auf der Weboberfläche meines SN2400 werden keine ISDN- bzw. FXS-Interfaces angezeigt.
Meine Context CS Switch sieht wie folgt aus:
Hat jemand von euch eine Idee warum mit diese Interfaces nicht angezeigt werden?
Danke im Voraus, lg Dani
context cs switch
national-prefix 0
international-prefix 00
routing-table called-e164 Fax
route 9011 dest-interface fxs_4_3
route 11 dest-interface fxs_4_3
route default dest-interface SIP_GW
routing-table called-e164 RT_CDPN_ISDN_2_SIP
route .T dest-table Fax
routing-table calling-e164 RT_CDPN_SIP_2_ISDN
route .T dest-service HUNT-PUBLIC-PSTN CF_TO_PSTN
mapping-table calling-e164 to calling-e164 MT_ADD_KOPFNR
map (.%) to 72363351\1
mapping-table calling-type-of-number to calling-type-of-number MT_TON_PSTN
map default to national
complex-function CF_TO_PSTN
execute 1 MT_ADD_KOPFNR
execute 2 MT_TON_PSTN
interface isdn ISDN_1_0
route call dest-table RT_CDPN_ISDN_2_SIP
dtmf-dialing
interface isdn ISDN_1_1
dtmf-dialing
interface isdn ISDN_1_2
interface isdn ISDN_1_3
interface sip SIP_GW
bind gateway Asterisk
service default
route call dest-table RT_CDPN_SIP_2_ISDN
early-connect
early-disconnect
interface fxs fxs_4_0
route call dest-service HUNT-PUBLIC-PSTN
interface fxs fxs_4_1
interface fxs fxs_4_2
interface fxs fxs_4_3
service hunt-group HUNT-PUBLIC-PSTN
drop-cause normal-unspecified
drop-cause no-circuit-channel-available
drop-cause network-out-of-order
drop-cause temporary-failure
drop-cause switching-equipment-congestion
drop-cause access-info-discarded
drop-cause circuit-channel-not-available
drop-cause resources-unavailable
route call 1 dest-interface ISDN_1_0
route call 2 dest-interface ISDN_1_1
route call 3 dest-interface ISDN_1_2
route call 4 dest-interface ISDN_1_3
context cs switch
no shutdown
