Why such returns do not show me the reason, knowing that I have updated the Firmware revision is V3.40(AOF.2)D0??
There is an image attached please help>>>
What do you want to say? I assume, that you don´t use AVM Fritzbox. Then you should open a own threat for your problem. Have you talked with O2 hotline to clear up problems?
