[2016-11-17 08:53:45] VERBOSE[4477][C-00000003] pbx.c: Executing [90810972599362540@from-sip-external:1] NoOp("SIP/91.64.147.180-00000005", "Received incoming SIP connection from unknown peer to 90810972599362540") in new stack
[2016-11-17 08:53:45] VERBOSE[4477][C-00000003] pbx.c: Executing [90810972599362540@from-sip-external:2] Set("SIP/91.64.147.180-00000005", "DID=90810972599362540") in new stack
[2016-11-17 08:53:45] VERBOSE[4477][C-00000003] pbx.c: Executing [90810972599362540@from-sip-external:3] Goto("SIP/91.64.147.180-00000005", "s,1") in new stack
[2016-11-17 08:53:45] VERBOSE[4477][C-00000003] pbx_builtins.c: Goto (from-sip-external,s,1)
[2016-11-17 08:53:45] VERBOSE[4477][C-00000003] pbx.c: Executing [s@from-sip-external:1] GotoIf("SIP/91.64.147.180-00000005", "1?checklang:noanonymous") in new stack
[2016-11-17 08:53:45] VERBOSE[4477][C-00000003] pbx_builtins.c: Goto (from-sip-external,s,2)
[2016-11-17 08:53:45] VERBOSE[4477][C-00000003] pbx.c: Executing [s@from-sip-external:2] GotoIf("SIP/91.64.147.180-00000005", "1?setlanguage:from-trunk,90810972599362540,1") in new stack
[2016-11-17 08:53:45] VERBOSE[4477][C-00000003] pbx_builtins.c: Goto (from-sip-external,s,3)
[2016-11-17 08:53:45] VERBOSE[4477][C-00000003] pbx.c: Executing [s@from-sip-external:3] Set("SIP/91.64.147.180-00000005", "CHANNEL(language)=de") in new stack
[2016-11-17 08:53:45] VERBOSE[4477][C-00000003] pbx.c: Executing [s@from-sip-external:4] Goto("SIP/91.64.147.180-00000005", "from-trunk,90810972599362540,1") in new stack
[2016-11-17 08:53:45] VERBOSE[4477][C-00000003] pbx_builtins.c: Goto (from-trunk,90810972599362540,1)
[2016-11-17 08:53:45] VERBOSE[4477][C-00000003] pbx.c: Executing [90810972599362540@from-trunk:1] Set("SIP/91.64.147.180-00000005", "__FROM_DID=90810972599362540") in new stack
[2016-11-17 08:53:45] VERBOSE[4477][C-00000003] pbx.c: Executing [90810972599362540@from-trunk:2] NoOp("SIP/91.64.147.180-00000005", "Received an unknown call with DID set to 90810972599362540") in new stack
[2016-11-17 08:53:45] VERBOSE[4477][C-00000003] pbx.c: Executing [90810972599362540@from-trunk:3] Goto("SIP/91.64.147.180-00000005", "s,a2") in new stack
[2016-11-17 08:53:45] VERBOSE[4477][C-00000003] pbx_builtins.c: Goto (from-trunk,s,2)
[2016-11-17 08:53:45] VERBOSE[4477][C-00000003] pbx.c: Executing [s@from-trunk:2] Answer("SIP/91.64.147.180-00000005", "") in new stack
[2016-11-17 08:53:45] VERBOSE[4477][C-00000003] pbx.c: Spawn extension (from-trunk, s, 2) exited non-zero on 'SIP/91.64.147.180-00000005'
[2016-11-17 08:53:45] VERBOSE[4477][C-00000003] pbx.c: Executing [h@from-trunk:1] Macro("SIP/91.64.147.180-00000005", "hangupcall,") in new stack
[2016-11-17 08:53:45] VERBOSE[4477][C-00000003] pbx.c: Executing [s@macro-hangupcall:1] GotoIf("SIP/91.64.147.180-00000005", "1?theend") in new stack
[2016-11-17 08:53:45] VERBOSE[4477][C-00000003] pbx_builtins.c: Goto (macro-hangupcall,s,3)
[2016-11-17 08:53:45] VERBOSE[4477][C-00000003] pbx.c: Executing [s@macro-hangupcall:3] ExecIf("SIP/91.64.147.180-00000005", "0?Set(CDR(recordingfile)=)") in new stack
[2016-11-17 08:53:45] VERBOSE[4477][C-00000003] pbx.c: Executing [s@macro-hangupcall:4] Hangup("SIP/91.64.147.180-00000005", "") in new stack
[2016-11-17 08:53:45] VERBOSE[4477][C-00000003] app_macro.c: Spawn extension (macro-hangupcall, s, 4) exited non-zero on 'SIP/91.64.147.180-00000005' in macro 'hangupcall'
[2016-11-17 08:53:45] VERBOSE[4477][C-00000003] pbx.c: Spawn extension (from-trunk, h, 1) exited non-zero on 'SIP/91.64.147.180-00000005'
[2016-11-17 08:53:50] VERBOSE[2603] chan_sip.c: Unregistered SIP '1001'
[2016-11-17 08:55:59] VERBOSE[2603][C-00000004] netsock2.c: Using SIP VIDEO TOS bits 136
[2016-11-17 08:55:59] VERBOSE[2603][C-00000004] netsock2.c: Using SIP VIDEO CoS mark 6
[2016-11-17 08:55:59] VERBOSE[2603][C-00000004] netsock2.c: Using SIP RTP TOS bits 184
[2016-11-17 08:55:59] VERBOSE[2603][C-00000004] netsock2.c: Using SIP RTP CoS mark 5
[2016-11-17 08:55:59] VERBOSE[4687][C-00000004] pbx.c: Executing [900441970868554@from-sip-external:1] NoOp("SIP/91.64.147.180-00000006", "Received incoming SIP connection from unknown peer to 900441970868554") in new stack
[2016-11-17 08:55:59] VERBOSE[4687][C-00000004] pbx.c: Executing [900441970868554@from-sip-external:2] Set("SIP/91.64.147.180-00000006", "DID=900441970868554") in new stack
[2016-11-17 08:55:59] VERBOSE[4687][C-00000004] pbx.c: Executing [900441970868554@from-sip-external:3] Goto("SIP/91.64.147.180-00000006", "s,1") in new stack
[2016-11-17 08:55:59] VERBOSE[4687][C-00000004] pbx_builtins.c: Goto (from-sip-external,s,1)
[2016-11-17 08:55:59] VERBOSE[4687][C-00000004] pbx.c: Executing [s@from-sip-external:1] GotoIf("SIP/91.64.147.180-00000006", "1?checklang:noanonymous") in new stack
[2016-11-17 08:55:59] VERBOSE[4687][C-00000004] pbx_builtins.c: Goto (from-sip-external,s,2)
[2016-11-17 08:55:59] VERBOSE[4687][C-00000004] pbx.c: Executing [s@from-sip-external:2] GotoIf("SIP/91.64.147.180-00000006", "1?setlanguage:from-trunk,900441970868554,1") in new stack
[2016-11-17 08:55:59] VERBOSE[4687][C-00000004] pbx_builtins.c: Goto (from-sip-external,s,3)
[2016-11-17 08:55:59] VERBOSE[4687][C-00000004] pbx.c: Executing [s@from-sip-external:3] Set("SIP/91.64.147.180-00000006", "CHANNEL(language)=de") in new stack
[2016-11-17 08:55:59] VERBOSE[4687][C-00000004] pbx.c: Executing [s@from-sip-external:4] Goto("SIP/91.64.147.180-00000006", "from-trunk,900441970868554,1") in new stack
[2016-11-17 08:55:59] VERBOSE[4687][C-00000004] pbx_builtins.c: Goto (from-trunk,900441970868554,1)
[2016-11-17 08:55:59] VERBOSE[4687][C-00000004] pbx.c: Executing [900441970868554@from-trunk:1] Set("SIP/91.64.147.180-00000006", "__FROM_DID=900441970868554") in new stack
[2016-11-17 08:55:59] VERBOSE[4687][C-00000004] pbx.c: Executing [900441970868554@from-trunk:2] NoOp("SIP/91.64.147.180-00000006", "Received an unknown call with DID set to 900441970868554") in new stack
[2016-11-17 08:55:59] VERBOSE[4687][C-00000004] pbx.c: Executing [900441970868554@from-trunk:3] Goto("SIP/91.64.147.180-00000006", "s,a2") in new stack
[2016-11-17 08:55:59] VERBOSE[4687][C-00000004] pbx_builtins.c: Goto (from-trunk,s,2)
[2016-11-17 08:55:59] VERBOSE[4687][C-00000004] pbx.c: Executing [s@from-trunk:2] Answer("SIP/91.64.147.180-00000006", "") in new stack
[2016-11-17 08:56:00] VERBOSE[4687][C-00000004] pbx.c: Executing [s@from-trunk:3] Log("SIP/91.64.147.180-00000006", "WARNING,Friendly Scanner from 209.222.99.210") in new stack
[2016-11-17 08:56:00] WARNING[4687][C-00000004] Ext. s: Friendly Scanner from 209.222.99.210
[2016-11-17 08:56:00] VERBOSE[4687][C-00000004] pbx.c: Executing [s@from-trunk:4] Wait("SIP/91.64.147.180-00000006", "2") in new stack
[2016-11-17 08:56:02] VERBOSE[4687][C-00000004] pbx.c: Executing [s@from-trunk:5] Playback("SIP/91.64.147.180-00000006", "ss-noservice") in new stack
[2016-11-17 08:56:02] VERBOSE[4687][C-00000004] file.c: <SIP/91.64.147.180-00000006> Playing 'ss-noservice.slin16' (language 'de')
[2016-11-17 08:56:08] VERBOSE[4687][C-00000004] pbx.c: Executing [s@from-trunk:6] SayAlpha("SIP/91.64.147.180-00000006", "900441970868554") in new stack
[2016-11-17 08:56:08] VERBOSE[4687][C-00000004] file.c: <SIP/91.64.147.180-00000006> Playing 'digits/9.slin16' (language 'de')
[2016-11-17 08:56:09] VERBOSE[4687][C-00000004] file.c: <SIP/91.64.147.180-00000006> Playing 'digits/0.slin16' (language 'de')
[2016-11-17 08:56:10] VERBOSE[4687][C-00000004] file.c: <SIP/91.64.147.180-00000006> Playing 'digits/4.slin16' (language 'de')
[2016-11-17 08:56:11] VERBOSE[4687][C-00000004] file.c: <SIP/91.64.147.180-00000006> Playing 'digits/4.slin16' (language 'de')
[2016-11-17 08:56:12] VERBOSE[4687][C-00000004] file.c: <SIP/91.64.147.180-00000006> Playing 'digits/1.slin16' (language 'de')
[2016-11-17 08:56:13] VERBOSE[4687][C-00000004] file.c: <SIP/91.64.147.180-00000006> Playing 'digits/9.slin16' (language 'de')
[2016-11-17 08:56:14] VERBOSE[4687][C-00000004] file.c: <SIP/91.64.147.180-00000006> Playing 'digits/7.slin16' (language 'de')
[2016-11-17 08:56:14] VERBOSE[4687][C-00000004] file.c: <SIP/91.64.147.180-00000006> Playing 'digits/0.slin16' (language 'de')
[2016-11-17 08:56:15] VERBOSE[4687][C-00000004] file.c: <SIP/91.64.147.180-00000006> Playing 'digits/8.slin16' (language 'de')
[2016-11-17 08:56:16] VERBOSE[4687][C-00000004] file.c: <SIP/91.64.147.180-00000006> Playing 'digits/6.slin16' (language 'de')
[2016-11-17 08:56:17] VERBOSE[4687][C-00000004] file.c: <SIP/91.64.147.180-00000006> Playing 'digits/8.slin16' (language 'de')
[2016-11-17 08:56:18] VERBOSE[4687][C-00000004] file.c: <SIP/91.64.147.180-00000006> Playing 'digits/5.slin16' (language 'de')
[2016-11-17 08:56:19] VERBOSE[4687][C-00000004] file.c: <SIP/91.64.147.180-00000006> Playing 'digits/5.slin16' (language 'de')
[2016-11-17 08:56:19] VERBOSE[4687][C-00000004] file.c: <SIP/91.64.147.180-00000006> Playing 'digits/4.slin16' (language 'de')
[2016-11-17 08:56:20] VERBOSE[4687][C-00000004] pbx.c: Executing [s@from-trunk:7] Hangup("SIP/91.64.147.180-00000006", "") in new stack
[2016-11-17 08:56:20] VERBOSE[4687][C-00000004] pbx.c: Spawn extension (from-trunk, s, 7) exited non-zero on 'SIP/91.64.147.180-00000006'
[2016-11-17 08:56:20] VERBOSE[4687][C-00000004] pbx.c: Executing [h@from-trunk:1] Macro("SIP/91.64.147.180-00000006", "hangupcall,") in new stack
[2016-11-17 08:56:20] VERBOSE[4687][C-00000004] pbx.c: Executing [s@macro-hangupcall:1] GotoIf("SIP/91.64.147.180-00000006", "1?theend") in new stack
[2016-11-17 08:56:20] VERBOSE[4687][C-00000004] pbx_builtins.c: Goto (macro-hangupcall,s,3)
[2016-11-17 08:56:20] VERBOSE[4687][C-00000004] pbx.c: Executing [s@macro-hangupcall:3] ExecIf("SIP/91.64.147.180-00000006", "0?Set(CDR(recordingfile)=)") in new stack
[2016-11-17 08:56:20] VERBOSE[4687][C-00000004] pbx.c: Executing [s@macro-hangupcall:4] Hangup("SIP/91.64.147.180-00000006", "") in new stack
[2016-11-17 08:56:20] VERBOSE[4687][C-00000004] app_macro.c: Spawn extension (macro-hangupcall, s, 4) exited non-zero on 'SIP/91.64.147.180-00000006' in macro 'hangupcall'
[2016-11-17 08:56:20] VERBOSE[4687][C-00000004] pbx.c: Spawn extension (from-trunk, h, 1) exited non-zero on 'SIP/91.64.147.180-00000006'
[2016-11-17 08:56:31] WARNING[2603] chan_sip.c: Retransmission timeout reached on transmission b6d6b17f20a1ceb68952e2f7a9c0567b for seqno 1 (Critical Response) -- See https://wiki.asterisk.org/wiki/display/AST/SIP+Retransmissions
Packet timed out after 32000ms with no response
[2016-11-17 08:56:38] VERBOSE[2517] asterisk.c: Remote UNIX connection
[2016-11-17 08:56:38] VERBOSE[5521] asterisk.c: Remote UNIX connection disconnected
[2016-11-17 08:56:38] VERBOSE[5523] asterisk.c: Remote UNIX connection disconnected
[2016-11-17 08:58:18] VERBOSE[4341] asterisk.c: Remote UNIX connection disconnected
