Help: pppoe fehler
didomauro
29 Apr 2005
Hy!
Traurig für meine Sprache: ich bin italienisch.
Mein Fritz! schließt nicht an und der führende DSL bleibt immer weg, selbst wenn Energie das Endblitzen führte. Er gibt diese Anzeige:
DES Verbindungsabbaus Grund: PPOE Fehler
Das ich mein fritz!Boxfon WLAN in Italien, tatsächlich ich benutze, änderte von annex B zur annex A.
Firmware version: 08.03.53
Hallo, Mauro.
Hy!
Sorry for my language: i'm italian.
My Fritz! doesn't connect, and the led DSL remains always off, even if power led stops flashing. It gives this message:
Grund des Verbindungsabbaus: PPOE Fehler
I use my fritz!Box fon WLAN in Italy, in fact I changed from annex B to annex A.
Hi, Mauro.
Fritzbox con Alice
Ciao Mauro,
Ho il tuo stesso problema.
Anche a me arriva questo stesso errore.
Io uso Alice.
Hai trovato una soluzione?
ciao
Luppone
Ciao Luppone,
benvenuto in questa tribuna di discussione di VoIP. Articoli qui devono usare tedesco o inglese. Prego usi una di queste lingue. Mille grazie e continuano a godere il VoIP :)
And now we continue in English oder wir machen in Deutsch weiter. ;-)
Grazie,
--gandalf.
Fritzbox con Alice
Ciao Mauro,
I have the same problem.
I get the same error message.
I use Alice.
Did you solve your problem?
ciao
Lupone
Your firmware version seems to be very old. Is there any special reason for that? If not, I would suggest to update. Did you test your DSL-connection with another DSL-modem or -router? Does it work? Is "Annex A" shown in the Web GUI of your FritzBox?
Alice & Fritzbox 7050
thank you for your fast answer.
Yes, I have the latest Firmware installed, and I have Annex A, and it is visible in the Gui, but I can't connect the DSL, only the Phone works.
I can easely connect with my AliceModem, and If I connect the Fritzbox behind the ADSL Modem, it works fine, but then I can't get the Phone to work.
What am I doing wrong???
