bekomme OpenVPN einfach nicht ans laufen.
Möchte gerne 2 FBF beide 7170 miteinander tunneln
mein Eintrag in der debug.cfg der server Box sieht wie folgt aus:
## OpenVPN
#OpenVPN Kopieren und ausfuerbar machen
cp $usbdir/openvpn/openvpn /var/tmp/openvpn
chmod +x /var/tmp/openvpn
#OpenVPN - static.key erzeugen
#wird in die Datei /var/tmp/static.key geschrieben
echo # 2048 bit openvpn static key > /var/tmp/static.key
echo # >> /var/tmp/static.key
echo -----BEGIN OpenVPN Static key V1----- >> /var/tmp/static.key
echo xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx >> /var/tmp/static.key
echo -----END OpenVPN Static key V1----- >> /var/tmp/static.key
chmod 0600 /var/tmp/static.key
#server.conf für openvpn schreiben
#Config-Datei für openvpn tun0 Interface
echo dev tun0 >> /var/tmp/server.conf
echo dev-node /dev/misc/net/tun >> /var/tmp/server.conf
echo ifconfig 192.168.100.1 192.168.100.2 >> /var/tmp/server.conf
echo port 1199 >> /var/tmp/server.conf
echo secret /var/tmp/static.key >> /var/tmp/server.conf
echo tun-mtu 1500 >> /var/tmp/server.conf
echo fragment 1400 >> /var/tmp/server.conf
echo float >> /var/tmp/server.conf
echo keepalive 120 250 >> /var/tmp/server.conf
echo verb 4 >> /var/tmp/server.conf
echo mssfix 1350 >> /var/tmp/server.conf
echo route 192.168.178.0 255.255.255.0 >> /var/tmp/server.conf
chmod 0600 /var/tmp/server.conf
#OpenVPN starten
/var/tmp/openvpn --cd /var/tmp --daemon --config server.conf --dev-node /dev/misc/net/tun
und hier mein Eintrag in der debug.cfg der client Box:
## OpenVPN
cp $usbdir/fritzbox/openvpn/openvpn /var/tmp/openvpn
#client.conf für openvpn schreiben
echo dev tun0 >> /var/tmp/client.conf
echo dev-node /dev/misc/net/tun >> /var/tmp/client.conf
echo remote xxxxx.dyndns.org >> /var/tmp/client.conf
echo ifconfig 192.168.100.2 192.168.100.1 >> /var/tmp/client.conf
echo port 1199 >> /var/tmp/client.conf
echo secret /var/tmp/static.key >> /var/tmp/client.conf
echo tun-mtu 1500 >> /var/tmp/client.conf
echo fragment 1400 >> /var/tmp/client.conf
echo float >> /var/tmp/client.conf
echo keepalive 120 250 >> /var/tmp/client.conf
echo verb 4 >> /var/tmp/client.conf
echo mssfix 1350 >> /var/tmp/client.conf
echo route 192.168.178.0 255.255.255.0 >> /var/tmp/client.conf
chmod 0600 /var/tmp/client.conf
#OpenVPN starten
/var/tmp/openvpn --cd /var/tmp --daemon --config client.conf --dev-node /dev/misc/net/tun
unter remote in der client.conf steht normal die dyndns.org der server Box
benutze den Port 1199, ist das ok, oder muß ich den 1194 verwenden?
den 1199 auf beiden Boxen über die virtuell IP freigeschaltet
Fehlt noch was oder habe ich was falsch gemacht???
Kann mir jemand helfen???
## OpenVPN
#OpenVPN starten
## OpenVPN
#OpenVPN starten
