No web interface on FBF
leijona
8 Mai 2008
Hello,
excuse my english but I am kind of desperate. I have an FBF (international version , annex A, firmware 06.04.49) not used as router nor modem. I have it running openvpn. In order to save memory I wanted to stop as many daemons as I could without interupting its working order. I stopped the dsld , the igdd and the ctlmng without any problem. Everything was fine until I saw the multid. I edited the /var/flash/debug.cfg file to stop the multid. Now I am left with no access to the web interface nor telnet !!!! The box replys to ping requests. Is there any way to start the multid again ??? or I am screwed .... :noidea:
Did you try to reset the box by telephone? Connect a telephone to the box box and dial
#991*15901590*
Then the box will reset to factory settings.
Thanks for your suggestion only it didn't resolve my problem. Someone suggested a firmware upgrade tool that works without the web interface. I downloaded it from ftp://ftp.avm.de/fritz.box . That tool erased and wrote the flash from the beginning so my FBF is as new.
Now the problem is that I cannot pass the pseudo_update.image that I created using the-construct.com online tool. When I click the update button depending with the browser and the version it either shows the overview page right away or freezes for a while and shows the overview page again.
Any ideas why this is happening ?
Dont bother .... silly me, I restarted the box and worked. Thanks anyhow
