sf3978
IPPF-Promi
- Mitglied seit
- 2 Dez 2007
- Beiträge
- 8,014
- Punkte für Reaktionen
- 28
- Punkte
- 48
-DIPTABLES_VERSION=\"1.3.7\" -c -o libiptc/libip4tc.o libiptc/libip4tc.c
iptables.c: In function 'print_firewall':
iptables.c:1412: warning: passing argument 1 of 'ipt_get_target' discards qualifiers from pointer target type
iptables.c: In function 'print_firewall_line':
iptables.c:1525: warning: passing argument 1 of 'ipt_get_target' discards qualifiers from pointer target type
libiptc/libip4tc.c:130: warning: 'dump_entry' defined but not used
CC arch/mips/mm/tlbex.o
arch/mips/kernel/syscall.c: In function `_sys_clone':
arch/mips/kernel/syscall.c:201: warning: cast to pointer from integer of different size
arch/mips/kernel/syscall.c:204: warning: cast to pointer from integer of different size
arch/mips/kernel/syscall.c: In function `sys_ipc':
arch/mips/kernel/syscall.c:337: warning: cast to pointer from integer of different size
CC arch/mips/kernel/time.o
AS arch/mips/mm/tlbex-fault.o
CC arch/mips/mm/ioremap.o
arch/mips/kernel/time.c: In function `time_init':
arch/mips/kernel/time.c:618: warning: implicit declaration of function `init_mips_clocksource'
CC arch/mips/math-emu/ieee754d.o
arch/mips/kernel/init_task.c:16: warning: missing initializer
arch/mips/kernel/init_task.c:16: warning: (near initialization for `init_mm.context')
LDS arch/mips/kernel/vmlinux.lds
Kernel/signal.c: In function `do_sigaltstack':
kernel/signal.c:2396: warning: cast to pointer from integer of different size
CC mm/filemap.o
mm/filemap.c: In function `generic_file_buffered_write':
mm/filemap.c:2182: warning: comparison of unsigned expression >= 0 is always true
CC kernel/sys.o
CC kernel/rcupdate.o
mm/page_alloc.c: In function `alloc_node_mem_map':
mm/page_alloc.c:2464: warning: int format, long unsigned int arg (arg 2)
mm/page_alloc.c:2466: warning: int format, long unsigned int arg (arg 2)
mm/page_alloc.c:2468: warning: unsigned int format, pointer arg (arg 2)
mm/page_alloc.c:2470: warning: unsigned int format, pointer arg (arg 2)
CC kernel/extable.o
CC mm/page-writeback.o
CC kernel/params.o
CC mm/pdflush.o
CC kernel/posix-timers.o
CC mm/readahead.o
CC kernel/kthread.o
CC kernel/wait.o
CC mm/swap.o
CC kernel/kfifo.o
CC mm/truncate.o
CC kernel/sys_ni.o
CC kernel/posix-cpu-timers.o
CC mm/vmscan.o
CC kernel/mutex.o
CC mm/prio_tree.o
CC kernel/hrtimer.o
CC mm/util.o
CC mm/mmzone.o
CC mm/vmstat.o
CC kernel/rwsem.o
CC kernel/latency.o
CC mm/backing-dev.o
CC kernel/nsproxy.o
CC mm/fremap.o
CC kernel/srcu.o
CC mm/highmem.o
CC kernel/env.o
CC kernel/stacktrace.o
CC mm/madvise.o
CC kernel/irq/handle.o
kernel/irq/handle.c:61: warning: missing initializer
kernel/irq/handle.c:61: warning: (near initialization for `irq_desc[0].wake_depth')
CC kernel/irq/manage.o
CC mm/memory.o
CC kernel/irq/spurious.o
CC kernel/irq/resend.o
CC kernel/irq/chip.o
CC mm/mincore.o
CC kernel/irq/autoprobe.o
CC mm/mlock.o
CC kernel/irq/proc.o
CC mm/mmap.o
LD kernel/irq/built-in.o
CC kernel/time/ntp.o
CC kernel/time/clocksource.o
CC mm/mprotect.o
CC kernel/time/jiffies.o
LD kernel/time/built-in.o
CC mm/mremap.o
CC kernel/module.o
CC mm/msync.o
CC mm/rmap.o
kernel/module.c: In function `module_add_driver':
kernel/module.c:2420: warning: ignoring return value of `sysfs_create_link', declared with attribute warn_unused_result
CC kernel/kallsyms.o
CC kernel/ksysfs.o
CC mm/vmalloc.o
CC kernel/softlockup.o
CC mm/bounce.o
LD kernel/built-in.o
CC fs/open.o
CC mm/page_io.o
CC mm/swap_state.o
CC mm/swapfile.o
CC fs/read_write.o
CC mm/thrash.o
CC fs/file_table.o
CC mm/tiny-shmem.o
CC fs/super.o
CC mm/slab.o
mm/slab.c: In function `kmem_cache_create':
mm/slab.c:2229: warning: comparison of unsigned expression < 0 is always false
CC fs/char_dev.o
CC fs/stat.o
LD mm/built-in.o
CC ipc/util.o
CC fs/exec.o
fs/exec.c: In function `count':
fs/exec.c:197: warning: cast to pointer from integer of different size
fs/exec.c: In function `copy_strings':
fs/exec.c:227: warning: cast to pointer from integer of different size
CC ipc/msgutil.o
E_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -c -o pptp_callmgr.o pptp_callmgr.c
/home/slightly/freetz-1.0.1/toolchain/target/bin/mipsel-linux-uclibc-gcc -o pptp pptp.o pptp_gre.o ppp_fcs.o pptp_ctrl.o dirutil.o vector.o inststr.o util.o version.o pptp_quirks.o orckit_quirks.o pqueue.o pptp_callmgr.o -lutil
make[1]: Leaving directory `/home/slightly/freetz-1.0.1/source/pptp-1.7.1'
mkdir -p packages/pptp-1.7.1/root/usr/sbin/
cp source/pptp-1.7.1/pptp packages/pptp-1.7.1/root/usr/sbin/pptp
/home/slightly/freetz-1.0.1/toolchain/target/bin/mipsel-linux-uclibc-strip --remove-section={.comment,.note,.pdr} packages/pptp-1.7.1/root/usr/sbin/pptp
Please copy the following file into the 'dl/fw' sub-directory manually:
FRITZ.Box_Fon_WLAN_7270.Labor.54.04.63-13014.image
make: *** [dl/fw/FRITZ.Box_Fon_WLAN_7270.Labor.54.04.63-13014.image] Fehler 3
also mit tr069 disabled startet die box ständig durch
bei pptp gestartet ist sie ab und an mal 1-2 min online
