Sat Oct 26 20:46:57 2013 OpenVPN 2.3.2 mipsel-unknown-linux-gnu [SSL (OpenSSL)] [LZO] [IPv6] built on Oct 16 2013
Sat Oct 26 20:46:57 2013 WARNING: using --pull/--client and --ifconfig together is probably not what you want
Sat Oct 26 20:46:57 2013 Control Channel Authentication: using '/tmp/flash/openvpn/static.key' as a OpenVPN static key file
Sat Oct 26 20:46:57 2013 Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
Sat Oct 26 20:46:57 2013 Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
Sat Oct 26 20:46:57 2013 Socket Buffers: R=[110592->131072] S=[110592->131072]
Sat Oct 26 20:46:57 2013 NOTE: chroot will be delayed because of --client, --pull, or --up-delay
Sat Oct 26 20:46:57 2013 NOTE: UID/GID downgrade will be delayed because of --client, --pull, or --up-delay
Sat Oct 26 20:46:57 2013 UDPv4 link local: [undef]
Sat Oct 26 20:46:57 2013 UDPv4 link remote: [AF_INET]213.232.200.172:1194
Sat Oct 26 20:46:57 2013 TLS: Initial packet from [AF_INET]213.232.200.172:1194, sid=209aba27 39f30f5b
Sat Oct 26 20:46:57 2013 WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
Sat Oct 26 20:46:58 2013 VERIFY OK: depth=1, C=RU, ST=MR, L=Moscow, O=ivacy.com, CN=ivacy.com CA, [email protected]
Sat Oct 26 20:46:58 2013 VERIFY OK: nsCertType=SERVER
Sat Oct 26 20:46:58 2013 VERIFY OK: depth=0, C=RU, ST=MR, L=Moscow, O=ivacy.com, CN=openvpn.ivacy.com, [email protected]
Sat Oct 26 20:47:03 2013 Data Channel Encrypt: Cipher 'BF-CBC' initialized with 128 bit key
Sat Oct 26 20:47:03 2013 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Sat Oct 26 20:47:03 2013 Data Channel Decrypt: Cipher 'BF-CBC' initialized with 128 bit key
Sat Oct 26 20:47:03 2013 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Sat Oct 26 20:47:03 2013 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
Sat Oct 26 20:47:03 2013 [openvpn.ivacy.com] Peer Connection Initiated with [AF_INET]213.232.200.172:1194
Sat Oct 26 20:47:05 2013 SENT CONTROL [openvpn.ivacy.com]: 'PUSH_REQUEST' (status=1)
Sat Oct 26 20:47:05 2013 PUSH: Received control message: 'PUSH_REPLY,route 1.0.0.0 255.0.0.0,dhcp-option DNS 1.254.2.2,dhcp-option DNS 1.254.2.3,dhcp-option DOMAIN vpn,explicit-exit-notify 2,route-gateway 1.2.112.1,topology subnet,ping 10,ping-restart 60,ifconfig 1.2.112.105 255.255.252.0'
Sat Oct 26 20:47:05 2013 Options error: Unrecognized option or missing parameter(s) in [PUSH-OPTIONS]:5: explicit-exit-notify (2.3.2)
Sat Oct 26 20:47:05 2013 OPTIONS IMPORT: timers and/or timeouts modified
Sat Oct 26 20:47:05 2013 OPTIONS IMPORT: --ifconfig/up options modified
Sat Oct 26 20:47:05 2013 OPTIONS IMPORT: route options modified
Sat Oct 26 20:47:05 2013 OPTIONS IMPORT: route-related options modified
Sat Oct 26 20:47:05 2013 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
Sat Oct 26 20:47:05 2013 TUN/TAP device tun0 opened
Sat Oct 26 20:47:05 2013 TUN/TAP TX queue length set to 100
Sat Oct 26 20:47:05 2013 do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
Sat Oct 26 20:47:05 2013 /sbin/ifconfig tun0 1.2.112.105 netmask 255.255.252.0 mtu 1500 broadcast 1.2.115.255
Sat Oct 26 20:47:05 2013 /sbin/route add -net 1.0.0.0 netmask 255.0.0.0 gw 1.2.112.1
Sat Oct 26 20:47:05 2013 chroot to '/var/tmp/openvpn' and cd to '/' succeeded
Sat Oct 26 20:47:05 2013 GID set to openvpn
Sat Oct 26 20:47:05 2013 UID set to openvpn
Sat Oct 26 20:47:05 2013 Initialization Sequence Completed
Sat Oct 26 21:47:03 2013 TLS: soft reset sec=0 bytes=38231/0 pkts=714/0
Sat Oct 26 21:47:04 2013 VERIFY OK: depth=1, C=RU, ST=MR, L=Moscow, O=ivacy.com, CN=ivacy.com CA, [email protected]
Sat Oct 26 21:47:04 2013 VERIFY OK: nsCertType=SERVER
Sat Oct 26 21:47:04 2013 VERIFY OK: depth=0, C=RU, ST=MR, L=Moscow, O=ivacy.com, CN=openvpn.ivacy.com, [email protected]
Sat Oct 26 21:47:08 2013 Data Channel Encrypt: Cipher 'BF-CBC' initialized with 128 bit key
Sat Oct 26 21:47:08 2013 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Sat Oct 26 21:47:08 2013 Data Channel Decrypt: Cipher 'BF-CBC' initialized with 128 bit key
Sat Oct 26 21:47:08 2013 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Sat Oct 26 21:47:08 2013 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
Sat Oct 26 21:48:09 2013 [openvpn.ivacy.com] Inactivity timeout (--ping-restart), restarting
Sat Oct 26 21:48:09 2013 SIGUSR1[soft,ping-restart] received, process restarting
Sat Oct 26 21:48:09 2013 Restart pause, 2 second(s)
Sat Oct 26 21:48:11 2013 Socket Buffers: R=[110592->131072] S=[110592->131072]
Sat Oct 26 21:48:11 2013 UDPv4 link local: [undef]
Sat Oct 26 21:48:11 2013 UDPv4 link remote: [AF_INET]213.232.200.172:1194
Sat Oct 26 21:48:11 2013 TLS: Initial packet from [AF_INET]213.232.200.172:1194, sid=4bc06035 d6032839
Sat Oct 26 21:48:11 2013 VERIFY OK: depth=1, C=RU, ST=MR, L=Moscow, O=ivacy.com, CN=ivacy.com CA, [email protected]
Sat Oct 26 21:48:11 2013 VERIFY OK: nsCertType=SERVER
Sat Oct 26 21:48:11 2013 VERIFY OK: depth=0, C=RU, ST=MR, L=Moscow, O=ivacy.com, CN=openvpn.ivacy.com, [email protected]
Sat Oct 26 21:48:16 2013 Data Channel Encrypt: Cipher 'BF-CBC' initialized with 128 bit key
Sat Oct 26 21:48:16 2013 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Sat Oct 26 21:48:16 2013 Data Channel Decrypt: Cipher 'BF-CBC' initialized with 128 bit key
Sat Oct 26 21:48:16 2013 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Sat Oct 26 21:48:16 2013 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
Sat Oct 26 21:48:16 2013 [openvpn.ivacy.com] Peer Connection Initiated with [AF_INET]213.232.200.172:1194
Sat Oct 26 21:48:18 2013 SENT CONTROL [openvpn.ivacy.com]: 'PUSH_REQUEST' (status=1)
Sat Oct 26 21:48:18 2013 PUSH: Received control message: 'PUSH_REPLY,route 1.0.0.0 255.0.0.0,dhcp-option DNS 1.254.2.2,dhcp-option DNS 1.254.2.3,dhcp-option DOMAIN vpn,explicit-exit-notify 2,route-gateway 1.2.112.1,topology subnet,ping 10,ping-restart 60,ifconfig 1.2.112.11 255.255.252.0'
Sat Oct 26 21:48:18 2013 Options error: Unrecognized option or missing parameter(s) in [PUSH-OPTIONS]:5: explicit-exit-notify (2.3.2)
Sat Oct 26 21:48:18 2013 OPTIONS IMPORT: timers and/or timeouts modified
Sat Oct 26 21:48:18 2013 OPTIONS IMPORT: --ifconfig/up options modified
Sat Oct 26 21:48:18 2013 OPTIONS IMPORT: route options modified
Sat Oct 26 21:48:18 2013 OPTIONS IMPORT: route-related options modified
Sat Oct 26 21:48:18 2013 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
Sat Oct 26 21:48:18 2013 Preserving previous TUN/TAP instance: tun0
Sat Oct 26 21:48:18 2013 NOTE: Pulled options changed on restart, will need to close and reopen TUN/TAP device.
Sat Oct 26 21:48:18 2013 /sbin/route del -net 1.0.0.0 netmask 255.0.0.0
Sat Oct 26 21:48:18 2013 ERROR: Linux route delete command failed: could not execute external program
Sat Oct 26 21:48:18 2013 Closing TUN/TAP interface
Sat Oct 26 21:48:18 2013 /sbin/ifconfig tun0 0.0.0.0
Sat Oct 26 21:48:18 2013 Linux ip addr del failed: could not execute external program
Sat Oct 26 21:48:20 2013 ERROR: Cannot open TUN/TAP dev /dev/net/tun: No such file or directory (errno=2)
Sat Oct 26 21:48:20 2013 Exiting due to fatal error
