Korrektes Kabel zur Verlängerung der Easybell-Leitung
vimt
10 Okt 2018
First - Sorry for bad German, I use a translation feature.
I need to extend a simple ring line from the basement of the building to my studio. The installation man told me he could not move the cable from the basement to the studio. There must be a box with a 6-way plug in the studio - as shown.
This means that I have to extend the line myself, but I do not know what type of cable to use. It is for a simple DSL line and has to be about 20 meters long
Has anyone ever had this problem or know what kind of cable I should buy?
any help appreciated
Das Bild und die Beschreibung deutet eher auf eine fehlende Steigleitung vom Keller (APL) zur Wohnung hin. Die Türform im Bildhintergrund deutet auf ein älteres Mietshaus hin (Vermutung), wo der Eigentümer verantwortlich wäre. Wenn ein Techniker kein Kabel verlegen kann, wird er sicherlich den APL kennen und die Verlegungsmöglichkeiten eruiert haben.(mehrere Stockwerke vom Basement zum Studio? ergeben u.U. ca. 20m)
LG
Did you order the Easybell account as a "complete account"? And there was no telephone line in your studio before?
In this case it is the f*#g damn duty of the installer to move the line up in your studio and to mount such a so-called "TAE-Dose" as shown in your pic! It seems he was too lazy to do this (time-comnsuming) work - but he has to do! As instructed by the provider.
Regards
Hendrik
