;! Automatically generated configuration file
;! Filename: extensions.conf (/var/packages/Asterisk/target/etc/asterisk/extensions.conf)
;! Generator: Manager
;! Creation Date: Mon Sep 12 09:49:01 2016
; extensions.conf - the Asterisk dial plan
; Static extension configuration file, used by
; the pbx_config module. This is where you configure all your
; inbound and outbound calls in Asterisk.
; This configuration file is reloaded
; - With the "dialplan reload" command in the CLI
; - With the "reload" command (that reloads everything) in the CLI
; The "General" category is for certain variables.
[general]
; If static is set to no, or omitted, then the pbx_config will rewrite
; this file when extensions are modified. Remember that all comments
; made in the file will be lost when that happens.
; XXX Not yet implemented XXX
static = yes
; if static=yes and writeprotect=no, you can save dialplan by
; CLI command "dialplan save" too
writeprotect = no
; If autofallthrough is set, then if an extension runs out of
; things to do, it will terminate the call with BUSY, CONGESTION
; or HANGUP depending on Asterisk's best guess. This is the default.
; If autofallthrough is not set, then if an extension runs out of
; things to do, Asterisk will wait for a new extension to be dialed
; (this is the original behavior of Asterisk 1.0 and earlier).
;autofallthrough=no
; If extenpatternmatchnew is set (true, yes, etc), then a new algorithm that uses
; a Trie to find the best matching pattern is used. In dialplans
; with more than about 20-40 extensions in a single context, this
; new algorithm can provide a noticeable speedup.
; With 50 extensions, the speedup is 1.32x
; with 88 extensions, the speedup is 2.23x
; with 138 extensions, the speedup is 3.44x
; with 238 extensions, the speedup is 5.8x
; with 438 extensions, the speedup is 10.4x
; With 1000 extensions, the speedup is ~25x
; with 10,000 extensions, the speedup is 374x
; Basically, the new algorithm provides a flat response
; time, no matter the number of extensions.
; By default, the old pattern matcher is used.
; ****This is a new feature! *********************
; The new pattern matcher is for the brave, the bold, and
; the desperate. If you have large dialplans (more than about 50 extensions
; in a context), and/or high call volume, you might consider setting
; this value to "yes" !!
; Please, if you try this out, and are forced to return to the
; old pattern matcher, please report your reasons in a bug report
; on https://issues.asterisk.org. We have made good progress in providing
; something compatible with the old matcher; help us finish the job!
; This value can be switched at runtime using the cli command "dialplan set extenpatternmatchnew true"
; or "dialplan set extenpatternmatchnew false", so you can experiment to your hearts content.
;extenpatternmatchnew=no
; If clearglobalvars is set, global variables will be cleared
; and reparsed on a dialplan reload, or Asterisk reload.
; If clearglobalvars is not set, then global variables will persist
; through reloads, and even if deleted from the extensions.conf or
; one of its included files, will remain set to the previous value.
; NOTE: A complication sets in, if you put your global variables into
; the AEL file, instead of the extensions.conf file. With clearglobalvars
; set, a "reload" will often leave the globals vars cleared, because it
; is not unusual to have extensions.conf (which will have no globals)
; load after the extensions.ael file (where the global vars are stored).
; So, with "reload" in this particular situation, first the AEL file will
; clear and then set all the global vars, then, later, when the extensions.conf
; file is loaded, the global vars are all cleared, and then not set, because
; they are not stored in the extensions.conf file.
clearglobalvars = no
; User context is where entries from users.conf are registered. The
; default value is 'default'
;userscontext=default
; You can include other config files, use the #include command
; (without the ';'). Note that this is different from the "include" command
; that includes contexts within other contexts. The #include command works
; in all asterisk configuration files.
;#include "filename.conf"
;#include <filename.conf>
;#include filename.conf
; You can execute a program or script that produces config files, and they
; will be inserted where you insert the #exec command. The #exec command
; works on all asterisk configuration files. However, you will need to
; activate them within asterisk.conf with the "execincludes" option. They
; are otherwise considered a security risk.
;#exec /opt/bin/build-extra-contexts.sh
;#exec /opt/bin/build-extra-contexts.sh --foo="bar"
;#exec </opt/bin/build-extra-contexts.sh --foo="bar">
;#exec "/opt/bin/build-extra-contexts.sh --foo=\"bar\""
; The "Globals" category contains global variables that can be referenced
; in the dialplan with the GLOBAL dialplan function:
; ${GLOBAL(VARIABLE)}
; ${${GLOBAL(VARIABLE)}} or ${text${GLOBAL(VARIABLE)}} or any hybrid
; Unix/Linux environmental variables can be reached with the ENV dialplan
; function: ${ENV(VARIABLE)}
[globals]
CONSOLE = Console/dsp
IAXINFO = guest
TRUNK = DAHDI/G2
TRUNKMSD = 1
FEATURES =
DIALOPTIONS =
RINGTIME = 20
FOLLOWMEOPTIONS =
PAGING_HEADER = Intercom
620 = SIP/620
CID_620 = 620
trunk_1 = SIP/trunk_1
CID_trunk_1 = 621
trunk_3 = SIP/trunk_3
CID_trunk_3 = 623
trunk_4 = SIP/trunk_4
CID_trunk_4 = 624
trunk_5 = SIP/trunk_5
CID_trunk_5 = 625
trunk_6 = SIP/trunk_6
CID_trunk_6 = 626
trunk_7 = SIP/trunk_7
CID_trunk_7 = 627
trunk_8 = SIP/trunk_8
trunk_2 = SIP/trunk_2
CID_trunk_2 = 622
trunk_9 = SIP/trunk_9
CID_trunk_9 = 620
trunk_10 = SIP/trunk_10
CID_trunk_10 = 621
trunk_11 = SIP/trunk_11
CID_trunk_11 = 622
trunk_12 = SIP/trunk_12
CID_trunk_12 = 623
CID_trunk_8 = 628
trunk_13 = SIP/trunk_13
CID_trunk_13 = 624
trunk_14 = SIP/trunk_14
CID_trunk_14 = 625
trunk_15 = SIP/trunk_15
CID_trunk_15 = 626
trunk_16 = SIP/trunk_16
CID_trunk_16 = 627
FOLLOWME_6017 = 0
trunk_17 = SIP/trunk_17
CID_trunk_17 = 629
;TRUNK=IAX2/user:pass@provider
;FREENUMDOMAIN=mydomain.com ; domain to send on outbound
; freenum calls (uses outbound-freenum
; context)
; WARNING WARNING WARNING WARNING
; If you load any other extension configuration engine, such as pbx_ael.so,
; your global variables may be overridden by that file. Please take care to
; use only one location to set global variables, and you will likely save
; yourself a ton of grief.
; Any category other than "General" and "Globals" represent
; extension contexts, which are collections of extensions.
; Extension names may be numbers, letters, or combinations
; thereof. If an extension name is prefixed by a '_'
; character, it is interpreted as a pattern rather than a
; literal. In patterns, some characters have special meanings:
; X - any digit from 0-9
; Z - any digit from 1-9
; N - any digit from 2-9
; [1235-9] - any digit in the brackets (in this example, 1,2,3,5,6,7,8,9)
; . - wildcard, matches anything remaining (e.g. _9011. matches
; anything starting with 9011 excluding 9011 itself)
; ! - wildcard, causes the matching process to complete as soon as
; it can unambiguously determine that no other matches are possible
; For example, the extension _NXXXXXX would match normal 7 digit dialings,
; while _1NXXNXXXXXX would represent an area code plus phone number
; preceded by a one.
; Each step of an extension is ordered by priority, which must always start
; with 1 to be considered a valid extension. The priority "next" or "n" means
; the previous priority plus one, regardless of whether the previous priority
; was associated with the current extension or not. The priority "same" or "s"
; means the same as the previously specified priority, again regardless of
; whether the previous entry was for the same extension. Priorities may be
; immediately followed by a plus sign and another integer to add that amount
; (most useful with 's' or 'n'). Priorities may then also have an alias, or
; label, in parentheses after their name which can be used in goto situations.
; Contexts contain several lines, one for each step of each extension. One may
; include another context in the current one as well, optionally with a date
; and time. Included contexts are included in the order they are listed.
; Switches may also be included within a context. The order of matching within
; a context is always exact extensions, pattern match extensions, includes, and
; switches. Includes are always processed depth-first. So for example, if you
; would like a switch "A" to match before context "B", simply put switch "A" in
; an included context "C", where "C" is included in your original context
; before "B".
;[context]
;exten => someexten,{priority|label{+|-}offset}[(alias)],application(arg1,arg2,...)
; Timing list for includes is
; <time range>,<days of week>,<days of month>,<months>[,<timezone>]
; Note that ranges may be specified to wrap around the ends. Also, minutes are
; fine-grained only down to the closest even minute.
;include => daytime,9:00-17:00,mon-fri,*,*
;include => weekend,*,sat-sun,*,*
;include => weeknights,17:02-8:58,mon-fri,*,*
; ignorepat can be used to instruct drivers to not cancel dialtone upon receipt
; of a particular pattern. The most commonly used example is of course '9'
; like this:
;ignorepat => 9
; so that dialtone remains even after dialing a 9. Please note that ignorepat
; only works with channels which receive dialtone from the PBX, such as DAHDI,
; Phone, and VPB. Other channels, such as SIP and MGCP, which generate their
; own dialtone and converse with the PBX only after a number is complete, are
; generally unaffected by ignorepat (unless DISA or another method is used to
; generate a dialtone after answering the channel).
; Sample entries for extensions.conf
[dundi-e164-canonical]
;include => stdexten
; List canonical entries here
;exten => 12564286000,1,Gosub(6000,stdexten(IAX2/foo))
;exten => 12564286000,n,Goto(default,s,1) ; exited Voicemail
;exten => _125642860XX,1,Dial(IAX2/otherbox/${EXTEN:7})
[dundi-e164-customers]
; If you are an ITSP or Reseller, list your customers here.
;exten => _12564286000,1,Dial(SIP/customer1)
;exten => _12564286001,1,Dial(IAX2/customer2)
[dundi-e164-via-pstn]
; If you are freely delivering calls to the PSTN, list them here
;exten => _1256428XXXX,1,Dial(DAHDI/G2/${EXTEN:7}) ; Expose all of 256-428
;exten => _1256325XXXX,1,Dial(DAHDI/G2/${EXTEN:7}) ; Ditto for 256-325
[dundi-e164-local]
; Context to put your dundi IAX2 or SIP user in for
; full access
include => dundi-e164-canonical
include => dundi-e164-customers
include => dundi-e164-via-pstn
[dundi-e164-switch]
; Just a wrapper for the switch
switch => DUNDi/e164
[dundi-e164-lookup]
; Locally to lookup, try looking for a local E.164 solution
; then try DUNDi if we don't have one.
include => dundi-e164-local
include => dundi-e164-switch
; DUNDi can also be implemented as a Macro instead of using
; the Local channel driver.
[macro-dundi-e164]
; ARG1 is the extension to Dial
; Extension "s" is not a wildcard extension that matches "anything".
; In macros, it is the start extension. In most other cases,
; you have to goto "s" to execute that extension.
; Note: In old versions of Asterisk the PBX in some cases defaulted to
; extension "s" when a given extension was wrong (like in AMI originate).
; This is no longer the case.
; For wildcard matches, see above - all pattern matches start with
; an underscore.
exten => s,1,Goto(${ARG1},1)
include => dundi-e164-lookup
; Here are the entries you need to participate in the IAXTEL
; call routing system. Most IAXTEL numbers begin with 1-700, but
; there are exceptions. For more information, and to sign
; up, please go to www.gnophone.com or www.iaxtel.com
[iaxtel700]
exten => _91700XXXXXXX,1,Dial(IAX2/${GLOBAL(IAXINFO)}@iaxtel.com/${EXTEN:1}@iaxtel)
; The SWITCH statement permits a server to share the dialplan with
; another server. Use with care: Reciprocal switch statements are not
; allowed (e.g. both A -> B and B -> A), and the switched server needs
; to be on-line or else dialing can be severly delayed.
[iaxprovider]
;switch => IAX2/user:[key]@myserver/mycontext
[trunkint]
; International long distance through trunk
exten => _9011.,1,Macro(dundi-e164,${EXTEN:4})
exten => _9011.,n,Dial(${GLOBAL(TRUNK)}/${FILTER(0-9,${EXTEN:${GLOBAL(TRUNKMSD)}})})
[trunkld]
; Long distance context accessed through trunk
exten => _91NXXNXXXXXX,1,Macro(dundi-e164,${EXTEN:1})
exten => _91NXXNXXXXXX,n,Dial(${GLOBAL(TRUNK)}/${EXTEN:${GLOBAL(TRUNKMSD)}})
[trunklocal]
; Local seven-digit dialing accessed through trunk interface
exten => _9NXXXXXX,1,Dial(${GLOBAL(TRUNK)}/${EXTEN:${GLOBAL(TRUNKMSD)}})
[trunktollfree]
; Long distance context accessed through trunk interface
exten => _91800NXXXXXX,1,Dial(${GLOBAL(TRUNK)}/${EXTEN:${GLOBAL(TRUNKMSD)}})
exten => _91888NXXXXXX,1,Dial(${GLOBAL(TRUNK)}/${EXTEN:${GLOBAL(TRUNKMSD)}})
exten => _91877NXXXXXX,1,Dial(${GLOBAL(TRUNK)}/${EXTEN:${GLOBAL(TRUNKMSD)}})
exten => _91866NXXXXXX,1,Dial(${GLOBAL(TRUNK)}/${EXTEN:${GLOBAL(TRUNKMSD)}})
[international]
; Master context for international long distance
ignorepat => 9
include => longdistance
include => trunkint
[longdistance]
; Master context for long distance
ignorepat => 9
include => local
include => trunkld
[local]
; Master context for local, toll-free, and iaxtel calls only
ignorepat => 9
include => default
include => trunklocal
include => iaxtel700
include => trunktollfree
include => iaxprovider
;Include parkedcalls (or the context you define in features conf)
;to enable call parking.
include => parkedcalls
; You can use an alternative switch type as well, to resolve
; extensions that are not known here, for example with remote
; IAX switching you transparently get access to the remote
; Asterisk PBX
; switch => IAX2/user:password@bigserver/local
; An "lswitch" is like a switch but is literal, in that
; variable substitution is not performed at load time
; but is passed to the switch directly (presumably to
; be substituted in the switch routine itself)
; lswitch => Loopback/12${EXTEN}@othercontext
; An "eswitch" is like a switch but the evaluation of
; variable substitution is performed at runtime before
; being passed to the switch routine.
; eswitch => IAX2/context@${CURSERVER}
; The following two contexts are a template to enable the ability to dial
; ISN numbers. For more information about what an ISN number is, please see
; http://www.freenum.org.
; This is the dialing hook. use:
; include => outbound-freenum
[outbound-freenum]
; We'll add more digits as needed. The purpose is to dial things
; like extension numbers at domains (ITAD number) so we're matching
; on lengths of 1 through 6 prior to the separator (the asterisk
exten => _X*X!,1,Goto(outbound-freenum2,${EXTEN},1)
exten => _XX*X!,1,Goto(outbound-freenum2,${EXTEN},1)
exten => _XXX*X!,1,Goto(outbound-freenum2,${EXTEN},1)
exten => _XXXX*X!,1,Goto(outbound-freenum2,${EXTEN},1)
exten => _XXXXX*X!,1,Goto(outbound-freenum2,${EXTEN},1)
exten => _XXXXXX*X!,1,Goto(outbound-freenum2,${EXTEN},1)
[outbound-freenum2]
; This is the handler which performs the dialing logic. It is called
; from the [outbound-freenum] context
exten => _X!,1,Verbose(2,Performing ISN lookup for ${EXTEN})
same => n,Set(SUFFIX=${CUT(EXTEN,*,2-)}) ; make sure the suffix is all digits as well
same => n,GotoIf($["${FILTER(0-9,${SUFFIX})}" != "${SUFFIX}"]?fn-CONGESTION,1)
; filter out bad characters per the README-SERIOUSLY.best-practices.txt document
same => n,Set(TIMEOUT(absolute)=10800)
same => n,Set(isnresult=${ENUMLOOKUP(${EXTEN},sip,,1,freenum.org)}) ; perform our lookup with freenum.org
same => n,GotoIf($["${isnresult}" != ""]?from)
same => n,Set(DIALSTATUS=CONGESTION)
same => n,Goto(fn-CONGESTION,1)
same => n(from),Set(__SIPFROMUSER=${CALLERID(num)})
same => n,GotoIf($["${GLOBAL(FREENUMDOMAIN)}" = ""]?dial) ; check if we set the FREENUMDOMAIN global variable in [global]
same => n,Set(__SIPFROMDOMAIN=${GLOBAL(FREENUMDOMAIN)}) ; if we did set it, then we'll use it for our outbound dialing domain
same => n(dial),Dial(SIP/${isnresult},40)
same => n,Goto(fn-${DIALSTATUS},1)
exten => fn-BUSY,1,Busy()
exten => _f[n]-.,1,NoOp(ISN: ${DIALSTATUS})
same => n,Congestion()
[macro-trunkdial]
; Standard trunk dial macro (hangs up on a dialstatus that should
; terminate call)
; ${ARG1} - What to dial
exten => s,1,Dial(${ARG1})
exten => s,n,Goto(s-${DIALSTATUS},1)
exten => s-NOANSWER,1,Hangup
exten => s-BUSY,1,Hangup
exten => _s-.,1,NoOp
[stdexten]
; Standard extension subroutine:
; ${EXTEN} - Extension
; ${ARG1} - Device(s) to ring
; ${ARG2} - Optional context in Voicemail
; Note that the current version will drop through to the next priority in the
; case of their pressing '#'. This gives more flexibility in what do to next:
; you can prompt for a new extension, or drop the call, or send them to a
; general delivery mailbox, or...
; The use of the LOCAL() function is purely for convenience. Any variable
; initially declared as LOCAL() will disappear when the innermost Gosub context
; in which it was declared returns. Note also that you can declare a LOCAL()
; variable on top of an existing variable, and its value will revert to its
; previous value (before being declared as LOCAL()) upon Return.
exten => _X.,50000(stdexten),NoOp(Start stdexten)
exten => _X.,n,Set(LOCAL(ext)=${EXTEN})
exten => _X.,n,Set(LOCAL(dev)=${ARG1})
exten => _X.,n,Set(LOCAL(cntx)=${ARG2})
exten => _X.,n,Set(LOCAL(mbx)=${ext}${IF($[!${ISNULL(${cntx})}]?@${cntx})})
exten => _X.,n,Dial(${dev},20) ; Ring the interface, 20 seconds maximum
exten => _X.,n,Goto(stdexten-${DIALSTATUS},1) ; Jump based on status (NOANSWER,BUSY,CHANUNAVAIL,CONGESTION,ANSWER)
exten => stdexten-NOANSWER,1,Voicemail(${mbx},u) ; If unavailable, send to voicemail w/ unavail announce
exten => stdexten-NOANSWER,n,Return() ; If they press #, return to start
exten => stdexten-BUSY,1,Voicemail(${mbx},b) ; If busy, send to voicemail w/ busy announce
exten => stdexten-BUSY,n,Return() ; If they press #, return to start
exten => _stde[x]te[n]-.,1,Goto(stdexten-NOANSWER,1) ; Treat anything else as no answer
exten => a,1,VoicemailMain(${mbx}) ; If they press *, send the user into VoicemailMain
exten => a,n,Return()
[stdPrivacyexten]
; ${ARG1} - Extension
; ${ARG2} - Device(s) to ring
; ${ARG3} - Optional DONTCALL context name to jump to (assumes the s,1 extension-priority)
; ${ARG4} - Optional TORTURE context name to jump to (assumes the s,1 extension-priority)`
; ${ARG5} - Context in voicemail (if empty, then "default")
; See above note in stdexten about priority handling on exit.
exten => _X.,60000(stdPrivacyexten),NoOp(Start stdPrivacyexten)
exten => _X.,n,Set(LOCAL(ext)=${ARG1})
exten => _X.,n,Set(LOCAL(dev)=${ARG2})
exten => _X.,n,Set(LOCAL(dontcntx)=${ARG3})
exten => _X.,n,Set(LOCAL(tortcntx)=${ARG4})
exten => _X.,n,Set(LOCAL(cntx)=${ARG5})
exten => _X.,n,Set(LOCAL(mbx)="${ext}"$["${cntx}" ? "@${cntx}" :: ""])
exten => _X.,n,Dial(${dev},20,p) ; Ring the interface, 20 seconds maximum, call screening
; option (or use P for databased call _X.creening)
exten => stdexten-NOANSWER,n,NoOp(Finish stdPrivacyexten NOANSWER)
exten => stdexten-BUSY,n,NoOp(Finish stdPrivacyexten BUSY)
exten => stdexten-DONTCALL,1,Goto(${dontcntx},s,1) ; Callee chose to send this call to a polite "Don't call again" script.
exten => stdexten-TORTURE,1,Goto(${tortcntx},s,1) ; Callee chose to send this call to a telemarketer torture script.
exten => a,n,Return
[macro-page];
; Paging macro:
; Check to see if SIP device is in use and DO NOT PAGE if they are
; ${ARG1} - Device to page
exten => s,1,ChanIsAvail(${ARG1},s) ; s is for ANY call
exten => s,n,GoToIf($[${AVAILSTATUS} = "1"]?autoanswer:fail)
exten => s,n(autoanswer),Set(_ALERT_INFO="RA") ; This is for the PolyComs
exten => s,n,SIPAddHeader(Call-Info: Answer-After=0) ; This is for the Grandstream, Snoms, and Others
exten => s,n,NoOp() ; Add others here and Post on the Wiki!!!!
exten => s,n,Dial(${ARG1})
exten => s,n(fail),Hangup
[demo]
include => stdexten
; We start with what to do when a call first comes in.
exten => s,1,Wait(1) ; Wait a second, just for fun
exten => s,n,Answer ; Answer the line
exten => s,n,Set(TIMEOUT(digit)=5) ; Set Digit Timeout to 5 seconds
exten => s,n,Set(TIMEOUT(response)=10) ; Set Response Timeout to 10 seconds
exten => s,n(restart),BackGround(demo-congrats) ; Play a congratulatory message
exten => s,n(instruct),BackGround(demo-instruct) ; Play some instructions
exten => s,n,WaitExten ; Wait for an extension to be dialed.
exten => 2,1,BackGround(demo-moreinfo) ; Give some more information.
exten => 2,n,Goto(s,instruct)
exten => 3,1,Set(CHANNEL(language)=fr) ; Set language to french
exten => 3,n,Goto(s,restart) ; Start with the congratulations
exten => 1000,1,Goto(default,s,1)
; We also create an example user, 1234, who is on the console and has
; voicemail, etc.
exten => 1234,1,Playback(transfer,skip) ; "Please hold while..."
; (but skip if channel is not up)
exten => 1234,n,Gosub(${EXTEN},stdexten(${GLOBAL(CONSOLE)}))
exten => 1234,n,Goto(default,s,1) ; exited Voicemail
exten => 1235,1,Voicemail(1234,u) ; Right to voicemail
exten => 1236,1,Dial(Console/dsp) ; Ring forever
exten => 1236,n,Voicemail(1234,b) ; Unless busy
; # for when they're done with the demo
exten => #,1,Playback(demo-thanks) ; "Thanks for trying the demo"
exten => #,n,Hangup ; Hang them up.
; A timeout and "invalid extension rule"
exten => t,1,Goto(#,1) ; If they take too long, give up
exten => i,1,Playback(invalid) ; "That's not valid, try again"
; Create an extension, 500, for dialing the
; Asterisk demo.
exten => 500,1,Playback(demo-abouttotry) ; Let them know what's going on
exten => 500,n,Dial(IAX2/[email protected]/s@default) ; Call the Asterisk demo
exten => 500,n,Playback(demo-nogo) ; Couldn't connect to the demo site
exten => 500,n,Goto(s,6) ; Return to the start over message.
; Create an extension, 600, for evaluating echo latency.
exten => 600,1,Playback(demo-echotest) ; Let them know what's going on
exten => 600,n,Echo ; Do the echo test
exten => 600,n,Playback(demo-echodone) ; Let them know it's over
exten => 600,n,Goto(s,6) ; Start over
; You can use the Macro Page to intercom a individual user
exten => 76245,1,Macro(page,SIP/Grandstream1)
; or if your peernames are the same as extensions
exten => _7XXX,1,Macro(page,SIP/${EXTEN})
; System Wide Page at extension 7999
exten => 7999,1,Set(TIMEOUT(absolute)=60)
exten => 7999,2,Page(Local/Grandstream1@page&Local/Xlite1@page&Local/1234@page/n,d)
; Give voicemail at extension 8500
exten => 8500,1,VoicemailMain
exten => 8500,n,Goto(s,6)
; Here's what a phone entry would look like (IXJ for example)
;exten => 1265,1,Dial(Phone/phone0,15)
;exten => 1265,n,Goto(s,5)
; The page context calls up the page macro that sets variables needed for auto-answer
; It is in is own context to make calling it from the Page() application as simple as
; Local/{peername}@page
[page]
exten => _X.,1,Macro(page,SIP/${EXTEN})
;[mainmenu]
; Example "main menu" context with submenu
;exten => s,1,Answer
;exten => s,n,Background(thanks) ; "Thanks for calling press 1 for sales, 2 for support, ..."
;exten => s,n,WaitExten
;exten => 1,1,Goto(submenu,s,1)
;exten => 2,1,Hangup
;include => default
;[submenu]
;exten => s,1,Ringing ; Make them comfortable with 2 seconds of ringback
;exten => s,n,Wait,2
;exten => s,n,Background(submenuopts) ; "Thanks for calling the sales department. Press 1 for steve, 2 for..."
;exten => 1,1,Goto(default,steve,1)
;exten => 2,1,Goto(default,mark,2)
[public]
; ATTENTION: If your Asterisk is connected to the internet and you do
; not have allowguest=no in sip.conf, everybody out there may use your
; public context without authentication. In that case you want to
; double check which services you offer to the world.
include => demo
[default]
exten = 6000,1,Dial(SIP/6000)
exten = 6000,hint,SIP/6000,CustomPresence:6000
exten = 6001,1,Dial(SIP/6001)
exten = 6001,hint,SIP/6001,CustomPresence:6001
exten = 6002,1,Dial(SIP/6002)
exten = 6002,hint,SIP/6002,CustomPresence:6002
exten = 6003,1,Dial(SIP/6003)
exten = 6003,hint,SIP/6003,CustomPresence:6003
exten = 6004,1,Dial(SIP/6004)
exten = 6004,hint,SIP/6004,CustomPresence:6004
exten = 6005,1,Dial(SIP/6005)
exten = 6005,hint,SIP/6005,CustomPresence:6005
exten = 6006,1,Dial(SIP/6006)
exten = 6006,hint,SIP/6006,CustomPresence:6006
exten = 6007,1,Dial(SIP/6007)
exten = 6007,hint,SIP/6007,CustomPresence:6007
exten = 6008,1,Dial(SIP/6008)
exten = 6008,hint,SIP/6008,CustomPresence:6008
exten = 6009,1,Dial(SIP/6009)
exten = 6009,hint,SIP/6009,CustomPresence:6009
exten = 6010,1,Dial(SIP/6010)
exten = 6010,hint,SIP/6010,CustomPresence:6010
exten = 6011,1,Dial(SIP/6011)
exten = 6011,hint,SIP/6011,CustomPresence:6011
exten = 6012,1,Dial(SIP/6012)
exten = 6012,hint,SIP/6012,CustomPresence:6012
exten = 6013,1,Dial(SIP/6013)
exten = 6013,hint,SIP/6013,CustomPresence:6013
exten = 6014,1,Dial(SIP/6014)
exten = 6014,hint,SIP/6014,CustomPresence:6014
exten = _#6XXX,1,Set(MBOX=${EXTEN:1}@default)
exten = _#6XXX,n,VoiceMail(${MBOX})
exten = a,1,VoicemailMain(${MBOX})
exten = 99,1,VoiceMailMain(${CALLERID(num)}@default)
;include = demo \; This line was commented by ASTERISK GUI
; An extension like the one below can be used for FWD, Nikotel, sipgate etc.
; Note that you must have a [sipprovider] section in sip.conf
;exten => _41X.,1,Dial(SIP/${FILTER(0-9,${EXTEN:2})}@sipprovider,,r)
; Real extensions would go here. Generally you want real extensions to be
; 4 or 5 digits long (although there is no such requirement) and start with a
; single digit that is fairly large (like 6 or 7) so that you have plenty of
; room to overlap extensions and menu options without conflict. You can alias
; them with names, too, and use global variables
;exten => 6245,hint,SIP/Grandstream1&SIP/Xlite1(Joe Schmoe) ; Channel hints for presence
;exten => 6245,1,Dial(SIP/Grandstream1,20,rt) ; permit transfer
;exten => 6245,n(dial),Dial(${HINT},20,rtT) ; Use hint as listed
;exten => 6245,n,Voicemail(6245,u) ; Voicemail (unavailable)
;exten => 6245,s+1,Hangup ; s+1, same as n
;exten => 6245,dial+101,Voicemail(6245,b) ; Voicemail (busy)
;exten => 6361,1,Dial(IAX2/JaneDoe,,rm) ; ring without time limit
;exten => 6389,1,Dial(MGCP/aaln/[email protected])
;exten => 6390,1,Dial(JINGLE/caller/callee) ; Dial via jingle using labels
;exten => 6391,1,Dial(JINGLE/[email protected]/[email protected]) ;Dial via jingle using asterisk as the transport and calling mogorman.
;exten => 6394,1,Dial(Local/6275/n) ; this will dial ${MARK}
;exten => 6275,1,Gosub(${EXTEN},stdexten(${MARK}))
; assuming ${MARK} is something like DAHDI/2
;exten => 6275,n,Goto(default,s,1) ; exited Voicemail
;exten => mark,1,Goto(6275,1) ; alias mark to 6275
;exten => 6536,1,Gosub(${EXTEN},stdexten(${WIL}))
; Ditto for wil
;exten => 6536,n,Goto(default,s,1) ; exited Voicemail
;exten => wil,1,Goto(6236,1)
;If you want to subscribe to the status of a parking space, this is
;how you do it. Subscribe to extension 6600 in sip, and you will see
;the status of the first parking lot with this extensions' help
;exten => 6600,hint,park:701@parkedcalls
;exten => 6600,1,noop
;To subscribe to the availability of a free member in the 'markq' queue.
;Note: '_avail' is added to the QueueName
;exten => 8501,hint,Queue:markq_avail
;exten => 8501,1,Queue(markq)
; You can also monitor the status of a queue by providing a hint for a
; particular queue name.
;exten => 8502,hint,Queue:markq
;exten => 8502,1,Queue(markq)
; Some other handy things are an extension for checking voicemail via
; voicemailmain
;exten => 8500,1,VoicemailMain
;exten => 8500,n,Hangup
; Or a conference room (you'll need to edit meetme.conf to enable this room)
;exten => 8600,1,Meetme(1234)
; Or playing an announcement to the called party, as soon it answers
;exten = 8700,1,Dial(${MARK},30,A(/path/to/my/announcemsg))
; example of a compartmentalized company called "acme"
; this is the context that your incoming IAX/SIP trunk dumps you in...
;[acme-incoming]
;exten => s,1,Wait(1)
;exten => s,n,Answer()
;exten => s,n(menu),Playback(acme/vm-brief-menu)
;exten => s,n(exten),Background(vm-enter-num-to-call)
;exten => s,n,WaitExten(5)
;exten => s,n(goodbye),Playback(vm-goodbye)
;exten => s,n(end),Hangup()
;include => acme-extens
;exten => i,1,Playback(vm-invalid)
;exten => i,n,Goto(s,exten) ; optionally, transfer to operator
;exten => t,1,Goto(s,goodbye)
; this is the context our internal SIP hardphones use (see sip.conf)
;[acme-internal]
;exten => s,1,Answer()
;include => trunkint
;include => trunkld
;include => trunklocal
; you can test what your system sounds like to outside callers by dialing this
;exten => 777,1,DISA(no-password,acme-incoming)
; grouping of acme's extensions... never used directly, always included.
;[acme-extens]
;exten => 111,1,Gosub(111,stdexten(SIP/pete_1,acme))
;exten => 111,n,Goto(s,exten)
;exten => 112,1,Gosub(112,stdexten(SIP/nancy_1,acme))
;exten => 112,n,Goto(s,end)
; end of acme example
; Time context: you can patch this in via the following.
; [acme-internal]
; exten => 777,1,Gosub(time)
; exten => 777,n,Hangup()
; include => time
; Note: if you're geographically spread out, you can have SIP extensions
; specify their own local timezone in sip.conf as:
; [boi]
; type=friend
; context=acme-internal
; callerid="Boise Ofc. <2083451111>"
; ; use system-wide default timezone of MST7MDT
; [lws]
; type=friend
; callerid="Lewiston Ofc. <2087431111>"
; setvar=timezone=PST8PDT
; "timezone" isn't a 'reserved' name in any way, and other places where
; the timezone is significant (e.g. calls to "SayUnixTime()", etc) will
; require modification as well. Note that voicemail.conf already has
; a mechanism for timezones.
[time]
exten => _X.,30000(time),NoOp(Time: ${EXTEN} ${timezone})
exten => _X.,n,Wait(0.25)
exten => _X.,n,Answer()
; the amount of delay is set for English; you may need to adjust this time
; for other languages if there's no pause before the synchronizing beep.
exten => _X.,n,Set(FUTURETIME=$[${EPOCH} + 12])
exten => _X.,n,SayUnixTime(${FUTURETIME},Zulu,HNS)
exten => _X.,n,SayPhonetic(z)
; use the timezone associated with the extension (sip only), or system-wide
; default if one hasn't been set.
exten => _X.,n,SayUnixTime(${FUTURETIME},${timezone},HNS)
exten => _X.,n,Playback(spy-local)
exten => _X.,n,WaitUntil(${FUTURETIME})
exten => _X.,n,Playback(beep)
exten => _X.,n,Return()
; ANI context: use in the same way as "time" above
[ani]
exten => _X.,40000(ani),NoOp(ANI: ${EXTEN})
exten => _X.,n,Playback(vm-from)
exten => _X.,n,SayDigits(${CALLERID(ani)})
exten => _X.,n,Wait(1.25)
exten => _X.,n,SayDigits(${CALLERID(ani)}) ; playback again in case of missed digit
; For more information on applications, just type "core show applications" at your
; friendly Asterisk CLI prompt.
; "core show application <command>" will show details of how you
; use that particular application in this file, the dial plan.
; "core show functions" will list all dialplan functions
; "core show function <COMMAND>" will show you more information about
; one function. Remember that function names are UPPER CASE.
[macro-stdexten]
exten = s,1,Set(__DYNAMIC_FEATURES=${FEATURES})
exten = s,2,Set(ORIG_ARG1=${ARG1})
exten = s,3,GotoIf($["${FOLLOWME_${ARG1}}" = "1"]?6:4)
exten = s,4,Dial(${ARG2},${RINGTIME},${DIALOPTIONS})
exten = s,5,Goto(s-${DIALSTATUS},1)
exten = s,6,Macro(stdexten-followme,${ARG1},${ARG2})
exten = s-NOANSWER,1,Voicemail(${ORIG_ARG1},u)
exten = s-NOANSWER,2,Goto(default,s,1)
exten = s-BUSY,1,Voicemail(${ORIG_ARG1},b)
exten = s-BUSY,2,Goto(default,s,1)
exten = _s-.,1,Goto(s-NOANSWER,1)
exten = a,1,VoicemailMain(${ORIG_ARG1})
[macro-stdexten-followme]
exten = s,1,Answer
exten = s,3,Dial(${ARG2},${RINGTIME},${DIALOPTIONS})
exten = s,4,Set(__FMCIDNUM=${CALLERID(num)})
exten = s,5,Set(__FMCIDNAME=${CALLERID(name)})
exten = s,6,Followme(${ORIG_ARG1},${FOLLOWMEOPTIONS})
exten = s,7,Voicemail(${ORIG_ARG1},u)
[macro-pagingintercom]
exten = s,1,SIPAddHeader(Alert-Info: ${PAGING_HEADER})
exten = s,2,Page(${ARG1},${ARG2})
exten = s,3,Hangup
[conferences]
[ringgroups]
exten = 6402,1,Goto(ringroups-custom-3,s,1)
exten = 6403,1,Goto(ringroups-custom-4,s,1)
exten = 6405,1,Goto(ringroups-custom-6,s,1)
exten = 6407,1,Goto(ringroups-custom-8,s,1)
exten = 6409,1,Goto(ringroups-custom-10,s,1)
exten = 6411,1,Goto(ringroups-custom-12,s,1)
exten = 102,1,Goto(ringroups-custom-5,s,1)
exten = 104,1,Goto(ringroups-custom-7,s,1)
exten = 105,1,Goto(ringroups-custom-13,s,1)
exten = 101,1,Goto(ringroups-custom-1,s,1)
exten = 6400,1,Goto(ringroups-custom-14,s,1)
exten = 50,1,Goto(ringroups-custom-11,s,1)
exten = 21,1,Goto(ringroups-custom-2,s,1)
exten = 2,1,Goto(ringroups-custom-9,s,1)
[queues]
[voicemenus]
[voicemailgroups]
exten = 6600,1,NoOp(Samsys)
exten = 6600,2,VoiceMail(6001@default)
exten = 6601,1,NoOp(AWS)
exten = 6601,2,VoiceMail(6015@default)
[directory]
exten = #,1,Directory(default,default,f)
[page_an_extension]
[pagegroups]
[asterisk_guitools]
exten = executecommand,1,System(${command})
exten = executecommand,n,Hangup()
exten = record_vmenu,1,Answer
exten = record_vmenu,n,Playback(vm-intro)
exten = record_vmenu,n,Record(${var1},0,500,k)
exten = record_vmenu,n,Playback(vm-saved)
exten = record_vmenu,n,Playback(vm-goodbye)
exten = record_vmenu,n,Hangup
exten = play_file,1,Answer
exten = play_file,n,Playback(${var1})
exten = play_file,n,Hangup
[macro-local-callingrule-cid-0.1]
exten = s,1,Set(CALLERID(all)=${IF($[${LEN(${ARG4})} > 2]?${ARG4}:)})
exten = s,n,Goto(${ARG1},${ARG2},${ARG3})
[macro-trunkdial-failover-0.3]
exten = s,1,GotoIf($[${LEN(${FMCIDNUM})} > 6]?1-fmsetcid,1)
exten = s,n,GotoIf($[${LEN(${GLOBAL_OUTBOUNDCIDNAME})} > 1]?1-setgbobname,1)
exten = s,n,Set(CALLERID(num)=${IF($[${LEN(${CID_${CALLERID(num)}})} > 2]?${CID_${CALLERID(num)}}:)})
exten = s,n,Set(CALLERID(all)=${IF($[${LEN(${ARG5})} > 2]?${ARG5}:)})
exten = s,n,GotoIf($[${LEN(${CALLERID(num)})} > 6]?1-dial,1)
exten = s,n,Set(CALLERID(all)=${IF($[${LEN(${CID_${ARG3}})} > 6]?${CID_${ARG3}}:${GLOBAL_OUTBOUNDCID})})
exten = s,n,Goto(1-dial,1)
exten = 1-setgbobname,1,Set(CALLERID(name)=${GLOBAL_OUTBOUNDCIDNAME})
exten = 1-setgbobname,n,Goto(s,3)
exten = 1-fmsetcid,1,Set(CALLERID(num)=${FMCIDNUM})
exten = 1-fmsetcid,n,Set(CALLERID(name)=${FMCIDNAME})
exten = 1-fmsetcid,n,Goto(s,4)
exten = 1-dial,1,Dial(${ARG1})
exten = 1-dial,n,Gotoif(${LEN(${ARG2})} > 0 ?1-${DIALSTATUS},1:1-out,1)
exten = 1-CHANUNAVAIL,1,Dial(${ARG2})
exten = 1-CHANUNAVAIL,n,Hangup()
exten = 1-CONGESTION,1,Dial(${ARG2})
exten = 1-CONGESTION,n,Hangup()
exten = 1-out,1,Hangup()
[queue-member-manager]
exten = handle_member,1,Verbose(2, Looping through queues to log in or out queue members)
exten = handle_member,n,Set(thisActiveMember=${CHANNEL(channeltype)}/${CHANNEL(peername)})
exten = handle_member,n,Set(queue_field=2)
exten = handle_member,n,Set(thisQueueXtn=${CUT(QUEUES,\,,${queue_field})})
exten = handle_member,n,While($[${EXISTS(${thisQueueXtn})}])
exten = handle_member,n,Macro(member-loginlogout)
exten = handle_member,n,Set(queue_field=$[${queue_field} + 1])
exten = handle_member,n,EndWhile()
[macro-member-loginlogout]
exten = s,1,Verbose(2, Logging queue member in or out of the request queue)
exten = s,n,Set(thisQueue=${thisQueueXtn})
exten = s,n,Set(queueMembers=${QUEUE_MEMBER_LIST(${thisQueue})})
exten = s,n,Set(field=1)
exten = s,n,Set(logged_in=0)
exten = s,n,Set(thisQueueMember=${CUT(queueMembers,\,,${field})})
exten = s,n,While($[${EXISTS(${thisQueueMember})}])
exten = s,n,GotoIf($["${thisQueueMember}" != "${thisActiveMember}"]?check_next)
exten = s,n,Set(logged_in=1)
exten = s,n,ExitWhile()
exten = s,n(check_next),Set(field=$[${field} + 1])
exten = s,n,EndWhile()
exten = s,n,MacroIf($[${logged_in} = 0]?q_login:q_logout)
[macro-q_login]
exten = s,1,Verbose(2, Logging ${thisActiveMember} into the ${thisQueue} queue)
exten = s,n,AddQueueMember(${thisQueue},${thisActiveMember})
exten = s,n,Playback(silence/1)
exten = s,n,ExecIf($["${AQMSTATUS}" = "ADDED"]?Playback(agent-loginok):Playback(an-error-has-occurred))
[macro-q_logout]
exten = s,1,Verbose(2, Logged ${thisActiveMember} out of ${thisQueue} queue)
exten = s,n,RemoveQueueMember(${thisQueue},${thisActiveMember})
exten = s,n,ExecIf($["${RQMSTATUS}" = "REMOVED"]?Playback(agent-loggedoff):Playback(an-error-has-occurred))
[DID_620]
include = DID_620_default
[CallingRule_outgoing]
exten = _0.,1,Macro(trunkdial-failover-0.3,${620}/${EXTEN:0},${trunk_9}/${EXTEN:0},620,trunk_9)
[CallingRule_outgoing2]
exten = _0.,1,Macro(trunkdial-failover-0.3,${trunk_8}/${EXTEN:0},${trunk_9}/${EXTEN:0},trunk_8,trunk_9)
[CallingRule_outgoing3]
exten = _0.,1,Macro(trunkdial-failover-0.3,${trunk_2}/${EXTEN:0},${trunk_9}/${EXTEN:0},trunk_2,trunk_9)
[astsms]
exten => _.,1,NoOp(SMS receiving dialplan invoked)
exten => _.,n,NoOp(To ${MESSAGE(to)})
exten => _.,n,NoOp(From ${MESSAGE(from)})
exten => _.,n,NoOp(Body ${MESSAGE(body)})
exten => _.,n,Set(ACTUALTO=${CUT(MESSAGE(to),@,1)})
exten => _.,n,MessageSend(${ACTUALTO},${MESSAGE(from)})
exten => _.,n,NoOp(Send status is ${MESSAGE_SEND_STATUS})
exten => _.,n,GotoIf($["${MESSAGE_SEND_STATUS}" != "SUCCESS"]?
exten => _.,n,Hangup()
exten => h,1,Hangup()
exten => _.,n(sendfailedmsg),Set(MESSAGE(body)="[${STRFTIME(${EPOCH},,
exten => _.,n,Set(ME_1=${CUT(MESSAGE(from),<,2)})
exten => _.,n,Set(ACTUALFROM=${CUT(ME_1,@,1)})
exten => _.,n,MessageSend(${ACTUALFROM},ServiceCenter)
[DID_trunk_1]
include = DID_trunk_1_default
[DID_trunk_1_default]
[DID_trunk_3]
include = DID_trunk_3_default
[DID_trunk_3_default]
[DID_trunk_4]
include = DID_trunk_4_default
[DID_trunk_4_default]
[DID_trunk_5]
include = DID_trunk_5_default
[DID_trunk_5_default]
[DID_trunk_6]
include = DID_trunk_6_default
[DID_trunk_6_default]
[DID_trunk_7]
include = DID_trunk_7_default
[DID_trunk_7_default]
[DID_trunk_8]
include = DID_trunk_8_default
[DID_trunk_8_default]
[CallingRule_outgoing4]
exten = _0.,1,Macro(trunkdial-failover-0.3,${trunk_3}/${EXTEN:0},${trunk_9}/${EXTEN:0},trunk_3,trunk_9)
[DLPN_9962471]
include = CallingRule_outgoing4
include = default
include = parkedcalls
include = conferences
include = ringgroups
include = voicemenus
include = queues
include = voicemailgroups
include = directory
include = pagegroups
include = page_an_extension
include = pickup
[CallingRule_outgoing5]
exten = _0.,1,Macro(trunkdial-failover-0.3,${trunk_4}/${EXTEN:0},${trunk_9}/${EXTEN:0},trunk_4,trunk_9)
[DLPN_9962472]
include = CallingRule_outgoing5
include = default
include = queues
include = directory
include = pickup
[ringroups-custom-3]
exten = s,1,NoOp(Sascha Weingaertner)
exten = s,n,Dial(SIP/6008&SIP/6011,20,${DIALOPTIONS}i)
exten = s,n,Goto(voicemailgroups,6601,1)
[ringroups-custom-4]
exten = s,1,NoOp(Horst Muehleck)
exten = s,n,Dial(SIP/6009&SIP/6012,20,${DIALOPTIONS}i)
[DID_621]
include = DID_621_default
[DID_623]
include = DID_623_default
[DID_624]
include = DID_624_default
[DID_625]
include = DID_625_default
[DID_626]
include = DID_626_default
[DID_627]
include = DID_627_default
[DID_628]
include = DID_628_default
[DID_621_default]
exten = s,1,Goto(ringroups-custom-5,s,1)
[DID_623_default]
exten = s,1,Goto(ringroups-custom-3,s,1)
[DID_624_default]
exten = s,1,Goto(ringroups-custom-4,s,1)
[DID_625_default]
[DID_626_default]
[DID_627_default]
[DID_628_default]
[DID_620_default]
exten = 620,1,Goto(ringroups-custom-1,s,1)
exten = 623,1,Goto(ringroups-custom-13,s,1)
exten = 621,1,Goto(ringroups-custom-5,s,1)
exten = 622,1,Goto(ringroups-custom-7,s,1)
[DLPN_9962470]
include = CallingRule_outgoing3
include = default
include = queues
include = directory
include = pickup
[CallingRule_outgoing6]
exten = _0.,1,Macro(trunkdial-failover-0.3,${trunk_1}/${EXTEN:0},${trunk_9}/${EXTEN:0},trunk_1,trunk_9)
[DLPN_5487960]
include = CallingRule_outgoing6
include = default
include = queues
include = directory
include = pickup
[DLPN_9989950]
include = default
include = queues
include = directory
include = pickup
[DLPN_9962467]
include = CallingRule_outgoing2
include = default
include = queues
include = directory
include = pickup
[DID_trunk_2]
include = DID_trunk_2_default
[DID_trunk_2_default]
[CallingRule_outgoing7]
exten = _0.,1,Macro(trunkdial-failover-0.3,${trunk_5}/${EXTEN:0},${trunk_9}/${EXTEN:0},trunk_5,trunk_9)
[DLPN_9962473]
include = CallingRule_outgoing7
include = default
include = queues
include = directory
include = pickup
[ringroups-custom-6]
exten = s,1,NoOp(Werner Braun)
exten = s,n,Dial(SIP/6005,20,${DIALOPTIONS}i)
[CallingRule_outgoing8]
exten = _0.,1,Macro(trunkdial-failover-0.3,${trunk_6}/${EXTEN:0},${trunk_9}/${EXTEN:0},trunk_6,trunk_9)
[DLPN_9962474]
include = CallingRule_outgoing8
include = default
include = queues
include = directory
include = pickup
[DID_trunk_9]
include = DID_trunk_9_default
[DID_trunk_9_default]
exten = 620,1,Goto(ringroups-custom-11,s,1)
exten = 622,1,Goto(ringroups-custom-9,s,1)
exten = 625,1,Goto(ringroups-custom-2,s,1)
[CallingRule_outgoing9]
exten = _0.,1,Macro(trunkdial-failover-0.3,${trunk_9}/${EXTEN:0},${620}/${EXTEN:0},trunk_9,620,45350)
[DLPN_45350]
include = CallingRule_outgoing9
include = default
include = queues
include = directory
include = pickup
[DID_trunk_10]
include = DID_trunk_10_default
[DID_trunk_10_default]
[DID_trunk_11]
include = DID_trunk_11_default
[DID_trunk_11_default]
[DID_trunk_12]
include = DID_trunk_12_default
[DID_trunk_12_default]
[DID_trunk_13]
include = DID_trunk_13_default
[DID_trunk_13_default]
[DID_trunk_14]
include = DID_trunk_14_default
[DID_trunk_14_default]
[DID_trunk_15]
include = DID_trunk_15_default
[DID_trunk_15_default]
[DID_trunk_16]
include = DID_trunk_16_default
[DID_trunk_16_default]
[ringroups-custom-8]
exten = s,1,NoOp(Christian Schwank)
exten = s,n,Dial(SIP/6000,20,${DIALOPTIONS}i)
[ringroups-custom-10]
exten = s,1,NoOp(Phillip Liversidge)
exten = s,n,Dial(SIP/6016,20,${DIALOPTIONS}i)
[ringroups-custom-12]
exten = s,1,NoOp(Marion Zwilling)
exten = s,n,Dial(SIP/6018,20,${DIALOPTIONS}i)
[CallingRule_outgoing10]
exten = _0.,1,Macro(trunkdial-failover-0.3,${trunk_10}/${EXTEN:0},${620}/${EXTEN:0},trunk_10,620)
[CallingRule_outgoing11]
exten = _0.,1,Macro(trunkdial-failover-0.3,${trunk_11}/${EXTEN:0},${620}/${EXTEN:0},trunk_11,620)
[CallingRule_outgoing12]
exten = _0.,1,Macro(trunkdial-failover-0.3,${trunk_12}/${EXTEN:0},${620}/${EXTEN:0},trunk_12,620)
[CallingRule_outgoing13]
exten = _0.,1,Macro(trunkdial-failover-0.3,${trunk_13}/${EXTEN:0},${620}/${EXTEN:0},trunk_13,620)
[CallingRule_outgoing14]
exten = _0.,1,Macro(trunkdial-failover-0.3,${trunk_14}/${EXTEN:0},${620}/${EXTEN:0},trunk_14,620)
[CallingRule_outgoing15]
exten = _0.,1,Macro(trunkdial-failover-0.3,${trunk_15}/${EXTEN:0},${620}/${EXTEN:0},trunk_15,620)
[CallingRule_outgoing16]
exten = _0.,1,Macro(trunkdial-failover-0.3,${trunk_16}/${EXTEN:0},${620}/${EXTEN:0},trunk_16,620)
[DLPN_9478180]
include = CallingRule_outgoing10
include = default
include = queues
include = directory
include = pickup
[DLPN_9478181]
include = CallingRule_outgoing11
include = default
include = queues
include = directory
include = pickup
[DLPN_9478182]
include = CallingRule_outgoing12
include = default
include = queues
include = directory
include = pickup
[DLPN_9478183]
include = CallingRule_outgoing13
include = default
include = queues
include = directory
include = pickup
[DLPN_9478184]
include = CallingRule_outgoing14
include = default
include = queues
include = directory
include = pickup
[DLPN_9478185]
include = CallingRule_outgoing15
include = default
include = queues
include = directory
include = pickup
[DLPN_9478186]
include = CallingRule_outgoing16
include = default
include = queues
include = directory
include = pickup
[ringroups-custom-5]
exten = s,1,NoOp(SAMSYS Dennis Schreiber)
exten = s,n,Dial(SIP/6002&SIP/6006&SIP/6013,20,${DIALOPTIONS}i)
exten = s,n,Goto(voicemailgroups,6600,1)
[ringroups-custom-7]
exten = s,1,NoOp(SAMSYS Katja Braun)
exten = s,n,Dial(SIP/6014,20,${DIALOPTIONS}i)
[ringroups-custom-13]
exten = s,1,NoOp(SAMSYS Jo Braun)
exten = s,n,Dial(SIP/6001&SIP/6003&SIP/6004,20,${DIALOPTIONS}i)
[ringroups-custom-1]
exten = s,1,NoOp(SAMSYS Zentrale)
exten = s,n,Dial(SIP/6001&SIP/6004&SIP/6003&SIP/6014&SIP/6013&SIP/6002&SIP/6006,20,${DIALOPTIONS}i)
[ringroups-custom-14]
exten = s,1,NoOp(AWS Dagmar Schwahn)
exten = s,n,Dial(SIP/6017,20,${DIALOPTIONS}i)
[DID_trunk_17]
include = DID_trunk_17_default
[DID_trunk_17_default]
[CallingRule_outgoing1]
exten = _0.,1,Macro(trunkdial-failover-0.3,${trunk_7}/${EXTEN:0},${trunk_9}/${EXTEN:0},trunk_7,trunk_9,9962475)
[ringroups-custom-11]
exten = s,1,NoOp(AWS Zentrale)
exten = s,n,Dial(SIP/6000&SIP/6017&SIP/6018&SIP/6015,20,${DIALOPTIONS}i)
[ringroups-custom-2]
exten = s,1,NoOp(AWS Gerd Stuber)
exten = s,n,Dial(SIP/6010&SIP/6000,20,${DIALOPTIONS}i)
[ringroups-custom-9]
exten = s,1,NoOp(AWS Hardy Schwank)
exten = s,n,Dial(SIP/6015,20,${DIALOPTIONS}i)
[pickup]
exten => _*8.,1,SET(GLOBAL(PICKUPMARK)=${EXTEN:2})
exten => _*8.,n,Pickup(${EXTEN:2}@PICKUPMARK)
