- Mitglied seit
- 14 Jul 2013
- Beiträge
- 3
- Punkte für Reaktionen
- 0
- Punkte
- 0
Hi everyone,
I noticed that my 7270v3 (currently with FRITZ! 05:51 OS) uses a lot of CPU (especially in software IRQ) during simple file transfers, even during internal-only file transfers (eg. between laptop and NAS). Typical example:
Even without top, almost 80% of CPU time in sirq seems a little too much to me.
I noticed that QoS filters have a measurable, but not substantial, impact on CPU usage. In your opinion, is this normal? Is it possible to improve the situation with Freetz, which options would you recommend?
Thanks in advance!
# top
Mem: 50820K used, 8480K free, 0K shrd, 4856K buff, 16060K cached
CPU: 0.3% usr 1.9% sys 0.0% nic 15.8% idle 0.0% io 5.6% irq 76.2% sirq
Load average: 1.53 1.20 0.78 2/73 2213
PID PPID USER STAT VSZ %VSZ CPU %CPU COMMAND
232 2 root SW 0 0.0 0 8.0 [capi_schedw/0]
2211 2167 root R 1440 2.4 0 7.0 top
3 2 root SW 0 0.0 0 6.8 [ksoftirqd/0]
1870 2 root RWN 0 0.0 0 4.9 [kdsld_token]
Thanks in advance!
