How to us mktffs.pl for creating mtd3 & mtd4
bartdubelaar
9 Mai 2006
Hello all,
Sorry for writing in english but writing this in german might make it even more difficult to read.
To make a long story short: I have set my firmware_version from avm to avme and now my fritz!box fon no longer boots. I can reset the firmware with the recoverimage.exe but this doesn't help. I can still access the box with ftp at boot time. So what I suppose I have to do is create new mtd3 and mtd4 files to set the avme setting back to avm. For creating these files I have read here on the forums I need to use mktffs.pl, but I can not find anywhere how to use it! Whe I run it like this; ./mktffs.pl nothing happens at all. The "beispiel" on wehavemorefun.de doesn't make things clearer either.
Can anyone help me with changing my avme setting back to avm and how to use mktffs.pl?
Thanks a lot!
Bart Dubelaar
I have already solved my problem by resetting the firmware_version value to avm via FTP access.
I used this command:
quote SETENV firmware_version,avm
After reboot my Fritz!Box Fon worked again!
Note that in many posts on this forum the usage of SETENV is explained wrong. You need to use a , between the variable and the value, not a space!
Greetings,
Bart Dubelaar
J500
