[INFO] ettercap
Stable 2.0
elysium@elysium-VirtualBox:~/freetz-stable-2.0$ sudo patch -p0 < ../Downloads/ettercap_proper.patch.txt
patching file make/ettercap/Makefile.in
patching file make/ettercap/external.files
patching file make/ettercap/external.in
patching file make/ettercap/patches/200-NS_GET32.patch
patching file make/ettercap/patches/100-iconv_cross.patch
patching file make/ettercap/Config.in
patching file make/ettercap/ettercap.mk
Mach mal im stable 2.0
make ettercap-precompiled
Oh man ich bin sooo doof :D
Bei der Fehlermeldung in meinem ersten post habe ich eine Zeile vergessen.
Da stenad was die ganze Zeit schief lief
checking for correct ltmain.sh version... grep: character class syntax is [[:space:]], not [:space:]
no
*** Gentoo sanity check failed! ***
*** libtool.m4 and ltmain.sh have a version mismatch! ***
*** (libtool.m4 = 1.5.18, ltmain.sh = ) ***
Please run:
libtoolize --copy --force
if appropriate, please contact the maintainer of this
package (or your distribution) for help.
I don't know if this happens in i686 systems (tough it probably does).
In diesen Files:
/home/elysium/freetz-stable-2.0/source/target-mipsel_uClibc-0.9.32.1/ettercap-NG-0.7.3/configure.before_rpath_fix
/home/elysium/freetz-stable-2.0/source/target-mipsel_uClibc-0.9.32.1/ettercap-NG-0.7.3/config.log
/home/elysium/freetz-stable-2.0/source/target-mipsel_uClibc-0.9.32.1/ettercap-NG-0.7.3/aclocal.m4
[:space:] durch [[:space:]] ersetzen und es funktioniert wunderbar. :)
Hunk #1 FAILED at 106.
1 out of 1 hunk FAILED -- saving rejects to file make/Config.in.rej
patching file make/external.in
Hunk #1 FAILED at 11.
1 out of 1 hunk FAILED -- saving rejects to file make/external.in.rej
Die Fehler im Patch hab ich manuell eingetragen. Hat sich nur das aussehen der Datei etwas geändert.
Danke dir vielmals für den patch und die Hilfe!
muisyle
