE_usbip is not set
# FREETZ_MODULE_usbip_common_mod is not set
# FREETZ_MODULE_usbserial is not set
# FREETZ_MODULE_pl2303 is not set
# FREETZ_MODULE_ftdi_sio is not set
# FREETZ_MODULE_hci_usb is not set
# FREETZ_MODULE_dm_mod is not set
# FREETZ_MODULE_dm_crypt is not set
# fs
# FREETZ_MODULE_cifs is not set
# FREETZ_MODULE_coda is not set
# FREETZ_MODULE_ext3 is not set
# FREETZ_MODULE_ext2 is not set
# FREETZ_MODULE_fat is not set
# FREETZ_MODULE_fuse is not set
# FREETZ_MODULE_jbd is not set
# FREETZ_MODULE_lockd is not set
# FREETZ_MODULE_mini_fo is not set
# FREETZ_MODULE_minix is not set
# FREETZ_MODULE_nfsd is not set
# FREETZ_MODULE_exportfs is not set
# FREETZ_MODULE_nfs is not set
# FREETZ_MODULE_nls_cp437 is not set
# FREETZ_MODULE_nls_cp852 is not set
# FREETZ_MODULE_nls_iso8859_15 is not set
# FREETZ_MODULE_nls_iso8859_1 is not set
# FREETZ_MODULE_nls_utf8 is not set
# FREETZ_MODULE_ntfs is not set
# FREETZ_MODULE_reiserfs is not set
# FREETZ_MODULE_smbfs is not set
# FREETZ_MODULE_udf is not set
# FREETZ_MODULE_unionfs is not set
# FREETZ_MODULE_vfat is not set
# FREETZ_MODULE_msdods is not set
# FREETZ_MODULE_jffs2 is not set
# FREETZ_MODULE_mbcache is not set
# lib
# FREETZ_MODULE_crc_ccitt is not set
# net
# FREETZ_MODULE_bluetooth is not set
# FREETZ_MODULE_l2cap is not set
# FREETZ_MODULE_bnep is not set
# FREETZ_MODULE_rfcomm is not set
# FREETZ_MODULE_sunrpc is not set
# Shared libraries
# FREETZ_STRIP_LIBRARIES is not set
# Libraries -------------------------------
# FREETZ_LIB_libbluetooth is not set
# FREETZ_LIB_libopenobex is not set
# Crypto & SSL
# GnuPG ----------------------------------
# FREETZ_LIB_libgpg_error is not set
# FREETZ_LIB_libgcrypt is not set
# SSL ------------------------------------
# FREETZ_LIB_libcyassl is not set
# FREETZ_LIB_libmatrixssl is not set
# FREETZ_LIB_libxyssl is not set
# FREETZ_LIB_libcrypto is not set
# FREETZ_LIB_libssl is not set
# Data compression
# FREETZ_LIB_liblzo2 is not set
# FREETZ_LIB_libz is not set
# Graphics & fonts
# FREETZ_LIB_libfreetype is not set
# FREETZ_LIB_libart_lgpl_2 is not set
# FREETZ_LIB_libjpeg is not set
# FREETZ_LIB_libpng12 is not set
# uClibc
FREETZ_LIB_ld_uClibc=y
FREETZ_LIB_libcrypt=y
FREETZ_LIB_libdl=y
FREETZ_LIB_libm=y
FREETZ_LIB_libnsl=y
FREETZ_LIB_libpthread=y
# FREETZ_LIB_libresolv is not set
FREETZ_LIB_librt=y
# FREETZ_LIB_libthread_db is not set
FREETZ_LIB_libuClibc=y
# FREETZ_LIB_libutil is not set
# FREETZ_LIB_libuClibcxx is not set
FREETZ_LIB_libgcc_s=y
# FREETZ_LIB_libglib is not set
# GLib2
# FREETZ_LIB_libglib2 is not set
# FREETZ_LIB_libgobject2 is not set
# FREETZ_LIB_libgmodule2 is not set
# FREETZ_LIB_libgthread2 is not set
# ncurses
# FREETZ_LIB_libncurses is not set
# terminfo database
# Select terminfo database entries to install (see help of 'Show all items')
# FREETZ_LIB_libterminfo is not set
# FREETZ_LIB_libform is not set
# FREETZ_LIB_libmenu is not set
# FREETZ_LIB_libpanel is not set
# FREETZ_LIB_libcapi20 is not set
# FREETZ_LIB_libcurl is not set
# FREETZ_LIB_libevent is not set
# FREETZ_LIB_libid3tag is not set
# FREETZ_LIB_libmad is not set
# FREETZ_LIB_libpcap is not set
# Readline
# FREETZ_LIB_libreadline is not set
# FREETZ_LIB_libhistory is not set
# FREETZ_LIB_libusb is not set
# FREETZ_LIB_libelf is not set
# FREETZ_LIB_libintl is not set
# FREETZ_LIB_libiconv is not set
# FREETZ_LIB_libftdi is not set
# FREETZ_LIB_libsysfs is not set
# FREETZ_LIB_libpopt is not set
# FREETZ_LIB_libdevmapper is not set
# Compiler options
FREETZ_DOWNLOAD_TOOLCHAIN=y
# FREETZ_BUILD_TOOLCHAIN is not set
FREETZ_TARGET_CROSS="mipsel-linux-uclibc-"
FREETZ_TARGET_CFLAGS="-Os -pipe -march=4kc -Wa,--trap"
FREETZ_JLEVEL=2
FREETZ_KERNEL_CROSS="mipsel-unknown-linux-gnu-"
FREETZ_KERNEL_VERSION_2_6_13_1=y
# FREETZ_KERNEL_VERSION_2_6_19_2 is not set
FREETZ_KERNEL_VERSION="2.6.13.1"
FREETZ_TARGET_UCLIBC_VERSION_0_9_28=y
# FREETZ_TARGET_UCLIBC_VERSION_0_9_29 is not set
FREETZ_TARGET_GCC_VERSION="4.2.1"
FREETZ_TARGET_UCLIBC_VERSION="0.9.28"
FREETZ_TARGET_BINUTILS_VERSION="2.17.50.0.17"
FREETZ_TARGET_UCLIBC_REF="mod"
# FREETZ_STATIC_TOOLCHAIN is not set
FREETZ_TARGET_GXX=y
# FREETZ_TARGET_CCACHE is not set
# FREETZ_TARGET_NLS is not set
FREETZ_TARGET_LFS=y
FREETZ_KERNEL_GCC_VERSION="3.4.6"
FREETZ_KERNEL_BINUTILS_VERSION="2.17.50.0.17"
# GNU debugger (gdb)
# FREETZ_PACKAGE_GDB is not set
# FREETZ_PACKAGE_GDB_SERVER is not set
# FREETZ_PACKAGE_GDB_HOST is not set
das ganze bitte in code nicht quote-tags.
Das ist auch nicht die ganze-config.
.config sollte man am besten als Datei anhängen und die Meldungen in code-tags
MfG
Okay das tut mir leid ich mach am besten mal einen neuen Thread auf das hier ist ja eigentlich gar nicht mein Problem!
ja aber .. was soll ich nun machen ..
bei mir war das auch noch so das er die original fw auf dem AVM server nicht gefunden hat.. nach einem kleinen check habe ich dann die firmwareversion auf dem avm ftp gefunden und habe den pfad angepasst.
nach einem erneuten "make clean" und make erhielt ich dann die meldung die ich auf der letzten seite postete.
jemand ne idee... ???
cherrs
Also meinst du das das auch mein Problem ist, dass er die Firmware nicht gefunden hat?
ich hoffe ich bekomme hilfe bei meinem problem und habe nur auf die frage von Silent-Tears geantwortet.
aber hätte er die firmaware bei dir nicht gefunden wärst du gar nicht so weit gekommen ..
nun was mach ich mit meinem problem ?
Hunk #1 FAILED at 1.
1 out of 1 hunk FAILED -- saving rejects to file etc/inittab.rej
ERROR: modpatch: Error in patch-file ./patches/120-inittab_console.patch
ach ja 3270 mit aktueller firmware.
@boert
Die aktuelle Firmware wird momentan nicht von Freetz unterstützt. Ich komm erst nächste Woche dazu das in den Trunk einzubauen.
MfG Oliver
nun ja ... jezz kernel ich seit sonntag an dem ding rum ;)
hehe .. so n mist. extra schönes ubuntu gebaut und so.
nun ja aber ich bin jezz ersma ne woche selbst nicht verkernelungsfähig aus zeitlichen gründen. Iss also nich sooo schlimm .. das gröbste hab ich ja wohl erst mal hinter mir .. ich freu mich schon sooo auf freetz !
danke für die antwort oli ;)
cheers
r.
