Q:What is Dial Plan used for?How to configure it?
A
ial plan is used to convert the number dialed to the number actually sent based on "dial number", "ddd prefix", "idd prefix", "ddd code", "idd code"these parameters. Parameter "use dial plan"contains 5 options:
1."disable"
Number sent is the same as number dialed.
2."enable"
If the number dialed is prefixed by "idd prefix", the number sent will be the rest part of the number dialed dropping off the "idd prefix".
Otherwise, if the number dialed is prefixed by "ddd prefix", the number sent will be "idd code"+ the rest part of the number dialed dropping off the "ddd prefix".
Otherwise, the number sent will be "idd code"+ "ddd code"+ the number dialed.
For example: set "ddd code"= 10, "idd code"=86, "idd prefix"=00, "ddd prefix"=0.
If the number dialed is 00-1-4089821818, the number sent will be 1-4089821818.
If the number dialed is 021-82378008, the number sent will be 8621-82378008.
If the number dialed is 82378008, the number sent will be 861082378008.
3."dial number"
Convert the number dialed to a new number according to "enable"dial plan, then prefix "dial number"to this new number. This new number is the number sent.
4."prefix"
Effective only when "dial number"is not empty. This serves for those calling cards.
The number sent is just "dial number". During the call connection, program will automatically send out a number made up with ["account"+ "pin"+ number converted by "enable"dial plan + ‘#’].
5."hotline"
The number sent is "dial number". Whenever the handset is lifted up, this number will be automatically dialed out.
