Neuer SCCP-Channeltreiber
Wo bekomme ich die Firmware her?
Gruss
sWastel
Gruss
sWastel
Bei dem Cisco-Händler deines Vertrauens!
Kurzum man braucht eine Lizenz (CCO) die ungefähr 150 Dollar/Euro? kostet um die Firmware downloaden zu können. SCCP/Skinny-Firmwareversionen findet man leider auch nicht über den Esel, da die meisten Anwender wohl SIP favorisieren.
Folgendes fand ich noch zum CTL-File:
Security Configuration Screen
The Security Configuration screen shows the following information:
•Web Access—Indicates whether web access is enabled (Yes) or disabled (No) for the phone. You configure web access in Cisco CallManager Administration.
•Security Mode—Displays the security mode that is set for the phone. You configure the security mode in Cisco CallManager Administration.
•MIC—Indicates whether a manufacturing installed certificate (used for the security features) is installed on the phone (Yes) or is not installed on the phone (No).
•LSC—Indicates whether a locally significant certificate (used for the security features) is installed on the phone (Yes) or is not installed on the phone (No).
•CTL—Displays the MD5 hash of the certificate trust list (CTL) file that is installed in the phone. If no CTL file is installed on the phone, this field displays No. (If security is configured for the phone, the CTL file installs automatically when the phone reboots or resets. For more information about this file, refer to Cisco IP Phone Authentication and Encryption for Cisco CallManager 4.0(1).)
To display the Security Configuration screen, press the Settings button and then select Security Configuration.
To exit the Security Configuration screen, press the Exit softkey.
If neither the primary TFTP server nor the backup TFTP server is listed in the CTL file, you must unlock the CTL file before you can save changes that you make on the Network Configuration menu to the TFTP Server 1 option or the TFTP Server 2 option. (For information about changing these options, see the "Network Configuration Menu" section on page 4-6.) To unlock the CTL file from the Security Configuration screen, follow these steps:
Procedure
Step 1 Press **# to unlock options on the Security Configuration menu.
If you decide not to continue, press **# again to lock options on this menu.
Step 2 Highlight the CTL option.
Step 3 Press the Unlock softkey to unlock the CTL file.
After you change and save the TFTP Server 1 or the TFTP Server 2 option, the CTL file will be locked automatically.
Note When you press the Unlock softkey, it changes to Lock. If you decide not to change the TFTP Server 1 or TFTP Server 2 option, press the Lock softkey to lock the CTL file.
Hab nur noch die XMLDefault.cnf.xml im tftp!
In der Asterisk Console:
asterisk*CLI> sccp show devices
NAME             ADDRESS         MAC              CALLID
Phone7970        10.253.1.29     SEP0014A89EF88A
asterisk*CLI> sccp show lines
NAME             DEVICE           MWI  Chs  Active Channel
79701            SEP0014A89EF88A  OFF  0    --
asterisk*CLI>
sccp.conf
asterisk # cat sccp.conf
; (SCCP*)
; An implementation of Skinny Client Control Protocol (SCCP)
; Sergio Chersovani ([email protected])
; http://chan-sccp.belios.de
[general]
keepalive = 300                         ; phone keep alive message evey 60 secs. Used to check the voicemail
debug = 10                                      ; console debug level. 1 => 10
context = outgoing
dateFormat = D-M-Y                      ; M-D-Y in any order. Use M/D/YA (for 12h format)
bindaddr = 10.253.1.25                  ; replace with the ip address of the asterisk server (RTP important param)
port = 2000                                     ; listen on port 2000 (Skinny, default)
disallow=all                            ; First disallow all codecs
allow=ulaw                                      ; Allow codecs in order of preference
;allow=alaw                                     ;
;firstdigittimeout = 16                 ; dialing timeout for the 1st digit
;digittimeout = 8                               ; more digits
[devices]
type        = 7970                                      ; device type (see below)
autologin   = 79701,,79701  ; lines list. You can add an empty line for an empty button (7960, 7970, 7940, 7920)
description = Phone7970                         ; internal description. Not important
;tzoffset  = +2
transfer = 1                                            ; enable or disable the transfer capability. It does remove the transfer softkey
;speeddial =                                            ; you can add an empty speedial if you want an empty button (7960, 7970, 7920)
;speeddial = 1000,name                          ; speeddial number and name
device => SEP0014A89EF88A                       ; device name SEP<MAC>
[lines]
id          = 1000                      ; future use
pin         = 1234                      ; future use
label       = 79701                     ; button line label (7960, 7970, 7940, 7920)
description = Line 79701                ; top diplay description
context     = outgoing
incominglimit = 1                       ; more than 1 incoming call = call waiting.
transfer = 1                            ; per line transfer capability. on, off, 1, 0
;mailbox = 1001                         ; voicemail.conf (syntax: vmbox[@context][:folder])
;vmnum = 600                                    ; voicemail number to dial
cid_name = cisco                        ; caller id name
cid_num = 79701
line => 79701
; phone types
;    12 -- Cisco IP Phone 12SP+ (or other 12 variants)
;    30 -- Cisco IP Phone 30VIP (or other 30 variants)
;  7902 -- Cisco IP Phone 7902G
;  7905 -- Cisco IP Phone 7905G
;  7910 -- Cisco IP Phone 7910
;  7912 -- Cisco IP Phone 7912G
;  7935 -- Cisco IP Conference Station 7935
;  7936 -- Cisco IP Conference Station 7936
;  7920 -- Cisco IP Wireless Phone 7920
;  7940 -- Cisco IP Phone 7940
;  7960 -- Cisco IP Phone 7960
;  7970 -- Cisco IP Phone 7970
;  7914 -- Cisco IP Phone 7960 with a 7914 addon
;   ata -- Cisco ATA-186 or Cisco ATA-188 (untested)
asterisk #
Kannst du mal deine sccp.conf mir geben?
Und den Abschnitt der extensions.conf!
Gruss
sWastel
sorry - aber ich habe kein 7970!
Deine sccp.conf ist wohl in Ordnung (sonst wäre das phone nicht angemeldet).
gewählt wird wie folgt: ...dial(SCCP/79701,,)
Wenn sich das Telefon anmeldet! Kommt dies am Ende:
--schnipp---
    -- SEP0014A89EF88A: CISCO:    16 G.729 Annex A + B         AST:     0 unknown
    -- SEP0014A89EF88A: CISCO:    11 G.729                     AST:     0 unknown
    -- SEP0014A89EF88A: CISCO:    12 G.729 Annex A             AST:   256 G.729A
    -- SEP0014A89EF88A: >> Got message LineStatReqMessage
    -- SEP0014A89EF88A: Configuring line number 1
    -- SEP0014A89EF88A: >> Got message ForwardStatReqMessage
    -- SEP0014A89EF88A: Got Forward Status Request.  Line: 1
    -- SCCP: cleanup old sessions of 10.253.1.29
    -- SEP0014A89EF88A: Old session marked down
    -- SCCP: Accepted connection from 10.253.1.29
    -- SCCP: Using ip 10.253.1.25
    -- SEP0014A89EF88A: Killing Session 10.253.1.29
asterisk*CLI>
Liegt das an der Fehlenden Firmware?
Gruss
sWastel
Du solltest die Frage am besten über die mailing-list stellen:
http://lists.berlios.de/pipermail/chan-sccp-users/
PS: dein phone braucht eine feste IP bzw. im DHCP-Server die IP an die Mac-Adresse binden. Es sieht nämlich so aus, dass der dhcp-lease abgelaufen ist und das phone in kurzen Abständen immer eine Neue erhält!
Das einzige was noch fehlt, sind die Firmware Dateien!
Bekommt man die noch wo anders her, als von Cisco?
Gruss
sWastel
Gruss
sWastel
Legal jedenfalls nicht!
Frag mal an wo du dein phone gekauft hast.
Das Telefon hab ich ersteigert!
Gruss
sWastel
Dann solltest du dich an den Verkäufer halten oder eine Lizenz erwerben, was jedoch für Privatleute sehr schwierig ist. Wenn dies alles nicht hilft hast du einen Briefbeschwerer ersteigert!
PS: Ich habe meine beiden phones mit Firmware und Lizenz bei ebay gekauft s.o.
So hab ich jetzt die Firmware! Auf dem Telefon war Firmware 6 drauf!
Habe einen Factory Reset durchgeführt!
Jetzt bootet das Telefon immer neu, und die Birnchen blinken die ganze Zeit!
Was muss ich tuen?
Gruss
sWastel
Ich hatte dir verschiedene Links u.a. zu mailinglisten gepostet - die musst du lesen!!!
@Netview Danke für deine Unterstützung!
Jetzt funktioniert das Cisco 7970G.
Ich hab vergessen beim dhcp server den tftp einzutragen!
Gruss
sWastel
Keine Mitglieder online.
phili2025
