- Mitglied seit
- 21 Jul 2013
- Beiträge
- 21
- Punkte für Reaktionen
- 0
- Punkte
- 0
[B]freetz@freetz-linux:~/freetz-trunk$ cd make/
freetz@freetz-linux:~/freetz-trunk/make$ rm -r -f iplog/
freetz@freetz-linux:~/freetz-trunk/make$ svn co http://svn.freetz.org/branches/sf3978_packages/make/iplog/[/B]
A iplog/iplog.mk
A iplog/files
A iplog/files/var.tar
A iplog/files/var.tar/var
A iplog/files/var.tar/var/tmp
A iplog/files/var.tar/var/tmp/flash
A iplog/files/var.tar/var/tmp/flash/iplog
A iplog/files/var.tar/var/tmp/flash/iplog/iplog.conf.sample
A iplog/external.files
A iplog/external.in
A iplog/patches
A iplog/patches/110_in_honor_of_avm_.patch
A iplog/patches/100_in_honor_of_freetz_.patch
A iplog/patches/200_remove_inet_ntoa_r.patch
A iplog/Config.in
Ausgecheckt, Revision 10951.
[B]freetz@freetz-linux:~/freetz-trunk/make$ cd ..
freetz@freetz-linux:~/freetz-trunk$ make iplog-dirclean[/B]
rm -f -r source/target-mips_gcc-4.6.4_uClibc-0.9.32.1/iplog-2.2.3
rm -f -r packages/target-mips_gcc-4.6.4_uClibc-0.9.32.1/iplog-2.2.3
rm -f packages/target-mips_gcc-4.6.4_uClibc-0.9.32.1/.iplog-2.2.3
rm -f -r packages/target-mips_gcc-4.6.4_uClibc-0.9.32.1/iplog-2.2.3; rm -f packages/target-mips_gcc-4.6.4_uClibc-0.9.32.1/.iplog-2.2.3;
[B]freetz@freetz-linux:~/freetz-trunk$ make iplog-precompiled[/B]
mkdir -p packages/target-mips_gcc-4.6.4_uClibc-0.9.32.1/iplog-2.2.3/root
if test -d make/iplog/files; then tar -c -C make/iplog/files --exclude=.svn . | tar -x -C packages/target-mips_gcc-4.6.4_uClibc-0.9.32.1/iplog-2.2.3 ; fi
---> package/iplog: preparing... tools/gunzip -c dl/iplog-2.2.3.tar.gz | tar -C source/target-mips_gcc-4.6.4_uClibc-0.9.32.1 -x
set -e; shopt -s nullglob; for i in make/iplog/patches/*.patch; do tools/freetz_patch source/target-mips_gcc-4.6.4_uClibc-0.9.32.1/iplog-2.2.3 $i; done
applying patch file make/iplog/patches/100_in_honor_of_freetz_.patch
patching file src/iplog_options.c
applying patch file make/iplog/patches/110_in_honor_of_avm_.patch
patching file src/iplog.h
applying patch file make/iplog/patches/200_remove_inet_ntoa_r.patch
patching file src/iplog_util.c
configuring... (conf_cmd() { ./configure "$@" || { printf "\n\\033[33m%s\\033[m\n" "ERROR: Build failed."; exit 1; } }; cd source/target-mips_gcc-4.6.4_uClibc-0.9.32.1/iplog-2.2.3; rm -f config.{cache,status}; cp -a ./configure ./configure.before_rpath_fix; sed -i -r -e "s|(runpath_var=)[$]runpath_var|\1|g" -e "s|(hardcode_into_libs=).+$|\1no|g" -e '/hardcode_libdir_flag_spec[_A-Za-z0-9]*=/s/[$][{]wl[}]-?-rpath(,| [$][{]wl[}])[$]libdir/-D__SOMETHING_NON_EMPTY_TO_FOOL_LIBTOOL__/g' -e 's/(hardcode_libdir_flag_spec(_ld)?=)[$]lt_([[][]]_LT_AC_TAGVAR[(])?hardcode_libdir_flag_spec[_A-Za-z0-9]*(, *[$]1[)])?/\1/g' ./configure; PATH="/home/freetz/freetz-trunk/toolchain/build/mips_gcc-4.6.4_uClibc-0.9.32.1/mips-linux-uclibc/bin:/home/freetz/freetz-trunk/toolchain/build/mips_gcc-4.6.4/mips-unknown-linux-gnu/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games" CC="/home/freetz/freetz-trunk/toolchain/build/mips_gcc-4.6.4_uClibc-0.9.32.1/mips-linux-uclibc/bin/mips-linux-uclibc-gcc" CXX="/home/freetz/freetz-trunk/toolchain/build/mips_gcc-4.6.4_uClibc-0.9.32.1/mips-linux-uclibc/bin/mips-linux-uclibc-g++-wrapper" CFLAGS="-march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64" CXXFLAGS="-march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64" LDFLAGS="" PKG_CONFIG_PATH="/home/freetz/freetz-trunk/toolchain/build/mips_gcc-4.6.4_uClibc-0.9.32.1/mips-linux-uclibc/bin/../lib/pkgconfig" PKG_CONFIG_LIBDIR="/home/freetz/freetz-trunk/toolchain/build/mips_gcc-4.6.4_uClibc-0.9.32.1/mips-linux-uclibc/bin/../lib/pkgconfig" GLOBAL_LIBDIR=/home/freetz/freetz-trunk/toolchain/build/mips_gcc-4.6.4_uClibc-0.9.32.1/mips-linux-uclibc/usr/lib FREETZ_TARGET_LFS="y" CONFIG_SITE=/home/freetz/freetz-trunk/include/site/mips-linux-uclibc conf_cmd --cache-file=/home/freetz/freetz-trunk/source/target-mips_gcc-4.6.4_uClibc-0.9.32.1/config.cache --target=mips-linux --host=mips-linux --build=i386-pc-linux-gnu --program-prefix="" --program-suffix="" --prefix=/usr --exec-prefix=/usr --bindir=/usr/bin --datadir=/usr/share --includedir=/usr/include --infodir=/usr/share/info --libdir=/usr/lib --libexecdir=/usr/lib --localstatedir=/var --mandir=/usr/share/man --sbindir=/usr/sbin --sysconfdir=/etc --with-gnu-ld --disable-nls --without-x --disable-maintainer-mode --with-libpcap=/usr/lib/freetz --with-libpcap-libs=/home/freetz/freetz-trunk/toolchain/build/mips_gcc-4.6.4_uClibc-0.9.32.1/mips-linux-uclibc/usr/lib --with-libpcap-includes=/home/freetz/freetz-trunk/toolchain/build/mips_gcc-4.6.4_uClibc-0.9.32.1/mips-linux-uclibc/usr/include )
loading site script /home/freetz/freetz-trunk/include/site/mips-linux-uclibc
loading cache /home/freetz/freetz-trunk/source/target-mips_gcc-4.6.4_uClibc-0.9.32.1/config.cache
checking for a BSD compatible install... (cached) /usr/bin/install -c
checking whether build environment is sane... yes
checking whether make sets ${MAKE}... (cached) yes
checking for working aclocal... found
checking for working autoconf... found
checking for working automake... found
checking for working autoheader... found
checking for working makeinfo... found
checking whether to enable maintainer-specific portions of Makefiles... no
checking for gcc... (cached) /home/freetz/freetz-trunk/toolchain/build/mips_gcc-4.6.4_uClibc-0.9.32.1/mips-linux-uclibc/bin/mips-linux-uclibc-gcc
checking whether the C compiler (/home/freetz/freetz-trunk/toolchain/build/mips_gcc-4.6.4_uClibc-0.9.32.1/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 ) works... yes
checking whether the C compiler (/home/freetz/freetz-trunk/toolchain/build/mips_gcc-4.6.4_uClibc-0.9.32.1/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 ) is a cross-compiler... yes
checking whether we are using GNU C... (cached) yes
checking whether /home/freetz/freetz-trunk/toolchain/build/mips_gcc-4.6.4_uClibc-0.9.32.1/mips-linux-uclibc/bin/mips-linux-uclibc-gcc accepts -g... (cached) yes
checking for a BSD compatible install... /usr/bin/install -c
checking host system type... mips-mips-linux-gnu
checking for __attribute__... (cached) yes
checking for dprintf... (cached) yes
checking for vasprintf... (cached) yes
checking for getopt_long... (cached) yes
checking for localtime_r... (cached) yes
checking for inet_aton... (cached) yes
checking for vsnprintf... (cached) yes
checking for snprintf... (cached) yes
checking for getpagesize... (cached) yes
checking how to run the C preprocessor... (cached) /home/freetz/freetz-trunk/toolchain/build/mips_gcc-4.6.4_uClibc-0.9.32.1/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -E
checking for paths.h... (cached) yes
checking for sys/sockio.h... (cached) no
checking for ANSI C header files... (cached) yes
checking for u_int32_t... (cached) yes
checking for u_int16_t... (cached) yes
checking for u_int8_t... (cached) yes
checking for ipaddr_t... no
checking for in_port_t... yes
checking for pthread_create in -lpthread... (cached) yes
checking for pthread_cancel in -lpthread... (cached) yes
checking for getservbyport_r... (cached) yes
checking whether getservbyport_r takes 6 args... yes
checking for gethostbyaddr_r... (cached) yes
checking whether gethostbyaddr_r takes 8 args... yes
checking for getprotobynumber_r... (cached) yes
checking whether getprotobynumber_r takes 5 args... yes
checking for pcap_open_live in -lpcap... (cached) yes
checking if sockaddr struct has sa_len member... (cached) no
checking for pcap.h... (cached) yes
creating ./config.status
creating Makefile
creating src/Makefile
creating src/gnu/Makefile
creating config.h
Please remember to use GNU make to build iplog.
iplog will not build with BSD (or any other) make.
You can get GNU make from any GNU mirror in /pub/gnu/make
PATH=""/home/freetz/freetz-trunk/toolchain/build/mips_gcc-4.6.4_uClibc-0.9.32.1/mips-linux-uclibc/bin:/home/freetz/freetz-trunk/toolchain/build/mips_gcc-4.6.4/mips-unknown-linux-gnu/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games"" \
make -j2 -C source/target-mips_gcc-4.6.4_uClibc-0.9.32.1/iplog-2.2.3
make[1]: Betrete Verzeichnis '/home/freetz/freetz-trunk/source/target-mips_gcc-4.6.4_uClibc-0.9.32.1/iplog-2.2.3'
make all-recursive
make[2]: Betrete Verzeichnis '/home/freetz/freetz-trunk/source/target-mips_gcc-4.6.4_uClibc-0.9.32.1/iplog-2.2.3'
Making all in src
make[3]: Betrete Verzeichnis '/home/freetz/freetz-trunk/source/target-mips_gcc-4.6.4_uClibc-0.9.32.1/iplog-2.2.3/src'
Making all in gnu
make[4]: Betrete Verzeichnis '/home/freetz/freetz-trunk/source/target-mips_gcc-4.6.4_uClibc-0.9.32.1/iplog-2.2.3/src/gnu'
make[4]: Für das Ziel »all« ist nichts zu tun.
make[4]: Verlasse Verzeichnis '/home/freetz/freetz-trunk/source/target-mips_gcc-4.6.4_uClibc-0.9.32.1/iplog-2.2.3/src/gnu'
make[4]: Betrete Verzeichnis '/home/freetz/freetz-trunk/source/target-mips_gcc-4.6.4_uClibc-0.9.32.1/iplog-2.2.3/src'
/home/freetz/freetz-trunk/toolchain/build/mips_gcc-4.6.4_uClibc-0.9.32.1/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/lib/freetz -I/home/freetz/freetz-trunk/toolchain/build/mips_gcc-4.6.4_uClibc-0.9.32.1/mips-linux-uclibc/usr/include -march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -D_REENTRANT -c getopt.c
/home/freetz/freetz-trunk/toolchain/build/mips_gcc-4.6.4_uClibc-0.9.32.1/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/lib/freetz -I/home/freetz/freetz-trunk/toolchain/build/mips_gcc-4.6.4_uClibc-0.9.32.1/mips-linux-uclibc/usr/include -march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -D_REENTRANT -c getopt1.c
/home/freetz/freetz-trunk/toolchain/build/mips_gcc-4.6.4_uClibc-0.9.32.1/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/lib/freetz -I/home/freetz/freetz-trunk/toolchain/build/mips_gcc-4.6.4_uClibc-0.9.32.1/mips-linux-uclibc/usr/include -march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -D_REENTRANT -c iplog_config.c
/home/freetz/freetz-trunk/toolchain/build/mips_gcc-4.6.4_uClibc-0.9.32.1/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/lib/freetz -I/home/freetz/freetz-trunk/toolchain/build/mips_gcc-4.6.4_uClibc-0.9.32.1/mips-linux-uclibc/usr/include -march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -D_REENTRANT -c iplog_dns.c
/home/freetz/freetz-trunk/toolchain/build/mips_gcc-4.6.4_uClibc-0.9.32.1/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/lib/freetz -I/home/freetz/freetz-trunk/toolchain/build/mips_gcc-4.6.4_uClibc-0.9.32.1/mips-linux-uclibc/usr/include -march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -D_REENTRANT -c iplog_icmp.c
/home/freetz/freetz-trunk/toolchain/build/mips_gcc-4.6.4_uClibc-0.9.32.1/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/lib/freetz -I/home/freetz/freetz-trunk/toolchain/build/mips_gcc-4.6.4_uClibc-0.9.32.1/mips-linux-uclibc/usr/include -march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -D_REENTRANT -c iplog_ident.c
/home/freetz/freetz-trunk/toolchain/build/mips_gcc-4.6.4_uClibc-0.9.32.1/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/lib/freetz -I/home/freetz/freetz-trunk/toolchain/build/mips_gcc-4.6.4_uClibc-0.9.32.1/mips-linux-uclibc/usr/include -march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -D_REENTRANT -c iplog_input.c
/home/freetz/freetz-trunk/toolchain/build/mips_gcc-4.6.4_uClibc-0.9.32.1/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/lib/freetz -I/home/freetz/freetz-trunk/toolchain/build/mips_gcc-4.6.4_uClibc-0.9.32.1/mips-linux-uclibc/usr/include -march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -D_REENTRANT -c iplog_lockfile.c
/home/freetz/freetz-trunk/toolchain/build/mips_gcc-4.6.4_uClibc-0.9.32.1/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/lib/freetz -I/home/freetz/freetz-trunk/toolchain/build/mips_gcc-4.6.4_uClibc-0.9.32.1/mips-linux-uclibc/usr/include -march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -D_REENTRANT -c iplog_options.c
/home/freetz/freetz-trunk/toolchain/build/mips_gcc-4.6.4_uClibc-0.9.32.1/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/lib/freetz -I/home/freetz/freetz-trunk/toolchain/build/mips_gcc-4.6.4_uClibc-0.9.32.1/mips-linux-uclibc/usr/include -march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -D_REENTRANT -c iplog_pcap.c
/home/freetz/freetz-trunk/toolchain/build/mips_gcc-4.6.4_uClibc-0.9.32.1/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/lib/freetz -I/home/freetz/freetz-trunk/toolchain/build/mips_gcc-4.6.4_uClibc-0.9.32.1/mips-linux-uclibc/usr/include -march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -D_REENTRANT -c iplog_scan.c
/home/freetz/freetz-trunk/toolchain/build/mips_gcc-4.6.4_uClibc-0.9.32.1/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/lib/freetz -I/home/freetz/freetz-trunk/toolchain/build/mips_gcc-4.6.4_uClibc-0.9.32.1/mips-linux-uclibc/usr/include -march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -D_REENTRANT -c iplog_syslog.c
/home/freetz/freetz-trunk/toolchain/build/mips_gcc-4.6.4_uClibc-0.9.32.1/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/lib/freetz -I/home/freetz/freetz-trunk/toolchain/build/mips_gcc-4.6.4_uClibc-0.9.32.1/mips-linux-uclibc/usr/include -march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -D_REENTRANT -c iplog_tcp.c
/home/freetz/freetz-trunk/toolchain/build/mips_gcc-4.6.4_uClibc-0.9.32.1/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/lib/freetz -I/home/freetz/freetz-trunk/toolchain/build/mips_gcc-4.6.4_uClibc-0.9.32.1/mips-linux-uclibc/usr/include -march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -D_REENTRANT -c iplog_udp.c
iplog_tcp.c: In function 'tcp_parser':
iplog_tcp.c:151:19: warning: passing argument 5 of 'sendto' from incompatible pointer type [enabled by default]
/home/freetz/freetz-trunk/toolchain/build/mips_gcc-4.6.4_uClibc-0.9.32.1/mips-linux-uclibc/bin/../lib/gcc/mips-linux-uclibc/4.6.4/../../../../mips-linux-uclibc/include/sys/socket.h:155:16: note: expected 'const struct sockaddr *' but argument is of type 'struct sockaddr_in *'
/home/freetz/freetz-trunk/toolchain/build/mips_gcc-4.6.4_uClibc-0.9.32.1/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/lib/freetz -I/home/freetz/freetz-trunk/toolchain/build/mips_gcc-4.6.4_uClibc-0.9.32.1/mips-linux-uclibc/usr/include -march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -D_REENTRANT -c iplog_util.c
/home/freetz/freetz-trunk/toolchain/build/mips_gcc-4.6.4_uClibc-0.9.32.1/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/lib/freetz -I/home/freetz/freetz-trunk/toolchain/build/mips_gcc-4.6.4_uClibc-0.9.32.1/mips-linux-uclibc/usr/include -march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -D_REENTRANT -c iplog.c
iplog_util.c: In function 'host_lookup':
iplog_util.c:416:3: warning: return makes pointer from integer without a cast [enabled by default]
iplog_util.c:436:4: warning: return makes pointer from integer without a cast [enabled by default]
/home/freetz/freetz-trunk/toolchain/build/mips_gcc-4.6.4_uClibc-0.9.32.1/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/lib/freetz -I/home/freetz/freetz-trunk/toolchain/build/mips_gcc-4.6.4_uClibc-0.9.32.1/mips-linux-uclibc/usr/include -march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -D_REENTRANT -c snprintf.c
/home/freetz/freetz-trunk/toolchain/build/mips_gcc-4.6.4_uClibc-0.9.32.1/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -D_REENTRANT -L/usr/lib/freetz -L/home/freetz/freetz-trunk/toolchain/build/mips_gcc-4.6.4_uClibc-0.9.32.1/mips-linux-uclibc/usr/lib -o iplog getopt.o getopt1.o iplog_config.o iplog_dns.o iplog_icmp.o iplog_ident.o iplog_input.o iplog_lockfile.o iplog_options.o iplog_pcap.o iplog_scan.o iplog_syslog.o iplog_tcp.o iplog_udp.o iplog_util.o iplog.o snprintf.o -lpthread -lpcap
make[4]: Verlasse Verzeichnis '/home/freetz/freetz-trunk/source/target-mips_gcc-4.6.4_uClibc-0.9.32.1/iplog-2.2.3/src'
make[3]: Verlasse Verzeichnis '/home/freetz/freetz-trunk/source/target-mips_gcc-4.6.4_uClibc-0.9.32.1/iplog-2.2.3/src'
make[3]: Betrete Verzeichnis '/home/freetz/freetz-trunk/source/target-mips_gcc-4.6.4_uClibc-0.9.32.1/iplog-2.2.3'
make[3]: Verlasse Verzeichnis '/home/freetz/freetz-trunk/source/target-mips_gcc-4.6.4_uClibc-0.9.32.1/iplog-2.2.3'
make[2]: Verlasse Verzeichnis '/home/freetz/freetz-trunk/source/target-mips_gcc-4.6.4_uClibc-0.9.32.1/iplog-2.2.3'
make[1]: Verlasse Verzeichnis '/home/freetz/freetz-trunk/source/target-mips_gcc-4.6.4_uClibc-0.9.32.1/iplog-2.2.3'
mkdir -p packages/target-mips_gcc-4.6.4_uClibc-0.9.32.1/iplog-2.2.3/root/usr/bin/; cp source/target-mips_gcc-4.6.4_uClibc-0.9.32.1/iplog-2.2.3/src/iplog packages/target-mips_gcc-4.6.4_uClibc-0.9.32.1/iplog-2.2.3/root/usr/bin/iplog; /home/freetz/freetz-trunk/toolchain/build/mips_gcc-4.6.4_uClibc-0.9.32.1/mips-linux-uclibc/bin/mips-linux-uclibc-strip --remove-section={.comment,.note,.pdr} packages/target-mips_gcc-4.6.4_uClibc-0.9.32.1/iplog-2.2.3/root/usr/bin/iplog;
done.
dann ein make
STEP 1: UNPACK (SKIPPED)
detected firmware 7360_de 124.05.50 rev24690 (25.02.2013 13:39:11)
STEP 2: MODIFY
applying symlinks, deleting additional webinterfaces in: usr/www usr/www.nas usr/www.myfritz
applying patches
applying patches: 7360-de (05_5X)
applying patch file ./patches/devices/05_5X/105-S06-logging.sh
applying patch file ./patches/devices/05_5X/115-S20-modload.sh
applying patch file ./patches/devices/05_5X/200-tun-device.sh
patching build/modified/filesystem/etc/udev/rules.d/50-udev-default.rules
Language specific HTML directory: build/modified/filesystem/usr/www/all/html/de
applying patch file ./patches/devices/05_5X/120-rc.S-dev.patch
patching file etc/init.d/rc.S
applying patch file ./patches/devices/05_5X/140-rc.tail.sh-no_exit.patch
patching file etc/init.d/rc.tail.sh
applying patch file ./patches/devices/05_5X/de/190-webmenu.patch
patching file usr/www/all/templates/menu_page_end.html
patching file usr/www/all/menus/menu_freetz.lua
patching file usr/www/all/templates/menu_page_head.html
creating symlinks /tmp, /mod and /home
creating /mnt and /opt
setting freetz-version 'freetz-devel-10951'
applying patch file ./patches/scripts/100-3170_7170.sh
applying patch file ./patches/scripts/100-7112_7170.sh
applying patch file ./patches/scripts/100-7113_7170.sh
applying patch file ./patches/scripts/100-7140_7170.sh
applying patch file ./patches/scripts/100-7141_7170.sh
applying patch file ./patches/scripts/100-7240_7270.sh
applying patch file ./patches/scripts/100-7270v1_7270v2.sh
applying patch file ./patches/scripts/100-7270v2_7270v1.sh
applying patch file ./patches/scripts/100-7320_7330.sh
applying patch file ./patches/scripts/100-7340_7390.sh
applying patch file ./patches/scripts/100-7570_7270.sh
applying patch file ./patches/scripts/100-7570_iad7570.sh
applying patch file ./patches/scripts/100-enforce-urlader-settings.sh
applying patch file ./patches/scripts/100_iad3331_7170.sh
applying patch file ./patches/scripts/100-w701v_7170.sh
applying patch file ./patches/scripts/100-w900v_7170.sh
applying patch file ./patches/scripts/100-w920v_7570.sh
applying patch file ./patches/scripts/101-ctlmgr_wrapper.sh
applying patch file ./patches/scripts/105-onlinechanged.sh
patching /bin/onlinechanged
applying patch file ./patches/scripts/108-tffs_nodes.sh
applying tffs_nodes patch
patching build/modified/filesystem/etc/init.d/S08-tffs
applying patch file ./patches/scripts/109-rc.net-multid-wrapper.sh
replacing multid by a wrapper
patching build/modified/filesystem/etc/init.d/rc.net
applying patch file ./patches/scripts/110-inittab.sh
applying patch file ./patches/scripts/110-multid-wait.sh
applying multid-wait patch
applying patch file ./patches/scripts/110-system_status.sh
applying patch file ./patches/scripts/115-rc.S.sh
applying patch file ./patches/scripts/116-usbroot_S46-usb.sh
applying patch file ./patches/scripts/120-dev_led.sh
applying /dev/led patch
patching build/modified/filesystem/bin/update_led_on
patching build/modified/filesystem/bin/update_led_off
applying patch file ./patches/scripts/130-fstab.sh
applying patch file ./patches/scripts/140-remove-uClibc.sh
removing uClibc-0.9.32 files
rm -rf build/modified/filesystem/lib/*0.9.32*
removing uClibc links
rm -rf build/modified/filesystem/lib/ld-linux.so*
rm -rf build/modified/filesystem/usr/lib/ld-linux.so*
rm -rf build/modified/filesystem/lib/ld-uClibc.so*
rm -rf build/modified/filesystem/usr/lib/ld-uClibc.so*
rm -rf build/modified/filesystem/lib/ld.so*
rm -rf build/modified/filesystem/usr/lib/ld.so*
rm -rf build/modified/filesystem/lib/libc.so*
rm -rf build/modified/filesystem/usr/lib/libc.so*
rm -rf build/modified/filesystem/lib/libcrypt.so*
rm -rf build/modified/filesystem/usr/lib/libcrypt.so*
rm -rf build/modified/filesystem/lib/libdl.so*
rm -rf build/modified/filesystem/usr/lib/libdl.so*
rm -rf build/modified/filesystem/lib/libld-uClibc*
rm -rf build/modified/filesystem/usr/lib/libld-uClibc*
rm -rf build/modified/filesystem/lib/libm.so*
rm -rf build/modified/filesystem/usr/lib/libm.so*
rm -rf build/modified/filesystem/lib/libnsl.so*
rm -rf build/modified/filesystem/usr/lib/libnsl.so*
rm -rf build/modified/filesystem/lib/libpthread.so*
rm -rf build/modified/filesystem/usr/lib/libpthread.so*
rm -rf build/modified/filesystem/lib/libthread_db.so*
rm -rf build/modified/filesystem/usr/lib/libthread_db.so*
rm -rf build/modified/filesystem/lib/libresolv.so*
rm -rf build/modified/filesystem/usr/lib/libresolv.so*
rm -rf build/modified/filesystem/lib/librt.so*
rm -rf build/modified/filesystem/usr/lib/librt.so*
rm -rf build/modified/filesystem/lib/libubacktrace.so*
rm -rf build/modified/filesystem/usr/lib/libubacktrace.so*
rm -rf build/modified/filesystem/lib/libutil.so*
rm -rf build/modified/filesystem/usr/lib/libutil.so*
linking ld.so.1
applying patch file ./patches/scripts/170-rename_ar7login.sh
renaming ar7login to make way for wrapper script
applying patch file ./patches/scripts/180-printk.sh
applying printk patch
patching build/modified/filesystem/etc/init.d/S11-piglet
applying patch file ./patches/scripts/190-webmenu.sh
applying webmenu patch
patching build/modified/filesystem/usr/www/all/html/de/menus/menu2.html
applying patch file ./patches/scripts/195-webmenu_signed.sh
applying patch file ./patches/scripts/197-freetzmount.sh
applying FREETZMOUNT patch
patching build/modified/filesystem/etc/hotplug/storage
patching build/modified/filesystem/etc/hotplug/udev-mount-sd
patching run_mount script
patching /etc/hotplug/storage
applying patch file ./patches/scripts/198-usbroot.sh
applying patch file ./patches/scripts/200-vcc.sh
applying patch file ./patches/scripts/210-ata.sh
applying patch file ./patches/scripts/210-enum.sh
applying patch file ./patches/scripts/210-international.sh
applying patch file ./patches/scripts/220-assistant.sh
applying patch file ./patches/scripts/220-cdrom-iso.sh
applying patch file ./patches/scripts/220-chronyd.sh
applying patch file ./patches/scripts/220-help.sh
applying patch file ./patches/scripts/220-remove-nas.sh
applying patch file ./patches/scripts/221-remove_myfritz.sh
applying patch file ./patches/scripts/225-remove_fhem.sh
applying patch file ./patches/scripts/230-openssl.sh
applying patch file ./patches/scripts/240-add-dsl-expert-pages.sh
applying patch file ./patches/scripts/250-remove_avm_inetd.sh
removing AVM inetd
rm -rf build/modified/filesystem/bin/inetdctl
rm -rf build/modified/filesystem/etc/inetd.conf
rm -rf build/modified/filesystem/etc/init.d/S75-inetd
applying patch file ./patches/scripts/260-remove_tr069.sh
applying patch file ./patches/scripts/270-remove_ethernet_over_usb.sh
applying patch file ./patches/scripts/275-multiple_printers.sh
applying patch file ./patches/scripts/280-remove_upnp.sh
applying patch file ./patches/scripts/290-replace_websrv.sh
applying patch file ./patches/scripts/300-remove-samba.sh
applying patch file ./patches/scripts/310-remove_kids.sh
applying patch file ./patches/scripts/315-remove-qos.sh
applying patch file ./patches/scripts/320-remove_capiotcp.sh
applying patch file ./patches/scripts/320-remove-dsld.sh
applying patch file ./patches/scripts/325-remove-showdsldstat.sh
applying patch file ./patches/scripts/330-remove-telephony.sh
applying patch file ./patches/scripts/331-remove-voipd.sh
applying patch file ./patches/scripts/340-remove_dect_update.sh
applying patch file ./patches/scripts/345-hide_dsl.sh
applying patch file ./patches/scripts/350-add_remove_annex_file.sh
applying patch file ./patches/scripts/355-remove_dsl_control.sh
applying patch file ./patches/scripts/360-remove-wlan.sh
applying patch file ./patches/scripts/370-remove_dtrace.sh
removing dtrace file
rm -rf build/modified/filesystem/usr/bin/dtrace
applying patch file ./patches/scripts/380-remove-umtsd.sh
applying patch file ./patches/scripts/381-modify-umtsd.sh
applying patch file ./patches/scripts/382-enable-gsmvoice.sh
applying patch file ./patches/scripts/385-remove-ntfs.sh
applying patch file ./patches/scripts/386-remove_fat.sh
applying patch file ./patches/scripts/390-remove_e2fsprogs.sh
remove AVM's e2fsprogs binaries
rm -rf build/modified/filesystem/sbin/blkid
rm -rf build/modified/filesystem/usr/sbin/blkid
rm -rf build/modified/filesystem/usr/sbin/e2fsck
rm -rf build/modified/filesystem/usr/sbin/fsck.ext3
rm -rf build/modified/filesystem/usr/sbin/fsck.ext2
rm -rf build/modified/filesystem/usr/sbin/fsck.ext4dev
rm -rf build/modified/filesystem/sbin/mkfs
rm -rf build/modified/filesystem/sbin/mkswap
remove AVM's e2fsprogs libraries
rm -rf build/modified/filesystem/usr/lib/libblkid*
rm -rf build/modified/filesystem/usr/lib/libcom_err*
rm -rf build/modified/filesystem/usr/lib/libe2p*
rm -rf build/modified/filesystem/usr/lib/libext2fs*
rm -rf build/modified/filesystem/usr/lib/libuuid*
applying patch file ./patches/scripts/400-remove-inetdctl.sh
applying patch file ./patches/scripts/401-remove_ftpd.sh
remove banner from AVM ftpd
applying patch file ./patches/scripts/410-remove_piglet.sh
applying patch file ./patches/scripts/420-remove_printserv.sh
applying patch file ./patches/scripts/460-MAXDEVCOUNT.sh
applying patch file ./patches/scripts/480-alarmclock.sh
applying patch file ./patches/scripts/490-remove-ramzswap.sh
applying patch file ./patches/scripts/500-remove-mediasrv.sh
applying patch file ./patches/scripts/510-remove_aha.sh
applying patch file ./patches/scripts/510-remove_aura_usb.sh
applying patch file ./patches/scripts/510-remove_avm_vpn.sh
applying patch file ./patches/scripts/510-remove_minid.sh
applying patch file ./patches/scripts/520-remove_dect.sh
applying patch file ./patches/scripts/530-remove_support.sh
applying patch file ./patches/scripts/540-remove_webdav.sh
applying patch file ./patches/scripts/550-add_reg_external_in_gui.sh
applying patch file ./patches/scripts/560-remove_lsof.sh
applying patch file ./patches/scripts/565-remove_more.sh
removing more
rm -rf build/modified/filesystem/bin/more
applying patch file ./patches/scripts/570-remove_strace.sh
applying patch file ./patches/scripts/580-remove_jffs2.sh
applying patch file ./patches/scripts/585-remove_isofs.sh
applying patch file ./patches/scripts/590-remove_libfuse.sh
applying patch file ./patches/scripts/600-replace_mdev.sh
applying patch file ./patches/scripts/610-remove_socat.sh
applying patch file ./patches/scripts/700-add_bash_to_etc_shells.sh
applying patch file ./patches/scripts/700-set_lang_to_utf8.sh
applying patch file ./patches/scripts/900-add_options_cfg.sh
creating options.cfg
adding FREETZ_AVMDAEMON_DISABLE_NTP
adding FREETZ_AVM_VERSION_05_5X_MIN
adding FREETZ_BUSYBOX_KLOGD
adding FREETZ_PACKAGE_INETD
adding FREETZ_TARGET_IPV6_SUPPORT
applying patch file ./patches/scripts/999-remove_run_clock.sh
removing oem: none
installing mod base
installing libs
ld_uClibc .................... 10.20 Kb
libcrypt ..................... 6.82 Kb
libctlmgr .................... 1.80 Kb
libdl ........................ 4.22 Kb
libgcc_s ..................... 20.47 Kb
libm ......................... 31.20 Kb
libpcap ...................... 65.91 Kb
libpthread ................... 21.51 Kb
librt ........................ 2.38 Kb
libuClibc .................... 191.51 Kb
installing busybox
replacing busybox
installing symlinks
kernel modules installed: 69 (68 files)
installing packages
syslogd-cgi-0.2.3 ............ 3.12 Kb
inetd-0.2 .................... 2.97 Kb
haserl-0.9.30 ................ 8.72 Kb
iplog-2.2.3 .................. 19.54 Kb
mod-1.0 ...................... 98.76 Kb
modcgi-0.3 ................... 3.41 Kb
invoking custom script
processing mod base options
setting colored style as default
patching security level (1)
integrated FREETZMOUNT
integrated Box-Info
integrated FREETZ-Info
integrated .config (stripped)
stripping leftover unstripped binaries
build/modified/filesystem/usr/sbin/oamd
build/modified/filesystem/usr/sbin/oamctl
build/modified/filesystem/usr/share/ctlmgr/libplcctlmgr.so
build/modified/filesystem/usr/share/ctlmgr/libwlan.so
build/modified/filesystem/usr/share/ctlmgr/libctlwebdav.so
build/modified/filesystem/lib/libdslsmiface.so.0.0.0
build/modified/filesystem/lib/libm-0.9.32.1.so
build/modified/filesystem/lib/librt-0.9.32.1.so
build/modified/filesystem/lib/ld-uClibc-0.9.32.1.so
build/modified/filesystem/lib/libcrypt-0.9.32.1.so
build/modified/filesystem/lib/libtiinterpreter.so.0.0.0
build/modified/filesystem/lib/libuClibc-0.9.32.1.so
build/modified/filesystem/lib/libdl-0.9.32.1.so
build/modified/filesystem/lib/libwlancsi.so
build/modified/filesystem/lib/libpthread-0.9.32.1.so
build/modified/filesystem/lib/libwlanparams.so
build/modified/filesystem/bin/wlancfgconv
build/modified/filesystem/bin/wlancfgctl
done.
STEP 3: PACK
checking for left over Subversion directories
integrate freetz info file into image
packing var.tar
creating filesystem image
SquashFS block size: 65536 (64 kB)
merging kernel image
kernel image size: 15503616 (max: 32899072, free: 17395456)
Aproximately free time for the answering machine: 8461s (141min 1s)
packing images/7360_05.50-freetz-devel-10951.de_20130828-171850.image
done.
FINISHED
Image auf die FB; und die gleichen Symptome wie immer = Fritz.Box kann nicht angesprochen werden
