root@fritz:/var/mod/root# strace /usr/bin/opensc-tool -i
execve("/usr/bin/opensc-tool", ["/usr/bin/opensc-tool", "-i"], [/* 238 vars */]) = 0
old_mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS|0x4000000, -1, 0) = 0x2aaad000
open("/usr/lib/freetz/libdl.so.0", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/mod/lib/libdl.so.0", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/lib/libdl.so.0", O_RDONLY) = 3
fstat(3, {st_mode=S_IFREG|0755, st_size=9196, ...}) = 0
old_mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS|0x4000000, -1, 0) = 0x2aaae000
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\10\0\1\0\0\0\260\7\0\0004\0\0\0"..., 4096) = 4096
old_mmap(NULL, 77824, PROT_NONE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2aabe000
old_mmap(0x2aabe000, 6324, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED, 3, 0) = 0x2aabe000
old_mmap(0x2aacf000, 4208, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x1000) = 0x2aacf000
close(3) = 0
munmap(0x2aaae000, 4096) = 0
open("/usr/lib/freetz/libopensc.so.3", O_RDONLY) = 3
fstat(3, {st_mode=S_IFREG|0755, st_size=849424, ...}) = 0
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\10\0\1\0\0\0000\206\0\0004\0\0\0"..., 4096) = 4096
old_mmap(NULL, 925696, PROT_NONE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2aad1000
old_mmap(0x2aad1000, 819152, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED, 3, 0) = 0x2aad1000
old_mmap(0x2aba9000, 28892, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0xc8000) = 0x2aba9000
old_mmap(0x2abb1000, 6548, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x2abb1000
close(3) = 0
open("/usr/lib/freetz/libgcc_s.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/mod/lib/libgcc_s.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/lib/libgcc_s.so.1", O_RDONLY) = 3
fstat(3, {st_mode=S_IFREG|0666, st_size=55536, ...}) = 0
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\10\0\1\0\0\0p\32\0\0004\0\0\0"..., 4096) = 4096
old_mmap(NULL, 122880, PROT_NONE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2abb3000
old_mmap(0x2abb3000, 53884, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED, 3, 0) = 0x2abb3000
old_mmap(0x2abd0000, 1008, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0xd000) = 0x2abd0000
close(3) = 0
open("/usr/lib/freetz/libpthread.so.0", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/mod/lib/libpthread.so.0", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/lib/libpthread.so.0", O_RDONLY) = 3
fstat(3, {st_mode=S_IFREG|0755, st_size=72488, ...}) = 0
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\10\0\1\0\0\0\3203\0\0004\0\0\0"..., 4096) = 4096
old_mmap(NULL, 147456, PROT_NONE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2abd1000
old_mmap(0x2abd1000, 49800, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED, 3, 0) = 0x2abd1000
old_mmap(0x2abed000, 22124, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0xc000) = 0x2abed000
old_mmap(0x2abf3000, 6528, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x2abf3000
close(3) = 0
open("/usr/lib/freetz/libc.so.0", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/mod/lib/libc.so.0", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/lib/libc.so.0", O_RDONLY) = 3
fstat(3, {st_mode=S_IFREG|0755, st_size=418696, ...}) = 0
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\10\0\1\0\0\0\0\261\0\0004\0\0\0"..., 4096) = 4096
old_mmap(NULL, 507904, PROT_NONE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2abf5000
old_mmap(0x2abf5000, 411868, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED, 3, 0) = 0x2abf5000
old_mmap(0x2ac69000, 8056, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x64000) = 0x2ac69000
old_mmap(0x2ac6b000, 21744, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x2ac6b000
close(3) = 0
close(3) = 0
open("/usr/lib/freetz/libz.so.1", O_RDONLY) = 3
fstat(3, {st_mode=S_IFREG|0755, st_size=74484, ...}) = 0
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\10\0\1\0\0\0000\25\0\0004\0\0\0"..., 4096) = 4096
old_mmap(NULL, 139264, PROT_NONE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2ac71000
old_mmap(0x2ac71000, 72608, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED, 3, 0) = 0x2ac71000
old_mmap(0x2ac92000, 3520, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x11000) = 0x2ac92000
close(3) = 0
close(3) = 0
close(3) = 0
close(3) = 0
close(3) = 0
close(3) = 0
close(3) = 0
close(3) = 0
close(3) = 0
stat("/lib/ld-uClibc.so.0", {st_mode=S_IFREG|0755, st_size=21528, ...}) = 0
mprotect(0x2aacf000, 4096, PROT_READ) = 0
mprotect(0x2abed000, 4096, PROT_READ) = 0
mprotect(0x2ac69000, 4096, PROT_READ) = 0
mprotect(0x2aabc000, 4096, PROT_READ) = 0
ioctl(0, TIOCNXCL, {B38400 opost isig icanon echo ...}) = 0
ioctl(1, TIOCNXCL, {B38400 opost isig icanon echo ...}) = 0
getpid() = 3210
getrlimit(RLIMIT_STACK, {rlim_cur=8192*1024, rlim_max=0}) = 0
setrlimit(RLIMIT_STACK, {rlim_cur=2040*1024, rlim_max=0}) = 0
rt_sigaction(SIGRT_0, {SIG_DFL, [], SA_STACK|SA_INTERRUPT|SA_NOCLDWAIT|0x2bccaf0}, NULL, 16) = 0
rt_sigaction(SIGRT_1, {SIG_DFL, [], SA_STACK|SA_INTERRUPT|SA_SIGINFO|SA_NOCLDWAIT|0x2bcca04}, NULL, 16) = 0
rt_sigaction(SIGRT_2, {SIG_DFL, [], SA_STACK|SA_INTERRUPT|SA_SIGINFO|SA_NOCLDWAIT|0x2bcbee4}, NULL, 16) = 0
rt_sigprocmask(SIG_BLOCK, [RT_0], NULL, 16) = 0
rt_sigprocmask(SIG_UNBLOCK, [RT_1], NULL, 16) = 0
brk(0) = 0x415000
brk(0x416000) = 0x416000
write(1, "opensc", 6opensc) = 6
write(1, " ", 1 ) = 1
write(1, "0.12.2", 60.12.2) = 6
write(1, "[", 1[) = 1
write(1, "gcc ", 4gcc ) = 4
write(1, "4.6.3", 54.6.3) = 5
write(1, "]\n", 2]
) = 2
write(1, "Enabled features:", 17Enabled features:) = 17
write(1, " zlib pcsc(/usr/lib/freetz)", 27 zlib pcsc(/usr/lib/freetz)) = 27
write(1, "\n", 1
) = 1
open("/etc/opensc.conf", O_RDONLY|O_LARGEFILE) = -1 ENOENT (No such file or directory)
open("/usr/lib/freetz", O_RDONLY) = 3
fstat(3, {st_mode=S_IFDIR|0755, st_size=596, ...}) = 0
read(3, 0x2aaae000, 4096) = -1 EISDIR (Is a directory)
old_mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2aaaf000
write(2, "", 0) = 0
write(2, "/usr/bin/opensc-tool", 20/usr/bin/opensc-tool) = 20
write(2, ": '", 3: ') = 3
write(2, "/usr/lib/freetz", 15/usr/lib/freetz) = 15
write(2, "' is not an ELF file\n", 21' is not an ELF file
) = 21
munmap(0x2aaaf000, 4096) = 0
close(3) = 0
open("/usr/lib/freetz/freetz", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/mod/lib/freetz", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/lib/freetz", O_RDONLY) = -1 ENOENT (No such file or directory)
write(2, "", 0) = 0
) = 21
close(3) = 0
open("/usr/X11R6/lib/freetz", O_RDONLY) = -1 ENOENT (No such file or directory)
exit(0) = ?
