[Problem] Linphone PC vs. Linphone Android
usefulvid
20 Jun 2018
Ich bekomme am PC eine Verbindung zu Vodafone Kabel hin:
https://usefulvid.com/vodafone-kabel-deutschland-sip-linphone/
Auf dem Android Smartphone bekomme ich mit gleichen (?) Einstellungen keine Verbindung hin:
2018-06-27 15:47:07:456 [belle-sip] MESSAGE channel [0x92dd5400]: keep alive sent to [UDP://sip.kabelfon.vodafone.de:5060]
2018-06-27 15:47:20:010 [mediastreamer] MESSAGE Activity started:org.linphone.assistant.AssistantActivity@3a88259
2018-06-27 15:47:20:011 [mediastreamer] MESSAGE Activity resumed:org.linphone.assistant.AssistantActivity@3a88259
2018-06-27 15:47:20:011 [mediastreamer] MESSAGE runningActivities=1
2018-06-27 15:47:20:011 [mediastreamer] MESSAGE App has left background mode
2018-06-27 15:47:20:013 [liblinphone] MESSAGE Core callbacks [0x92621050] registered on core [0xa3a9b300]
2018-06-27 15:47:20:013 [liblinphone] MESSAGE Core callbacks [0x92621078] registered on core [0xa3a9b300]
2018-06-27 15:47:20:778 [liblinphone] MESSAGE Callbacks [0x92621078] unregistered on core [0xa3a9b300]
2018-06-27 15:47:20:778 [liblinphone] MESSAGE Callbacks [0x92621050] unregistered on core [0xa3a9b300]
2018-06-27 15:47:20:779 [mediastreamer] MESSAGE Activity paused:org.linphone.assistant.AssistantActivity@3a88259
2018-06-27 15:47:20:779 [mediastreamer] MESSAGE runningActivities=0
2018-06-27 15:47:20:843 [mediastreamer] MESSAGE Activity stopped:org.linphone.assistant.AssistantActivity@3a88259
2018-06-27 15:47:22:779 [mediastreamer] MESSAGE App has entered background mode
2018-06-27 15:47:29:391 [mediastreamer] MESSAGE Activity started:org.linphone.assistant.AssistantActivity@3a88259
2018-06-27 15:47:29:393 [mediastreamer] MESSAGE Activity resumed:org.linphone.assistant.AssistantActivity@3a88259
2018-06-27 15:47:29:393 [mediastreamer] MESSAGE runningActivities=1
2018-06-27 15:47:29:393 [mediastreamer] MESSAGE App has left background mode
2018-06-27 15:47:29:395 [liblinphone] MESSAGE Core callbacks [0x926210a0] registered on core [0xa3a9b300]
2018-06-27 15:47:29:396 [liblinphone] MESSAGE Core callbacks [0x926230f8] registered on core [0xa3a9b300]
2018-06-27 15:47:32:515 [liblinphone] MESSAGE Callbacks [0x926230f8] unregistered on core [0xa3a9b300]
2018-06-27 15:47:32:515 [liblinphone] MESSAGE Callbacks [0x926210a0] unregistered on core [0xa3a9b300]
2018-06-27 15:47:32:516 [mediastreamer] MESSAGE Activity paused:org.linphone.assistant.AssistantActivity@3a88259
2018-06-27 15:47:32:516 [mediastreamer] MESSAGE runningActivities=0
2018-06-27 15:47:32:612 [mediastreamer] MESSAGE Activity stopped:org.linphone.assistant.AssistantActivity@3a88259
2018-06-27 15:47:34:517 [mediastreamer] MESSAGE App has entered background mode
2018-06-27 15:47:37:460 [belle-sip] MESSAGE channel [0x92dd5400]: keep alive sent to [UDP://sip.kabelfon.vodafone.de:5060]
2018-06-27 15:47:39:137 [mediastreamer] MESSAGE Activity started:org.linphone.assistant.AssistantActivity@3a88259
2018-06-27 15:47:39:139 [mediastreamer] MESSAGE Activity resumed:org.linphone.assistant.AssistantActivity@3a88259
2018-06-27 15:47:39:139 [mediastreamer] MESSAGE runningActivities=1
2018-06-27 15:47:39:140 [mediastreamer] MESSAGE App has left background mode
2018-06-27 15:47:39:141 [liblinphone] MESSAGE Core callbacks [0x92625038] registered on core [0xa3a9b300]
2018-06-27 15:47:39:142 [liblinphone] MESSAGE Core callbacks [0x92625060] registered on core [0xa3a9b300]
2018-06-27 15:47:44:069 [liblinphone] MESSAGE Callbacks [0x92625060] unregistered on core [0xa3a9b300]
2018-06-27 15:47:44:069 [liblinphone] MESSAGE Callbacks [0x92625038] unregistered on core [0xa3a9b300]
2018-06-27 15:47:44:070 [mediastreamer] MESSAGE Activity paused:org.linphone.assistant.AssistantActivity@3a88259
2018-06-27 15:47:44:070 [mediastreamer] MESSAGE runningActivities=0
2018-06-27 15:47:44:195 [mediastreamer] MESSAGE Activity stopped:org.linphone.assistant.AssistantActivity@3a88259
2018-06-27 15:47:46:071 [mediastreamer] MESSAGE App has entered background mode
2018-06-27 15:47:56:613 [mediastreamer] MESSAGE Activity started:org.linphone.assistant.AssistantActivity@3a88259
2018-06-27 15:47:56:615 [mediastreamer] MESSAGE Activity resumed:org.linphone.assistant.AssistantActivity@3a88259
2018-06-27 15:47:56:615 [mediastreamer] MESSAGE runningActivities=1
2018-06-27 15:47:56:615 [mediastreamer] MESSAGE App has left background mode
2018-06-27 15:47:56:618 [liblinphone] MESSAGE Core callbacks [0x92625088] registered on core [0xa3a9b300]
2018-06-27 15:47:56:619 [liblinphone] MESSAGE Core callbacks [0x926250b0] registered on core [0xa3a9b300]
2018-06-27 15:48:01:375 [liblinphone] MESSAGE Callbacks [0x926250b0] unregistered on core [0xa3a9b300]
2018-06-27 15:48:01:375 [liblinphone] MESSAGE Callbacks [0x92625088] unregistered on core [0xa3a9b300]
2018-06-27 15:48:01:376 [mediastreamer] MESSAGE Activity paused:org.linphone.assistant.AssistantActivity@3a88259
2018-06-27 15:48:01:376 [mediastreamer] MESSAGE runningActivities=0
2018-06-27 15:48:01:462 [mediastreamer] MESSAGE Activity stopped:org.linphone.assistant.AssistantActivity@3a88259
2018-06-27 15:48:03:377 [mediastreamer] MESSAGE App has entered background mode
2018-06-27 15:48:07:479 [belle-sip] MESSAGE channel [0x92dd5400]: keep alive sent to [UDP://sip.kabelfon.vodafone.de:5060]
2018-06-27 15:48:07:925 [mediastreamer] MESSAGE Activity started:org.linphone.assistant.AssistantActivity@3a88259
2018-06-27 15:48:07:926 [mediastreamer] MESSAGE Activity resumed:org.linphone.assistant.AssistantActivity@3a88259
2018-06-27 15:48:07:929 [mediastreamer] MESSAGE runningActivities=1
2018-06-27 15:48:07:929 [mediastreamer] MESSAGE App has left background mode
2018-06-27 15:48:07:931 [liblinphone] MESSAGE Core callbacks [0x926250d8] registered on core [0xa3a9b300]
2018-06-27 15:48:07:931 [liblinphone] MESSAGE Core callbacks [0x92625e20] registered on core [0xa3a9b300]
2018-06-27 15:48:23:239 [liblinphone] MESSAGE linphone_proxy_config_is_server_config_changed : 0
2018-06-27 15:48:23:244 [liblinphone] MESSAGE Publish params have changed on proxy config [0x91bb1380]
2018-06-27 15:48:23:245 [liblinphone] MESSAGE linphone_core_find_auth_info(): returning auth info username=+493322xxxxxx, realm=technik.kabel-deutschland.de
2018-06-27 15:48:23:293 [liblinphone] MESSAGE LinphoneProxyConfig [0x91bb1380] about to register (LinphoneCore version: 3.12.0-2403-gc448d2e00)
2018-06-27 15:48:23:324 [belle-sip] MESSAGE bellesip_wake_lock_acquire(): Android wake lock [belle-sip transaction(0x92299ce0)] acquired [ref=0xb9a]
2018-06-27 15:48:23:325 [belle-sip] MESSAGE transaction [0x92299ce0]: starting transaction background task with id=[b9a].
2018-06-27 15:48:23:325 [belle-sip] MESSAGE Changing [client] [REGISTER] transaction [0x92299ce0], from state [INIT] to [TRYING]
2018-06-27 15:48:23:326 [belle-sip] MESSAGE channel [0x92dd5400]: message sent to [UDP://sip.kabelfon.vodafone.de:5060], size: [878] bytes
REGISTER sip:sip.kabelfon.vodafone.de SIP/2.0
Via: SIP/2.0/UDP 192.168.0.106:46511;branch=z9hG4bK.V-RK4i2RP;rport
To: sip:[email protected]
CSeq: 20 REGISTER
Call-ID: 7Wm2gv8KzK
Max-Forwards: 70
Supported: replaces, outbound, gruu
Accept: application/sdp
Accept: text/plain
Accept: application/vnd.gsma.rcs-ft-http+xml
Contact: <sip:[email protected]:46511;app-id=929724111839;pn-type=firebase;pn-tok=cONlYuFBPds:APA91bHrBtwPbMW3EJuN7aSD_rl2rQJcunAGWYQYCQ60wxgRDBMlnteSa5IIozTr5rmcax5RAGvO1GI9fb3HOMUcOKO20afETsC33eMT-mud9DgAueLNNRvUhiJ3MtRy9j_o0QtBw4r2GuG_jI0wHgB7_6vX16vS_A;pn-silent=1;transport=udp>;+sip.instance="<urn:uuid:83a72315-3616-409b-8727-e67b5d4c7278>";+org.linphone.specs=groupchat
Expires: 3600
User-Agent: LinphoneAndroid/4.0.0 (belle-sip/1.6.3)
2018-06-27 15:48:23:326 [belle-sip] MESSAGE Neither Expires header nor corresponding Contact header found, checking from original request
2018-06-27 15:48:23:326 [belle-sip] MESSAGE Refresher [0x91bc1630] takes ownership of transaction [0x92299ce0]
2018-06-27 15:48:23:327 [liblinphone] MESSAGE Proxy config [0x91bb1380] for identity [sip:[email protected]] moving from state [LinphoneRegistrationNone] to [LinphoneRegistrationProgress] on core [0xa3a9b300]
2018-06-27 15:48:23:333 [mediastreamer] MESSAGE New registration state [Progress]
2018-06-27 15:48:23:339 [liblinphone] MESSAGE Linphone core [0xa3a9b300] notified [registration_state_changed]
2018-06-27 15:48:23:643 [belle-sip] MESSAGE bellesip_wake_lock_acquire(): Android wake lock [belle-sip recv channel] acquired [ref=0xbaa]
2018-06-27 15:48:23:643 [belle-sip] MESSAGE channel [0x92dd5400]: starting recv background task with id=[baa].
2018-06-27 15:48:23:644 [belle-sip] MESSAGE channel [0x92dd5400]: received [437] new bytes from [UDP://sip.kabelfon.vodafone.de:5060]:
SIP/2.0 401 Unauthorized
Via: SIP/2.0/UDP 192.168.0.106:46511;received=91.64.249.208;branch=z9hG4bK.V-RK4i2RP;rport=46511
To: <sip:[email protected]>;tag=SDua2oe99-wl65ib66
CSeq: 20 REGISTER
Call-ID: 7Wm2gv8KzK
WWW-Authenticate: Digest realm="technik.kabel-deutschland.de", nonce="emRNLsZDs2yUizeuOgKasg==",algorithm=MD5
Content-Length: 0
2018-06-27 15:48:23:670 [belle-sip] MESSAGE channel [0x92dd5400] [437] bytes parsed
2018-06-27 15:48:23:670 [belle-sip] MESSAGE Found transaction matching response.
2018-06-27 15:48:23:670 [belle-sip] MESSAGE Changing [client] [REGISTER] transaction [0x92299ce0], from state [TRYING] to [COMPLETED]
2018-06-27 15:48:23:671 [liblinphone] MESSAGE linphone_core_find_auth_info(): returning auth info username=+493322xxxxxx, realm=technik.kabel-deutschland.de
2018-06-27 15:48:23:672 [belle-sip] MESSAGE Auth info found for [3322xxxxx] realm [technik.kabel-deutschland.de]
2018-06-27 15:48:23:675 [belle-sip] MESSAGE bellesip_wake_lock_acquire(): Android wake lock [belle-sip transaction(0x9229a0a0)] acquired [ref=0x200bb2]
2018-06-27 15:48:23:675 [belle-sip] MESSAGE transaction [0x9229a0a0]: starting transaction background task with id=[200bb2].
2018-06-27 15:48:23:675 [belle-sip] MESSAGE Changing [client] [REGISTER] transaction [0x9229a0a0], from state [INIT] to [TRYING]
2018-06-27 15:48:23:677 [belle-sip] MESSAGE channel [0x92dd5400]: message sent to [UDP://sip.kabelfon.vodafone.de:5060], size: [1092] bytes
Via: SIP/2.0/UDP 192.168.0.106:46511;branch=z9hG4bK.0g-9Tj0WL;rport
CSeq: 21 REGISTER
Call-ID: 7Wm2gv8KzK
Max-Forwards: 70
Accept: text/plain
Expires: 3600
Authorization:  Digest realm="technik.kabel-deutschland.de", nonce="emRNLsZDs2yUizeuOgKasg==", algorithm=MD5, username="3322xxxxx",  uri="sip:sip.kabelfon.vodafone.de", response="6b2122b0af713549cf143dfaa6a7872c"
2018-06-27 15:48:23:678 [belle-sip] MESSAGE channel [0x92dd5400]: ending recv background task with id=[baa].
2018-06-27 15:48:23:680 [belle-sip] MESSAGE bellesip_wake_lock_release(): Android wake lock released [ref=0xbaa]
2018-06-27 15:48:23:991 [belle-sip] MESSAGE bellesip_wake_lock_acquire(): Android wake lock [belle-sip recv channel] acquired [ref=0x100bb6]
2018-06-27 15:48:23:992 [belle-sip] MESSAGE channel [0x92dd5400]: starting recv background task with id=[100bb6].
2018-06-27 15:48:23:992 [belle-sip] MESSAGE channel [0x92dd5400]: received [335] new bytes from [UDP://sip.kabelfon.vodafone.de:5060]:
SIP/2.0 500 Server Internal Error
Via: SIP/2.0/UDP 192.168.0.106:46511;received=91.64.249.208;branch=z9hG4bK.0g-9Tj0WL;rport=46511
To: <sip:[email protected]>;tag=SDua2oe99-9j9xijfi
CSeq: 21 REGISTER
Call-ID: 7Wm2gv8KzK
Content-Length: 0
2018-06-27 15:48:24:007 [belle-sip] MESSAGE channel [0x92dd5400] [335] bytes parsed
2018-06-27 15:48:24:008 [belle-sip] MESSAGE Found transaction matching response.
2018-06-27 15:48:24:008 [belle-sip] MESSAGE Changing [client] [REGISTER] transaction [0x9229a0a0], from state [TRYING] to [COMPLETED]
2018-06-27 15:48:24:008 [belle-sip] MESSAGE Refresher[0x91bc1630]: scheduling next timer in 60000 ms for purpose [retry]
2018-06-27 15:48:24:008 [bctbx] MESSAGE Register refresher [500] reason [Server Internal Error] for proxy [<sip:sip.kabelfon.vodafone.de;transport=udp>]
2018-06-27 15:48:24:009 [liblinphone] MESSAGE Proxy config [0x91bb1380] for identity [sip:[email protected]] moving from state [LinphoneRegistrationProgress] to [LinphoneRegistrationFailed] on core [0xa3a9b300]
2018-06-27 15:48:24:010 [mediastreamer] MESSAGE New registration state [Failed]
2018-06-27 15:48:24:077 [liblinphone] MESSAGE Linphone core [0xa3a9b300] notified [registration_state_changed]
2018-06-27 15:48:24:078 [belle-sip] MESSAGE channel[0x92dd5400]: this server is encountering internal errors, moving to error state to eventually connect to another IP.
2018-06-27 15:48:24:078 [belle-sip] MESSAGE channel 0x92dd5400: state ERROR
2018-06-27 15:48:24:078 [belle-sip] MESSAGE channel [0x92dd5400]: ending recv background task with id=[100bb6].
2018-06-27 15:48:24:080 [belle-sip] MESSAGE bellesip_wake_lock_release(): Android wake lock released [ref=0x100bb6]
2018-06-27 15:48:24:137 [belle-sip] MESSAGE transaction [0x92299ce0] channel state changed to [ERROR]
2018-06-27 15:48:24:137 [belle-sip] MESSAGE Changing [client] [REGISTER] transaction [0x92299ce0], from state [COMPLETED] to [TERMINATED]
2018-06-27 15:48:24:137 [belle-sip] MESSAGE Client internal REGISTER transaction [0x92299ce0] terminated
2018-06-27 15:48:24:138 [belle-sip] MESSAGE transaction [0x92299ce0]: ending transaction background task with id=[b9a].
2018-06-27 15:48:24:140 [belle-sip] MESSAGE bellesip_wake_lock_release(): Android wake lock released [ref=0xb9a]
2018-06-27 15:48:24:140 [belle-sip] MESSAGE transaction [0x9229a0a0] channel state changed to [ERROR]
2018-06-27 15:48:24:140 [belle-sip] MESSAGE Changing [client] [REGISTER] transaction [0x9229a0a0], from state [COMPLETED] to [TERMINATED]
2018-06-27 15:48:24:141 [belle-sip] MESSAGE Client internal REGISTER transaction [0x9229a0a0] terminated
2018-06-27 15:48:24:141 [belle-sip] MESSAGE transaction [0x9229a0a0]: ending transaction background task with id=[200bb2].
2018-06-27 15:48:24:147 [belle-sip] MESSAGE bellesip_wake_lock_release(): Android wake lock released [ref=0x200bb2]
2018-06-27 15:48:24:147 [belle-sip] MESSAGE Channel [0x92dd5400] destroyed
2018-06-27 15:48:31:441 [mediastreamer] MESSAGE This device (bq/Aquaris M5/msm8916) declares it has a built-in echo canceller.
2018-06-27 15:48:31:441 [mediastreamer] MESSAGE No information available for [bq/Aquaris M5/msm8916],
2018-06-27 15:48:31:442 [mediastreamer] MESSAGE Sound device information for [bq/Aquaris M5/msm8916] is: builtin=[yes], delay=[0] ms
2018-06-27 15:48:31:499 [liblinphone] MESSAGE Callbacks [0x92625e20] unregistered on core [0xa3a9b300]
2018-06-27 15:48:31:500 [liblinphone] MESSAGE Callbacks [0x926250d8] unregistered on core [0xa3a9b300]
2018-06-27 15:48:31:501 [mediastreamer] MESSAGE Activity paused:org.linphone.assistant.AssistantActivity@3a88259
2018-06-27 15:48:31:501 [mediastreamer] MESSAGE runningActivities=0
2018-06-27 15:48:31:527 [mediastreamer] MESSAGE Activity started:org.linphone.activities.LinphoneActivity@6cc7d6c
2018-06-27 15:48:31:528 [mediastreamer] MESSAGE [Permission] Contacts permission is granted
2018-06-27 15:48:31:528 [mediastreamer] MESSAGE [Permission] Read phone state permission is granted
2018-06-27 15:48:31:529 [mediastreamer] MESSAGE [Permission] Read external storage for ring tone permission is granted
2018-06-27 15:48:31:530 [mediastreamer] MESSAGE Activity resumed:org.linphone.activities.LinphoneActivity@6cc7d6c
2018-06-27 15:48:31:530 [mediastreamer] MESSAGE runningActivities=1
2018-06-27 15:48:31:531 [liblinphone] MESSAGE Core callbacks [0x92821ba8] registered on core [0xa3a9b300]
2018-06-27 15:48:31:532 [liblinphone] MESSAGE linphone_core_find_auth_info(): returning auth info username=+493322xxxxxx, realm=technik.kabel-deutschland.de
2018-06-27 15:48:31:533 [belle-sip] MESSAGE Auth info found for [3322xxxxx] realm [technik.kabel-deutschland.de]
2018-06-27 15:48:31:535 [belle-sip] MESSAGE bellesip_wake_lock_acquire(): Android wake lock [belle-sip transaction(0x9229a820)] acquired [ref=0x200baa]
2018-06-27 15:48:31:535 [belle-sip] MESSAGE transaction [0x9229a820]: starting transaction background task with id=[200baa].
2018-06-27 15:48:31:535 [belle-sip] MESSAGE Transaction [0x9229a0a0] deleted
2018-06-27 15:48:31:536 [belle-sip] MESSAGE belle_sip_client_transaction_send_request(): waiting channel to be ready
2018-06-27 15:48:31:538 [belle-sip] MESSAGE bellesip_wake_lock_acquire(): Android wake lock [belle-sip send channel] acquired [ref=0xb9e]
2018-06-27 15:48:31:539 [belle-sip] MESSAGE channel [0x932c65c0]: starting send background task with id=[b9e].
2018-06-27 15:48:31:539 [belle-sip] MESSAGE channel [0x932c65c0]: starting resolution of sip.kabelfon.vodafone.de
2018-06-27 15:48:31:539 [belle-sip] MESSAGE channel 0x932c65c0: state RES_IN_PROGRESS
2018-06-27 15:48:31:539 [belle-sip] MESSAGE transaction [0x9229a820] channel state changed to [RES_IN_PROGRESS]
2018-06-27 15:48:31:598 [belle-sip] MESSAGE resconf using application supplied dns server list.
2018-06-27 15:48:31:599 [belle-sip] MESSAGE Resolver is using DNS server(s):
2018-06-27 15:48:31:599 [belle-sip] MESSAGE     192.168.0.1
2018-06-27 15:48:31:601 [belle-sip] MESSAGE resolver_process_data dns_res_check() in progress
2018-06-27 15:48:31:607 [belle-sip] MESSAGE DNS resolution awaiting response, queued to main loop
2018-06-27 15:48:31:608 [liblinphone] MESSAGE Proxy config [0x91bb1380] for identity [sip:[email protected]] moving from state [LinphoneRegistrationFailed] to [LinphoneRegistrationProgress] on core [0xa3a9b300]
2018-06-27 15:48:31:608 [mediastreamer] MESSAGE New registration state [Progress]
2018-06-27 15:48:31:610 [liblinphone] MESSAGE linphone_core_find_auth_info(): returning auth info username=+493322xxxxxx, realm=
2018-06-27 15:48:31:613 [liblinphone] MESSAGE Linphone core [0xa3a9b300] notified [registration_state_changed]
2018-06-27 15:48:31:615 [liblinphone] MESSAGE Notifying all friends that we are [open]
2018-06-27 15:48:31:615 [liblinphone] MESSAGE Core callbacks [0x926250d8] registered on core [0xa3a9b300]
2018-06-27 15:48:31:618 [liblinphone] MESSAGE linphone_core_find_auth_info(): returning auth info username=+493322xxxxxx, realm=
2018-06-27 15:48:31:626 [belle-sip] MESSAGE SRV _sip._udp.sip.kabelfon.vodafone.de resolved to [target:sip.kabelfon.vodafone.de. port:5060 prio:10 weight:100]
2018-06-27 15:48:31:626 [belle-sip] MESSAGE Starting A/AAAA query for srv result [sip.kabelfon.vodafone.de.]
2018-06-27 15:48:31:627 [belle-sip] MESSAGE resconf using application supplied dns server list.
2018-06-27 15:48:31:627 [belle-sip] MESSAGE Resolver is using DNS server(s):
2018-06-27 15:48:31:627 [belle-sip] MESSAGE     192.168.0.1
2018-06-27 15:48:31:629 [belle-sip] MESSAGE resolver_process_data dns_res_check() in progress
2018-06-27 15:48:31:630 [belle-sip] MESSAGE DNS resolution awaiting response, queued to main loop
2018-06-27 15:48:31:630 [belle-sip] MESSAGE resconf using application supplied dns server list.
2018-06-27 15:48:31:631 [belle-sip] MESSAGE Resolver is using DNS server(s):
2018-06-27 15:48:31:631 [belle-sip] MESSAGE     192.168.0.1
2018-06-27 15:48:31:633 [belle-sip] MESSAGE resolver_process_data dns_res_check() in progress
2018-06-27 15:48:31:633 [belle-sip] MESSAGE DNS resolution awaiting response, queued to main loop
2018-06-27 15:48:31:696 [belle-sip] MESSAGE sip.kabelfon.vodafone.de. resolved to 88.134.209.241
2018-06-27 15:48:31:697 [belle-sip] MESSAGE A query finished for srv result [sip.kabelfon.vodafone.de.]
2018-06-27 15:48:31:697 [belle-sip] MESSAGE All A/AAAA results for combined resolution have arrived.
2018-06-27 15:48:31:697 [belle-sip] MESSAGE channel 0x932c65c0: state RES_DONE
2018-06-27 15:48:31:697 [belle-sip] MESSAGE transaction [0x9229a820] channel state changed to [RES_DONE]
2018-06-27 15:48:31:697 [belle-sip] MESSAGE channel 0x932c65c0: state CONNECTING
2018-06-27 15:48:31:697 [belle-sip] MESSAGE transaction [0x9229a820] channel state changed to [CONNECTING]
2018-06-27 15:48:31:698 [belle-sip] MESSAGE Trying to connect to [UDP://::ffff:88.134.209.241:5060]
2018-06-27 15:48:31:699 [belle-sip] MESSAGE Channel has local address 192.168.0.106:46511
2018-06-27 15:48:31:699 [belle-sip] MESSAGE channel 0x932c65c0: state READY
2018-06-27 15:48:31:699 [belle-sip] MESSAGE transaction [0x9229a820] channel state changed to [READY]
2018-06-27 15:48:31:700 [belle-sip] MESSAGE Changing [client] [REGISTER] transaction [0x9229a820], from state [INIT] to [TRYING]
2018-06-27 15:48:31:701 [belle-sip] MESSAGE channel [0x932c65c0]: message sent to [UDP://sip.kabelfon.vodafone.de:5060], size: [1092] bytes
Via: SIP/2.0/UDP 192.168.0.106:46511;branch=z9hG4bK.DNbyDuFGR;rport
CSeq: 22 REGISTER
Call-ID: 7Wm2gv8KzK
Max-Forwards: 70
Accept: text/plain
Expires: 3600
2018-06-27 15:48:31:701 [belle-sip] MESSAGE channel [0x932c65c0]: ending send background task with id=[b9e].
2018-06-27 15:48:31:704 [belle-sip] MESSAGE bellesip_wake_lock_release(): Android wake lock released [ref=0xb9e]
2018-06-27 15:48:31:907 [belle-sip] MESSAGE bellesip_wake_lock_acquire(): Android wake lock [belle-sip recv channel] acquired [ref=0x200bba]
2018-06-27 15:48:31:907 [belle-sip] MESSAGE channel [0x932c65c0]: starting recv background task with id=[200bba].
2018-06-27 15:48:31:907 [belle-sip] MESSAGE channel [0x932c65c0]: received [437] new bytes from [UDP://sip.kabelfon.vodafone.de:5060]:
Via: SIP/2.0/UDP 192.168.0.106:46511;received=91.64.249.208;branch=z9hG4bK.DNbyDuFGR;rport=46511
To: <sip:[email protected]>;tag=SDua2oe99-xid5nndn
CSeq: 22 REGISTER
Call-ID: 7Wm2gv8KzK
WWW-Authenticate: Digest realm="technik.kabel-deutschland.de", nonce="uIoghdfhgdfgdfhgdfg1Ph651A==",algorithm=MD5
Content-Length: 0
2018-06-27 15:48:31:924 [belle-sip] MESSAGE channel [0x932c65c0] [437] bytes parsed
2018-06-27 15:48:31:924 [belle-sip] MESSAGE channel [0x932c65c0]: discovered public ip and port are [91.64.249.208:46511]
2018-06-27 15:48:31:924 [belle-sip] MESSAGE Found transaction matching response.
2018-06-27 15:48:31:924 [belle-sip] MESSAGE Changing [client] [REGISTER] transaction [0x9229a820], from state [TRYING] to [COMPLETED]
2018-06-27 15:48:31:925 [liblinphone] MESSAGE linphone_core_find_auth_info(): returning auth info username=+493322xxxxxx, realm=technik.kabel-deutschland.de
2018-06-27 15:48:31:925 [belle-sip] MESSAGE Auth info found for [3322xxxxx] realm [technik.kabel-deutschland.de]
2018-06-27 15:48:31:927 [belle-sip] MESSAGE bellesip_wake_lock_acquire(): Android wake lock [belle-sip transaction(0x92611d20)] acquired [ref=0x100bc2]
2018-06-27 15:48:31:927 [belle-sip] MESSAGE transaction [0x92611d20]: starting transaction background task with id=[100bc2].
2018-06-27 15:48:31:928 [belle-sip] MESSAGE Changing [client] [REGISTER] transaction [0x92611d20], from state [INIT] to [TRYING]
2018-06-27 15:48:31:929 [belle-sip] MESSAGE channel [0x932c65c0]: message sent to [UDP://sip.kabelfon.vodafone.de:5060], size: [1092] bytes
Via: SIP/2.0/UDP 192.168.0.106:46511;branch=z9hG4bK.Q5gDRlRaX;rport
CSeq: 23 REGISTER
Call-ID: 7Wm2gv8KzK
Max-Forwards: 70
Accept: text/plain
Expires: 3600
Authorization:  Digest realm="technik.kabel-deutschland.de", nonce="uIoghdfhgdfgdfhgdfg1Ph651A==", algorithm=MD5, username="3322xxxxx",  uri="sip:sip.kabelfon.vodafone.de", response="41abf65d48f6b1f89df6a399bd56eee6"
2018-06-27 15:48:31:930 [belle-sip] MESSAGE channel [0x932c65c0]: ending recv background task with id=[200bba].
2018-06-27 15:48:31:931 [belle-sip] MESSAGE bellesip_wake_lock_release(): Android wake lock released [ref=0x200bba]
2018-06-27 15:48:32:135 [mediastreamer] MESSAGE Activity stopped:org.linphone.assistant.AssistantActivity@3a88259
2018-06-27 15:48:32:137 [mediastreamer] MESSAGE Activity destroyed:org.linphone.assistant.AssistantActivity@3a88259
2018-06-27 15:48:32:273 [belle-sip] MESSAGE bellesip_wake_lock_acquire(): Android wake lock [belle-sip recv channel] acquired [ref=0xbb6]
2018-06-27 15:48:32:274 [belle-sip] MESSAGE channel [0x932c65c0]: starting recv background task with id=[bb6].
2018-06-27 15:48:32:274 [belle-sip] MESSAGE channel [0x932c65c0]: received [335] new bytes from [UDP://sip.kabelfon.vodafone.de:5060]:
Via: SIP/2.0/UDP 192.168.0.106:46511;received=91.64.249.208;branch=z9hG4bK.Q5gDRlRaX;rport=46511
To: <sip:[email protected]>;tag=SDua2oe99-ks9k0dld
CSeq: 23 REGISTER
Call-ID: 7Wm2gv8KzK
Content-Length: 0
2018-06-27 15:48:32:289 [belle-sip] MESSAGE channel [0x932c65c0] [335] bytes parsed
2018-06-27 15:48:32:289 [belle-sip] MESSAGE Found transaction matching response.
2018-06-27 15:48:32:289 [belle-sip] MESSAGE Changing [client] [REGISTER] transaction [0x92611d20], from state [TRYING] to [COMPLETED]
2018-06-27 15:48:32:289 [belle-sip] MESSAGE Refresher[0x91bc1630]: scheduling next timer in 60000 ms for purpose [retry]
2018-06-27 15:48:32:289 [bctbx] MESSAGE Register refresher [500] reason [Server Internal Error] for proxy [<sip:sip.kabelfon.vodafone.de;transport=udp>]
2018-06-27 15:48:32:290 [liblinphone] MESSAGE Proxy config [0x91bb1380] for identity [sip:[email protected]] moving from state [LinphoneRegistrationProgress] to [LinphoneRegistrationFailed] on core [0xa3a9b300]
2018-06-27 15:48:32:290 [mediastreamer] MESSAGE New registration state [Failed]
2018-06-27 15:48:32:291 [liblinphone] MESSAGE linphone_core_find_auth_info(): returning auth info username=+493322xxxxxx, realm=
2018-06-27 15:48:32:295 [liblinphone] MESSAGE Linphone core [0xa3a9b300] notified [registration_state_changed]
2018-06-27 15:48:32:296 [belle-sip] MESSAGE channel[0x932c65c0]: this server is encountering internal errors, moving to error state to eventually connect to another IP.
2018-06-27 15:48:32:296 [belle-sip] MESSAGE channel 0x932c65c0: state ERROR
2018-06-27 15:48:32:296 [belle-sip] MESSAGE channel [0x932c65c0]: ending recv background task with id=[bb6].
2018-06-27 15:48:32:297 [belle-sip] MESSAGE bellesip_wake_lock_release(): Android wake lock released [ref=0xbb6]
2018-06-27 15:48:32:297 [belle-sip] MESSAGE transaction [0x9229a820] channel state changed to [ERROR]
2018-06-27 15:48:32:297 [belle-sip] MESSAGE Changing [client] [REGISTER] transaction [0x9229a820], from state [COMPLETED] to [TERMINATED]
2018-06-27 15:48:32:298 [belle-sip] MESSAGE Client internal REGISTER transaction [0x9229a820] terminated
2018-06-27 15:48:32:298 [belle-sip] MESSAGE transaction [0x9229a820]: ending transaction background task with id=[200baa].
2018-06-27 15:48:32:299 [belle-sip] MESSAGE bellesip_wake_lock_release(): Android wake lock released [ref=0x200baa]
2018-06-27 15:48:32:300 [belle-sip] MESSAGE transaction [0x92611d20] channel state changed to [ERROR]
2018-06-27 15:48:32:300 [belle-sip] MESSAGE Changing [client] [REGISTER] transaction [0x92611d20], from state [COMPLETED] to [TERMINATED]
2018-06-27 15:48:32:301 [belle-sip] MESSAGE Client internal REGISTER transaction [0x92611d20] terminated
2018-06-27 15:48:32:301 [belle-sip] MESSAGE transaction [0x92611d20]: ending transaction background task with id=[100bc2].
2018-06-27 15:48:32:303 [belle-sip] MESSAGE bellesip_wake_lock_release(): Android wake lock released [ref=0x100bc2]
2018-06-27 15:48:32:303 [belle-sip] MESSAGE Transaction [0x9229a820] deleted
2018-06-27 15:48:32:303 [belle-sip] MESSAGE Channel [0x932c65c0] destroyed
2018-06-27 15:48:37:502 [liblinphone] MESSAGE Callbacks [0x926250d8] unregistered on core [0xa3a9b300]
2018-06-27 15:48:37:503 [liblinphone] MESSAGE Callbacks [0x92821ba8] unregistered on core [0xa3a9b300]
2018-06-27 15:48:37:503 [mediastreamer] MESSAGE Activity paused:org.linphone.activities.LinphoneActivity@6cc7d6c
2018-06-27 15:48:37:504 [mediastreamer] MESSAGE runningActivities=0
2018-06-27 15:48:37:604 [mediastreamer] MESSAGE Activity stopped:org.linphone.activities.LinphoneActivity@6cc7d6c
2018-06-27 15:48:39:504 [mediastreamer] MESSAGE App has entered background mode
versuch mal csipsimple android.
csipsimple ist mir zu alt.
Zoiper geht problemlos... ich kapiers nicht
Moinsen
Zoiper hat meines Wissens standardmässig STUN aktiviert.
Nein, ein STUN Server kann beliebig gewählt werden.
Zum Beispiel: stun.ekiga.net, stun.1und1.de, stun.sipgate.net:10000
...ohne Portangabe ist der Standard Port: 3478
...ist zum überwinden von NAT gedacht ( nicht CGN(AT) ).
Kurz geschrieben: Der dynamisch gewählte SIP-Ausgangsport ( Richtung Internet ) wird als Rückkanal genutzt
...genauso wie der auszuhandelnde RTP Audioport.
Ohne STUN hats kein Audio auf einer Seite, es bleibt also stumm und es kommen keine Anrufe rein.
Das ist ja nicht mein Problem, der Account meldet sich ja nicht an einen Anruf nach außen kann ich nicht tätigen.
Ich habs trotzdem versucht, hat abe keine Auswirkung, anmeldung ist nicht möglich.
Versuch doch mal zu beschreiben in welchen Netzen du es wie versuchst.
1. Heimisches WLAN == NAT - Direktanmeldung beim SIP Provider nur mit STUN
2. Heimisches WLAN == NAT - Direktanmeldung an FRITZ!Box IP-Telefon ohne STUN
3. Mobilfunkinternet == CGN - Keine (direkte) Anmeldung beim Provider möglich ( mit oder ohne STUN )
4. Mobilfunkinternet mit VPN nach Hause - Anmeldung an FRITZ!Box IP-Telefon ohne STUN ( wie 2. )
1. Heimisches WLAN (gleiches Netzwerk wo Linphone am PC problemlos geht)
2. Die Box kann sich auch anmelden. Nummern sind auch eingerichtet nutze ich aber nicht über die Box.
3. nicht getestet
4. das wollte ich testen sobald 1) geht.
Die Box nimmt aber den SIP Port UDP/TCP 5060 für sich in Beschlag.
Siehe: Diagnose -> Sicherheit
Also muss das Mobile einen anderen SIP Port nutzen und dies den Provider bei der Anmeldung mitteilen.
...sowas macht halt STUN.
Wenn die Box das in beschlag nimmt warum geht dann zoiper auf android und linphone am pc?
Stun hab ich versucht hilft auch nicht.
Warum das mit dem PC funktioniert, kann nur ein SIP-Log offenbaren.
Mit einem unregistrierten PhonerLite mit STUN sieht das so aus...
17:03:51,539: T: 212.42.244.116:5060 (UDP)
INVITE sip:[email protected] SIP/2.0
Via: SIP/2.0/UDP 87.123.145.29:61000;branch=z9hG4bK8025a0225279e811800396acffd28d87;rport
Call-ID: [email protected]
CSeq: 1 INVITE
Contact: <sip:[email protected]:61000>
Content-Type: application/sdp
Mime-Version: 1.0
Allow: INVITE, ACK, BYE, CANCEL, INFO, MESSAGE, NOTIFY, OPTIONS, REFER, UPDATE, PRACK
Max-Forwards: 70
P-Early-Media: supported
User-Agent: SIPPER for PhonerLite
Session-Expires: 1800
Supported: 100rel, replaces, from-change, timer
P-Preferred-Identity: <sip:[email protected]>
Content-Length:   388
v=0
o=- 4026036927 1 IN IP4 87.123.145.29
s=SIPPER for PhonerLite
c=IN IP4 87.123.145.29
t=0 0
m=audio 5062 RTP/AVP 9 8 0 101
a=rtpmap:9 G722/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=crypto:1 AES_CM_128_HMAC_SHA1_80 inline:ahE/y6HePN9Gxev3zokGNo9sJCHuoDo8JRDwiR+/
a=encryption:optional
a=ssrc:2858604517
a=sendrecv
17:03:51,539: R: 212.42.244.116:5060 (UDP)
SIP/2.0 200 OK
Via: SIP/2.0/UDP 87.123.145.29:61000;branch=z9hG4bK8025a0225279e811800396acffd28d87;rport=61000
To: <sip:[email protected]>;tag=71022CA9-5B34F8A4000C1D95-69C65700
CSeq: 1 INVITE
Server: Sip Express Media Server (1.6.0 (x86_64/linux))
Contact: <sip:212.42.244.116:5060;transport=udp>
Content-Length: 278
v=0
o=sems 1285455604 1153118420 IN IP4 212.42.244.116
s=sems
c=IN IP4 212.42.244.116
t=0 0
m=audio 20090 RTP/AVP 9 8 0 101
a=rtpmap:9 g722/8000
a=fmtp:101 0-16
a=sendonly
a=direction:both
17:03:51,539: Connect Active Indication: 0F 00 02 00 03 82 1E 00 01 01 00 00 00 00 00
17:03:51,539: Connect Active Response: 0C 00 02 00 03 83 1E 00 01 01 00 00
17:03:51,539: Connect B3 Request: 0D 00 02 00 82 80 0F 00 01 01 00 00 00
ACK sip:212.42.244.116:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 87.123.145.29:61000;branch=z9hG4bK8025a0225279e811800496acffd28d87;rport
CSeq: 1 ACK
Max-Forwards: 70
Content-Length: 0
17:03:51,617: Connect B3 Confirm: 0E 00 02 00 82 81 0F 00 01 01 01 00 00 00
17:03:51,617: Connect B3 Active Indication: 0D 00 02 00 83 82 21 00 01 01 01 00 00
17:03:51,617: Connect B3 Active Response: 0C 00 02 00 83 83 21 00 01 01 01 00
17:03:51,617: Facility Request: 19 00 02 00 80 80 10 00 01 01 01 00 01 00 0A 01 00 64 00 3C 00 00 00 00 00
17:03:51,617: Facility (DTMF on/off) Request
17:03:51,617: Open capture sound device: Default
17:03:51,664: capture sound device opened
17:03:51,664: Open render sound device: Default
17:03:51,664: render sound device opened
17:03:51,679: Facility Confirm: 11 00 02 00 80 81 10 00 01 00 00 00 00 00 01 00 00
17:03:51,679: Facility Confirm (DTMF)
17:04:13,633: T: 217.10.68.152:3478
STUN
  public ip: 87.123.145.29:61000
( Nichts zensiert, du könntest mich jetzt sogar erreichen auf SIP UDP Port 61000 )
Die STUN Ausgabe siehst du ganz Unten ;)
