DEBUG: Response:
220 ADAM2 FTP Server ready
DEBUG: Sent
USER adam2
DEBUG: Response:
331 Password required for adam2
DEBUG: Sent
PASS adam2
DEBUG: Response:
230 User adam2 successfully logged in
DEBUG: Sent
SYST
DEBUG: Response:
215 AVM EVA Version 1.11744 0x0 0x46409
DEBUG: Sent
GETENV memsize
DEBUG: Response:
memsize 0x20000000
200 GETENV command successful
DEBUG: Memory size found : 0x20000000 (512 MB)
DEBUG: Memory size used : 0x08000000 (128 MB)
DEBUG: Image size found : 0x0301da00
DEBUG: Set memory size to : 0x04fe2600
DEBUG: Set MTD RAM device to: 0x84fe2600,0x88000000
DEBUG: Sent
SETENV memsize 0x04fe2600
DEBUG: Response:
200 SETENV command successful
DEBUG: Sent
SETENV kernel_args_tmp mtdram1=0x84fe2600,0x88000000
DEBUG: Response:
DEBUG: Sent
TYPE I
DEBUG: Response:
200 Type set to BINARY
DEBUG: Sent
MEDIA SDRAM
DEBUG: Response:
200 Media set to MEDIA_SDRAM
DEBUG: Uploading file 'C:\......\Freetz\7590AX_08.00.image.in-memory' to '0x84fe2600 0x88000000' ...
DEBUG: Sent
P@SW
DEBUG: Response:
227 Entering Passive Mode (192,168,178,1,12,22)
DEBUG: Sent
STOR 0x84fe2600 0x88000000
DEBUG: Response:
501 unknown variable 0x84fe2600
DEBUG: Sent
SETENV memsize 0x20000000
DEBUG: Response:
DEBUG: Sent
UNSETENV kernel_args_tmp
DEBUG: Response:
501 environment variable not set
DEBUG: Sent
QUIT
DEBUG: Response:
221 Thank you for using the FTP service on ADAM2
221 Goodbye.
Ausnahme beim Aufrufen von "Invoke" mit 0 Argument(en): "Error uploading image file."
In C:\.....\Freetz\EVA-FTP-Client.ps1:638 Zeichen:21
+ $ScriptBlock.Invoke()
+ CategoryInfo : NotSpecified: (:) [], ParentContainsErrorRecordException
+ FullyQualifiedErrorId : RuntimeException
