last trunk kconfig-3.1-rc9/.unpacked] Error 2
graymalking
4 Feb 2008
Hy, sorry if you have just spoken about this problem.
After a long time I tried to re-use freetz.
I'm using Ubuntu 10 -
By terminal I've sent
$ svn co http://svn.freetz.org/trunk freetz-devel_r7843 -r 7843
then I tried to send make menuconfig this is the error
mkdir -p /home/andrea/trunk_7800/source/host-tools/kconfig-3.1-rc9/scripts
tar -C /home/andrea/trunk_7800/source/host-tools/kconfig-3.1-rc9/scripts --wildcards --strip-components=1 \
-xzf dl/kconfig-3.1-rc9.tar.gz */basic */kconfig */Makefile.{build,host,lib} */Kbuild.include
gzip: stdin: not in gzip format
tar: Child returned status 1
tar: Error is not recoverable: exiting now
make: *** [/home/andrea/trunk_7800/source/host-tools/kconfig-3.1-rc9/.unpacked] Errore 2
I think the problem is to unpacked kconfig-3.1-rc9.tar.gz
Just to see i tried do unpacked the file using other software (es 7zip) and every time I've got an error signal.
I tried to use old trunk but all versions with kconfig-3.1-rc9 have the same problem and the older one(with different kconfig) does not find the file in the internet link.
Thanks for your answer
The revision you checked out is rather old, so the kconfig version used in that revision seems no longer available.
Maybe you just misread the wiki? I new I saw "Rev 7843" somewhere ;-)
To check out latest trunk, you do something like this:
Only if you need a special revision (e.g. Rev 7777) you add "-r <revision>" to this command
 svn co http://svn.freetz.org/trunk freetz-devel_r7777 -r 7777
