Bei uns funktioniert fast alles...
DIS-TDCSU:1-9-79-1;
H500: AMO TDCSU STARTED
H08: NO TRUNK FOUND
AMO-TDCSU-111 DIGITAL TRUNKS
DISPLAY COMPLETED;
<dis-tdcsu:1-6-79-1;
DIS-TDCSU:1-6-79-1;
+------------------------ DIGITAL TRUNK (FORMAT=L) -------------------------+
| DEV = S2CONN PEN = 1-06-079-1 |
| COTNO = 70 COPNO = 70 DPLN = 0 |
| ITR = 0 COS = 100 LCOSV = 32 |
| LCOSD = 32 CCT = xxxxxxxxxx DESTNO = 70 |
| PROTVAR = PSS1V2 SEGMENT = 1 TCHARG = N |
| SUPPRESS = 0 DGTPR = CHIMAP = N |
| ISDNCC = ISDNAC = ISDNLC = |
| ISDNIP = ISDNNP = |
| PNPL2C = PNPL1C = PNPLC = |
| PNPL2P = PNPL1P = PNPAC = |
| TRACOUNT = 31 SATCOUNT = MANY NNO = 770 |
| ALARMNO = 2 FIDX = 1 CARRIER = 8 |
| ZONE = EMPTY COTX = 15 FWDX = 10 |
| DOMTYPE = DOMAINNO = TPROFNO = |
| INIGHT = |
| CCHDL = UUSCCX = 16 UUSCCY = 8 |
| TGRP = 70 SRCHMODE = CIR BCNEG = Y |
| BCGR = 1 INS = Y LWPAR = 4 |
| BCHAN 1 && 30 |
AMOUNT OF B-CHANNELS IN THIS DISPLAY-OUTPUT: 30
DISPLAY COMPLETED;
<reg-tdcsu:1-6-79-1;
REG-TDCSU:1-6-79-1;
ADD-TDCSU:NEW , 1-06-079-1 , 70, 70, 0, 0, 100,32,32,"xxxxxxxxxx", 70
,PSS1V2,1,N,0, , , , , , , ,
, , , , ,31, MANY,770 , 2, 1,8,EMPTY, 15,10,N
, , , , , , 16, 8, S2CONN,
70,CIR,
1&&30
,Y,1,Y,4;
REGENERATE COMPLETED;
<DISPLAY-COT:COTNO=70;
H500: AMO COT STARTED
COT: 70 INFO:
DEVICE: INDEP SOURCE: DB
PARAMETER:
PRIORITY FOR AC WILL BE DETERMINED FROM MESSAGE PRI
RECALL IF USER HANGS UP IN CONSULTATION CALL RCL
TRUNK CALL TRANSFER XFER
TRUNK SIGNALING ANSWER ANS
CHANGEOVER FROM HOLD TO RING TONE CHRT
KNOCKING OVERRIDE POSSIBLE KNOR
CALL EXTEND FOR BUSY, RING OR CALL STATE CEBC
NETWORKWIDE AUTOMATIC CALLBACK ON BUSY CBBN
NETWORKWIDE AUTOMATIC CALLBACK ON FREE CBFN
NETWORKWIDE CALL FORWARDING PERMITTED FWDN
NETWORKWIDE FORWARDING NO-ANSWER FNAN
DON'T RELEASE CALL TO BUSY HUNT GROUP BSHT
SEND NO NODE NUMBER TO PARTNER LWNC
CONNECTION TO ROUTE OPTIMIZATION NODE ROPT
INCOMING CIRCUIT FROM SYSTEM WITHOUT LCR NLCR
TSC-SIGNALING FOR NETWORKWIDE FEATURES (MANDATORY) TSCS
INCOMING CDR BY ZONE OR FROM LINE ICZL
INCOMING CIRCUIT FROM SYSTEM WITHOUT LCR (DATA) NLRD
INTERWORKING CALLBACK - NO ANSWER AND MAILBOX CALLBACK IWCB
AOC PER CALL (AUTOMATICAL OR ON REQUEST), MAND. CORNET-NQ AOCC
LINE WITH IMPLICIT NUMBERS LINO
CONTROLLED TRUNK AND LINE SELECTION CTLS
NO TONE NTON
AMO-COT -111 CLASS OF TRUNK FOR CALL PROCESSING
DISPLAY COMPLETED;
<DISPLAY-COP:COPNO=70;
H500: AMO COP STARTED
COP: 70 INFO:
PARAMETER:
LINE WITH END-OF-DIAL EOD
SPECIAL MODE SFRM
CODE CALLING RELEASE AFTER EVERY TASK CCR
REGISTRATION OF LAYER 3 ADVISORIES L3AR
CO TRUNK ACCESS:
TRUNK ACCESS TA
TOLL ACCESS:
TRUNK ACCESS TA
AMO-COP -111 CLASS OF PARAMETER FOR DEVICE HANDLER
DISPLAY COMPLETED;
<DISPLAY-COSSU:TYPE=COS,COS=100;
H500: AMO COSSU STARTED
| COS | VOICE | FAX | TTX | VTX | DTE |
| 100 |> |
| | TA | TA | TA | TA | TA |
| | TNOTCR | TNOTCR | TNOTCR | TNOTCR | TNOTCR |
| | VCE | FAX | TTX | BASIC | BASIC |
| | NOANSA | BASIC | BASIC | VSM | DSM |
| | FWDNWK | | | | |
| | FWDBSY | | | | |
| | CTLS | | | | |
AMO-COSSU-111 CLASSES OF SERVICE, SWITCHING UNIT
DISPLAY COMPLETED;
<DISPLAY-RICHT:MODE=CD,TGRP=070;
H500: AMO RICHT STARTED
| ROUTES FOR ALL DPLN SVC = VCE |
|CODE |NAME, CQMAX, |TGRP|P| DTMF |LRTE|CPAR|U F|
| |DESTNO AND CPS |CCNO|L+---+---+----------------+-----+ | |N W|
| | 1 11111| |B|CNV|DSP| TEXT |PULS | | |I D|
| |12345 67890 12345| | | | | |PAUSE| | |T B|
|070 |..... ..... .....| 70| | F | W | |PP80 |1399| | |
|NEUTRAL|xxxxxxxxxxx | 7| | | | | | | | |
| |DNNO: 770| 5| | | | | | | | |
| |DESTNO : 70 | | | | | | | | | |
| |ROUTOPT : YES | | | | | | | | | |
| |REROUT : YES | | | | | | | | | |
| ROUTES FOR ALL DPLN SVC = TTX |
|070 |..... ..... .....| 70| | | | | |1399| | |
| ROUTES FOR ALL DPLN SVC = VTX |
| ROUTES FOR ALL DPLN SVC = FAX |
| ROUTES FOR ALL DPLN SVC = DTE |
<DISPLAY-LDAT:TGRP=70;
H500: AMO LDAT STARTED
| LROUTE = 1399 NAME = GRESHAM ST. SERVICE = ALL |
| TYPE = NWLCR DNNO OF ROUTE = 770 |
| SERVICE INFO = |
| | | | | | SCHEDULE | CARRIER |BAND| |
| LRTEL | LVAL | TGRP | ODR |LAUTH| ABCDEFGH | ZONE |WDTH| LATTR |
| 1 | 1 | 70 |1001 | 1 | ******** | 9 EMPTY | 1 | WCHREG |
| | DNNO = 770 | |
| 2 | 2 | 5 |1001 | 1 | ******** | 9 EMPTY | 1 | WCHREG |
| | DNNO = 770 | |
| 3 | 3 | 7 |1001 | 1 | ******** | 9 EMPTY | 1 | WCHREG |
| | DNNO = 770 | |
