JFritz 0.6.2.01 veröffentlicht
@Robert:
Folgender Text in der debug.txt:
(16:05:24) DEBUG: logging to file "E:\Programme\Jfritz\debug.txt" has been enabled
(16:05:24) DEBUG: Error processing the user save location(File not found), using defaults
(16:05:26) DEBUG: Save other properties
(16:05:26) DEBUG: Saving to file E:\Programme\Jfritz\jfritz.properties.xml
(Update) Program version: 0.6.2.01
(Update) Locale: de_de
(Update) Update on start: false
(Update) Saving update-properties......done
(16:05:26) DEBUG: Operating System : Windows XP
(16:05:26) DEBUG: JFritz runs on Windows
(16:05:26) DEBUG: Loading the german number to city list
(16:05:26) DEBUG: Subdirectory: /number
(16:05:26) DEBUG: full path: E:\Programme\Jfritz/number
(16:05:26) DEBUG: 5205 Lines read from areacodes_germany.csv
(16:05:26) DEBUG: numberMap size: 5204
(16:05:26) DEBUG: Loading the austrian number to city list
(16:05:26) DEBUG: 1029 Lines read from areacodes_austria.csv
(16:05:26) DEBUG: numberMap size: 1029
(16:05:26) DEBUG: Urlstr: http://192.xxx.x:80/cgi-bin/webcm
(16:05:26) DEBUG: Postdata: getpage=../html/de/menus/menu2.html&var%3Alang=de&var%3Amenu=home&var%3Apagename=home&login%3Acommand%2Fpassword=
(16:05:30) DEBUG: Detected Firmware: 29.04.29 de
(16:05:30) DEBUG: Saving to file E:\Programme\Jfritz\jfritz.phonebook.xml
(16:05:30) DEBUG: Sorting unfiltered data
(16:05:30) DEBUG: searching lastCall for allPersons in the phonebook....
(16:05:30) DEBUG: ...done
(16:05:30) DEBUG: searching all Persons for the CallerList...
(16:05:30) DEBUG: CallMonitorList: Added new event listener de.moonflower.jfritz.callmonitor.DisplayCallsMonitor@1afae45
(16:05:30) DEBUG: CallMonitorList: Added new event listener de.moonflower.jfritz.callmonitor.DisconnectMonitor@18f1d7e
(16:05:31) DEBUG: Start commandline parsing
(16:05:31) DEBUG: Multiple instance lock: Another instance is already running.
(16:05:34) DEBUG: Multiple instance lock: User decided to shut down this instance.
(16:05:34) DEBUG: Main.exit(0)
Da steht auch drin, das eine andere Instanz bereits laufen soll... (ist aber nicht so)???
Das heisst, dass du auf "Ja" geklickt hast und somit JFritz selbst beendet hast. Du musst "Nein" auswählen. Aktiviere also den Debug-Modus und klicke dann bei der JFritz-Meldung auf "Nein".
@robert
wie befohlen ;)
(18:13:35) DEBUG: logging to file "E:\Programme\Jfritz\debug.txt" has been enabled
(18:13:35) DEBUG: Error processing the user save location(File not found), using defaults
(18:13:36) DEBUG: Save other properties
(18:13:36) DEBUG: Saving to file E:\Programme\Jfritz\jfritz.properties.xml
(18:13:36) DEBUG: Operating System : Windows XP
(18:13:36) DEBUG: JFritz runs on Windows
(18:13:36) DEBUG: Loading the german number to city list
(18:13:36) DEBUG: Subdirectory: /number
(18:13:36) DEBUG: full path: E:\Programme\Jfritz/number
(18:13:36) DEBUG: 5205 Lines read from areacodes_germany.csv
(18:13:36) DEBUG: numberMap size: 5204
(18:13:36) DEBUG: Loading the austrian number to city list
(18:13:36) DEBUG: 1029 Lines read from areacodes_austria.csv
(18:13:36) DEBUG: numberMap size: 1029
(18:13:36) DEBUG: Urlstr: http://192.xx.xxx.x:80/cgi-bin/webcm
(18:13:36) DEBUG: Postdata: getpage=../html/de/menus/menu2.html&var%3Alang=de&var%3Amenu=home&var%3Apagename=home&login%3Acommand%2Fpassword=
(18:13:39) DEBUG: Detected Firmware: 29.04.29 de
(18:13:40) DEBUG: Saving to file E:\Programme\Jfritz\jfritz.phonebook.xml
(18:13:40) DEBUG: Sorting unfiltered data
(18:13:40) DEBUG: searching lastCall for allPersons in the phonebook....
(18:13:40) DEBUG: ...done
(18:13:40) DEBUG: searching all Persons for the CallerList...
(18:13:40) DEBUG: CallMonitorList: Added new event listener de.moonflower.jfritz.callmonitor.DisplayCallsMonitor@1afae45
(18:13:40) DEBUG: CallMonitorList: Added new event listener de.moonflower.jfritz.callmonitor.DisconnectMonitor@18f1d7e
(18:13:41) DEBUG: Start commandline parsing
(18:13:41) DEBUG: Multiple instance lock: Another instance is already running.
(18:13:43) DEBUG: Multiple instance lock: User decided NOT to shut down this instance.
(18:13:43) DEBUG: New instance of JFrame
(18:13:43) DEBUG: Create JFritz-GUI
(18:13:47) DEBUG: reading Buttons
(JFritzUpdate) ERROR: invocation target exception
java.lang.reflect.InvocationTargetException
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at de.moonflower.jfritz.autoupdate.JFritzUpdate.startJFritz(JFritzUpdate.java:197)
at de.moonflower.jfritz.autoupdate.JFritzUpdate.main(JFritzUpdate.java:165)
Caused by: java.lang.NullPointerException
at de.moonflower.jfritz.callerlist.CallerTable.valueChanged(CallerTable.java:238 )
at javax.swing.DefaultListSelectionModel.fireValueChanged(Unknown Source)
at javax.swing.DefaultListSelectionModel.changeSelection(Unknown Source)
at javax.swing.DefaultListSelectionModel.removeSelectionIntervalImpl(Unknown Source)
at javax.swing.DefaultListSelectionModel.removeSelectionInterval(Unknown Source)
at javax.swing.JTable.checkLeadAnchor(Unknown Source)
at javax.swing.JTable.tableChanged(Unknown Source)
at javax.swing.JTable.setModel(Unknown Source)
at javax.swing.JTable.<init>(Unknown Source)
at de.moonflower.jfritz.callerlist.CallerTable.<init>(CallerTable.java:71)
at de.moonflower.jfritz.callerlist.CallerListPanel.createCallerListTable(CallerListPanel.java:357)
at de.moonflower.jfritz.callerlist.CallerListPanel.<init>(CallerListPanel.java:241)
at de.moonflower.jfritz.JFritzWindow.createGUI(JFritzWindow.java:200)
at de.moonflower.jfritz.JFritzWindow.<init>(JFritzWindow.java:143)
at de.moonflower.jfritz.JFritz.createJFrame(JFritz.java:183)
at de.moonflower.jfritz.Main.main(Main.java:657)
... 6 more
(18:13:48 ) DEBUG: Starting shutdown thread..
(18:13:48 ) DEBUG: Shutdown thread done.
Keine Teilnehmerdaten nach Rückwärtssuche mit JFRITZ
Hallo, wer kann helfen?
Nach dem Abrufen der Daten mit Jfritz v06.2.01 von meiner Fritzbox 7170 werden nach der Rückwärtssuche keine Teilnehmerdaten angezeigt. Was kann die Ursache sein?
Danke für eine Antwort.
habe genau das gleiche Problem, (an zwei verschiedenen Rechnern)
Das scheint das Problem zu sein das jFritz die xml Dateien nicht richtig auswertet.
siehe hier
astrolux schrieb:
OT @Onemsiz, warum "krähst" Du das gleich an ...zig Stellen und Threads? Und was hat daszu bedeuten?
Das Thema kann man unter mehreren Überschriften unterbringen. So habe ich das auch gemacht.
Daraus braucht man keine Welle zu machen und nicht so militaerisch auftreten.
Wenn das hier so gewollt ist, so werde ich kein Doppel-Post erstellen.
Richtig. In den Forumsregeln steht, dass keine Doppel-Posts erlaubt sind. Ausserdem gab es deine Frage schon öfters und die wurde auch mit einer Begründung abgelehnt.
Gruß,
Rob
Gruß,
Rob
ok. Danke für ausführliche Anwort (bin eben Anfaenger)
Ich habe jetzt nicht den ganzen Thread verfolgt, ich hatte jedenfalls auch so eine InvocationTargetException und bei mir war die Lösung (openSUSE 10.2, x86_64) ein 32-Bit-Java zu nehmen, d.h. konkret:
/usr/lib/jvm/jre-1.5.0-sun/bin/java -jar jfritz.jar
Repeter
