[PATCH] lighttpd Konfigurationsfrontend
es liegt an /etc/init.d/rc.lighttpd der kommt mit dem "[" nicht zu recht... :-/
Aber der lighttpd brauch das "["
Bitte entschuldige irgendwie habe ich überlesen das du die andere meinst
das hier ist die /tmp/flash/lighttpd_conf
cat << EOF
server.modules = ( "mod_access", "mod_compress", "mod_webdav" )
index-file.names = ( "index.php", "index.html", "index.cgi",  "index.htm", "default.htm", "index.rb" )
mimetype.assign = (
".pdf" => "application/pdf",
".sig" => "application/pgp-signature",
".spl" => "application/futuresplash",
".class" => "application/octet-stream",
".ps" => "application/postscript",
".torrent" => "application/x-bittorrent",
".dvi" => "application/x-dvi",
".gz" => "application/x-gzip",
".pac" => "application/x-ns-proxy-autoconfig",
".swf" => "application/x-shockwave-flash",
".tar.gz" => "application/x-tgz",
".tgz" => "application/x-tgz",
".tar" => "application/x-tar",
".zip" => "application/zip",
".mp3" => "audio/mpeg",
".m3u" => "audio/x-mpegurl",
".wma" => "audio/x-ms-wma",
".wax" => "audio/x-ms-wax",
".ogg" => "application/ogg",
".wav" => "audio/x-wav",
".gif" => "image/gif",
".jar" => "application/x-java-archive",
".jpg" => "image/jpeg",
".jpeg" => "image/jpeg",
".png" => "image/png",
".xbm" => "image/x-xbitmap",
".xpm" => "image/x-xpixmap",
".xwd" => "image/x-xwindowdump",
".css" => "text/css",
".html" => "text/html",
".htm" => "text/html",
".js" => "text/javascript",
".asc" => "text/plain",
".c" => "text/plain",
".cpp" => "text/plain",
".log" => "text/plain",
".conf" => "text/plain",
".text" => "text/plain",
".txt" => "text/plain",
".dtd" => "text/xml",
".xml" => "text/xml",
".mpeg" => "video/mpeg",
".mpg" => "video/mpeg",
".mov" => "video/quicktime",
".qt" => "video/quicktime",
".avi" => "video/x-msvideo",
".asf" => "video/x-ms-asf",
".asx" => "video/x-ms-asf",
".wmv" => "video/x-ms-wmv",
".bz2" => "application/x-bzip",
".tbz" => "application/x-bzip-compressed-tar",
".tar.bz2" => "application/x-bzip-compressed-tar",
"" => "application/octet-stream",
url.access-deny = ( "~", ".inc" )
static-file.exclude-extensions = ( ".php", ".pl", ".fcgi", ".rb", ".cgi" )
server.port = 85
server.pid-file = "/var/run/lighttpd.pid"
server.username = "wwwrun"
server.groupname = "wwwrun"
connection.kbytes-per-second = 0
server.kbytes-per-second = 0
dir-listing.activate = "enable"
dir-listing.encoding = "utf-8"
server.errorlog = "/var/media/ftp/uStor01/dokumente/intranet/logs/error.log"
server.modules += ( "mod_accesslog" )
accesslog.filename = "/var/media/ftp/uStor01/dokumente/intranet/logs/access.log"
server.modules += ( "mod_status" )
status.enable-sort = "enable"
status.config-url = "/server-config"
 status.statistics-url = "/server-statistics"
 status.status-url = "/server-status"
server.modules += ( "mod_fastcgi" )
fastcgi.server = ( ".php" => (( "socket" => "/var/run/lighttpd/php-fastcgi.socket", "bin-path" => "/var/media/ftp/uStor01/dokumente/intranet/php/php-cgi", "max-procs" => 3 )) )
server.document-root = "/var/media/ftp/uStor01/dokumente/intranet/htdocs/"
compress.cache-dir = "/var/media/ftp/uStor01/dokumente/intranet/cache"
$HTTP["url"] =~ "^/dav($|/)" {
    webdav.activate = "enable"
EOF
oder willst du die haben "/var/mod/etc/lighttpd/lighttpd.conf"?
## Rudi-Editor
## Bitte umgebende Zeilen NICHT löschen ('cat > ...', 'RUDI_EOF')
cat > /var/mod/etc/lighttpd/lighttpd.conf << 'RUDI_EOF'
mimetype.assign = (
server.port = 85
RUDI_EOF
Ja da fehlt nen stück. Vermutlich weil vor HTTP dieses "$" steht schneidet der das einfach weg :-(
Das brauche ich aber da er ansonsten die Config nicht erkennt
http://www.ip-phone-forum.de/showpost.php?p=1512869&postcount=293
Wenn ich die nämlich entferne findet der lighttpd gar keine Konfiguration.
/ # /etc/init.d/rc.lighttpd
Starting lighttpd web server .../ # /tmp/flash/lighttpd_conf: line 3: syntax err
or: unexpected "("
2010-03-28 21:05:46: (configfile.c.1202) a default document-root has to be set
2010-03-28 21:05:46: (server.c.613) setting default values failed
daemon failed.
ich habe das "cat << EOF" entfernt weil ich dachte du meinst das so.
Sorry ich bin kein Großer Linux Kenner somit fällt mir nicht wirklich auf was du genau meinst.
Versuche es mal damit (Anführungszeichen in der zweiten Zeile beachten):
cat > /tmp/flash/lighttpd_conf << 'RUDI_EOF'
cat << 'EOF'
Vielen Dank, das hat funktioniert. :)
:groesste:
Ich habe gerade ein Update zum freetz-devel-4622 durchgeführt damit ich bftpd 2.6 nutzen kann, nun macht mir aber wieder der lighttpd Probleme.
/var/mod/root # /etc/init.d/rc.lighttpd
/usr/bin/modreg file lighttpd_user: Registration without <pkg> argument is depre
cated. Please switch to the new style. See /usr/bin/modreg for more details.
/usr/bin/modreg file lighttpd_rights: Registration without <pkg> argument is dep
recated. Please switch to the new style. See /usr/bin/modreg for more details.
/usr/bin/modreg file lighttpd_add: Registration without <pkg> argument is deprec
Starting lighttpd web server .../var/mod/root # done.
Er lief seit gestern eigentlich wunderbar... Doch nachdem Update startet der nicht mehr. :-/ Es steht zwar da "Starting lighttpd web server ...done." Danach ist er aber auch schon wieder "Stopped"
Ich wollte es nur erstmal melden damit es gefixt werden kann :)
Eigentlich sollten diese deprecated warnings nicht den Start stören. Vielleicht liegts doch an was anderem.
MfG Oliver
Ich habe mir gerade mit der Rudi-Shell
meine Konfiguration (/tmp/flash/lighttpd_conf)
cat << 'EOF'
mimetype.assign = (
server.port = 85
server.modules += ( "mod_fastcgi", "mod_alias" )
alias.url = ( "/mp3/" => "/var/media/ftp/uStor01/fritz/mediabox/" )
EOF
kopiert, danach gelöscht und die Config erneut Hochgeladen, rechte Gesetzt, und Modsave, danach hat es wieder Funktioniert.
Jetzt habe ich die Anlage Neugestartet und mit einmal geht das wieder nicht mehr. :confused:
/var/mod/root # ls -ld /tmp/flash/lighttpd_conf
-rwxr-xr-x 1 root root 3113 Mar 29 13:32 /tmp/flash/lighttpd_conf
/var/mod/root #
EDIT:
Erneut die Konfiguration über Rudi Hochgeladen, erneut chmod 755 /tmp/flash/lighttpd_conf ausgeführt und nochmal modsave, nun geht das ganze wieder mal bis zum nächsten Neustart der Anlage Oo.
Nutze ich aber chmod 755 /tmp/flash/lighttpd_conf und Modsave auf die bereits existierende /tmp/flash/lighttpd_conf an lässt der sich nicht starten Oder besser gesagt beendet der sich gleich wieder nach dem "Starting lighttpd web server ...done."
Ich verstehe ne warum der ständig einen neuen Frischen Dateiupload haben möchte wo eigentlich das gleiche drin steht wie vorher...
Solange ich die Anlage nicht neustarte kann ich den Lighthttpd beenden, neustarten usw. Das geht alles Wunderbar, selbst Änderungen an der Config über Rudi nimmt er an. Ohne Probleme zu machen.
Aber ein Neustart und das wars.
Dann mach das Prozedere bitte nochmal und rufe anschließend statt modsave "modsave flash" auf und poste die Ausgabe.
MfG Oliver
Du meinst also die Anlage Neustarten --> die /tmp/flash/lighttpd_conf löschen --> Mit rudi neu hochladen --> chmod --> modsave flash?
/var/mod/root # modsave flash
Writing /var/flash/freetz...done.
32256 bytes written.
/var/mod/root #
Edit: nun geht selbst mein Trick nicht mehr Oo immer "Starting lighttpd web server ...done." und das wars
Sehr schön. Jetzt bitte ein Reboot und "ls -al /tmp/flash".
MfG Oliver
/var/mod/root # ls -al /tmp/flash
drwxr-xr-x    6 root     root            0 Jan  1  2000 .
drwxrwxrwt    5 root     root            0 Mar 29 15:03 ..
-rw-r--r--    1 root     root          298 Mar 29 12:08 avm-firewall.diff
-rw-r--r--    1 root     root           28 Mar 24 23:05 bftpd.diff
-rwxr-xr-x    1 root     root          934 Mar 25 14:37 bftpd_conf
-rw-r--r--    1 root     root            2 Mar 28 21:59 lighttpd-htdigest.user
-rw-r--r--    1 root     root            1 Mar 28 21:59 lighttpd-rights.user
-rw-r--r--    1 root     root          505 Mar 26 10:32 lighttpd.diff
-rwxr-xr-x    1 root     root         3113 Mar 29 14:56 lighttpd_conf
drwxr-xr-x    2 root     root            0 Jan  1  2000 mod
-rw-r--r--    1 root     root          218 Mar 29 14:49 mod.diff
-rw-r--r--    1 root     root          267 Mar 25 01:22 ntpd.conf
-rw-r--r--    1 root     root           59 Jan  1  2000 openntpd.diff
drwxr-xr-x    2 root     root            0 Mar 17 12:58 php
-rw-r--r--    1 root     root         4100 Mar 17 12:58 php.ini
drwxr-xr-x    2 root     root            0 Jan  1  2000 privoxy
-rw-r--r--    1 root     root           34 Mar 13 11:45 privoxy.diff
drwx------    2 root     root            0 Jan  1  2000 users
-rw-r--r--    1 root     root           91 Mar 24 20:50 vsftpd.diff
/var/mod/root #
Starting lighttpd web server .../var/mod/root # /tmp/flash/lighttpd_conf: line 8
: not found
done.
Ich habe gerade die /tmp/flash/lighttpd_conf gelöscht, dann Lighttpd gestartet, so das er also die default Config nimmt.
Danach wieder beendet meine Config hochgeladen chmod --> Modsave flash und danach hat der sich wieder mit meiner config starten lassen
EDIT3:
Ich hab grade mal das Errorlog überprüft... Ich glaube ich komme den Fehler langsam näher :)
2010-03-29 15:31:24: (log.c.166) server started
2010-03-29 15:31:24: (mod_fastcgi.c.978) bind failed for: unix:/var/run/lighttpd/php-fastcgi.socket-0 No such file or directory
2010-03-29 15:31:24: (mod_fastcgi.c.1399) [ERROR]: spawning fcgi failed.
2010-03-29 15:31:24: (server.c.931) Configuration of plugins failed. Going down.
Ah Langsam verstehe ich das ganze :)
Meine Konfiguration basiert auf der von /etc/init.d/rc.lighttpd.
Da ich aber meine fertige Config nutze übergeht die "/etc/init.d/rc.lighttpd" die ganze Verzeichniserstellung legt also nix an.
somit findet der die Verzeichnisse nicht.
Da ich aber zuerst die Standard Config benutzt habe, haben die ganzen Verzeichnisse usw bereits existiert, somit kam es nicht zu diesen Fehler.
Nachdem Neustart der Anlage waren die aber verschwunden somit trat der Fehler auf.
Nun meine Frage ich habe bereits das Verzeichnis "/var/run/lighttpd/" erstellt und php vom Stick mittels
"/ # cp /var/media/ftp/uStor01/dokumente/intranet/php/php-cgi /var/run/lighttpd/php-fastcgi.socket-0" dorthin kopiert nun bekomme ich diese Meldung
2010-03-29 15:58:22: (mod_fastcgi.c.978) bind failed for: unix:/var/run/lighttpd/php-fastcgi.socket-0 Address already in use
Ich glaube/hoffe das ich langsam auf dem richtigen Weg bin, aber irgendwie weiß ich nun nicht wie es weiter geht.
